Topic ""low-tech" keep alive"
Betcour
One feature that would be very useful, and probably not difficult to implement : a way to have an automatic "keep-alive" done by sending a useless command to the server (instead of the "null packet" solution).
My ISP keeps closing idle connexions avec 3 min, and the "keep-alive" solution (sending null-packet) doesn't fix this. So I need to either keep pressing "refresh" regularly to keep the connexion up or reconnect (which takes a while). Needless to say, this is horribly painful Sad
OK, maybe in next version. For what protocol do you need this (SCP/SFTP)?
That's awesome Smile
Any protocol will do actually, so long as I don't have to reconnect every 3 min, my life will be made a lot easier.
And thanks a lot for this incredible software that is WinSCP Very Happy
Mark
Ditto on that! WinSCP would be near perfect if only I didn't have to keep reconnecting. I often edit files "on the fly" and it never fails - as soon as I'm ready to save it back to the remote server, I find I've been disconnected.
PLEASE find a way to keep the session alive! I'll be eternally grateful Very Happy
The second mean of keepalives was added in the last release already, see Connection tab of login dialog.
Mark
Just downloaded the latest release and tried it out. Good job - no more disconnects!
Thanks!
