Topic "Telnet Bug and SSH RE-Authentication BUg"
emunity
Version 3.4.2
Some of my SSH shells work fine. I authenticate the first time I connect then I do not have to re-Authenticate again.
Some of my other shells keep askingme to Authenticate with every connection.
THis is not a problem with the shell provder because I can connect to every single one of the shells without having to re-authenticate in Secure-CRT client.
It looks like Port 23 or Telnet is not working at all.
I cannot connect to my shells using WINSCP but I can connect using Secure-CRT.
Also another problem. It is very slow process for it to connect and open the session. Almost 30 seconds. That to me seems a bit too long.
Is that also a bug in WInSCP version 3.4.2.?
I do not understand. You should be asked to authenticate with every connection, unless you save your password to stored session.
WinSCP supports only SSH protocol, not Telnet.
emunity
SO How can I make it so it will remember my passord? I set up all my sessions the same. I did nothing different. SOme shells want to re-authenticate and some do not?
Tell me how to set the WINSCP to save the password for SSH protocol.
thanks
[quote="emunity"]
Enter your password on login dialog along with all other login data and click "save".
emunity
[quote="prikryl"]
I did that. It is still prompting me for a password on two of my shells. Oxygenshell and Satexas Shells.
Sounds like a bug to me.
Please post a log file.
emunity
OK here it is: Oxygenshell and B2.shells. Oxygenshell is promtping me for a passward everytime ass well as Satexas Shells and JEah shells. Acmeshells, B2.Shell and TAKIWEB shells do not prompt me for a password every time I login.
I only inlcluded the Oxygenshell and B2 shell login and session log.
. Closing connection.
. WinSCP Version 3.4.2 (Build 197)
. Login time: Tuesday, January 06, 2004 10:26:12 PM
. Session name: B2-STORM
. Host name: storm.b2shells.net (Port: 22)
. User name: imunity (Password: Yes, Key file: No)
. Transfer Protocol: SCP
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: H:\Incoming\bots\botnet tools, Remote directory: /usr/home/imunity/eggdrop, Update: No, Cache: Yes
. Looking up host "storm.b2shells.net"
. Connecting to 209.126.200.141 port 22
. Server version: SSH-1.99-[- lighting.b2shells.net SSH -]
. We claim version: SSH-2.0-WinSCP-release-3.4.2.197
. Host key fingerprint is:
. ssh-rsa 1024 bc:20:fd:b8:f8:0b:7d:32:fc:e9:70:30:6d:a9:91:32
! Using username "imunity".
. Keyboard-interactive authentication refused
. Session password prompt (imunity@storm.b2shells.net's password: )
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SCP protocol.
> echo "WinSCP: this is end-of-file:0"
< Warning: no access to tty (Bad file descriptor).
< Thus no job control in this shell.
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$status" selected.
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$status"
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$status"
> unalias "cd" ; echo "WinSCP: this is end-of-file:$status"
> unalias "ls" ; echo "WinSCP: this is end-of-file:$status"
> unalias "groups" ; echo "WinSCP: this is end-of-file:$status"
> unalias "scp" ; echo "WinSCP: this is end-of-file:$status"
> unalias "rm" ; echo "WinSCP: this is end-of-file:$status"
> unalias "mv" ; echo "WinSCP: this is end-of-file:$status"
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$status"
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$status"
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$status"
> unalias "chown" ; echo "WinSCP: this is end-of-file:$status"
> unalias "unset" ; echo "WinSCP: this is end-of-file:$status"
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$status"
> unalias "alias" ; echo "WinSCP: this is end-of-file:$status"
> unalias "ln" ; echo "WinSCP: this is end-of-file:$status"
> unalias "%s" ; echo "WinSCP: this is end-of-file:$status"
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$status"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$status"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$status"
. Looking up current user groups.
> groups ; echo "WinSCP: this is end-of-file:$status"
< imunity
. Following groups found:
. imunity
. Changing directory to "/usr/home/imunity/eggdrop".
> cd "/usr/home/imunity/eggdrop" ; echo "WinSCP: this is end-of-file:$status"
> pwd ; echo "WinSCP: this is end-of-file:$status"
< /usr/home/imunity/eggdrop
. Listing current directory.
> ls -la ; echo "WinSCP: this is end-of-file:$status"
< total 564
< drwx------ 12 imunity imunity 1024 Jan 6 20:00 .
< drwx-----x 4 imunity imunity 512 Dec 30 19:56 ..
< drwxr-xr-x 2 imunity imunity 1536 Jan 6 02:25 BotLogs
< -rwxr--r-- 1 imunity imunity 2275 Dec 30 23:27 ORi0N.botchk
< -rw-r--r-- 1 imunity imunity 25159 Dec 30 16:54 README
< drwxr-xr-x 5 imunity imunity 512 Dec 30 16:54 doc
< lrwxr-xr-x 1 imunity imunity 14 Dec 30 16:54 eggdrop -> eggdrop-1.6.15
< -rwxr-xr-x 1 imunity imunity 305920 Dec 30 16:54 eggdrop-1.6.15
< -rw-r--r-- 1 imunity imunity 51039 Dec 30 16:54 eggdrop.conf
< drwxr-xr-x 3 imunity imunity 512 Dec 30 16:54 filesys
< drwxr-xr-x 4 imunity imunity 512 Jan 1 05:33 help
< drwxr-xr-x 2 imunity imunity 1024 Dec 30 16:54 language
< drwxr-xr-x 2 imunity imunity 512 Dec 30 16:54 logs
< lrwxr-xr-x 1 imunity imunity 14 Dec 30 16:54 modules -> modules-1.6.15
< drwxr-xr-x 2 imunity imunity 512 Dec 30 16:54 modules-1.6.15
< -rw------- 1 imunity imunity 1536 Jan 6 20:00 orion.chan
< -rw------- 1 imunity imunity 1534 Jan 6 00:00 orion.chan~bak
< -rw-r--r-- 1 imunity imunity 7698 Jan 6 03:10 orion.config
< -rw------- 1 imunity imunity 111 Jan 6 20:00 orion.notes
< -rw------- 1 imunity imunity 25182 Jan 6 20:00 orion.user
< -rw------- 1 imunity imunity 24874 Jan 6 00:00 orion.user~bak
< -rw-r--r-- 1 imunity imunity 5 Dec 30 23:25 pid.ORi0N
< -rw-r--r-- 1 imunity imunity 5 Dec 30 23:26 pid.sH3LLs
< -rwxr--r-- 1 imunity imunity 2280 Dec 30 23:28 sH3LLs.botchk
< drwxr-xr-x 2 imunity imunity 1024 Jan 1 04:59 scripts
< -rw------- 1 imunity imunity 1537 Jan 6 20:00 shells.chan
< -rw------- 1 imunity imunity 1535 Jan 6 00:00 shells.chan~bak
< -rw-r--r-- 1 imunity imunity 7704 Jan 6 03:10 shells.config
< -rw------- 1 imunity imunity 113 Jan 6 20:00 shells.notes
< -rw------- 1 imunity imunity 25199 Jan 6 20:00 shells.user
< -rw------- 1 imunity imunity 24846 Jan 6 00:00 shells.user~bak
< drwxr-xr-x 2 imunity imunity 512 Dec 30 16:54 text
< drwxr-xr-x 2 imunity imunity 512 Jan 6 03:15 tmp
. Reading symlink "eggdrop".
> ls -lad "eggdrop-1.6.15" ; echo "WinSCP: this is end-of-file:$status"
. Reading symlink "modules".
> ls -lad "modules-1.6.15" ; echo "WinSCP: this is end-of-file:$status"
. Startup conversation with host finished.
. Login time: Tuesday, January 06, 2004 10:26:39 PM
. Session name: Oxygenshell
. Host name: 69.50.189.162 (Port: 22)
. Proxy: none
. Local directory: H:\Incoming\bots\botnet tools, Remote directory: /home2/friends/imunity/eggdrop, Update: No, Cache: Yes
. Looking up host "69.50.189.162"
. Connecting to 69.50.189.162 port 22
. Server version: SSH-2.0-OpenSSH_3.5p1 FreeBSD-20030917
. ssh-dss 1024 a7:a4:8a:8d:0b:33:57:3e:7c:a0:62:d4:00:68:67:4c
! admin@oxygenshell.com -
! This is a private computer system which is
! restricted to authorized individuals.
! Actual or attempted unauthorized use of this
! computer system will result in criminal
! and/or civil prosecution.
! Any information obtained by monitoring,
! reviewing or recording is subject to review
! by law enforcement organizations in
! connection with the investigation or
! prosecution of possible criminal activity on
! this system.
! If you wish to continue please login
. Server prompt (Password:)
. Access granted
. Trying "$status".
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `echo': not an alias
< WinSCP: this is end-of-file:1
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `pwd': not an alias
> unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `cd': not an alias
> unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `ls': not an alias
> unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `groups': not an alias
> unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `scp': not an alias
> unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `rm': not an alias
> unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `mv': not an alias
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `mkdir': not an alias
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `chmod': not an alias
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `chgrp': not an alias
> unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `chown': not an alias
> unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `unset': not an alias
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `unalias': not an alias
> unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `alias': not an alias
> unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `ln': not an alias
> unalias "%s" ; echo "WinSCP: this is end-of-file:$?"
! -bash: unalias: `%s': not an alias
> unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
> groups ; echo "WinSCP: this is end-of-file:$?"
< imunity
. imunity
. Changing directory to "/home2/friends/imunity/eggdrop".
> cd "/home2/friends/imunity/eggdrop" ; echo "WinSCP: this is end-of-file:$?"
> pwd ; echo "WinSCP: this is end-of-file:$?"
< /home2/friends/imunity/eggdrop
> ls -la ; echo "WinSCP: this is end-of-file:$?"
< total 576
< drwx------ 12 imunity imunity 1024 Jan 6 23:00 .
< drwxr-xr-x 7 imunity imunity 512 Dec 21 21:42 ..
< drwxrwxrwx 2 imunity imunity 512 Jan 6 00:16 BotLogs
< -rwxr--r-- 1 imunity imunity 2284 Jan 3 07:04 FeND3R.botchk
< -rwxr--r-- 1 imunity imunity 2284 Jan 3 07:04 GiBS0N.botchk
< -rwxrwxrwx 1 imunity imunity 25159 Oct 28 02:47 README
< drwxrwxrwx 5 imunity imunity 512 Oct 28 02:47 doc
< lrwxr-xr-x 1 imunity imunity 14 Oct 28 02:47 eggdrop -> eggdrop-1.6.15
< -rwxrwxrwx 1 imunity imunity 295104 Oct 28 02:47 eggdrop-1.6.15
< -rwxrwxrwx 1 imunity imunity 51039 Oct 28 02:47 eggdrop.conf
< -rw------- 1 imunity imunity 2265 Jan 6 23:00 fender.chan
< -rwxrwxrwx 1 imunity imunity 2263 Jan 6 00:00 fender.chan~bak
< -rwxrwxrwx 1 imunity imunity 8073 Jan 6 06:10 fender.config
< -rw------- 1 imunity imunity 28138 Jan 6 23:00 fender.user
< -rw------- 1 imunity imunity 27661 Jan 6 00:00 fender.user~bak
< drwxrwxrwx 3 imunity imunity 512 Oct 28 02:47 filesys
< -rw------- 1 imunity imunity 2264 Jan 6 23:00 gibson.chan
< -rwxrwxrwx 1 imunity imunity 2261 Jan 6 00:00 gibson.chan~bak
< -rwxrwxrwx 1 imunity imunity 8023 Jan 6 06:10 gibson.config
< -rw------- 1 imunity imunity 28126 Jan 6 23:00 gibson.user
< -rw------- 1 imunity imunity 27703 Jan 6 00:00 gibson.user~bak
< drwxrwxrwx 4 imunity imunity 512 Jan 1 08:19 help
< drwxrwxrwx 2 imunity imunity 1024 Oct 28 02:47 language
< drwxrwxrwx 2 imunity imunity 512 Oct 28 02:47 logs
< lrwxr-xr-x 1 imunity imunity 14 Oct 28 02:47 modules -> modules-1.6.15
< drwxrwxrwx 2 imunity imunity 512 Oct 28 02:47 modules-1.6.15
< -rw-r--r-- 1 imunity imunity 5 Jan 5 20:00 pid.FeND3R
< -rw-r--r-- 1 imunity imunity 5 Jan 5 20:00 pid.GiBS0N
< drwxrwxrwx 2 imunity imunity 1024 Jan 3 07:04 scripts
< drwxrwxrwx 2 imunity imunity 512 Oct 28 02:47 text
< drwxrwxrwx 2 imunity imunity 512 Oct 28 02:48 tmp
> ls -lad "eggdrop-1.6.15" ; echo "WinSCP: this is end-of-file:$?"
> ls -lad "modules-1.6.15" ; echo "WinSCP: this is end-of-file:$?"
[/quote]
This tells that normal password-authentication does not take place. Instead the servers issues generic prompt for something (the password here). Since WinsCP 3.4, the prompt dialog should state something like 'This prompt is issued by the server. It is part of either keyboard-interactive, TIS or Cryptocard authentication'
Is such case WinSCP cannot use stored password (apart from normal password authentication), because the server may ask generally for anything. And WinSCP does not know for what it is asking for actually.
If your server does not require this kind of authentication, you may turn off WinSCP attempt for it by unchecking "Attempt 'keyboard-interactive' authentication (SSH2)" on Authentication tab of Login dialog.
emunity
Its still asking for a password. session password Sad
Why does it work ok in Secure CRT and not in WINscp? THats the part I don't understand?
emunity
Wow, this did work though:
Uncheck as you said but for this to work correctly I had to check "Attempt TIS or Cryptocard Authentication SSH1"
THat fixed all the shells that were prompting for Re-Authentication!!!
PERFECT!!
THanks all is good now Razz
PS
Can anyone figure out my passwors from my log I posted if so can you delete that for me?
THanks so much for you help your program is the best I have ever tried or have ever seen anywhere antime Razz
GREAT JOB
I believe that this is nonsense. TIC/Cryptocard works only with SSH1, you use SSH2. And even if it works, the effect would be just opposite, another prompt would be displayed.
I have tried to start authentication agains your server with username 'imunity'. With the default settings I'm prompted for password via keyboard-interactive authentication. The prompt has title "Server prompt" and states "This prompt is issued by the server. It is part of either keyboard-interactive, TIS or Cryptocard authentication". In this case the stored password cannot be used (even if I know it Smile).
For the second attempt I have turned off 'Attempt 'keyboard-interactive' authentication'. Now I'm prompted for normal session password. In such case stored password would be used.
The password is never stored to the log.
emunity
But it doesn't work that way. I have a password in the password field and its stored. It is however working the way I said from my last reply to you. Don't know what to say anymore but at least it works Razz
