resume transfer
resume transfer
i have a problem.
say, i have 200 files to upload.
in the middle of uploading file #100,
my pc crash or power down or something else happen.
how can i resume the transfer???
i choose dont overwrite,
but it still show up a 'Copy Failed' dialog
that i must click OK for 100 times???
Re: resume transfer
I do not understand. You transfered like 50 files and you want to finish transfering the other 50? Select the other 50 files and upload.
Please write me an exact steps that you do, so I can reproduce the behaviour.
you're half right.
i can just select the remaining file to transfer.
that's if i know which file has been upload,
and which has not...
if i got all the files in one folder,
it's easy to know.
but, if those file are spread in ten folders,
then, i have to go through each folder to check
which file is not upload yet...
that is the problem.
Re: resume transfer
try upload a folder with lots of subfolder and files in it.
(i was uploading tikiwiki php, for exact)
in the middle of uploading, interupt it.
(say, the line is disconnected or maybe a crash)
then, how can you resume the transfer?
i tried re-upload the tikiwiki folder,
when WinSCP pop-up saying the file already exist,
i choose to Not overwrite and same action for the rest.
but, for each existing file, WinSCP still pop-up
for an error.
