Topic "Timeout waiting for external command to complete the command"
Pushkar_K
Thanks for providing us such a nice program.
I am using WinSCP to transfer files from my Windows machine to remote linux machine.
I get "Timeout waiting for ..." error when I try to transfer some large file for. e.g. 10 GB file.
I am using WinSCP.com with SFTP (and WinSCP 4.1)with automatically generated scripts.
Script works fine for files of sizes upto few 100 MBs.
I searched into forums about this problem ,but none of the posts are relevant to the problem I am facing.
Can you tell me where the problem is ?
Thanks in advance.
Pushkar_K
Sorry , I was wrong about WinSCP version. I am using WinSCP 4.2.
Do you mean Timeout waiting for external console to complete the command?
Pushkar_K
Yes, the same error.
But I am not redirecting output of WinSCP.com or WinSCP.exe.
What I am doing is running a bat file from command prompt that calls WinSCP.com /script=myScript.tmp and this WinSCP.com copies the files.
Will using keepalive option help ?
I did not use keepalive because while copying we are sending data continuosly , so server should not timeout.
Thanks for your timely response.
No keepalive won't help.
Pushkar_K
I have sent you a mail.
Thanks for your prompt reply.
JoseETX
I have the same problem.
Would you put the solucion in the forum?
Thanks in advace.
What version of WinSCP? What are you doing actually? Have you read the article linked above?
I am using WinSCP to transfer files from Windows Server to Windows Server.
I get "Timeout waiting for ..." error when I try to transfer some large file for. e.g. 18 GB file.
I am using WinSCP.com with SFTP (and WinSCP 4.2.9)with automatically generated scripts.
Script works fine before with a file of 10GB.
Thanks in advance.
I have sent a email.
Thanks in advance.
Irfan_s
I am using winscp and experiencing the same time issue mentioned above....first day it ran successfully without errors but second day onwards it started giving me a timeout error. I am using winscp version 4. Please help
Did you read the article linked in my first post?
