Topic "Multiple Watch Folders..?"
topcat888
Hi
I want to use the 'Keep Retmote Directory up to Date' but I have a problem, the subfolders are not all within the same folder stucture... In others words I want to be able to pick multiple folders to watch at the same time within the same session, is this possible becasue I can only see that you can pick only one folder and its subs..??
Start it from common root and use exclude/include mask to narrow down the set of directories to watch.
topcat888
Thanks for the pointer... I have tried that and can not get it to work, could you give me some examples..?
What is more suitable for you? Exclude or include mask?
topcat888
Definetly the include mask...
