Topic "Auto refresh directories when using background transfer"
featurerequest1
I use background transfer function by default so I can work with directories while transferring files. But sometimes I don't need to and I stay in the same directory. After the operation finishes I have to refresh this directory manually, because WinSCP doesn't do it (even if "automatically refresh directory after operation" is enabled).
Is this intentional or is it a bug? If it is intentional I think that it should be improved in a way that auto refresh occurs if user stays in the same directory (for cases like mine).
Oh, and keep up the good work! Wink
Currently, you need to have directory cache enabled for refresh to work. Have you?
