Topic "Automatic start on specified directory (command line)"
Hi all!
I want start a session on specified directory with command line.
And I can't do that...
I try:
c:\>winscp.exe sftp://login:passw@ remote_directory=/dir
But nothing...
I don't use synchronise because I want just start on the directory.
When I use the GUI, on Environment/Directories options, It's work perfectly if I indicate the Remote directory without Local directory. But I can't find the associated command line...
Any idea?
Many thanks!
