synchronization dosn't work
Sew.
I want to synchronize with WinSCP 4.3.2 from a SFTP server to my local storage.
The SFTP server is a linux Darwin (Kernel Version 10.6.0) and my PC have Windows Server 2008 R2 Standard
The problem is, that the batch mode not working properly.
No files are synchronized even when local directory is completely completly EMPTY
WinSCP GUI works correctly.
bat:
"C:\Program Files (x86)\WinSCP\WinSCP.exe" /script="D:\backup\config_WinSCP - do not remove!\script_Projects.txt" /log="D:\backup\config_WinSCP - do not remove!\Projects_log.txt"
WinScp script:
option batch on
open Files_backup
option transfer binary
cd /Volumes
synchronize local "D:\backup\synchronized_folders\Files_(192.168.1.4)\Pioneer_Projects" Pioneer_Projects
close
LOG:
. 2011-02-26 04:52:01.338 --------------------------------------------------------------------------
. 2011-02-26 04:52:01.338 WinSCP Version 4.3.2 (Build 1201) (OS 6.1.7600)
. 2011-02-26 04:52:01.338 Login time: Saturday, February 26, 2011 4:52:01 AM
. 2011-02-26 04:52:01.338 Session name: Files_backup
. 2011-02-26 04:52:01.338 Host name: 192.168.1.6 (Port: 22)
. 2011-02-26 04:52:01.338 User name: root (Password: Yes, Key file: No)
. 2011-02-26 04:52:01.338 Tunnel: No
. 2011-02-26 04:52:01.338 Transfer Protocol: SFTP (SCP)
. 2011-02-26 04:52:01.338 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-02-26 04:52:01.338 Proxy: none
. 2011-02-26 04:52:01.338 SSH protocol version: 2; Compression: No
. 2011-02-26 04:52:01.338 Bypass authentication: No
. 2011-02-26 04:52:01.338 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-02-26 04:52:01.338 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-02-26 04:52:01.338 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-02-26 04:52:01.338 SFTP Bugs: -,-
. 2011-02-26 04:52:01.338 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-02-26 04:52:01.338 Shell: default
. 2011-02-26 04:52:01.338 EOL: 0, UTF: 2
. 2011-02-26 04:52:01.338 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-02-26 04:52:01.338 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-02-26 04:52:01.338 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-02-26 04:52:01.338 Cache directory changes: Yes, Permanent: Yes
. 2011-02-26 04:52:01.338 DST mode: 1
. 2011-02-26 04:52:01.338 Looking up host "192.168.1.6"
. 2011-02-26 04:52:01.338 Connecting to 192.168.1.6 port 22
. 2011-02-26 04:52:01.447 Server version: SSH-2.0-OpenSSH_5.2
. 2011-02-26 04:52:01.447 We believe remote version has SSH-2 ignore bug
. 2011-02-26 04:52:01.447 Using SSH protocol version 2
. 2011-02-26 04:52:01.447 We claim version: SSH-2.0-WinSCP_release_4.3.2
. 2011-02-26 04:52:01.494 Doing Diffie-Hellman group exchange
. 2011-02-26 04:52:01.510 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-02-26 04:52:01.993 Host key fingerprint is:
. 2011-02-26 04:52:01.993 ssh-rsa 2048 05:f1:94:57:07:de:ef:3b:7d:cf:65:09:61:52:97:28
. 2011-02-26 04:52:01.993 Initialised AES-256 SDCTR client->server encryption
. 2011-02-26 04:52:01.993 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-02-26 04:52:01.993 Initialised AES-256 SDCTR server->client encryption
. 2011-02-26 04:52:01.993 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-02-26 04:52:01.993 Using username "root".
. 2011-02-26 04:52:02.056 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password:)
. 2011-02-26 04:52:02.056 Using stored password.
. 2011-02-26 04:52:02.227 Prompt (5, SSH server authentication, , <no prompt>)
. 2011-02-26 04:52:02.227 Ignoring empty SSH server authentication request
. 2011-02-26 04:52:02.227 Access granted
. 2011-02-26 04:52:02.305 Opened channel for session
. 2011-02-26 04:52:02.305 Started a shell/command
. 2011-02-26 04:52:02.305 --------------------------------------------------------------------------
. 2011-02-26 04:52:02.305 Using SFTP protocol.
. 2011-02-26 04:52:02.321 Doing startup conversation with host.
> 2011-02-26 04:52:02.321 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-02-26 04:52:02.399 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2011-02-26 04:52:02.399 SFTP version 3 negotiated.
. 2011-02-26 04:52:02.399 Unknown server extension posix-rename@openssh.com="1"
. 2011-02-26 04:52:02.399 Unknown server extension statvfs@openssh.com="2"
. 2011-02-26 04:52:02.399 Unknown server extension fstatvfs@openssh.com="2"
. 2011-02-26 04:52:02.399 We believe the server has signed timestamps bug
. 2011-02-26 04:52:02.399 We will use UTF-8 strings for status messages only
. 2011-02-26 04:52:02.399 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2011-02-26 04:52:02.399 Getting current directory name.
. 2011-02-26 04:52:02.399 Getting real path for '.'
> 2011-02-26 04:52:02.399 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2011-02-26 04:52:02.399 Type: SSH_FXP_NAME, Size: 55, Number: 16
. 2011-02-26 04:52:02.399 Real path is '/private/var/root'
. 2011-02-26 04:52:02.399 Startup conversation with host finished.
< 2011-02-26 04:52:02.399 Script: Active session: [1] Files_backup
> 2011-02-26 04:52:02.399 Script: option transfer binary
< 2011-02-26 04:52:02.399 Script: transfer        binary
> 2011-02-26 04:52:02.399 Script: cd /Volumes/
. 2011-02-26 04:52:02.399 Cached directory change via "/Volumes/" to "/Volumes".
< 2011-02-26 04:52:02.399 Script: /Volumes
> 2011-02-26 04:52:02.399 Script: synchronize local "D:\backup\synchronized_folders\Files_(192.168.1.4)\Pioneer_Projects" Pioneer_Projects
< 2011-02-26 04:52:02.399 Script: Comparing...
. 2011-02-26 04:52:02.399 Collecting synchronization list for local directory 'D:\backup\synchronized_folders\Files_(192.168.1.4)\Pioneer_Projects' and remote directory 'Pioneer_Projects', mode = 1, params = 2
< 2011-02-26 04:52:02.399 Script: Nothing to synchronize.
> 2011-02-26 04:52:02.399 Script: close
. 2011-02-26 04:52:02.399 Closing connection.
. 2011-02-26 04:52:02.399 Sending special code: 12
. 2011-02-26 04:52:02.399 Sent EOF message
Seweryn Kazior
Re: synchronization dosn't work
Can you post a log file from GUI?
so I need to enable logging for these session?
I asking because these log has 55 MB (it is aroung 80GB to synchronize).
Sew.
. 2011-02-28 11:15:26.752 --------------------------------------------------------------------------
. 2011-02-28 11:15:26.752 WinSCP Version 4.3.2 (Build 1201) (OS 6.1.7600)
. 2011-02-28 11:15:26.752 Login time: Monday, February 28, 2011 11:15:26 AM
. 2011-02-28 11:15:26.752 Session name: Files_backup
. 2011-02-28 11:15:26.752 Host name: 192.168.1.6 (Port: 22)
. 2011-02-28 11:15:26.752 User name: root (Password: Yes, Key file: No)
. 2011-02-28 11:15:26.752 Tunnel: No
. 2011-02-28 11:15:26.752 Transfer Protocol: SFTP (SCP)
. 2011-02-28 11:15:26.752 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-02-28 11:15:26.752 Proxy: none
. 2011-02-28 11:15:26.752 SSH protocol version: 2; Compression: No
. 2011-02-28 11:15:26.752 Bypass authentication: No
. 2011-02-28 11:15:26.752 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-02-28 11:15:26.752 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-02-28 11:15:26.752 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-02-28 11:15:26.752 SFTP Bugs: -,-
. 2011-02-28 11:15:26.752 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-02-28 11:15:26.752 Shell: default
. 2011-02-28 11:15:26.752 EOL: 0, UTF: 2
. 2011-02-28 11:15:26.752 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-02-28 11:15:26.752 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-02-28 11:15:26.752 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-02-28 11:15:26.752 Cache directory changes: Yes, Permanent: Yes
. 2011-02-28 11:15:26.752 DST mode: 1
. 2011-02-28 11:15:26.768 Looking up host "192.168.1.6"
. 2011-02-28 11:15:26.768 Connecting to 192.168.1.6 port 22
. 2011-02-28 11:15:26.908 Server version: SSH-2.0-OpenSSH_5.2
. 2011-02-28 11:15:26.908 We believe remote version has SSH-2 ignore bug
. 2011-02-28 11:15:26.908 Using SSH protocol version 2
. 2011-02-28 11:15:26.908 We claim version: SSH-2.0-WinSCP_release_4.3.2
. 2011-02-28 11:15:27.002 Doing Diffie-Hellman group exchange
. 2011-02-28 11:15:27.002 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-02-28 11:15:27.376 Host key fingerprint is:
. 2011-02-28 11:15:27.376 ssh-rsa 2048 05:f1:94:57:07:de:ef:3b:7d:cf:65:09:61:52:97:28
. 2011-02-28 11:15:27.376 Initialised AES-256 SDCTR client->server encryption
. 2011-02-28 11:15:27.376 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-02-28 11:15:27.376 Initialised AES-256 SDCTR server->client encryption
. 2011-02-28 11:15:27.376 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-02-28 11:15:27.392 Using username "root".
. 2011-02-28 11:15:27.470 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password:)
. 2011-02-28 11:15:27.470 Using stored password.
. 2011-02-28 11:15:27.673 Prompt (5, SSH server authentication, , <no prompt>)
. 2011-02-28 11:15:27.673 Ignoring empty SSH server authentication request
. 2011-02-28 11:15:27.688 Access granted
. 2011-02-28 11:15:27.751 Opened channel for session
. 2011-02-28 11:15:27.751 Started a shell/command
. 2011-02-28 11:15:27.766 --------------------------------------------------------------------------
. 2011-02-28 11:15:27.766 Using SFTP protocol.
. 2011-02-28 11:15:27.766 Doing startup conversation with host.
> 2011-02-28 11:15:27.766 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-02-28 11:15:27.829 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2011-02-28 11:15:27.829 SFTP version 3 negotiated.
. 2011-02-28 11:15:27.829 Unknown server extension posix-rename@openssh.com="1"
. 2011-02-28 11:15:27.829 Unknown server extension statvfs@openssh.com="2"
. 2011-02-28 11:15:27.829 Unknown server extension fstatvfs@openssh.com="2"
. 2011-02-28 11:15:27.829 We believe the server has signed timestamps bug
. 2011-02-28 11:15:27.829 We will use UTF-8 strings for status messages only
. 2011-02-28 11:15:27.829 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2011-02-28 11:15:27.829 Getting current directory name.
. 2011-02-28 11:15:27.829 Getting real path for '.'
> 2011-02-28 11:15:27.829 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2011-02-28 11:15:27.844 Type: SSH_FXP_NAME, Size: 55, Number: 16
. 2011-02-28 11:15:27.844 Real path is '/private/var/root'
. 2011-02-28 11:15:27.844 Listing directory "/private/var/root".
> 2011-02-28 11:15:27.844 Type: SSH_FXP_OPENDIR, Size: 26, Number: 267
< 2011-02-28 11:15:27.844 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2011-02-28 11:15:27.844 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2011-02-28 11:15:27.844 Type: SSH_FXP_NAME, Size: 1245, Number: 524
> 2011-02-28 11:15:27.844 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2011-02-28 11:15:27.860 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2011-02-28 11:15:27.860 Status code: 1
> 2011-02-28 11:15:27.860 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2011-02-28 11:15:27.860 Startup conversation with host finished.
. 2011-02-28 11:15:32.758 Cached directory change via "/" to "/".
. 2011-02-28 11:15:32.758 Getting current directory name.
. 2011-02-28 11:15:32.758 Listing directory "/".
> 2011-02-28 11:15:32.758 Type: SSH_FXP_OPENDIR, Size: 10, Number: 1291
< 2011-02-28 11:15:32.758 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2011-02-28 11:15:32.758 Discarding reserved response
< 2011-02-28 11:15:32.758 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
> 2011-02-28 11:15:32.758 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
< 2011-02-28 11:15:32.868 Type: SSH_FXP_NAME, Size: 3159, Number: 1548
> 2011-02-28 11:15:32.977 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
. 2011-02-28 11:15:32.977 Reading symlink "etc".
> 2011-02-28 11:15:32.977 Type: SSH_FXP_READLINK, Size: 13, Number: 2067
> 2011-02-28 11:15:33.148 Type: SSH_FXP_STAT, Size: 13, Number: 2321
< 2011-02-28 11:15:33.148 Type: SSH_FXP_STATUS, Size: 28, Number: 1804
. 2011-02-28 11:15:33.148 Storing reserved response
< 2011-02-28 11:15:33.148 Type: SSH_FXP_NAME, Size: 43, Number: 2067
< 2011-02-28 11:15:33.414 Type: SSH_FXP_ATTRS, Size: 37, Number: 2321
. 2011-02-28 11:15:33.414 Reading symlink "tmp".
> 2011-02-28 11:15:33.414 Type: SSH_FXP_READLINK, Size: 13, Number: 2579
> 2011-02-28 11:15:33.554 Type: SSH_FXP_STAT, Size: 13, Number: 2833
< 2011-02-28 11:15:33.694 Type: SSH_FXP_NAME, Size: 43, Number: 2579
< 2011-02-28 11:15:33.694 Type: SSH_FXP_ATTRS, Size: 37, Number: 2833
. 2011-02-28 11:15:33.882 Reading symlink "var".
> 2011-02-28 11:15:33.960 Type: SSH_FXP_READLINK, Size: 13, Number: 3091
> 2011-02-28 11:15:33.960 Type: SSH_FXP_STAT, Size: 13, Number: 3345
< 2011-02-28 11:15:34.147 Type: SSH_FXP_NAME, Size: 43, Number: 3091
< 2011-02-28 11:15:34.194 Type: SSH_FXP_ATTRS, Size: 37, Number: 3345
< 2011-02-28 11:15:34.381 Status code: 1
> 2011-02-28 11:15:34.381 Type: SSH_FXP_CLOSE, Size: 13, Number: 3588
. 2011-02-28 11:15:49.076 Cached directory change via "Volumes" to "/Volumes".
. 2011-02-28 11:15:49.076 Getting current directory name.
. 2011-02-28 11:15:49.076 Listing directory "/Volumes".
> 2011-02-28 11:15:49.076 Type: SSH_FXP_OPENDIR, Size: 17, Number: 3851
< 2011-02-28 11:15:49.076 Type: SSH_FXP_STATUS, Size: 24, Number: 3588
. 2011-02-28 11:15:49.076 Discarding reserved response
< 2011-02-28 11:15:49.076 Type: SSH_FXP_HANDLE, Size: 13, Number: 3851
> 2011-02-28 11:15:49.138 Type: SSH_FXP_READDIR, Size: 13, Number: 4108
< 2011-02-28 11:15:49.263 Type: SSH_FXP_NAME, Size: 785, Number: 4108
> 2011-02-28 11:15:49.279 Type: SSH_FXP_READDIR, Size: 13, Number: 4364
. 2011-02-28 11:15:49.326 Reading symlink "Boot".
> 2011-02-28 11:15:49.326 Type: SSH_FXP_READLINK, Size: 22, Number: 4627
> 2011-02-28 11:15:49.513 Type: SSH_FXP_STAT, Size: 22, Number: 4881
< 2011-02-28 11:15:49.544 Type: SSH_FXP_STATUS, Size: 28, Number: 4364
. 2011-02-28 11:15:49.544 Storing reserved response
< 2011-02-28 11:15:49.544 Type: SSH_FXP_NAME, Size: 23, Number: 4627
< 2011-02-28 11:15:49.747 Type: SSH_FXP_ATTRS, Size: 37, Number: 4881
< 2011-02-28 11:15:49.778 Status code: 1
> 2011-02-28 11:15:49.950 Type: SSH_FXP_CLOSE, Size: 13, Number: 5124
. 2011-02-28 11:16:11.041 Cached directory change via "Users" to "/Volumes/Users".
. 2011-02-28 11:16:11.041 Getting current directory name.
. 2011-02-28 11:16:11.041 Listing directory "/Volumes/Users".
> 2011-02-28 11:16:11.041 Type: SSH_FXP_OPENDIR, Size: 23, Number: 5387
< 2011-02-28 11:16:11.041 Type: SSH_FXP_STATUS, Size: 24, Number: 5124
. 2011-02-28 11:16:11.041 Discarding reserved response
< 2011-02-28 11:16:11.041 Type: SSH_FXP_HANDLE, Size: 13, Number: 5387
> 2011-02-28 11:16:11.041 Type: SSH_FXP_READDIR, Size: 13, Number: 5644
< 2011-02-28 11:16:11.228 Type: SSH_FXP_NAME, Size: 4769, Number: 5644
> 2011-02-28 11:16:11.228 Type: SSH_FXP_READDIR, Size: 13, Number: 5900
< 2011-02-28 11:16:11.431 Type: SSH_FXP_STATUS, Size: 28, Number: 5900
< 2011-02-28 11:16:11.431 Status code: 1
> 2011-02-28 11:16:11.431 Type: SSH_FXP_CLOSE, Size: 13, Number: 6148
. 2011-02-28 11:16:14.645 Cached directory change via "/Volumes" to "/Volumes".
. 2011-02-28 11:16:14.645 Getting current directory name.
. 2011-02-28 11:16:14.660 Directory content loaded from cache.
. 2011-02-28 11:16:20.604 Cached directory change via "Pioneer_Projects" to "/Volumes/Pioneer_Projects".
. 2011-02-28 11:16:20.604 Getting current directory name.
. 2011-02-28 11:16:20.604 Listing directory "/Volumes/Pioneer_Projects".
> 2011-02-28 11:16:20.604 Type: SSH_FXP_OPENDIR, Size: 34, Number: 6411
< 2011-02-28 11:16:20.604 Type: SSH_FXP_STATUS, Size: 24, Number: 6148
. 2011-02-28 11:16:20.604 Discarding reserved response
< 2011-02-28 11:16:20.604 Type: SSH_FXP_HANDLE, Size: 13, Number: 6411
> 2011-02-28 11:16:20.604 Type: SSH_FXP_READDIR, Size: 13, Number: 6668
< 2011-02-28 11:16:20.744 Type: SSH_FXP_NAME, Size: 3294, Number: 6668
> 2011-02-28 11:16:20.822 Type: SSH_FXP_READDIR, Size: 13, Number: 6924
< 2011-02-28 11:16:20.916 Type: SSH_FXP_STATUS, Size: 28, Number: 6924
< 2011-02-28 11:16:20.916 Status code: 1
> 2011-02-28 11:16:21.025 Type: SSH_FXP_CLOSE, Size: 13, Number: 7172
. 2011-02-28 11:16:29.823 Collecting synchronization list for local directory 'D:\backup\synchronized_folders\Files_(192.168.1.6)\Pioneer_Projects' and remote directory '/Volumes/Pioneer_Projects', mode = 1, params = 66
. 2011-02-28 11:16:29.886 Listing directory "/Volumes/Pioneer_Projects".
> 2011-02-28 11:16:29.886 Type: SSH_FXP_OPENDIR, Size: 34, Number: 7435
< 2011-02-28 11:16:29.886 Type: SSH_FXP_STATUS, Size: 24, Number: 7172
. 2011-02-28 11:16:29.886 Discarding reserved response
< 2011-02-28 11:16:29.886 Type: SSH_FXP_HANDLE, Size: 13, Number: 7435
> 2011-02-28 11:16:30.073 Type: SSH_FXP_READDIR, Size: 13, Number: 7692
< 2011-02-28 11:16:30.104 Type: SSH_FXP_NAME, Size: 3294, Number: 7692
> 2011-02-28 11:16:30.120 Type: SSH_FXP_READDIR, Size: 13, Number: 7948
< 2011-02-28 11:16:30.323 Type: SSH_FXP_STATUS, Size: 28, Number: 7948
< 2011-02-28 11:16:30.323 Status code: 1
> 2011-02-28 11:16:30.323 Type: SSH_FXP_CLOSE, Size: 13, Number: 8196
. 2011-02-28 11:16:30.385 Collecting synchronization list for local directory 'D:\backup\synchronized_folders\Files_(192.168.1.6)\Pioneer_Projects\ Open Projects' and remote directory '/Volumes/Pioneer_Projects/ Open Projects', mode = 1, params = 66
. 2011-02-28 11:16:30.385 Listing directory "/Volumes/Pioneer_Projects/ Open Projects".
> 2011-02-28 11:16:30.541 Type: SSH_FXP_OPENDIR, Size: 49, Number: 8459
< 2011-02-28 11:16:30.541 Type: SSH_FXP_STATUS, Size: 24, Number: 8196
. 2011-02-28 11:16:30.541 Discarding reserved response
< 2011-02-28 11:16:30.541 Type: SSH_FXP_HANDLE, Size: 13, Number: 8459
> 2011-02-28 11:16:30.541 Type: SSH_FXP_READDIR, Size: 13, Number: 8716
< 2011-02-28 11:16:30.775 Type: SSH_FXP_NAME, Size: 1178, Number: 8716
> 2011-02-28 11:16:30.775 Type: SSH_FXP_READDIR, Size: 13, Number: 8972
< 2011-02-28 11:16:30.978 Type: SSH_FXP_STATUS, Size: 28, Number: 8972
< 2011-02-28 11:16:31.025 Status code: 1
> 2011-02-28 11:16:31.025 Type: SSH_FXP_CLOSE, Size: 13, Number: 9220
. 2011-02-28 11:16:31.025 Collecting synchronization list for local directory 'D:\backup\synchronized_folders\Files_(192.168.1.6)\Pioneer_Projects\ Open Projects\2004_and_Before' and remote directory '/Volumes/Pioneer_Projects/ Open Projects/2004_and_Before', mode = 1, params = 66
. 2011-02-28 11:16:31.025 Listing directory "/Volumes/Pioneer_Projects/ Open Projects/2004_and_Before".
Can you try to use an absolute path in the command, i.e.:
synchronize local "D:\backup\synchronized_folders\Files_(192.168.1.4)\Pioneer_Projects" /Volumes/Pioneer_Projects
I do not really expect this to help, but it is the only difference I see in the logs.
If it does not help (well actually, even if it helps), please send me an email, so I can send you back a debug version of WinSCP to track the problem. Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
