Topic "Required Shell script for Automation"
g.ganiraju
Hi ,
I need a automatio shell script for the following requiremnt.can any one please help me for this.
Requirement:
1. Connect to stage server and use WinSCP to retrive the file "xyz.dat" from the above mentioned server and path. This is the inventory file.
2. Open the inv.txt file present in E:\ABC. NOTE: inv.txt is used to process the data in Flx.mdb file.
3. Place the records in inv.txt and just validate for the number of records with the source file.
4. Delete the a.xls present in E:\ABC\
5. Once the latest inv.txt is ready, open the E:\ABC\Flx.mdb access file.
6. Click on Open, then on "Daily Sales Vs. buy Report".
7. Click on "Import Data" tab. "ALL EXISTING DATA WILL BE LOST !!!" msg will pop up. Just click on "OK" tab.
8. Flx.mdb will prompt for ODBC connection password. Supply the same to connect to GHI.WORLD. Username: DWH_ABC pwd : abcde
9. Once data gets imported, "Import Completed" pop-up window appears.
10. Click "OK". Then click on "Output to Excel" tab to export the data to excel sheet.
11. Pop-up window "Export Complete" appears. Click on "OK".
12. This export will generate an ijk.xls file in E:\ABC\ path. Open the .xls and run the below macros.
13. Goto Tools --> Macros --> Macros, to run the Macros from Excel sheet.
14. Run the macro - "PERSONAL.XLS!macNewIJK".
15. Click on the 'Sales vs buy' sheet below. Then go to Window->unfreeze pane.
16. Once done, save the ijk.xls as Sales vs. buy Report - <Month 'YY>.xls in E:\ABC folder.
Thanks.
g.ganiraju
I am very new to scripting.So can you please help me to write the script for the above requirement.Hope it helps me to learn to write ther scripts.
Thanks.
g.ganiraju
hi
Can you please help me out in this.
thanks.
g.ganiraju
Hi Prikryl,
I am waitig for your reply.so can you please help me out to write the script.
No. I won't write the script for you.
