Topic "WinSCP Hangs on invalid host"
shifter1
When the host is mistyped or not responding the WinSCP GUI hangs.
I am running 4.2.7 on Windows XP 64 bit, but I have also noticed it in Vista 64 bit.
It hangs for longer when trying to connect by passing the IP address rather than the hostname.
I.E. Trying to connect to "1.1.1.1" will hang longer than trying "nowhere.noplace.com"
For how long does it hang?
shifter1
It hangs for about 20 seconds, and then instantly tries to reconnect which causes more hang. Its very hard to break the loop unless you taskkill it.
OK. This is basically part of this issue.
Jaan
My vote for this issue. The unresponsiveness of WinSCP when it tries reconnect is indeed quite annoying.
