Topic "Host does not exist"
Apologies if this has been asked and answered before
I successfully created a script to retrieve files from a Solaris 10 Server and was working fine. However when trying to run this script today I now receive "Host does not exist", I am unaware of any changes to my end or the server end, so effectively it has just stopped working from what I can see.
However the following run from the command line works fine
winscp.exe /console /command "option batch off" "open root:password@172.x.x.x"
But the following does not work in a script and generates the "Host does not exist" error
I have added to the host key to the cache already
Any ideas would be appreciated
Do you mean that when you run
it works, while when you run
winscp.exe /console /script=script.txt
from the very same location, where script.txt includes command
it does not work?
It does not make much sense.
Try to turn on logging in both cases and compare the log files as described here:
