Topic "Error Code: 2 Request Code: 3 File not found. @ 100+ files"
flipman619
Error Code: 2 Request Code: 3 File not found. No such file or directory when file does exist.
Description:
I am able to download the files in question one at a time. However, when downloading the files in batch using a wildcard, the above error occurs. I have verified this by seeing the files listed in the GUI and by downloading them from thew GUI and command line via WinSCP and FileZilla.
It appears that WinSCP cannot find the 101th file and failes with the error described. When using "Option Batch Continue" all subesequent files returned by the wildcard fail with the same error.
System Info:
Currently using the latest version of WinSCP which was downloaded and installed today (4.3.2 installation package).
Running Windows 7 x64. I have not changed any configuration settings.
Steps to Reproduce:
I have tested this on the same SFTP site using several different logins and downloading several different sets of files.
Here is the commands I am using from the command line.
winscp /console /command "option batch continue" "option confirm off" "open sftp://<user>:<pass>@<host>:22 -hostkey=""ssh-dss 1024 06:ba:3c:18:30:ae:ea:51:f1:b4:9d:16:00:1f:b5:bc""" "get /Download/ c:\test\" "exit"
Logs are posted in seperate replies because of posting limitations.
flipman619
Copy of Log1:
. 2011-03-01 13:28:54.705 --------------------------------------------------------------------------
. 2011-03-01 13:28:54.705 WinSCP Version 4.3.2 (Build 1201) (OS 6.1.7600)
. 2011-03-01 13:28:54.705 Login time: Tuesday, March 01, 2011 1:28:54 PM
. 2011-03-01 13:28:54.705 Session name: <USER>@<HOST>
. 2011-03-01 13:28:54.705 Host name: <HOST> (Port: 22)
. 2011-03-01 13:28:54.706 User name: <USER> (Password: Yes, Key file: No)
. 2011-03-01 13:28:54.706 Tunnel: No
. 2011-03-01 13:28:54.706 Transfer Protocol: SFTP
. 2011-03-01 13:28:54.706 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-03-01 13:28:54.706 Proxy: none
. 2011-03-01 13:28:54.706 SSH protocol version: 2; Compression: No
. 2011-03-01 13:28:54.706 Bypass authentication: No
. 2011-03-01 13:28:54.706 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-03-01 13:28:54.706 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-03-01 13:28:54.706 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-03-01 13:28:54.706 SFTP Bugs: -,-
. 2011-03-01 13:28:54.706 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-03-01 13:28:54.706 Shell: default
. 2011-03-01 13:28:54.706 EOL: 0, UTF: 2
. 2011-03-01 13:28:54.706 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-03-01 13:28:54.706 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-03-01 13:28:54.706 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-03-01 13:28:54.706 Cache directory changes: Yes, Permanent: Yes
. 2011-03-01 13:28:54.706 DST mode: 1
. 2011-03-01 13:28:54.706 --------------------------------------------------------------------------
. 2011-03-01 13:28:54.707 Looking up host "<HOST>"
. 2011-03-01 13:28:55.087 Connecting to <IP ADDRESS> port 22
. 2011-03-01 13:28:55.303 Server version: SSH-2.0-1.36_sshlib GlobalSCAPE
. 2011-03-01 13:28:55.303 We believe remote version ignores SSH-2 maximum packet size
. 2011-03-01 13:28:55.303 We believe remote version has SSH-2 ignore bug
. 2011-03-01 13:28:55.303 Using SSH protocol version 2
. 2011-03-01 13:28:55.303 We claim version: SSH-2.0-WinSCP_release_4.3.2
. 2011-03-01 13:28:55.399 Doing Diffie-Hellman group exchange
. 2011-03-01 13:28:55.817 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-03-01 13:28:56.143 Host key fingerprint is:
. 2011-03-01 13:28:56.143 ssh-dss 1024 06:ba:3c:18:30:ae:ea:51:f1:b4:9d:16:00:1f:b5:bc
. 2011-03-01 13:28:56.143 Initialised AES-256 CBC client->server encryption
. 2011-03-01 13:28:56.143 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-03-01 13:28:56.143 Initialised AES-256 CBC server->client encryption
. 2011-03-01 13:28:56.144 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-03-01 13:28:56.503 Using username "<USER>".
. 2011-03-01 13:28:56.602 Prompt (6, SSH password, , &Password: )
. 2011-03-01 13:28:56.602 Using stored password.
. 2011-03-01 13:28:56.602 Sent password
. 2011-03-01 13:28:56.695 Access granted
. 2011-03-01 13:28:56.788 Opened channel for session
. 2011-03-01 13:28:57.256 Started a shell/command
. 2011-03-01 13:28:57.256 --------------------------------------------------------------------------
. 2011-03-01 13:28:57.256 Using SFTP protocol.
. 2011-03-01 13:28:57.256 Doing startup conversation with host.
> 2011-03-01 13:28:57.257 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-03-01 13:28:57.345 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2011-03-01 13:28:57.346 SFTP version 3 negotiated.
. 2011-03-01 13:28:57.346 We believe the server has signed timestamps bug
. 2011-03-01 13:28:57.346 We will use UTF-8 strings for status messages only
. 2011-03-01 13:28:57.346 Getting current directory name.
. 2011-03-01 13:28:57.346 Getting real path for '.'
> 2011-03-01 13:28:57.346 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2011-03-01 13:28:57.442 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2011-03-01 13:28:57.442 Real path is '/'
. 2011-03-01 13:28:57.442 Startup conversation with host finished.
< 2011-03-01 13:28:57.442 Script: Active session: [1] <USER>@<HOST>
> 2011-03-01 13:28:57.443 Script: get /Download/ c:\test\
. 2011-03-01 13:28:57.443 Listing file "/Download/".
> 2011-03-01 13:28:57.443 Type: SSH_FXP_LSTAT, Size: 19, Number: 263
< 2011-03-01 13:28:57.534 Type: SSH_FXP_ATTRS, Size: 21, Number: 263
. 2011-03-01 13:28:57.534 File: "/Download/"
. 2011-03-01 13:28:57.535 Listing directory "/Download".
> 2011-03-01 13:28:57.535 Type: SSH_FXP_OPENDIR, Size: 18, Number: 523
< 2011-03-01 13:28:57.654 Type: SSH_FXP_HANDLE, Size: 10, Number: 523
> 2011-03-01 13:28:57.654 Type: SSH_FXP_READDIR, Size: 10, Number: 780
< 2011-03-01 13:28:57.880 Type: SSH_FXP_NAME, Size: 30585, Number: 780
> 2011-03-01 13:28:57.880 Type: SSH_FXP_READDIR, Size: 10, Number: 1036
< 2011-03-01 13:28:57.979 Type: SSH_FXP_STATUS, Size: 22, Number: 1036
< 2011-03-01 13:28:57.980 Status code: 1
> 2011-03-01 13:28:57.980 Type: SSH_FXP_CLOSE, Size: 10, Number: 1284
. 2011-03-01 13:28:57.980 File: "/Download/01040-110130-0352-PARALLEL.zip"
. 2011-03-01 13:28:57.980 Copying "/Download/01040-110130-0352-PARALLEL.zip" to local directory started.
. 2011-03-01 13:28:57.980 Binary transfer mode selected.
. 2011-03-01 13:28:57.981 Confirming overwriting of file.
. 2011-03-01 13:28:57.981 Opening remote file.
> 2011-03-01 13:28:57.981 Type: SSH_FXP_OPEN, Size: 57, Number: 1539
< 2011-03-01 13:28:58.078 Type: SSH_FXP_STATUS, Size: 21, Number: 1284
. 2011-03-01 13:28:58.078 Discarding reserved response
< 2011-03-01 13:28:58.169 Type: SSH_FXP_HANDLE, Size: 10, Number: 1539
> 2011-03-01 13:28:58.169 Type: SSH_FXP_FSTAT, Size: 10, Number: 1800
> 2011-03-01 13:28:58.169 Type: SSH_FXP_READ, Size: 22, Number: 2053
< 2011-03-01 13:28:58.263 Type: SSH_FXP_ATTRS, Size: 29, Number: 1800
. 2011-03-01 13:28:58.263 Storing reserved response
< 2011-03-01 13:28:58.451 Status code: 1
. 2011-03-01 13:28:58.451 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:28:58.451 Type: SSH_FXP_CLOSE, Size: 10, Number: 2564
. 2011-03-01 13:28:58.453 File: "/Download/01040-110130-0623-PARALLEL.zip"
. 2011-03-01 13:28:58.453 Copying "/Download/01040-110130-0623-PARALLEL.zip" to local directory started.
. 2011-03-01 13:28:58.454 Binary transfer mode selected.
. 2011-03-01 13:28:58.454 Confirming overwriting of file.
. 2011-03-01 13:28:58.454 Opening remote file.
> 2011-03-01 13:28:58.455 Type: SSH_FXP_OPEN, Size: 57, Number: 2819
< 2011-03-01 13:28:58.546 Type: SSH_FXP_STATUS, Size: 21, Number: 2564
. 2011-03-01 13:28:58.546 Discarding reserved response
< 2011-03-01 13:28:58.657 Type: SSH_FXP_HANDLE, Size: 10, Number: 2819
> 2011-03-01 13:28:58.657 Type: SSH_FXP_FSTAT, Size: 10, Number: 3080
> 2011-03-01 13:28:58.657 Type: SSH_FXP_READ, Size: 22, Number: 3333
< 2011-03-01 13:28:58.752 Type: SSH_FXP_ATTRS, Size: 29, Number: 3080
. 2011-03-01 13:28:58.752 Storing reserved response
< 2011-03-01 13:28:58.936 Status code: 1
. 2011-03-01 13:28:58.936 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:28:58.936 Type: SSH_FXP_CLOSE, Size: 10, Number: 3844
. 2011-03-01 13:28:58.938 File: "/Download/01040-110131-0131-PARALLEL.zip"
. 2011-03-01 13:28:58.938 Copying "/Download/01040-110131-0131-PARALLEL.zip" to local directory started.
. 2011-03-01 13:28:58.939 Binary transfer mode selected.
. 2011-03-01 13:28:58.948 Confirming overwriting of file.
. 2011-03-01 13:28:58.949 Opening remote file.
> 2011-03-01 13:28:58.949 Type: SSH_FXP_OPEN, Size: 57, Number: 4099
< 2011-03-01 13:28:59.029 Type: SSH_FXP_STATUS, Size: 21, Number: 3844
. 2011-03-01 13:28:59.029 Discarding reserved response
< 2011-03-01 13:28:59.123 Type: SSH_FXP_HANDLE, Size: 10, Number: 4099
> 2011-03-01 13:28:59.123 Type: SSH_FXP_FSTAT, Size: 10, Number: 4360
> 2011-03-01 13:28:59.123 Type: SSH_FXP_READ, Size: 22, Number: 4613
< 2011-03-01 13:28:59.224 Type: SSH_FXP_ATTRS, Size: 29, Number: 4360
. 2011-03-01 13:28:59.224 Storing reserved response
< 2011-03-01 13:28:59.422 Status code: 1
. 2011-03-01 13:28:59.422 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:28:59.422 Type: SSH_FXP_CLOSE, Size: 10, Number: 5124
. 2011-03-01 13:28:59.424 File: "/Download/01040-110131-0325-PARALLEL.zip"
. 2011-03-01 13:28:59.424 Copying "/Download/01040-110131-0325-PARALLEL.zip" to local directory started.
. 2011-03-01 13:28:59.424 Binary transfer mode selected.
. 2011-03-01 13:28:59.425 Confirming overwriting of file.
. 2011-03-01 13:28:59.425 Opening remote file.
> 2011-03-01 13:28:59.425 Type: SSH_FXP_OPEN, Size: 57, Number: 5379
< 2011-03-01 13:28:59.519 Type: SSH_FXP_STATUS, Size: 21, Number: 5124
. 2011-03-01 13:28:59.519 Discarding reserved response
< 2011-03-01 13:28:59.612 Type: SSH_FXP_HANDLE, Size: 10, Number: 5379
> 2011-03-01 13:28:59.612 Type: SSH_FXP_FSTAT, Size: 10, Number: 5640
> 2011-03-01 13:28:59.612 Type: SSH_FXP_READ, Size: 22, Number: 5893
. 2011-03-01 13:28:59.702 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:28:59.702 Type: SSH_FXP_ATTRS, Size: 29, Number: 5640
. 2011-03-01 13:28:59.702 Storing reserved response
< 2011-03-01 13:28:59.953 Status code: 1
. 2011-03-01 13:28:59.953 5 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:28:59.953 Type: SSH_FXP_CLOSE, Size: 10, Number: 6916
< 2011-03-01 13:29:00.085 Type: SSH_FXP_STATUS, Size: 22, Number: 6661
. 2011-03-01 13:29:00.087 File: "/Download/01040-110131-0355-PARALLEL.zip"
. 2011-03-01 13:29:00.087 Copying "/Download/01040-110131-0355-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:00.088 Binary transfer mode selected.
. 2011-03-01 13:29:00.111 Confirming overwriting of file.
. 2011-03-01 13:29:00.111 Opening remote file.
> 2011-03-01 13:29:00.111 Type: SSH_FXP_OPEN, Size: 57, Number: 7171
< 2011-03-01 13:29:00.182 Type: SSH_FXP_STATUS, Size: 21, Number: 6916
. 2011-03-01 13:29:00.182 Discarding reserved response
< 2011-03-01 13:29:00.307 Type: SSH_FXP_HANDLE, Size: 10, Number: 7171
> 2011-03-01 13:29:00.307 Type: SSH_FXP_FSTAT, Size: 10, Number: 7432
> 2011-03-01 13:29:00.307 Type: SSH_FXP_READ, Size: 22, Number: 7685
. 2011-03-01 13:29:00.429 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:29:00.430 Type: SSH_FXP_ATTRS, Size: 29, Number: 7432
. 2011-03-01 13:29:00.430 Storing reserved response
< 2011-03-01 13:29:00.643 Status code: 1
. 2011-03-01 13:29:00.644 7 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:00.644 Type: SSH_FXP_CLOSE, Size: 10, Number: 9220
< 2011-03-01 13:29:00.738 Type: SSH_FXP_STATUS, Size: 22, Number: 8709
< 2011-03-01 13:29:00.738 Type: SSH_FXP_STATUS, Size: 22, Number: 8965
. 2011-03-01 13:29:00.739 File: "/Download/01040-110131-1024-PARALLEL.zip"
. 2011-03-01 13:29:00.740 Copying "/Download/01040-110131-1024-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:00.740 Binary transfer mode selected.
. 2011-03-01 13:29:00.746 Confirming overwriting of file.
. 2011-03-01 13:29:00.747 Opening remote file.
> 2011-03-01 13:29:00.747 Type: SSH_FXP_OPEN, Size: 57, Number: 9475
< 2011-03-01 13:29:00.834 Type: SSH_FXP_STATUS, Size: 21, Number: 9220
. 2011-03-01 13:29:00.834 Discarding reserved response
< 2011-03-01 13:29:00.928 Type: SSH_FXP_HANDLE, Size: 10, Number: 9475
> 2011-03-01 13:29:00.928 Type: SSH_FXP_FSTAT, Size: 10, Number: 9736
> 2011-03-01 13:29:00.928 Type: SSH_FXP_READ, Size: 22, Number: 9989
< 2011-03-01 13:29:01.025 Type: SSH_FXP_ATTRS, Size: 29, Number: 9736
. 2011-03-01 13:29:01.025 Storing reserved response
< 2011-03-01 13:29:01.244 Status code: 1
. 2011-03-01 13:29:01.244 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:01.244 Type: SSH_FXP_CLOSE, Size: 10, Number: 10500
. 2011-03-01 13:29:01.246 File: "/Download/01040-110131-1210-PARALLEL.zip"
. 2011-03-01 13:29:01.246 Copying "/Download/01040-110131-1210-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:01.247 Binary transfer mode selected.
. 2011-03-01 13:29:01.247 Confirming overwriting of file.
. 2011-03-01 13:29:01.247 Opening remote file.
> 2011-03-01 13:29:01.247 Type: SSH_FXP_OPEN, Size: 57, Number: 10755
< 2011-03-01 13:29:01.366 Type: SSH_FXP_STATUS, Size: 21, Number: 10500
. 2011-03-01 13:29:01.366 Discarding reserved response
< 2011-03-01 13:29:01.458 Type: SSH_FXP_HANDLE, Size: 10, Number: 10755
> 2011-03-01 13:29:01.458 Type: SSH_FXP_FSTAT, Size: 10, Number: 11016
> 2011-03-01 13:29:01.458 Type: SSH_FXP_READ, Size: 22, Number: 11269
. 2011-03-01 13:29:01.583 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:29:01.583 Type: SSH_FXP_ATTRS, Size: 29, Number: 11016
. 2011-03-01 13:29:01.583 Storing reserved response
< 2011-03-01 13:29:01.807 Status code: 1
. 2011-03-01 13:29:01.807 9 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:01.807 Type: SSH_FXP_CLOSE, Size: 10, Number: 13316
< 2011-03-01 13:29:01.807 Type: SSH_FXP_STATUS, Size: 22, Number: 12549
< 2011-03-01 13:29:01.813 Type: SSH_FXP_STATUS, Size: 22, Number: 12805
< 2011-03-01 13:29:01.906 Type: SSH_FXP_STATUS, Size: 22, Number: 13061
. 2011-03-01 13:29:01.907 File: "/Download/01040-110201-0126-PARALLEL.zip"
. 2011-03-01 13:29:01.908 Copying "/Download/01040-110201-0126-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:01.908 Binary transfer mode selected.
. 2011-03-01 13:29:01.920 Confirming overwriting of file.
. 2011-03-01 13:29:01.921 Opening remote file.
> 2011-03-01 13:29:01.921 Type: SSH_FXP_OPEN, Size: 57, Number: 13571
< 2011-03-01 13:29:01.921 Type: SSH_FXP_STATUS, Size: 21, Number: 13316
. 2011-03-01 13:29:01.921 Discarding reserved response
< 2011-03-01 13:29:02.008 Type: SSH_FXP_HANDLE, Size: 10, Number: 13571
> 2011-03-01 13:29:02.008 Type: SSH_FXP_FSTAT, Size: 10, Number: 13832
> 2011-03-01 13:29:02.008 Type: SSH_FXP_READ, Size: 22, Number: 14085
< 2011-03-01 13:29:02.101 Type: SSH_FXP_ATTRS, Size: 29, Number: 13832
. 2011-03-01 13:29:02.101 Storing reserved response
< 2011-03-01 13:29:02.334 Status code: 1
. 2011-03-01 13:29:02.334 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:02.334 Type: SSH_FXP_CLOSE, Size: 10, Number: 14596
. 2011-03-01 13:29:02.335 File: "/Download/01040-110201-0431-PARALLEL.zip"
. 2011-03-01 13:29:02.335 Copying "/Download/01040-110201-0431-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:02.336 Binary transfer mode selected.
. 2011-03-01 13:29:02.349 Confirming overwriting of file.
. 2011-03-01 13:29:02.349 Opening remote file.
> 2011-03-01 13:29:02.349 Type: SSH_FXP_OPEN, Size: 57, Number: 14851
< 2011-03-01 13:29:02.452 Type: SSH_FXP_STATUS, Size: 21, Number: 14596
. 2011-03-01 13:29:02.452 Discarding reserved response
< 2011-03-01 13:29:02.544 Type: SSH_FXP_HANDLE, Size: 10, Number: 14851
> 2011-03-01 13:29:02.544 Type: SSH_FXP_FSTAT, Size: 10, Number: 15112
> 2011-03-01 13:29:02.544 Type: SSH_FXP_READ, Size: 22, Number: 15365
< 2011-03-01 13:29:02.642 Type: SSH_FXP_ATTRS, Size: 29, Number: 15112
. 2011-03-01 13:29:02.642 Storing reserved response
< 2011-03-01 13:29:02.831 Status code: 1
. 2011-03-01 13:29:02.831 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:02.831 Type: SSH_FXP_CLOSE, Size: 10, Number: 15876
. 2011-03-01 13:29:02.833 File: "/Download/01040-110201-0445-PARALLEL.zip"
. 2011-03-01 13:29:02.833 Copying "/Download/01040-110201-0445-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:02.834 Binary transfer mode selected.
. 2011-03-01 13:29:02.866 Confirming overwriting of file.
. 2011-03-01 13:29:02.866 Opening remote file.
> 2011-03-01 13:29:02.866 Type: SSH_FXP_OPEN, Size: 57, Number: 16131
< 2011-03-01 13:29:02.927 Type: SSH_FXP_STATUS, Size: 21, Number: 15876
. 2011-03-01 13:29:02.927 Discarding reserved response
< 2011-03-01 13:29:03.018 Type: SSH_FXP_HANDLE, Size: 10, Number: 16131
> 2011-03-01 13:29:03.018 Type: SSH_FXP_FSTAT, Size: 10, Number: 16392
> 2011-03-01 13:29:03.018 Type: SSH_FXP_READ, Size: 22, Number: 16645
. 2011-03-01 13:29:03.110 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:29:03.110 Type: SSH_FXP_ATTRS, Size: 29, Number: 16392
. 2011-03-01 13:29:03.110 Storing reserved response
< 2011-03-01 13:29:03.458 Status code: 1
. 2011-03-01 13:29:03.458 11 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:03.458 Type: SSH_FXP_CLOSE, Size: 10, Number: 18948
< 2011-03-01 13:29:03.458 Type: SSH_FXP_STATUS, Size: 22, Number: 18181
< 2011-03-01 13:29:03.458 Type: SSH_FXP_STATUS, Size: 22, Number: 18437
< 2011-03-01 13:29:03.509 Type: SSH_FXP_STATUS, Size: 22, Number: 18693
. 2011-03-01 13:29:03.510 File: "/Download/01040-110201-0508-PARALLEL.zip"
. 2011-03-01 13:29:03.511 Copying "/Download/01040-110201-0508-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:03.511 Binary transfer mode selected.
. 2011-03-01 13:29:03.521 Confirming overwriting of file.
. 2011-03-01 13:29:03.522 Opening remote file.
> 2011-03-01 13:29:03.522 Type: SSH_FXP_OPEN, Size: 57, Number: 19203
< 2011-03-01 13:29:03.598 Type: SSH_FXP_STATUS, Size: 21, Number: 18948
. 2011-03-01 13:29:03.598 Discarding reserved response
< 2011-03-01 13:29:03.694 Type: SSH_FXP_HANDLE, Size: 10, Number: 19203
> 2011-03-01 13:29:03.694 Type: SSH_FXP_FSTAT, Size: 10, Number: 19464
> 2011-03-01 13:29:03.694 Type: SSH_FXP_READ, Size: 22, Number: 19717
< 2011-03-01 13:29:03.810 Type: SSH_FXP_ATTRS, Size: 29, Number: 19464
. 2011-03-01 13:29:03.810 Storing reserved response
< 2011-03-01 13:29:04.056 Status code: 1
. 2011-03-01 13:29:04.056 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:04.056 Type: SSH_FXP_CLOSE, Size: 10, Number: 20228
. 2011-03-01 13:29:04.057 File: "/Download/01040-110201-0540-PARALLEL.zip"
. 2011-03-01 13:29:04.058 Copying "/Download/01040-110201-0540-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:04.058 Binary transfer mode selected.
. 2011-03-01 13:29:04.066 Confirming overwriting of file.
. 2011-03-01 13:29:04.067 Opening remote file.
> 2011-03-01 13:29:04.067 Type: SSH_FXP_OPEN, Size: 57, Number: 20483
< 2011-03-01 13:29:04.151 Type: SSH_FXP_STATUS, Size: 21, Number: 20228
. 2011-03-01 13:29:04.151 Discarding reserved response
< 2011-03-01 13:29:04.238 Type: SSH_FXP_HANDLE, Size: 10, Number: 20483
> 2011-03-01 13:29:04.238 Type: SSH_FXP_FSTAT, Size: 10, Number: 20744
> 2011-03-01 13:29:04.238 Type: SSH_FXP_READ, Size: 22, Number: 20997
< 2011-03-01 13:29:04.332 Type: SSH_FXP_ATTRS, Size: 29, Number: 20744
. 2011-03-01 13:29:04.332 Storing reserved response
< 2011-03-01 13:29:04.522 Status code: 1
. 2011-03-01 13:29:04.522 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:04.522 Type: SSH_FXP_CLOSE, Size: 10, Number: 21508
. 2011-03-01 13:29:04.524 File: "/Download/01040-110201-0639-PARALLEL.zip"
. 2011-03-01 13:29:04.524 Copying "/Download/01040-110201-0639-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:04.524 Binary transfer mode selected.
. 2011-03-01 13:29:04.526 Confirming overwriting of file.
. 2011-03-01 13:29:04.526 Opening remote file.
> 2011-03-01 13:29:04.526 Type: SSH_FXP_OPEN, Size: 57, Number: 21763
< 2011-03-01 13:29:04.618 Type: SSH_FXP_STATUS, Size: 21, Number: 21508
. 2011-03-01 13:29:04.618 Discarding reserved response
< 2011-03-01 13:29:04.715 Type: SSH_FXP_HANDLE, Size: 10, Number: 21763
> 2011-03-01 13:29:04.715 Type: SSH_FXP_FSTAT, Size: 10, Number: 22024
> 2011-03-01 13:29:04.715 Type: SSH_FXP_READ, Size: 22, Number: 22277
< 2011-03-01 13:29:04.817 Type: SSH_FXP_ATTRS, Size: 29, Number: 22024
. 2011-03-01 13:29:04.817 Storing reserved response
< 2011-03-01 13:29:05.063 Status code: 1
. 2011-03-01 13:29:05.063 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:05.063 Type: SSH_FXP_CLOSE, Size: 10, Number: 22788
. 2011-03-01 13:29:05.065 File: "/Download/01040-110201-0840-PARALLEL.zip"
. 2011-03-01 13:29:05.065 Copying "/Download/01040-110201-0840-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:05.066 Binary transfer mode selected.
. 2011-03-01 13:29:05.066 Confirming overwriting of file.
. 2011-03-01 13:29:05.067 Opening remote file.
> 2011-03-01 13:29:05.067 Type: SSH_FXP_OPEN, Size: 57, Number: 23043
< 2011-03-01 13:29:05.148 Type: SSH_FXP_STATUS, Size: 21, Number: 22788
. 2011-03-01 13:29:05.148 Discarding reserved response
< 2011-03-01 13:29:05.249 Type: SSH_FXP_HANDLE, Size: 10, Number: 23043
> 2011-03-01 13:29:05.249 Type: SSH_FXP_FSTAT, Size: 10, Number: 23304
> 2011-03-01 13:29:05.249 Type: SSH_FXP_READ, Size: 22, Number: 23557
< 2011-03-01 13:29:05.342 Type: SSH_FXP_ATTRS, Size: 29, Number: 23304
. 2011-03-01 13:29:05.342 Storing reserved response
< 2011-03-01 13:29:05.542 Status code: 1
. 2011-03-01 13:29:05.542 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:05.542 Type: SSH_FXP_CLOSE, Size: 10, Number: 24068
. 2011-03-01 13:29:05.543 File: "/Download/01040-110201-0911-PARALLEL.zip"
. 2011-03-01 13:29:05.544 Copying "/Download/01040-110201-0911-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:05.544 Binary transfer mode selected.
. 2011-03-01 13:29:05.545 Confirming overwriting of file.
. 2011-03-01 13:29:05.545 Opening remote file.
> 2011-03-01 13:29:05.545 Type: SSH_FXP_OPEN, Size: 57, Number: 24323
< 2011-03-01 13:29:05.638 Type: SSH_FXP_STATUS, Size: 21, Number: 24068
. 2011-03-01 13:29:05.638 Discarding reserved response
< 2011-03-01 13:29:05.731 Type: SSH_FXP_HANDLE, Size: 10, Number: 24323
> 2011-03-01 13:29:05.731 Type: SSH_FXP_FSTAT, Size: 10, Number: 24584
> 2011-03-01 13:29:05.731 Type: SSH_FXP_READ, Size: 22, Number: 24837
< 2011-03-01 13:29:05.856 Type: SSH_FXP_ATTRS, Size: 29, Number: 24584
. 2011-03-01 13:29:05.856 Storing reserved response
< 2011-03-01 13:29:06.077 Status code: 1
. 2011-03-01 13:29:06.077 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:06.077 Type: SSH_FXP_CLOSE, Size: 10, Number: 25348
. 2011-03-01 13:29:06.078 File: "/Download/01040-110201-1051-PARALLEL.zip"
. 2011-03-01 13:29:06.079 Copying "/Download/01040-110201-1051-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:06.079 Binary transfer mode selected.
. 2011-03-01 13:29:06.085 Confirming overwriting of file.
. 2011-03-01 13:29:06.085 Opening remote file.
> 2011-03-01 13:29:06.085 Type: SSH_FXP_OPEN, Size: 57, Number: 25603
< 2011-03-01 13:29:06.203 Type: SSH_FXP_STATUS, Size: 21, Number: 25348
. 2011-03-01 13:29:06.203 Discarding reserved response
< 2011-03-01 13:29:06.293 Type: SSH_FXP_HANDLE, Size: 10, Number: 25603
> 2011-03-01 13:29:06.293 Type: SSH_FXP_FSTAT, Size: 10, Number: 25864
> 2011-03-01 13:29:06.293 Type: SSH_FXP_READ, Size: 22, Number: 26117
< 2011-03-01 13:29:06.382 Type: SSH_FXP_ATTRS, Size: 29, Number: 25864
. 2011-03-01 13:29:06.382 Storing reserved response
< 2011-03-01 13:29:06.583 Status code: 1
. 2011-03-01 13:29:06.583 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:06.583 Type: SSH_FXP_CLOSE, Size: 10, Number: 26628
. 2011-03-01 13:29:06.585 File: "/Download/01040-110202-0104-PARALLEL.zip"
. 2011-03-01 13:29:06.585 Copying "/Download/01040-110202-0104-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:06.586 Binary transfer mode selected.
. 2011-03-01 13:29:06.595 Confirming overwriting of file.
. 2011-03-01 13:29:06.595 Opening remote file.
> 2011-03-01 13:29:06.595 Type: SSH_FXP_OPEN, Size: 57, Number: 26883
< 2011-03-01 13:29:06.678 Type: SSH_FXP_STATUS, Size: 21, Number: 26628
. 2011-03-01 13:29:06.678 Discarding reserved response
< 2011-03-01 13:29:06.775 Type: SSH_FXP_HANDLE, Size: 10, Number: 26883
> 2011-03-01 13:29:06.775 Type: SSH_FXP_FSTAT, Size: 10, Number: 27144
> 2011-03-01 13:29:06.775 Type: SSH_FXP_READ, Size: 22, Number: 27397
< 2011-03-01 13:29:06.890 Type: SSH_FXP_ATTRS, Size: 29, Number: 27144
. 2011-03-01 13:29:06.891 Storing reserved response
< 2011-03-01 13:29:07.131 Status code: 1
. 2011-03-01 13:29:07.132 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:07.132 Type: SSH_FXP_CLOSE, Size: 10, Number: 27908
. 2011-03-01 13:29:07.133 File: "/Download/01040-110202-0133-PARALLEL.zip"
. 2011-03-01 13:29:07.133 Copying "/Download/01040-110202-0133-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:07.134 Binary transfer mode selected.
. 2011-03-01 13:29:07.151 Confirming overwriting of file.
. 2011-03-01 13:29:07.152 Opening remote file.
> 2011-03-01 13:29:07.152 Type: SSH_FXP_OPEN, Size: 57, Number: 28163
< 2011-03-01 13:29:07.228 Type: SSH_FXP_STATUS, Size: 21, Number: 27908
. 2011-03-01 13:29:07.228 Discarding reserved response
< 2011-03-01 13:29:07.323 Type: SSH_FXP_HANDLE, Size: 10, Number: 28163
> 2011-03-01 13:29:07.323 Type: SSH_FXP_FSTAT, Size: 10, Number: 28424
> 2011-03-01 13:29:07.323 Type: SSH_FXP_READ, Size: 22, Number: 28677
< 2011-03-01 13:29:07.412 Type: SSH_FXP_ATTRS, Size: 29, Number: 28424
. 2011-03-01 13:29:07.412 Storing reserved response
< 2011-03-01 13:29:07.620 Status code: 1
. 2011-03-01 13:29:07.620 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:07.620 Type: SSH_FXP_CLOSE, Size: 10, Number: 29188
. 2011-03-01 13:29:07.622 File: "/Download/01040-110202-0210-PARALLEL.zip"
. 2011-03-01 13:29:07.622 Copying "/Download/01040-110202-0210-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:07.623 Binary transfer mode selected.
. 2011-03-01 13:29:07.638 Confirming overwriting of file.
. 2011-03-01 13:29:07.639 Opening remote file.
> 2011-03-01 13:29:07.639 Type: SSH_FXP_OPEN, Size: 57, Number: 29443
< 2011-03-01 13:29:07.721 Type: SSH_FXP_STATUS, Size: 21, Number: 29188
. 2011-03-01 13:29:07.721 Discarding reserved response
< 2011-03-01 13:29:07.816 Type: SSH_FXP_HANDLE, Size: 10, Number: 29443
> 2011-03-01 13:29:07.816 Type: SSH_FXP_FSTAT, Size: 10, Number: 29704
> 2011-03-01 13:29:07.816 Type: SSH_FXP_READ, Size: 22, Number: 29957
. 2011-03-01 13:29:07.944 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:29:07.944 Type: SSH_FXP_ATTRS, Size: 29, Number: 29704
. 2011-03-01 13:29:07.944 Storing reserved response
< 2011-03-01 13:29:08.176 Status code: 1
. 2011-03-01 13:29:08.176 7 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:08.176 Type: SSH_FXP_CLOSE, Size: 10, Number: 31492
< 2011-03-01 13:29:08.269 Type: SSH_FXP_STATUS, Size: 22, Number: 30981
< 2011-03-01 13:29:08.270 Type: SSH_FXP_STATUS, Size: 22, Number: 31237
. 2011-03-01 13:29:08.272 File: "/Download/01040-110202-0306-PARALLEL.zip"
. 2011-03-01 13:29:08.272 Copying "/Download/01040-110202-0306-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:08.272 Binary transfer mode selected.
. 2011-03-01 13:29:08.295 Confirming overwriting of file.
. 2011-03-01 13:29:08.296 Opening remote file.
> 2011-03-01 13:29:08.296 Type: SSH_FXP_OPEN, Size: 57, Number: 31747
< 2011-03-01 13:29:08.364 Type: SSH_FXP_STATUS, Size: 21, Number: 31492
. 2011-03-01 13:29:08.364 Discarding reserved response
< 2011-03-01 13:29:08.452 Type: SSH_FXP_HANDLE, Size: 10, Number: 31747
> 2011-03-01 13:29:08.452 Type: SSH_FXP_FSTAT, Size: 10, Number: 32008
> 2011-03-01 13:29:08.452 Type: SSH_FXP_READ, Size: 22, Number: 32261
< 2011-03-01 13:29:08.543 Type: SSH_FXP_ATTRS, Size: 29, Number: 32008
. 2011-03-01 13:29:08.543 Storing reserved response
< 2011-03-01 13:29:08.739 Status code: 1
. 2011-03-01 13:29:08.739 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:08.739 Type: SSH_FXP_CLOSE, Size: 10, Number: 32772
. 2011-03-01 13:29:08.741 File: "/Download/01040-110202-0539-PARALLEL.zip"
. 2011-03-01 13:29:08.741 Copying "/Download/01040-110202-0539-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:08.741 Binary transfer mode selected.
. 2011-03-01 13:29:08.757 Confirming overwriting of file.
. 2011-03-01 13:29:08.757 Opening remote file.
> 2011-03-01 13:29:08.758 Type: SSH_FXP_OPEN, Size: 57, Number: 33027
< 2011-03-01 13:29:08.854 Type: SSH_FXP_STATUS, Size: 21, Number: 32772
. 2011-03-01 13:29:08.854 Discarding reserved response
< 2011-03-01 13:29:08.948 Type: SSH_FXP_HANDLE, Size: 10, Number: 33027
> 2011-03-01 13:29:08.948 Type: SSH_FXP_FSTAT, Size: 10, Number: 33288
> 2011-03-01 13:29:08.948 Type: SSH_FXP_READ, Size: 22, Number: 33541
< 2011-03-01 13:29:09.067 Type: SSH_FXP_ATTRS, Size: 29, Number: 33288
. 2011-03-01 13:29:09.067 Storing reserved response
< 2011-03-01 13:29:09.275 Status code: 1
. 2011-03-01 13:29:09.275 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:09.275 Type: SSH_FXP_CLOSE, Size: 10, Number: 34052
. 2011-03-01 13:29:09.277 File: "/Download/01040-110202-0623-PARALLEL.zip"
. 2011-03-01 13:29:09.278 Copying "/Download/01040-110202-0623-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:09.278 Binary transfer mode selected.
. 2011-03-01 13:29:09.292 Confirming overwriting of file.
. 2011-03-01 13:29:09.292 Opening remote file.
> 2011-03-01 13:29:09.292 Type: SSH_FXP_OPEN, Size: 57, Number: 34307
< 2011-03-01 13:29:09.368 Type: SSH_FXP_STATUS, Size: 21, Number: 34052
. 2011-03-01 13:29:09.368 Discarding reserved response
< 2011-03-01 13:29:09.470 Type: SSH_FXP_HANDLE, Size: 10, Number: 34307
> 2011-03-01 13:29:09.470 Type: SSH_FXP_FSTAT, Size: 10, Number: 34568
> 2011-03-01 13:29:09.470 Type: SSH_FXP_READ, Size: 22, Number: 34821
< 2011-03-01 13:29:09.564 Type: SSH_FXP_ATTRS, Size: 29, Number: 34568
. 2011-03-01 13:29:09.564 Storing reserved response
< 2011-03-01 13:29:09.768 Status code: 1
. 2011-03-01 13:29:09.769 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:09.769 Type: SSH_FXP_CLOSE, Size: 10, Number: 35332
. 2011-03-01 13:29:09.770 File: "/Download/01040-110202-0838-PARALLEL.zip"
. 2011-03-01 13:29:09.770 Copying "/Download/01040-110202-0838-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:09.771 Binary transfer mode selected.
. 2011-03-01 13:29:09.784 Confirming overwriting of file.
. 2011-03-01 13:29:09.784 Opening remote file.
> 2011-03-01 13:29:09.784 Type: SSH_FXP_OPEN, Size: 57, Number: 35587
< 2011-03-01 13:29:09.861 Type: SSH_FXP_STATUS, Size: 21, Number: 35332
. 2011-03-01 13:29:09.861 Discarding reserved response
< 2011-03-01 13:29:09.960 Type: SSH_FXP_HANDLE, Size: 10, Number: 35587
> 2011-03-01 13:29:09.960 Type: SSH_FXP_FSTAT, Size: 10, Number: 35848
> 2011-03-01 13:29:09.960 Type: SSH_FXP_READ, Size: 22, Number: 36101
< 2011-03-01 13:29:10.056 Type: SSH_FXP_ATTRS, Size: 29, Number: 35848
. 2011-03-01 13:29:10.056 Storing reserved response
< 2011-03-01 13:29:10.285 Status code: 1
. 2011-03-01 13:29:10.285 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:10.285 Type: SSH_FXP_CLOSE, Size: 10, Number: 36612
. 2011-03-01 13:29:10.286 File: "/Download/01040-110203-0116-PARALLEL.zip"
. 2011-03-01 13:29:10.287 Copying "/Download/01040-110203-0116-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:10.287 Binary transfer mode selected.
. 2011-03-01 13:29:10.288 Confirming overwriting of file.
. 2011-03-01 13:29:10.288 Opening remote file.
> 2011-03-01 13:29:10.288 Type: SSH_FXP_OPEN, Size: 57, Number: 36867
< 2011-03-01 13:29:10.382 Type: SSH_FXP_STATUS, Size: 21, Number: 36612
. 2011-03-01 13:29:10.382 Discarding reserved response
< 2011-03-01 13:29:10.511 Type: SSH_FXP_HANDLE, Size: 10, Number: 36867
> 2011-03-01 13:29:10.511 Type: SSH_FXP_FSTAT, Size: 10, Number: 37128
> 2011-03-01 13:29:10.511 Type: SSH_FXP_READ, Size: 22, Number: 37381
< 2011-03-01 13:29:10.612 Type: SSH_FXP_ATTRS, Size: 29, Number: 37128
. 2011-03-01 13:29:10.612 Storing reserved response
< 2011-03-01 13:29:10.810 Status code: 1
. 2011-03-01 13:29:10.810 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:10.810 Type: SSH_FXP_CLOSE, Size: 10, Number: 37892
. 2011-03-01 13:29:10.811 File: "/Download/01040-110203-0133-PARALLEL.zip"
. 2011-03-01 13:29:10.811 Copying "/Download/01040-110203-0133-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:10.812 Binary transfer mode selected.
. 2011-03-01 13:29:10.812 Confirming overwriting of file.
. 2011-03-01 13:29:10.812 Opening remote file.
> 2011-03-01 13:29:10.812 Type: SSH_FXP_OPEN, Size: 57, Number: 38147
< 2011-03-01 13:29:10.906 Type: SSH_FXP_STATUS, Size: 21, Number: 37892
. 2011-03-01 13:29:10.906 Discarding reserved response
< 2011-03-01 13:29:11.003 Type: SSH_FXP_HANDLE, Size: 10, Number: 38147
> 2011-03-01 13:29:11.003 Type: SSH_FXP_FSTAT, Size: 10, Number: 38408
> 2011-03-01 13:29:11.003 Type: SSH_FXP_READ, Size: 22, Number: 38661
< 2011-03-01 13:29:11.097 Type: SSH_FXP_ATTRS, Size: 29, Number: 38408
. 2011-03-01 13:29:11.097 Storing reserved response
< 2011-03-01 13:29:11.366 Status code: 1
. 2011-03-01 13:29:11.366 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:11.366 Type: SSH_FXP_CLOSE, Size: 10, Number: 39172
. 2011-03-01 13:29:11.368 File: "/Download/01040-110203-0622-PARALLEL.zip"
. 2011-03-01 13:29:11.368 Copying "/Download/01040-110203-0622-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:11.369 Binary transfer mode selected.
. 2011-03-01 13:29:11.394 Confirming overwriting of file.
. 2011-03-01 13:29:11.394 Opening remote file.
> 2011-03-01 13:29:11.394 Type: SSH_FXP_OPEN, Size: 57, Number: 39427
< 2011-03-01 13:29:11.469 Type: SSH_FXP_STATUS, Size: 21, Number: 39172
. 2011-03-01 13:29:11.469 Discarding reserved response
< 2011-03-01 13:29:11.567 Type: SSH_FXP_HANDLE, Size: 10, Number: 39427
> 2011-03-01 13:29:11.567 Type: SSH_FXP_FSTAT, Size: 10, Number: 39688
> 2011-03-01 13:29:11.567 Type: SSH_FXP_READ, Size: 22, Number: 39941
. 2011-03-01 13:29:11.662 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:29:11.662 Type: SSH_FXP_ATTRS, Size: 29, Number: 39688
. 2011-03-01 13:29:11.662 Storing reserved response
< 2011-03-01 13:29:11.901 Status code: 1
. 2011-03-01 13:29:11.901 7 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:11.901 Type: SSH_FXP_CLOSE, Size: 10, Number: 41476
< 2011-03-01 13:29:11.980 Type: SSH_FXP_STATUS, Size: 22, Number: 40965
< 2011-03-01 13:29:12.117 Type: SSH_FXP_STATUS, Size: 22, Number: 41221
. 2011-03-01 13:29:12.119 File: "/Download/01040-110203-0634-PARALLEL.zip"
. 2011-03-01 13:29:12.120 Copying "/Download/01040-110203-0634-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:12.121 Binary transfer mode selected.
. 2011-03-01 13:29:12.133 Confirming overwriting of file.
. 2011-03-01 13:29:12.134 Opening remote file.
> 2011-03-01 13:29:12.134 Type: SSH_FXP_OPEN, Size: 57, Number: 41731
< 2011-03-01 13:29:12.134 Type: SSH_FXP_STATUS, Size: 21, Number: 41476
. 2011-03-01 13:29:12.134 Discarding reserved response
< 2011-03-01 13:29:12.258 Type: SSH_FXP_HANDLE, Size: 10, Number: 41731
> 2011-03-01 13:29:12.258 Type: SSH_FXP_FSTAT, Size: 10, Number: 41992
> 2011-03-01 13:29:12.258 Type: SSH_FXP_READ, Size: 22, Number: 42245
< 2011-03-01 13:29:12.353 Type: SSH_FXP_ATTRS, Size: 29, Number: 41992
. 2011-03-01 13:29:12.353 Storing reserved response
< 2011-03-01 13:29:12.558 Status code: 1
. 2011-03-01 13:29:12.559 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:12.559 Type: SSH_FXP_CLOSE, Size: 10, Number: 42756
. 2011-03-01 13:29:12.560 File: "/Download/01040-110203-0645-PARALLEL.zip"
. 2011-03-01 13:29:12.560 Copying "/Download/01040-110203-0645-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:12.561 Binary transfer mode selected.
. 2011-03-01 13:29:12.574 Confirming overwriting of file.
. 2011-03-01 13:29:12.575 Opening remote file.
> 2011-03-01 13:29:12.575 Type: SSH_FXP_OPEN, Size: 57, Number: 43011
< 2011-03-01 13:29:12.693 Type: SSH_FXP_STATUS, Size: 21, Number: 42756
. 2011-03-01 13:29:12.693 Discarding reserved response
< 2011-03-01 13:29:12.820 Type: SSH_FXP_HANDLE, Size: 10, Number: 43011
> 2011-03-01 13:29:12.820 Type: SSH_FXP_FSTAT, Size: 10, Number: 43272
> 2011-03-01 13:29:12.820 Type: SSH_FXP_READ, Size: 22, Number: 43525
< 2011-03-01 13:29:12.925 Type: SSH_FXP_ATTRS, Size: 29, Number: 43272
. 2011-03-01 13:29:12.925 Storing reserved response
< 2011-03-01 13:29:13.119 Status code: 1
. 2011-03-01 13:29:13.119 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:13.119 Type: SSH_FXP_CLOSE, Size: 10, Number: 44036
. 2011-03-01 13:29:13.121 File: "/Download/01040-110203-0655-PARALLEL.zip"
. 2011-03-01 13:29:13.121 Copying "/Download/01040-110203-0655-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:13.121 Binary transfer mode selected.
. 2011-03-01 13:29:13.134 Confirming overwriting of file.
. 2011-03-01 13:29:13.134 Opening remote file.
> 2011-03-01 13:29:13.134 Type: SSH_FXP_OPEN, Size: 57, Number: 44291
< 2011-03-01 13:29:13.207 Type: SSH_FXP_STATUS, Size: 21, Number: 44036
. 2011-03-01 13:29:13.207 Discarding reserved response
< 2011-03-01 13:29:13.301 Type: SSH_FXP_HANDLE, Size: 10, Number: 44291
> 2011-03-01 13:29:13.301 Type: SSH_FXP_FSTAT, Size: 10, Number: 44552
> 2011-03-01 13:29:13.301 Type: SSH_FXP_READ, Size: 22, Number: 44805
< 2011-03-01 13:29:13.393 Type: SSH_FXP_ATTRS, Size: 29, Number: 44552
. 2011-03-01 13:29:13.393 Storing reserved response
< 2011-03-01 13:29:13.590 Status code: 1
. 2011-03-01 13:29:13.590 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:13.590 Type: SSH_FXP_CLOSE, Size: 10, Number: 45316
. 2011-03-01 13:29:13.592 File: "/Download/01040-110203-0838-PARALLEL.zip"
. 2011-03-01 13:29:13.592 Copying "/Download/01040-110203-0838-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:13.593 Binary transfer mode selected.
. 2011-03-01 13:29:13.605 Confirming overwriting of file.
. 2011-03-01 13:29:13.606 Opening remote file.
> 2011-03-01 13:29:13.606 Type: SSH_FXP_OPEN, Size: 57, Number: 45571
< 2011-03-01 13:29:13.684 Type: SSH_FXP_STATUS, Size: 21, Number: 45316
. 2011-03-01 13:29:13.684 Discarding reserved response
< 2011-03-01 13:29:13.773 Type: SSH_FXP_HANDLE, Size: 10, Number: 45571
> 2011-03-01 13:29:13.774 Type: SSH_FXP_FSTAT, Size: 10, Number: 45832
> 2011-03-01 13:29:13.774 Type: SSH_FXP_READ, Size: 22, Number: 46085
< 2011-03-01 13:29:13.872 Type: SSH_FXP_ATTRS, Size: 29, Number: 45832
. 2011-03-01 13:29:13.872 Storing reserved response
< 2011-03-01 13:29:14.062 Status code: 1
. 2011-03-01 13:29:14.062 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:14.062 Type: SSH_FXP_CLOSE, Size: 10, Number: 46596
. 2011-03-01 13:29:14.063 File: "/Download/01040-110203-1021-PARALLEL.zip"
. 2011-03-01 13:29:14.064 Copying "/Download/01040-110203-1021-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:14.064 Binary transfer mode selected.
. 2011-03-01 13:29:14.067 Confirming overwriting of file.
. 2011-03-01 13:29:14.068 Opening remote file.
> 2011-03-01 13:29:14.068 Type: SSH_FXP_OPEN, Size: 57, Number: 46851
< 2011-03-01 13:29:14.161 Type: SSH_FXP_STATUS, Size: 21, Number: 46596
. 2011-03-01 13:29:14.161 Discarding reserved response
< 2011-03-01 13:29:14.274 Type: SSH_FXP_HANDLE, Size: 10, Number: 46851
> 2011-03-01 13:29:14.274 Type: SSH_FXP_FSTAT, Size: 10, Number: 47112
> 2011-03-01 13:29:14.274 Type: SSH_FXP_READ, Size: 22, Number: 47365
< 2011-03-01 13:29:14.386 Type: SSH_FXP_ATTRS, Size: 29, Number: 47112
. 2011-03-01 13:29:14.386 Storing reserved response
< 2011-03-01 13:29:14.562 Status code: 1
. 2011-03-01 13:29:14.562 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:14.562 Type: SSH_FXP_CLOSE, Size: 10, Number: 47876
. 2011-03-01 13:29:14.563 File: "/Download/01040-110203-1113-PARALLEL.zip"
. 2011-03-01 13:29:14.564 Copying "/Download/01040-110203-1113-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:14.565 Binary transfer mode selected.
. 2011-03-01 13:29:14.575 Confirming overwriting of file.
. 2011-03-01 13:29:14.575 Opening remote file.
> 2011-03-01 13:29:14.575 Type: SSH_FXP_OPEN, Size: 57, Number: 48131
< 2011-03-01 13:29:14.658 Type: SSH_FXP_STATUS, Size: 21, Number: 47876
. 2011-03-01 13:29:14.658 Discarding reserved response
< 2011-03-01 13:29:14.744 Type: SSH_FXP_HANDLE, Size: 10, Number: 48131
> 2011-03-01 13:29:14.745 Type: SSH_FXP_FSTAT, Size: 10, Number: 48392
> 2011-03-01 13:29:14.745 Type: SSH_FXP_READ, Size: 22, Number: 48645
< 2011-03-01 13:29:14.833 Type: SSH_FXP_ATTRS, Size: 29, Number: 48392
. 2011-03-01 13:29:14.833 Storing reserved response
< 2011-03-01 13:29:15.022 Status code: 1
. 2011-03-01 13:29:15.022 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:15.022 Type: SSH_FXP_CLOSE, Size: 10, Number: 49156
. 2011-03-01 13:29:15.024 File: "/Download/01040-110203-1131-PARALLEL.zip"
. 2011-03-01 13:29:15.024 Copying "/Download/01040-110203-1131-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:15.025 Binary transfer mode selected.
. 2011-03-01 13:29:15.025 Confirming overwriting of file.
. 2011-03-01 13:29:15.025 Opening remote file.
> 2011-03-01 13:29:15.025 Type: SSH_FXP_OPEN, Size: 57, Number: 49411
< 2011-03-01 13:29:15.141 Type: SSH_FXP_STATUS, Size: 21, Number: 49156
. 2011-03-01 13:29:15.141 Discarding reserved response
< 2011-03-01 13:29:15.229 Type: SSH_FXP_HANDLE, Size: 10, Number: 49411
> 2011-03-01 13:29:15.230 Type: SSH_FXP_FSTAT, Size: 10, Number: 49672
> 2011-03-01 13:29:15.230 Type: SSH_FXP_READ, Size: 22, Number: 49925
. 2011-03-01 13:29:15.314 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:29:15.314 Type: SSH_FXP_ATTRS, Size: 29, Number: 49672
. 2011-03-01 13:29:15.314 Storing reserved response
< 2011-03-01 13:29:15.798 Status code: 1
. 2011-03-01 13:29:15.798 17 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:15.798 Type: SSH_FXP_CLOSE, Size: 10, Number: 52996
< 2011-03-01 13:29:15.868 Type: SSH_FXP_STATUS, Size: 22, Number: 52229
< 2011-03-01 13:29:16.002 Type: SSH_FXP_STATUS, Size: 22, Number: 52485
< 2011-03-01 13:29:16.002 Type: SSH_FXP_STATUS, Size: 22, Number: 52741
. 2011-03-01 13:29:16.004 File: "/Download/01040-110203-1136-PARALLEL.zip"
. 2011-03-01 13:29:16.004 Copying "/Download/01040-110203-1136-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:16.004 Binary transfer mode selected.
. 2011-03-01 13:29:16.026 Confirming overwriting of file.
. 2011-03-01 13:29:16.026 Opening remote file.
> 2011-03-01 13:29:16.026 Type: SSH_FXP_OPEN, Size: 57, Number: 53251
< 2011-03-01 13:29:16.027 Type: SSH_FXP_STATUS, Size: 21, Number: 52996
. 2011-03-01 13:29:16.027 Discarding reserved response
< 2011-03-01 13:29:16.114 Type: SSH_FXP_HANDLE, Size: 10, Number: 53251
> 2011-03-01 13:29:16.115 Type: SSH_FXP_FSTAT, Size: 10, Number: 53512
> 2011-03-01 13:29:16.115 Type: SSH_FXP_READ, Size: 22, Number: 53765
< 2011-03-01 13:29:16.210 Type: SSH_FXP_ATTRS, Size: 29, Number: 53512
. 2011-03-01 13:29:16.210 Storing reserved response
< 2011-03-01 13:29:16.442 Status code: 1
. 2011-03-01 13:29:16.442 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:16.442 Type: SSH_FXP_CLOSE, Size: 10, Number: 54276
. 2011-03-01 13:29:16.444 File: "/Download/01040-110203-1219-PARALLEL.zip"
. 2011-03-01 13:29:16.445 Copying "/Download/01040-110203-1219-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:16.445 Binary transfer mode selected.
. 2011-03-01 13:29:16.457 Confirming overwriting of file.
. 2011-03-01 13:29:16.458 Opening remote file.
> 2011-03-01 13:29:16.458 Type: SSH_FXP_OPEN, Size: 57, Number: 54531
< 2011-03-01 13:29:16.540 Type: SSH_FXP_STATUS, Size: 21, Number: 54276
. 2011-03-01 13:29:16.540 Discarding reserved response
< 2011-03-01 13:29:16.629 Type: SSH_FXP_HANDLE, Size: 10, Number: 54531
> 2011-03-01 13:29:16.630 Type: SSH_FXP_FSTAT, Size: 10, Number: 54792
> 2011-03-01 13:29:16.630 Type: SSH_FXP_READ, Size: 22, Number: 55045
< 2011-03-01 13:29:16.776 Type: SSH_FXP_ATTRS, Size: 29, Number: 54792
. 2011-03-01 13:29:16.776 Storing reserved response
< 2011-03-01 13:29:16.999 Status code: 1
. 2011-03-01 13:29:16.999 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:16.999 Type: SSH_FXP_CLOSE, Size: 10, Number: 55556
. 2011-03-01 13:29:17.000 File: "/Download/01040-110204-0252-PARALLEL.zip"
. 2011-03-01 13:29:17.001 Copying "/Download/01040-110204-0252-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:17.001 Binary transfer mode selected.
. 2011-03-01 13:29:17.011 Confirming overwriting of file.
. 2011-03-01 13:29:17.012 Opening remote file.
> 2011-03-01 13:29:17.012 Type: SSH_FXP_OPEN, Size: 57, Number: 55811
< 2011-03-01 13:29:17.107 Type: SSH_FXP_STATUS, Size: 21, Number: 55556
. 2011-03-01 13:29:17.108 Discarding reserved response
< 2011-03-01 13:29:17.209 Type: SSH_FXP_HANDLE, Size: 10, Number: 55811
> 2011-03-01 13:29:17.209 Type: SSH_FXP_FSTAT, Size: 10, Number: 56072
> 2011-03-01 13:29:17.210 Type: SSH_FXP_READ, Size: 22, Number: 56325
< 2011-03-01 13:29:17.306 Type: SSH_FXP_ATTRS, Size: 29, Number: 56072
. 2011-03-01 13:29:17.307 Storing reserved response
< 2011-03-01 13:29:17.509 Status code: 1
. 2011-03-01 13:29:17.509 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:17.509 Type: SSH_FXP_CLOSE, Size: 10, Number: 56836
. 2011-03-01 13:29:17.510 File: "/Download/01040-110204-0259-PARALLEL.zip"
. 2011-03-01 13:29:17.510 Copying "/Download/01040-110204-0259-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:17.511 Binary transfer mode selected.
. 2011-03-01 13:29:17.538 Confirming overwriting of file.
. 2011-03-01 13:29:17.539 Opening remote file.
> 2011-03-01 13:29:17.539 Type: SSH_FXP_OPEN, Size: 57, Number: 57091
< 2011-03-01 13:29:17.608 Type: SSH_FXP_STATUS, Size: 21, Number: 56836
. 2011-03-01 13:29:17.608 Discarding reserved response
< 2011-03-01 13:29:17.709 Type: SSH_FXP_HANDLE, Size: 10, Number: 57091
> 2011-03-01 13:29:17.709 Type: SSH_FXP_FSTAT, Size: 10, Number: 57352
> 2011-03-01 13:29:17.709 Type: SSH_FXP_READ, Size: 22, Number: 57605
. 2011-03-01 13:29:17.806 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:29:17.806 Type: SSH_FXP_ATTRS, Size: 29, Number: 57352
. 2011-03-01 13:29:17.806 Storing reserved response
< 2011-03-01 13:29:18.135 Status code: 1
. 2011-03-01 13:29:18.135 7 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:18.135 Type: SSH_FXP_CLOSE, Size: 10, Number: 59140
< 2011-03-01 13:29:18.226 Type: SSH_FXP_STATUS, Size: 22, Number: 58629
< 2011-03-01 13:29:18.227 Type: SSH_FXP_STATUS, Size: 22, Number: 58885
. 2011-03-01 13:29:18.228 File: "/Download/01040-110204-0425-PARALLEL.zip"
. 2011-03-01 13:29:18.228 Copying "/Download/01040-110204-0425-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:18.229 Binary transfer mode selected.
. 2011-03-01 13:29:18.246 Confirming overwriting of file.
. 2011-03-01 13:29:18.247 Opening remote file.
> 2011-03-01 13:29:18.247 Type: SSH_FXP_OPEN, Size: 57, Number: 59395
< 2011-03-01 13:29:18.324 Type: SSH_FXP_STATUS, Size: 21, Number: 59140
. 2011-03-01 13:29:18.324 Discarding reserved response
< 2011-03-01 13:29:18.420 Type: SSH_FXP_HANDLE, Size: 10, Number: 59395
> 2011-03-01 13:29:18.420 Type: SSH_FXP_FSTAT, Size: 10, Number: 59656
> 2011-03-01 13:29:18.420 Type: SSH_FXP_READ, Size: 22, Number: 59909
< 2011-03-01 13:29:18.530 Type: SSH_FXP_ATTRS, Size: 29, Number: 59656
. 2011-03-01 13:29:18.530 Storing reserved response
< 2011-03-01 13:29:18.739 Status code: 1
. 2011-03-01 13:29:18.739 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:18.739 Type: SSH_FXP_CLOSE, Size: 10, Number: 60420
. 2011-03-01 13:29:18.740 File: "/Download/01040-110204-0430-PARALLEL.zip"
. 2011-03-01 13:29:18.741 Copying "/Download/01040-110204-0430-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:18.741 Binary transfer mode selected.
. 2011-03-01 13:29:18.750 Confirming overwriting of file.
. 2011-03-01 13:29:18.750 Opening remote file.
> 2011-03-01 13:29:18.751 Type: SSH_FXP_OPEN, Size: 57, Number: 60675
< 2011-03-01 13:29:18.827 Type: SSH_FXP_STATUS, Size: 21, Number: 60420
. 2011-03-01 13:29:18.827 Discarding reserved response
< 2011-03-01 13:29:18.910 Type: SSH_FXP_HANDLE, Size: 10, Number: 60675
> 2011-03-01 13:29:18.910 Type: SSH_FXP_FSTAT, Size: 10, Number: 60936
> 2011-03-01 13:29:18.910 Type: SSH_FXP_READ, Size: 22, Number: 61189
< 2011-03-01 13:29:19.000 Type: SSH_FXP_ATTRS, Size: 29, Number: 60936
. 2011-03-01 13:29:19.001 Storing reserved response
< 2011-03-01 13:29:19.183 Status code: 1
. 2011-03-01 13:29:19.183 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:19.183 Type: SSH_FXP_CLOSE, Size: 10, Number: 61700
. 2011-03-01 13:29:19.184 File: "/Download/01040-110204-0507-PARALLEL.zip"
. 2011-03-01 13:29:19.184 Copying "/Download/01040-110204-0507-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:19.185 Binary transfer mode selected.
. 2011-03-01 13:29:19.185 Confirming overwriting of file.
. 2011-03-01 13:29:19.185 Opening remote file.
> 2011-03-01 13:29:19.185 Type: SSH_FXP_OPEN, Size: 57, Number: 61955
< 2011-03-01 13:29:19.317 Type: SSH_FXP_STATUS, Size: 21, Number: 61700
. 2011-03-01 13:29:19.318 Discarding reserved response
< 2011-03-01 13:29:19.417 Type: SSH_FXP_HANDLE, Size: 10, Number: 61955
> 2011-03-01 13:29:19.417 Type: SSH_FXP_FSTAT, Size: 10, Number: 62216
> 2011-03-01 13:29:19.418 Type: SSH_FXP_READ, Size: 22, Number: 62469
< 2011-03-01 13:29:19.553 Type: SSH_FXP_ATTRS, Size: 29, Number: 62216
. 2011-03-01 13:29:19.553 Storing reserved response
< 2011-03-01 13:29:19.739 Status code: 1
. 2011-03-01 13:29:19.739 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:19.740 Type: SSH_FXP_CLOSE, Size: 10, Number: 62980
. 2011-03-01 13:29:19.741 File: "/Download/01040-110204-0518-PARALLEL.zip"
. 2011-03-01 13:29:19.741 Copying "/Download/01040-110204-0518-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:19.742 Binary transfer mode selected.
. 2011-03-01 13:29:19.742 Confirming overwriting of file.
. 2011-03-01 13:29:19.742 Opening remote file.
> 2011-03-01 13:29:19.742 Type: SSH_FXP_OPEN, Size: 57, Number: 63235
< 2011-03-01 13:29:19.831 Type: SSH_FXP_STATUS, Size: 21, Number: 62980
. 2011-03-01 13:29:19.831 Discarding reserved response
< 2011-03-01 13:29:19.925 Type: SSH_FXP_HANDLE, Size: 10, Number: 63235
> 2011-03-01 13:29:19.925 Type: SSH_FXP_FSTAT, Size: 10, Number: 63496
> 2011-03-01 13:29:19.925 Type: SSH_FXP_READ, Size: 22, Number: 63749
< 2011-03-01 13:29:20.013 Type: SSH_FXP_ATTRS, Size: 29, Number: 63496
. 2011-03-01 13:29:20.013 Storing reserved response
< 2011-03-01 13:29:20.198 Status code: 1
. 2011-03-01 13:29:20.198 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:20.198 Type: SSH_FXP_CLOSE, Size: 10, Number: 64260
. 2011-03-01 13:29:20.200 File: "/Download/01040-110204-0628-PARALLEL.zip"
. 2011-03-01 13:29:20.200 Copying "/Download/01040-110204-0628-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:20.200 Binary transfer mode selected.
. 2011-03-01 13:29:20.206 Confirming overwriting of file.
. 2011-03-01 13:29:20.206 Opening remote file.
> 2011-03-01 13:29:20.206 Type: SSH_FXP_OPEN, Size: 57, Number: 64515
< 2011-03-01 13:29:20.289 Type: SSH_FXP_STATUS, Size: 21, Number: 64260
. 2011-03-01 13:29:20.289 Discarding reserved response
< 2011-03-01 13:29:20.374 Type: SSH_FXP_HANDLE, Size: 10, Number: 64515
> 2011-03-01 13:29:20.374 Type: SSH_FXP_FSTAT, Size: 10, Number: 64776
> 2011-03-01 13:29:20.375 Type: SSH_FXP_READ, Size: 22, Number: 65029
< 2011-03-01 13:29:20.471 Type: SSH_FXP_ATTRS, Size: 29, Number: 64776
. 2011-03-01 13:29:20.471 Storing reserved response
< 2011-03-01 13:29:20.664 Status code: 1
. 2011-03-01 13:29:20.664 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:20.664 Type: SSH_FXP_CLOSE, Size: 10, Number: 65540
. 2011-03-01 13:29:20.665 File: "/Download/01040-110204-1252-PARALLEL.zip"
. 2011-03-01 13:29:20.666 Copying "/Download/01040-110204-1252-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:20.666 Binary transfer mode selected.
. 2011-03-01 13:29:20.677 Confirming overwriting of file.
. 2011-03-01 13:29:20.678 Opening remote file.
> 2011-03-01 13:29:20.678 Type: SSH_FXP_OPEN, Size: 57, Number: 65795
< 2011-03-01 13:29:20.779 Type: SSH_FXP_STATUS, Size: 21, Number: 65540
. 2011-03-01 13:29:20.779 Discarding reserved response
< 2011-03-01 13:29:20.881 Type: SSH_FXP_HANDLE, Size: 10, Number: 65795
> 2011-03-01 13:29:20.881 Type: SSH_FXP_FSTAT, Size: 10, Number: 66056
> 2011-03-01 13:29:20.881 Type: SSH_FXP_READ, Size: 22, Number: 66309
< 2011-03-01 13:29:20.989 Type: SSH_FXP_ATTRS, Size: 29, Number: 66056
. 2011-03-01 13:29:20.989 Storing reserved response
< 2011-03-01 13:29:21.210 Status code: 1
. 2011-03-01 13:29:21.210 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:21.210 Type: SSH_FXP_CLOSE, Size: 10, Number: 66820
. 2011-03-01 13:29:21.212 File: "/Download/01040-110204-1253-PARALLEL.zip"
. 2011-03-01 13:29:21.212 Copying "/Download/01040-110204-1253-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:21.212 Binary transfer mode selected.
. 2011-03-01 13:29:21.223 Confirming overwriting of file.
. 2011-03-01 13:29:21.224 Opening remote file.
> 2011-03-01 13:29:21.224 Type: SSH_FXP_OPEN, Size: 57, Number: 67075
< 2011-03-01 13:29:21.304 Type: SSH_FXP_STATUS, Size: 21, Number: 66820
. 2011-03-01 13:29:21.304 Discarding reserved response
< 2011-03-01 13:29:21.386 Type: SSH_FXP_HANDLE, Size: 10, Number: 67075
> 2011-03-01 13:29:21.386 Type: SSH_FXP_FSTAT, Size: 10, Number: 67336
> 2011-03-01 13:29:21.386 Type: SSH_FXP_READ, Size: 22, Number: 67589
< 2011-03-01 13:29:21.483 Type: SSH_FXP_ATTRS, Size: 29, Number: 67336
. 2011-03-01 13:29:21.483 Storing reserved response
< 2011-03-01 13:29:21.693 Status code: 1
. 2011-03-01 13:29:21.693 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:21.693 Type: SSH_FXP_CLOSE, Size: 10, Number: 68100
. 2011-03-01 13:29:21.695 File: "/Download/01040-110205-0211-PARALLEL.zip"
. 2011-03-01 13:29:21.695 Copying "/Download/01040-110205-0211-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:21.695 Binary transfer mode selected.
. 2011-03-01 13:29:21.696 Confirming overwriting of file.
. 2011-03-01 13:29:21.696 Opening remote file.
> 2011-03-01 13:29:21.696 Type: SSH_FXP_OPEN, Size: 57, Number: 68355
< 2011-03-01 13:29:21.783 Type: SSH_FXP_STATUS, Size: 21, Number: 68100
. 2011-03-01 13:29:21.783 Discarding reserved response
< 2011-03-01 13:29:21.889 Type: SSH_FXP_HANDLE, Size: 10, Number: 68355
> 2011-03-01 13:29:21.889 Type: SSH_FXP_FSTAT, Size: 10, Number: 68616
> 2011-03-01 13:29:21.889 Type: SSH_FXP_READ, Size: 22, Number: 68869
< 2011-03-01 13:29:22.010 Type: SSH_FXP_ATTRS, Size: 29, Number: 68616
. 2011-03-01 13:29:22.010 Storing reserved response
< 2011-03-01 13:29:22.269 Status code: 1
. 2011-03-01 13:29:22.269 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:22.269 Type: SSH_FXP_CLOSE, Size: 10, Number: 69380
. 2011-03-01 13:29:22.271 File: "/Download/01040-110205-0309-PARALLEL.zip"
. 2011-03-01 13:29:22.271 Copying "/Download/01040-110205-0309-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:22.272 Binary transfer mode selected.
. 2011-03-01 13:29:22.292 Confirming overwriting of file.
. 2011-03-01 13:29:22.293 Opening remote file.
> 2011-03-01 13:29:22.293 Type: SSH_FXP_OPEN, Size: 57, Number: 69635
< 2011-03-01 13:29:22.362 Type: SSH_FXP_STATUS, Size: 21, Number: 69380
. 2011-03-01 13:29:22.362 Discarding reserved response
< 2011-03-01 13:29:22.456 Type: SSH_FXP_HANDLE, Size: 10, Number: 69635
> 2011-03-01 13:29:22.456 Type: SSH_FXP_FSTAT, Size: 10, Number: 69896
> 2011-03-01 13:29:22.456 Type: SSH_FXP_READ, Size: 22, Number: 70149
< 2011-03-01 13:29:22.552 Type: SSH_FXP_ATTRS, Size: 29, Number: 69896
. 2011-03-01 13:29:22.553 Storing reserved response
< 2011-03-01 13:29:22.759 Status code: 1
. 2011-03-01 13:29:22.759 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:22.759 Type: SSH_FXP_CLOSE, Size: 10, Number: 70660
. 2011-03-01 13:29:22.761 File: "/Download/01040-110205-0342-PARALLEL.zip"
. 2011-03-01 13:29:22.761 Copying "/Download/01040-110205-0342-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:22.761 Binary transfer mode selected.
. 2011-03-01 13:29:22.772 Confirming overwriting of file.
. 2011-03-01 13:29:22.772 Opening remote file.
> 2011-03-01 13:29:22.772 Type: SSH_FXP_OPEN, Size: 57, Number: 70915
< 2011-03-01 13:29:22.849 Type: SSH_FXP_STATUS, Size: 21, Number: 70660
. 2011-03-01 13:29:22.849 Discarding reserved response
< 2011-03-01 13:29:22.945 Type: SSH_FXP_HANDLE, Size: 10, Number: 70915
> 2011-03-01 13:29:22.945 Type: SSH_FXP_FSTAT, Size: 10, Number: 71176
> 2011-03-01 13:29:22.945 Type: SSH_FXP_READ, Size: 22, Number: 71429
< 2011-03-01 13:29:23.037 Type: SSH_FXP_ATTRS, Size: 29, Number: 71176
. 2011-03-01 13:29:23.037 Storing reserved response
< 2011-03-01 13:29:23.238 Status code: 1
. 2011-03-01 13:29:23.238 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:23.238 Type: SSH_FXP_CLOSE, Size: 10, Number: 71940
. 2011-03-01 13:29:23.239 File: "/Download/01040-110205-0806-PARALLEL.zip"
. 2011-03-01 13:29:23.240 Copying "/Download/01040-110205-0806-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:23.241 Binary transfer mode selected.
. 2011-03-01 13:29:23.241 Confirming overwriting of file.
. 2011-03-01 13:29:23.241 Opening remote file.
> 2011-03-01 13:29:23.241 Type: SSH_FXP_OPEN, Size: 57, Number: 72195
< 2011-03-01 13:29:23.332 Type: SSH_FXP_STATUS, Size: 21, Number: 71940
. 2011-03-01 13:29:23.332 Discarding reserved response
< 2011-03-01 13:29:23.429 Type: SSH_FXP_HANDLE, Size: 10, Number: 72195
> 2011-03-01 13:29:23.429 Type: SSH_FXP_FSTAT, Size: 10, Number: 72456
> 2011-03-01 13:29:23.429 Type: SSH_FXP_READ, Size: 22, Number: 72709
< 2011-03-01 13:29:23.522 Type: SSH_FXP_ATTRS, Size: 29, Number: 72456
. 2011-03-01 13:29:23.523 Storing reserved response
< 2011-03-01 13:29:23.706 Status code: 1
. 2011-03-01 13:29:23.706 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:23.706 Type: SSH_FXP_CLOSE, Size: 10, Number: 73220
. 2011-03-01 13:29:23.708 File: "/Download/01040-110206-0408-PARALLEL.zip"
. 2011-03-01 13:29:23.708 Copying "/Download/01040-110206-0408-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:23.709 Binary transfer mode selected.
. 2011-03-01 13:29:23.721 Confirming overwriting of file.
. 2011-03-01 13:29:23.722 Opening remote file.
> 2011-03-01 13:29:23.722 Type: SSH_FXP_OPEN, Size: 57, Number: 73475
< 2011-03-01 13:29:23.793 Type: SSH_FXP_STATUS, Size: 21, Number: 73220
. 2011-03-01 13:29:23.794 Discarding reserved response
< 2011-03-01 13:29:23.903 Type: SSH_FXP_HANDLE, Size: 10, Number: 73475
> 2011-03-01 13:29:23.903 Type: SSH_FXP_FSTAT, Size: 10, Number: 73736
> 2011-03-01 13:29:23.903 Type: SSH_FXP_READ, Size: 22, Number: 73989
< 2011-03-01 13:29:24.000 Type: SSH_FXP_ATTRS, Size: 29, Number: 73736
. 2011-03-01 13:29:24.001 Storing reserved response
< 2011-03-01 13:29:24.204 Status code: 1
. 2011-03-01 13:29:24.204 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:24.204 Type: SSH_FXP_CLOSE, Size: 10, Number: 74500
. 2011-03-01 13:29:24.205 File: "/Download/01040-110206-0528-PARALLEL.zip"
. 2011-03-01 13:29:24.205 Copying "/Download/01040-110206-0528-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:24.206 Binary transfer mode selected.
. 2011-03-01 13:29:24.219 Confirming overwriting of file.
. 2011-03-01 13:29:24.219 Opening remote file.
> 2011-03-01 13:29:24.219 Type: SSH_FXP_OPEN, Size: 57, Number: 74755
< 2011-03-01 13:29:24.297 Type: SSH_FXP_STATUS, Size: 21, Number: 74500
. 2011-03-01 13:29:24.297 Discarding reserved response
< 2011-03-01 13:29:24.425 Type: SSH_FXP_HANDLE, Size: 10, Number: 74755
> 2011-03-01 13:29:24.425 Type: SSH_FXP_FSTAT, Size: 10, Number: 75016
> 2011-03-01 13:29:24.425 Type: SSH_FXP_READ, Size: 22, Number: 75269
< 2011-03-01 13:29:24.527 Type: SSH_FXP_ATTRS, Size: 29, Number: 75016
. 2011-03-01 13:29:24.527 Storing reserved response
< 2011-03-01 13:29:24.733 Status code: 1
. 2011-03-01 13:29:24.733 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:29:24.733 Type: SSH_FXP_CLOSE, Size: 10, Number: 75780
. 2011-03-01 13:29:24.734 File: "/Download/01040-110206-0622-PARALLEL.zip"
. 2011-03-01 13:29:24.734 Copying "/Download/01040-110206-0622-PARALLEL.zip" to local directory started.
. 2011-03-01 13:29:24.735 Binary transfer mode selected.
. 2011-03-01 13:29:24.745 Confirming overwriting of file.
. 2011-03-01 13:29:24.745 Opening remote
flipman619
Copy of Log2 (alternate user with alternate set of files):
. 2011-03-01 13:42:25.191 --------------------------------------------------------------------------
. 2011-03-01 13:42:25.191 WinSCP Version 4.3.2 (Build 1201) (OS 6.1.7600)
. 2011-03-01 13:42:25.191 Login time: Tuesday, March 01, 2011 1:42:25 PM
. 2011-03-01 13:42:25.191 Session name: <USER2>@<HOST>
. 2011-03-01 13:42:25.191 Host name: <HOST> (Port: 22)
. 2011-03-01 13:42:25.192 User name: <USER2> (Password: Yes, Key file: No)
. 2011-03-01 13:42:25.192 Tunnel: No
. 2011-03-01 13:42:25.192 Transfer Protocol: SFTP
. 2011-03-01 13:42:25.192 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-03-01 13:42:25.192 Proxy: none
. 2011-03-01 13:42:25.192 SSH protocol version: 2; Compression: No
. 2011-03-01 13:42:25.192 Bypass authentication: No
. 2011-03-01 13:42:25.192 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-03-01 13:42:25.192 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-03-01 13:42:25.192 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-03-01 13:42:25.192 SFTP Bugs: -,-
. 2011-03-01 13:42:25.192 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-03-01 13:42:25.192 Shell: default
. 2011-03-01 13:42:25.192 EOL: 0, UTF: 2
. 2011-03-01 13:42:25.192 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-03-01 13:42:25.192 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-03-01 13:42:25.192 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-03-01 13:42:25.192 Cache directory changes: Yes, Permanent: Yes
. 2011-03-01 13:42:25.192 DST mode: 1
. 2011-03-01 13:42:25.192 --------------------------------------------------------------------------
. 2011-03-01 13:42:25.193 Looking up host "<HOST>"
. 2011-03-01 13:42:25.366 Connecting to <IP ADDRESS> port 22
. 2011-03-01 13:42:25.560 Server version: SSH-2.0-1.36_sshlib GlobalSCAPE
. 2011-03-01 13:42:25.560 We believe remote version ignores SSH-2 maximum packet size
. 2011-03-01 13:42:25.560 We believe remote version has SSH-2 ignore bug
. 2011-03-01 13:42:25.561 Using SSH protocol version 2
. 2011-03-01 13:42:25.561 We claim version: SSH-2.0-WinSCP_release_4.3.2
. 2011-03-01 13:42:25.653 Doing Diffie-Hellman group exchange
. 2011-03-01 13:42:26.080 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-03-01 13:42:26.426 Host key fingerprint is:
. 2011-03-01 13:42:26.427 ssh-dss 1024 06:ba:3c:18:30:ae:ea:51:f1:b4:9d:16:00:1f:b5:bc
. 2011-03-01 13:42:26.427 Initialised AES-256 CBC client->server encryption
. 2011-03-01 13:42:26.427 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-03-01 13:42:26.427 Initialised AES-256 CBC server->client encryption
. 2011-03-01 13:42:26.427 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-03-01 13:42:26.731 Using username "<USER2>".
. 2011-03-01 13:42:26.820 Prompt (6, SSH password, , &Password: )
. 2011-03-01 13:42:26.820 Using stored password.
. 2011-03-01 13:42:26.821 Sent password
. 2011-03-01 13:42:26.913 Access granted
. 2011-03-01 13:42:27.022 Opened channel for session
. 2011-03-01 13:42:27.337 Started a shell/command
. 2011-03-01 13:42:27.338 --------------------------------------------------------------------------
. 2011-03-01 13:42:27.338 Using SFTP protocol.
. 2011-03-01 13:42:27.338 Doing startup conversation with host.
> 2011-03-01 13:42:27.338 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-03-01 13:42:27.436 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2011-03-01 13:42:27.436 SFTP version 3 negotiated.
. 2011-03-01 13:42:27.436 We believe the server has signed timestamps bug
. 2011-03-01 13:42:27.436 We will use UTF-8 strings for status messages only
. 2011-03-01 13:42:27.436 Getting current directory name.
. 2011-03-01 13:42:27.436 Getting real path for '.'
> 2011-03-01 13:42:27.436 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2011-03-01 13:42:27.535 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2011-03-01 13:42:27.536 Real path is '/'
. 2011-03-01 13:42:27.536 Startup conversation with host finished.
< 2011-03-01 13:42:27.536 Script: Active session: [1] <USER2>@<HOST>
> 2011-03-01 13:42:27.536 Script: get /Download/ c:\test\
. 2011-03-01 13:42:27.536 Listing file "/Download/".
> 2011-03-01 13:42:27.536 Type: SSH_FXP_LSTAT, Size: 19, Number: 263
< 2011-03-01 13:42:27.651 Type: SSH_FXP_ATTRS, Size: 21, Number: 263
. 2011-03-01 13:42:27.651 File: "/Download/"
. 2011-03-01 13:42:27.651 Listing directory "/Download".
> 2011-03-01 13:42:27.651 Type: SSH_FXP_OPENDIR, Size: 18, Number: 523
< 2011-03-01 13:42:27.817 Type: SSH_FXP_HANDLE, Size: 10, Number: 523
> 2011-03-01 13:42:27.818 Type: SSH_FXP_READDIR, Size: 10, Number: 780
< 2011-03-01 13:42:28.145 Type: SSH_FXP_NAME, Size: 42492, Number: 780
> 2011-03-01 13:42:28.145 Type: SSH_FXP_READDIR, Size: 10, Number: 1036
< 2011-03-01 13:42:28.243 Type: SSH_FXP_STATUS, Size: 22, Number: 1036
< 2011-03-01 13:42:28.243 Status code: 1
> 2011-03-01 13:42:28.243 Type: SSH_FXP_CLOSE, Size: 10, Number: 1284
. 2011-03-01 13:42:28.243 File: "/Download/00669-110130-0352-PARALLEL.zip"
. 2011-03-01 13:42:28.243 Copying "/Download/00669-110130-0352-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:28.244 Binary transfer mode selected.
. 2011-03-01 13:42:28.272 Confirming overwriting of file.
. 2011-03-01 13:42:28.272 Opening remote file.
> 2011-03-01 13:42:28.273 Type: SSH_FXP_OPEN, Size: 57, Number: 1539
< 2011-03-01 13:42:28.352 Type: SSH_FXP_STATUS, Size: 21, Number: 1284
. 2011-03-01 13:42:28.352 Discarding reserved response
< 2011-03-01 13:42:28.461 Type: SSH_FXP_HANDLE, Size: 10, Number: 1539
> 2011-03-01 13:42:28.461 Type: SSH_FXP_FSTAT, Size: 10, Number: 1800
> 2011-03-01 13:42:28.461 Type: SSH_FXP_READ, Size: 22, Number: 2053
< 2011-03-01 13:42:28.555 Type: SSH_FXP_ATTRS, Size: 29, Number: 1800
. 2011-03-01 13:42:28.555 Storing reserved response
< 2011-03-01 13:42:28.756 Status code: 1
. 2011-03-01 13:42:28.756 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:28.756 Type: SSH_FXP_CLOSE, Size: 10, Number: 2564
. 2011-03-01 13:42:28.758 File: "/Download/00669-110130-0622-PARALLEL.zip"
. 2011-03-01 13:42:28.758 Copying "/Download/00669-110130-0622-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:28.759 Binary transfer mode selected.
. 2011-03-01 13:42:28.759 Confirming overwriting of file.
. 2011-03-01 13:42:28.760 Opening remote file.
> 2011-03-01 13:42:28.760 Type: SSH_FXP_OPEN, Size: 57, Number: 2819
< 2011-03-01 13:42:28.872 Type: SSH_FXP_STATUS, Size: 21, Number: 2564
. 2011-03-01 13:42:28.872 Discarding reserved response
< 2011-03-01 13:42:28.992 Type: SSH_FXP_HANDLE, Size: 10, Number: 2819
> 2011-03-01 13:42:28.992 Type: SSH_FXP_FSTAT, Size: 10, Number: 3080
> 2011-03-01 13:42:28.992 Type: SSH_FXP_READ, Size: 22, Number: 3333
< 2011-03-01 13:42:29.100 Type: SSH_FXP_ATTRS, Size: 29, Number: 3080
. 2011-03-01 13:42:29.100 Storing reserved response
< 2011-03-01 13:42:29.326 Status code: 1
. 2011-03-01 13:42:29.326 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:29.326 Type: SSH_FXP_CLOSE, Size: 10, Number: 3844
. 2011-03-01 13:42:29.327 File: "/Download/00669-110130-0714-PARALLEL.zip"
. 2011-03-01 13:42:29.328 Copying "/Download/00669-110130-0714-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:29.329 Binary transfer mode selected.
. 2011-03-01 13:42:29.385 Checking existence of partially transfered file.
. 2011-03-01 13:42:29.385 Confirming overwriting of file.
. 2011-03-01 13:42:29.386 Opening remote file.
> 2011-03-01 13:42:29.386 Type: SSH_FXP_OPEN, Size: 57, Number: 4099
< 2011-03-01 13:42:29.419 Type: SSH_FXP_STATUS, Size: 21, Number: 3844
. 2011-03-01 13:42:29.419 Discarding reserved response
< 2011-03-01 13:42:29.514 Type: SSH_FXP_HANDLE, Size: 10, Number: 4099
> 2011-03-01 13:42:29.515 Type: SSH_FXP_FSTAT, Size: 10, Number: 4360
> 2011-03-01 13:42:29.515 Type: SSH_FXP_READ, Size: 22, Number: 4613
. 2011-03-01 13:42:29.606 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:42:29.606 Type: SSH_FXP_ATTRS, Size: 29, Number: 4360
. 2011-03-01 13:42:29.606 Storing reserved response
< 2011-03-01 13:42:30.675 Status code: 1
. 2011-03-01 13:42:30.675 31 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:30.675 Type: SSH_FXP_CLOSE, Size: 10, Number: 9476
< 2011-03-01 13:42:30.676 Type: SSH_FXP_STATUS, Size: 22, Number: 8709
< 2011-03-01 13:42:30.772 Type: SSH_FXP_STATUS, Size: 22, Number: 8965
< 2011-03-01 13:42:30.866 Type: SSH_FXP_STATUS, Size: 22, Number: 9221
. 2011-03-01 13:42:30.868 File: "/Download/00669-110130-1010-PARALLEL.zip"
. 2011-03-01 13:42:30.869 Copying "/Download/00669-110130-1010-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:30.869 Binary transfer mode selected.
. 2011-03-01 13:42:30.880 Confirming overwriting of file.
. 2011-03-01 13:42:30.880 Opening remote file.
> 2011-03-01 13:42:30.880 Type: SSH_FXP_OPEN, Size: 57, Number: 9731
< 2011-03-01 13:42:30.881 Type: SSH_FXP_STATUS, Size: 21, Number: 9476
. 2011-03-01 13:42:30.881 Discarding reserved response
< 2011-03-01 13:42:30.977 Type: SSH_FXP_HANDLE, Size: 10, Number: 9731
> 2011-03-01 13:42:30.977 Type: SSH_FXP_FSTAT, Size: 10, Number: 9992
> 2011-03-01 13:42:30.977 Type: SSH_FXP_READ, Size: 22, Number: 10245
< 2011-03-01 13:42:31.073 Type: SSH_FXP_ATTRS, Size: 29, Number: 9992
. 2011-03-01 13:42:31.073 Storing reserved response
< 2011-03-01 13:42:31.273 Status code: 1
. 2011-03-01 13:42:31.273 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:31.273 Type: SSH_FXP_CLOSE, Size: 10, Number: 10756
. 2011-03-01 13:42:31.274 File: "/Download/00669-110131-0128-PARALLEL.zip"
. 2011-03-01 13:42:31.274 Copying "/Download/00669-110131-0128-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:31.275 Binary transfer mode selected.
. 2011-03-01 13:42:31.285 Confirming overwriting of file.
. 2011-03-01 13:42:31.285 Opening remote file.
> 2011-03-01 13:42:31.285 Type: SSH_FXP_OPEN, Size: 57, Number: 11011
< 2011-03-01 13:42:31.395 Type: SSH_FXP_STATUS, Size: 21, Number: 10756
. 2011-03-01 13:42:31.395 Discarding reserved response
< 2011-03-01 13:42:31.504 Type: SSH_FXP_HANDLE, Size: 10, Number: 11011
> 2011-03-01 13:42:31.504 Type: SSH_FXP_FSTAT, Size: 10, Number: 11272
> 2011-03-01 13:42:31.504 Type: SSH_FXP_READ, Size: 22, Number: 11525
< 2011-03-01 13:42:31.616 Type: SSH_FXP_ATTRS, Size: 29, Number: 11272
. 2011-03-01 13:42:31.617 Storing reserved response
< 2011-03-01 13:42:31.857 Status code: 1
. 2011-03-01 13:42:31.857 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:31.857 Type: SSH_FXP_CLOSE, Size: 10, Number: 12036
. 2011-03-01 13:42:31.859 File: "/Download/00669-110131-0155-PARALLEL.zip"
. 2011-03-01 13:42:31.860 Copying "/Download/00669-110131-0155-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:31.860 Binary transfer mode selected.
. 2011-03-01 13:42:31.860 Confirming overwriting of file.
. 2011-03-01 13:42:31.861 Opening remote file.
> 2011-03-01 13:42:31.861 Type: SSH_FXP_OPEN, Size: 57, Number: 12291
< 2011-03-01 13:42:31.949 Type: SSH_FXP_STATUS, Size: 21, Number: 12036
. 2011-03-01 13:42:31.949 Discarding reserved response
< 2011-03-01 13:42:32.044 Type: SSH_FXP_HANDLE, Size: 10, Number: 12291
> 2011-03-01 13:42:32.044 Type: SSH_FXP_FSTAT, Size: 10, Number: 12552
> 2011-03-01 13:42:32.044 Type: SSH_FXP_READ, Size: 22, Number: 12805
< 2011-03-01 13:42:32.163 Type: SSH_FXP_ATTRS, Size: 29, Number: 12552
. 2011-03-01 13:42:32.163 Storing reserved response
< 2011-03-01 13:42:32.382 Status code: 1
. 2011-03-01 13:42:32.382 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:32.382 Type: SSH_FXP_CLOSE, Size: 10, Number: 13316
. 2011-03-01 13:42:32.384 File: "/Download/00669-110131-0228-PARALLEL.zip"
. 2011-03-01 13:42:32.384 Copying "/Download/00669-110131-0228-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:32.385 Binary transfer mode selected.
. 2011-03-01 13:42:32.385 Confirming overwriting of file.
. 2011-03-01 13:42:32.385 Opening remote file.
> 2011-03-01 13:42:32.385 Type: SSH_FXP_OPEN, Size: 57, Number: 13571
< 2011-03-01 13:42:32.471 Type: SSH_FXP_STATUS, Size: 21, Number: 13316
. 2011-03-01 13:42:32.471 Discarding reserved response
< 2011-03-01 13:42:32.602 Type: SSH_FXP_HANDLE, Size: 10, Number: 13571
> 2011-03-01 13:42:32.602 Type: SSH_FXP_FSTAT, Size: 10, Number: 13832
> 2011-03-01 13:42:32.602 Type: SSH_FXP_READ, Size: 22, Number: 14085
< 2011-03-01 13:42:32.714 Type: SSH_FXP_ATTRS, Size: 29, Number: 13832
. 2011-03-01 13:42:32.714 Storing reserved response
< 2011-03-01 13:42:32.962 Status code: 1
. 2011-03-01 13:42:32.962 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:32.962 Type: SSH_FXP_CLOSE, Size: 10, Number: 14596
. 2011-03-01 13:42:32.964 File: "/Download/00669-110131-0245-PARALLEL.zip"
. 2011-03-01 13:42:32.964 Copying "/Download/00669-110131-0245-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:32.965 Binary transfer mode selected.
. 2011-03-01 13:42:32.965 Confirming overwriting of file.
. 2011-03-01 13:42:32.966 Opening remote file.
> 2011-03-01 13:42:32.966 Type: SSH_FXP_OPEN, Size: 57, Number: 14851
< 2011-03-01 13:42:33.072 Type: SSH_FXP_STATUS, Size: 21, Number: 14596
. 2011-03-01 13:42:33.072 Discarding reserved response
< 2011-03-01 13:42:33.185 Type: SSH_FXP_HANDLE, Size: 10, Number: 14851
> 2011-03-01 13:42:33.185 Type: SSH_FXP_FSTAT, Size: 10, Number: 15112
> 2011-03-01 13:42:33.186 Type: SSH_FXP_READ, Size: 22, Number: 15365
< 2011-03-01 13:42:33.285 Type: SSH_FXP_ATTRS, Size: 29, Number: 15112
. 2011-03-01 13:42:33.285 Storing reserved response
< 2011-03-01 13:42:33.524 Status code: 1
. 2011-03-01 13:42:33.525 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:33.525 Type: SSH_FXP_CLOSE, Size: 10, Number: 15876
. 2011-03-01 13:42:33.526 File: "/Download/00669-110131-0324-PARALLEL.zip"
. 2011-03-01 13:42:33.526 Copying "/Download/00669-110131-0324-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:33.527 Binary transfer mode selected.
. 2011-03-01 13:42:33.540 Confirming overwriting of file.
. 2011-03-01 13:42:33.540 Opening remote file.
> 2011-03-01 13:42:33.540 Type: SSH_FXP_OPEN, Size: 57, Number: 16131
< 2011-03-01 13:42:33.638 Type: SSH_FXP_STATUS, Size: 21, Number: 15876
. 2011-03-01 13:42:33.638 Discarding reserved response
< 2011-03-01 13:42:33.745 Type: SSH_FXP_HANDLE, Size: 10, Number: 16131
> 2011-03-01 13:42:33.745 Type: SSH_FXP_FSTAT, Size: 10, Number: 16392
> 2011-03-01 13:42:33.745 Type: SSH_FXP_READ, Size: 22, Number: 16645
< 2011-03-01 13:42:33.863 Type: SSH_FXP_ATTRS, Size: 29, Number: 16392
. 2011-03-01 13:42:33.863 Storing reserved response
< 2011-03-01 13:42:34.152 Status code: 1
. 2011-03-01 13:42:34.152 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:34.152 Type: SSH_FXP_CLOSE, Size: 10, Number: 17156
. 2011-03-01 13:42:34.154 File: "/Download/00669-110131-0351-PARALLEL.zip"
. 2011-03-01 13:42:34.155 Copying "/Download/00669-110131-0351-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:34.155 Binary transfer mode selected.
. 2011-03-01 13:42:34.173 Confirming overwriting of file.
. 2011-03-01 13:42:34.174 Opening remote file.
> 2011-03-01 13:42:34.174 Type: SSH_FXP_OPEN, Size: 57, Number: 17411
< 2011-03-01 13:42:34.232 Type: SSH_FXP_STATUS, Size: 21, Number: 17156
. 2011-03-01 13:42:34.232 Discarding reserved response
< 2011-03-01 13:42:34.330 Type: SSH_FXP_HANDLE, Size: 10, Number: 17411
> 2011-03-01 13:42:34.330 Type: SSH_FXP_FSTAT, Size: 10, Number: 17672
> 2011-03-01 13:42:34.330 Type: SSH_FXP_READ, Size: 22, Number: 17925
< 2011-03-01 13:42:34.424 Type: SSH_FXP_ATTRS, Size: 29, Number: 17672
. 2011-03-01 13:42:34.424 Storing reserved response
< 2011-03-01 13:42:34.674 Status code: 1
. 2011-03-01 13:42:34.674 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:34.674 Type: SSH_FXP_CLOSE, Size: 10, Number: 18436
. 2011-03-01 13:42:34.676 File: "/Download/00669-110131-0418-PARALLEL.zip"
. 2011-03-01 13:42:34.676 Copying "/Download/00669-110131-0418-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:34.676 Binary transfer mode selected.
. 2011-03-01 13:42:34.677 Confirming overwriting of file.
. 2011-03-01 13:42:34.677 Opening remote file.
> 2011-03-01 13:42:34.677 Type: SSH_FXP_OPEN, Size: 57, Number: 18691
< 2011-03-01 13:42:34.769 Type: SSH_FXP_STATUS, Size: 21, Number: 18436
. 2011-03-01 13:42:34.769 Discarding reserved response
< 2011-03-01 13:42:34.868 Type: SSH_FXP_HANDLE, Size: 10, Number: 18691
> 2011-03-01 13:42:34.868 Type: SSH_FXP_FSTAT, Size: 10, Number: 18952
> 2011-03-01 13:42:34.868 Type: SSH_FXP_READ, Size: 22, Number: 19205
. 2011-03-01 13:42:34.956 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:42:34.956 Type: SSH_FXP_ATTRS, Size: 29, Number: 18952
. 2011-03-01 13:42:34.956 Storing reserved response
< 2011-03-01 13:42:35.437 Status code: 1
. 2011-03-01 13:42:35.437 5 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:35.437 Type: SSH_FXP_CLOSE, Size: 10, Number: 20228
< 2011-03-01 13:42:35.535 Type: SSH_FXP_STATUS, Size: 22, Number: 19973
. 2011-03-01 13:42:35.536 File: "/Download/00669-110131-0642-PARALLEL.zip"
. 2011-03-01 13:42:35.537 Copying "/Download/00669-110131-0642-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:35.537 Binary transfer mode selected.
. 2011-03-01 13:42:35.545 Confirming overwriting of file.
. 2011-03-01 13:42:35.545 Opening remote file.
> 2011-03-01 13:42:35.545 Type: SSH_FXP_OPEN, Size: 57, Number: 20483
< 2011-03-01 13:42:35.665 Type: SSH_FXP_STATUS, Size: 21, Number: 20228
. 2011-03-01 13:42:35.665 Discarding reserved response
< 2011-03-01 13:42:35.762 Type: SSH_FXP_HANDLE, Size: 10, Number: 20483
> 2011-03-01 13:42:35.762 Type: SSH_FXP_FSTAT, Size: 10, Number: 20744
> 2011-03-01 13:42:35.762 Type: SSH_FXP_READ, Size: 22, Number: 20997
< 2011-03-01 13:42:35.872 Type: SSH_FXP_ATTRS, Size: 29, Number: 20744
. 2011-03-01 13:42:35.872 Storing reserved response
< 2011-03-01 13:42:36.068 Status code: 1
. 2011-03-01 13:42:36.068 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:36.068 Type: SSH_FXP_CLOSE, Size: 10, Number: 21508
. 2011-03-01 13:42:36.070 File: "/Download/00669-110131-1023-PARALLEL.zip"
. 2011-03-01 13:42:36.071 Copying "/Download/00669-110131-1023-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:36.072 Binary transfer mode selected.
. 2011-03-01 13:42:36.085 Confirming overwriting of file.
. 2011-03-01 13:42:36.085 Opening remote file.
> 2011-03-01 13:42:36.085 Type: SSH_FXP_OPEN, Size: 57, Number: 21763
< 2011-03-01 13:42:36.167 Type: SSH_FXP_STATUS, Size: 21, Number: 21508
. 2011-03-01 13:42:36.167 Discarding reserved response
< 2011-03-01 13:42:36.258 Type: SSH_FXP_HANDLE, Size: 10, Number: 21763
> 2011-03-01 13:42:36.258 Type: SSH_FXP_FSTAT, Size: 10, Number: 22024
> 2011-03-01 13:42:36.258 Type: SSH_FXP_READ, Size: 22, Number: 22277
< 2011-03-01 13:42:36.356 Type: SSH_FXP_ATTRS, Size: 29, Number: 22024
. 2011-03-01 13:42:36.356 Storing reserved response
< 2011-03-01 13:42:36.557 Status code: 1
. 2011-03-01 13:42:36.557 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:36.557 Type: SSH_FXP_CLOSE, Size: 10, Number: 22788
. 2011-03-01 13:42:36.559 File: "/Download/00669-110131-1121-PARALLEL.zip"
. 2011-03-01 13:42:36.560 Copying "/Download/00669-110131-1121-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:36.560 Binary transfer mode selected.
. 2011-03-01 13:42:36.560 Confirming overwriting of file.
. 2011-03-01 13:42:36.561 Opening remote file.
> 2011-03-01 13:42:36.561 Type: SSH_FXP_OPEN, Size: 57, Number: 23043
< 2011-03-01 13:42:36.682 Type: SSH_FXP_STATUS, Size: 21, Number: 22788
. 2011-03-01 13:42:36.682 Discarding reserved response
< 2011-03-01 13:42:36.784 Type: SSH_FXP_HANDLE, Size: 10, Number: 23043
> 2011-03-01 13:42:36.784 Type: SSH_FXP_FSTAT, Size: 10, Number: 23304
> 2011-03-01 13:42:36.784 Type: SSH_FXP_READ, Size: 22, Number: 23557
< 2011-03-01 13:42:36.882 Type: SSH_FXP_ATTRS, Size: 29, Number: 23304
. 2011-03-01 13:42:36.882 Storing reserved response
< 2011-03-01 13:42:37.110 Status code: 1
. 2011-03-01 13:42:37.111 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:37.111 Type: SSH_FXP_CLOSE, Size: 10, Number: 24068
. 2011-03-01 13:42:37.112 File: "/Download/00669-110131-1209-PARALLEL.zip"
. 2011-03-01 13:42:37.112 Copying "/Download/00669-110131-1209-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:37.113 Binary transfer mode selected.
. 2011-03-01 13:42:37.113 Confirming overwriting of file.
. 2011-03-01 13:42:37.114 Opening remote file.
> 2011-03-01 13:42:37.114 Type: SSH_FXP_OPEN, Size: 57, Number: 24323
< 2011-03-01 13:42:37.219 Type: SSH_FXP_STATUS, Size: 21, Number: 24068
. 2011-03-01 13:42:37.219 Discarding reserved response
< 2011-03-01 13:42:37.319 Type: SSH_FXP_HANDLE, Size: 10, Number: 24323
> 2011-03-01 13:42:37.319 Type: SSH_FXP_FSTAT, Size: 10, Number: 24584
> 2011-03-01 13:42:37.319 Type: SSH_FXP_READ, Size: 22, Number: 24837
< 2011-03-01 13:42:37.436 Type: SSH_FXP_ATTRS, Size: 29, Number: 24584
. 2011-03-01 13:42:37.437 Storing reserved response
< 2011-03-01 13:42:37.645 Status code: 1
. 2011-03-01 13:42:37.645 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:37.645 Type: SSH_FXP_CLOSE, Size: 10, Number: 25348
. 2011-03-01 13:42:37.647 File: "/Download/00669-110201-0109-PARALLEL.zip"
. 2011-03-01 13:42:37.648 Copying "/Download/00669-110201-0109-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:37.649 Binary transfer mode selected.
. 2011-03-01 13:42:37.669 Confirming overwriting of file.
. 2011-03-01 13:42:37.669 Opening remote file.
> 2011-03-01 13:42:37.669 Type: SSH_FXP_OPEN, Size: 57, Number: 25603
< 2011-03-01 13:42:37.738 Type: SSH_FXP_STATUS, Size: 21, Number: 25348
. 2011-03-01 13:42:37.738 Discarding reserved response
< 2011-03-01 13:42:37.832 Type: SSH_FXP_HANDLE, Size: 10, Number: 25603
> 2011-03-01 13:42:37.832 Type: SSH_FXP_FSTAT, Size: 10, Number: 25864
> 2011-03-01 13:42:37.832 Type: SSH_FXP_READ, Size: 22, Number: 26117
< 2011-03-01 13:42:37.927 Type: SSH_FXP_ATTRS, Size: 29, Number: 25864
. 2011-03-01 13:42:37.927 Storing reserved response
< 2011-03-01 13:42:38.148 Status code: 1
. 2011-03-01 13:42:38.148 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:38.148 Type: SSH_FXP_CLOSE, Size: 10, Number: 26628
. 2011-03-01 13:42:38.150 File: "/Download/00669-110201-0211-PARALLEL.zip"
. 2011-03-01 13:42:38.151 Copying "/Download/00669-110201-0211-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:38.152 Binary transfer mode selected.
. 2011-03-01 13:42:38.161 Confirming overwriting of file.
. 2011-03-01 13:42:38.161 Opening remote file.
> 2011-03-01 13:42:38.161 Type: SSH_FXP_OPEN, Size: 57, Number: 26883
< 2011-03-01 13:42:38.247 Type: SSH_FXP_STATUS, Size: 21, Number: 26628
. 2011-03-01 13:42:38.247 Discarding reserved response
< 2011-03-01 13:42:38.346 Type: SSH_FXP_HANDLE, Size: 10, Number: 26883
> 2011-03-01 13:42:38.346 Type: SSH_FXP_FSTAT, Size: 10, Number: 27144
> 2011-03-01 13:42:38.346 Type: SSH_FXP_READ, Size: 22, Number: 27397
< 2011-03-01 13:42:38.445 Type: SSH_FXP_ATTRS, Size: 29, Number: 27144
. 2011-03-01 13:42:38.445 Storing reserved response
< 2011-03-01 13:42:38.647 Status code: 1
. 2011-03-01 13:42:38.647 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:38.648 Type: SSH_FXP_CLOSE, Size: 10, Number: 27908
. 2011-03-01 13:42:38.649 File: "/Download/00669-110201-0429-PARALLEL.zip"
. 2011-03-01 13:42:38.650 Copying "/Download/00669-110201-0429-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:38.650 Binary transfer mode selected.
. 2011-03-01 13:42:38.658 Confirming overwriting of file.
. 2011-03-01 13:42:38.659 Opening remote file.
> 2011-03-01 13:42:38.659 Type: SSH_FXP_OPEN, Size: 57, Number: 28163
< 2011-03-01 13:42:38.748 Type: SSH_FXP_STATUS, Size: 21, Number: 27908
. 2011-03-01 13:42:38.748 Discarding reserved response
< 2011-03-01 13:42:38.839 Type: SSH_FXP_HANDLE, Size: 10, Number: 28163
> 2011-03-01 13:42:38.839 Type: SSH_FXP_FSTAT, Size: 10, Number: 28424
> 2011-03-01 13:42:38.839 Type: SSH_FXP_READ, Size: 22, Number: 28677
< 2011-03-01 13:42:38.939 Type: SSH_FXP_ATTRS, Size: 29, Number: 28424
. 2011-03-01 13:42:38.939 Storing reserved response
< 2011-03-01 13:42:39.164 Status code: 1
. 2011-03-01 13:42:39.164 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:39.164 Type: SSH_FXP_CLOSE, Size: 10, Number: 29188
. 2011-03-01 13:42:39.165 File: "/Download/00669-110201-0445-PARALLEL.zip"
. 2011-03-01 13:42:39.166 Copying "/Download/00669-110201-0445-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:39.166 Binary transfer mode selected.
. 2011-03-01 13:42:39.204 Checking existence of partially transfered file.
. 2011-03-01 13:42:39.205 Confirming overwriting of file.
. 2011-03-01 13:42:39.205 Opening remote file.
> 2011-03-01 13:42:39.205 Type: SSH_FXP_OPEN, Size: 57, Number: 29443
< 2011-03-01 13:42:39.279 Type: SSH_FXP_STATUS, Size: 21, Number: 29188
. 2011-03-01 13:42:39.279 Discarding reserved response
< 2011-03-01 13:42:39.409 Type: SSH_FXP_HANDLE, Size: 10, Number: 29443
> 2011-03-01 13:42:39.409 Type: SSH_FXP_FSTAT, Size: 10, Number: 29704
> 2011-03-01 13:42:39.409 Type: SSH_FXP_READ, Size: 22, Number: 29957
. 2011-03-01 13:42:39.528 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:42:39.529 Type: SSH_FXP_ATTRS, Size: 29, Number: 29704
. 2011-03-01 13:42:39.529 Storing reserved response
< 2011-03-01 13:42:40.310 Status code: 1
. 2011-03-01 13:42:40.310 11 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:40.310 Type: SSH_FXP_CLOSE, Size: 10, Number: 32260
< 2011-03-01 13:42:40.310 Type: SSH_FXP_STATUS, Size: 22, Number: 31493
< 2011-03-01 13:42:40.310 Type: SSH_FXP_STATUS, Size: 22, Number: 31749
< 2011-03-01 13:42:40.442 Type: SSH_FXP_STATUS, Size: 22, Number: 32005
. 2011-03-01 13:42:40.444 File: "/Download/00669-110201-0507-PARALLEL.zip"
. 2011-03-01 13:42:40.444 Copying "/Download/00669-110201-0507-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:40.445 Binary transfer mode selected.
. 2011-03-01 13:42:40.459 Confirming overwriting of file.
. 2011-03-01 13:42:40.460 Opening remote file.
> 2011-03-01 13:42:40.460 Type: SSH_FXP_OPEN, Size: 57, Number: 32515
< 2011-03-01 13:42:40.569 Type: SSH_FXP_STATUS, Size: 21, Number: 32260
. 2011-03-01 13:42:40.569 Discarding reserved response
< 2011-03-01 13:42:40.695 Type: SSH_FXP_HANDLE, Size: 10, Number: 32515
> 2011-03-01 13:42:40.695 Type: SSH_FXP_FSTAT, Size: 10, Number: 32776
> 2011-03-01 13:42:40.695 Type: SSH_FXP_READ, Size: 22, Number: 33029
< 2011-03-01 13:42:40.810 Type: SSH_FXP_ATTRS, Size: 29, Number: 32776
. 2011-03-01 13:42:40.810 Storing reserved response
< 2011-03-01 13:42:41.091 Status code: 1
. 2011-03-01 13:42:41.091 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:41.091 Type: SSH_FXP_CLOSE, Size: 10, Number: 33540
. 2011-03-01 13:42:41.093 File: "/Download/00669-110201-0520-PARALLEL.zip"
. 2011-03-01 13:42:41.093 Copying "/Download/00669-110201-0520-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:41.094 Binary transfer mode selected.
. 2011-03-01 13:42:41.118 Confirming overwriting of file.
. 2011-03-01 13:42:41.118 Opening remote file.
> 2011-03-01 13:42:41.119 Type: SSH_FXP_OPEN, Size: 57, Number: 33795
< 2011-03-01 13:42:41.197 Type: SSH_FXP_STATUS, Size: 21, Number: 33540
. 2011-03-01 13:42:41.197 Discarding reserved response
< 2011-03-01 13:42:41.305 Type: SSH_FXP_HANDLE, Size: 10, Number: 33795
> 2011-03-01 13:42:41.305 Type: SSH_FXP_FSTAT, Size: 10, Number: 34056
> 2011-03-01 13:42:41.305 Type: SSH_FXP_READ, Size: 22, Number: 34309
. 2011-03-01 13:42:41.424 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:42:41.424 Type: SSH_FXP_ATTRS, Size: 29, Number: 34056
. 2011-03-01 13:42:41.424 Storing reserved response
< 2011-03-01 13:42:41.918 Status code: 1
. 2011-03-01 13:42:41.919 5 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:41.919 Type: SSH_FXP_CLOSE, Size: 10, Number: 35332
< 2011-03-01 13:42:42.009 Type: SSH_FXP_STATUS, Size: 22, Number: 35077
. 2011-03-01 13:42:42.011 File: "/Download/00669-110201-0639-PARALLEL.zip"
. 2011-03-01 13:42:42.011 Copying "/Download/00669-110201-0639-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:42.012 Binary transfer mode selected.
. 2011-03-01 13:42:42.014 Confirming overwriting of file.
. 2011-03-01 13:42:42.014 Opening remote file.
> 2011-03-01 13:42:42.014 Type: SSH_FXP_OPEN, Size: 57, Number: 35587
< 2011-03-01 13:42:42.100 Type: SSH_FXP_STATUS, Size: 21, Number: 35332
. 2011-03-01 13:42:42.101 Discarding reserved response
< 2011-03-01 13:42:42.242 Type: SSH_FXP_HANDLE, Size: 10, Number: 35587
> 2011-03-01 13:42:42.242 Type: SSH_FXP_FSTAT, Size: 10, Number: 35848
> 2011-03-01 13:42:42.242 Type: SSH_FXP_READ, Size: 22, Number: 36101
< 2011-03-01 13:42:42.332 Type: SSH_FXP_ATTRS, Size: 29, Number: 35848
. 2011-03-01 13:42:42.332 Storing reserved response
< 2011-03-01 13:42:42.513 Status code: 1
. 2011-03-01 13:42:42.513 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:42.513 Type: SSH_FXP_CLOSE, Size: 10, Number: 36612
. 2011-03-01 13:42:42.514 File: "/Download/00669-110201-0654-PARALLEL.zip"
. 2011-03-01 13:42:42.515 Copying "/Download/00669-110201-0654-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:42.516 Binary transfer mode selected.
. 2011-03-01 13:42:42.535 Confirming overwriting of file.
. 2011-03-01 13:42:42.536 Opening remote file.
> 2011-03-01 13:42:42.536 Type: SSH_FXP_OPEN, Size: 57, Number: 36867
< 2011-03-01 13:42:42.638 Type: SSH_FXP_STATUS, Size: 21, Number: 36612
. 2011-03-01 13:42:42.638 Discarding reserved response
< 2011-03-01 13:42:42.736 Type: SSH_FXP_HANDLE, Size: 10, Number: 36867
> 2011-03-01 13:42:42.736 Type: SSH_FXP_FSTAT, Size: 10, Number: 37128
> 2011-03-01 13:42:42.736 Type: SSH_FXP_READ, Size: 22, Number: 37381
< 2011-03-01 13:42:42.823 Type: SSH_FXP_ATTRS, Size: 29, Number: 37128
. 2011-03-01 13:42:42.823 Storing reserved response
< 2011-03-01 13:42:43.001 Status code: 1
. 2011-03-01 13:42:43.001 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:43.001 Type: SSH_FXP_CLOSE, Size: 10, Number: 37892
. 2011-03-01 13:42:43.003 File: "/Download/00669-110201-0839-PARALLEL.zip"
. 2011-03-01 13:42:43.003 Copying "/Download/00669-110201-0839-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:43.004 Binary transfer mode selected.
. 2011-03-01 13:42:43.021 Confirming overwriting of file.
. 2011-03-01 13:42:43.022 Opening remote file.
> 2011-03-01 13:42:43.022 Type: SSH_FXP_OPEN, Size: 57, Number: 38147
< 2011-03-01 13:42:43.089 Type: SSH_FXP_STATUS, Size: 21, Number: 37892
. 2011-03-01 13:42:43.089 Discarding reserved response
< 2011-03-01 13:42:43.180 Type: SSH_FXP_HANDLE, Size: 10, Number: 38147
> 2011-03-01 13:42:43.180 Type: SSH_FXP_FSTAT, Size: 10, Number: 38408
> 2011-03-01 13:42:43.180 Type: SSH_FXP_READ, Size: 22, Number: 38661
< 2011-03-01 13:42:43.264 Type: SSH_FXP_ATTRS, Size: 29, Number: 38408
. 2011-03-01 13:42:43.264 Storing reserved response
< 2011-03-01 13:42:43.469 Status code: 1
. 2011-03-01 13:42:43.469 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:43.469 Type: SSH_FXP_CLOSE, Size: 10, Number: 39172
. 2011-03-01 13:42:43.471 File: "/Download/00669-110201-0911-PARALLEL.zip"
. 2011-03-01 13:42:43.475 Copying "/Download/00669-110201-0911-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:43.476 Binary transfer mode selected.
. 2011-03-01 13:42:43.476 Confirming overwriting of file.
. 2011-03-01 13:42:43.476 Opening remote file.
> 2011-03-01 13:42:43.476 Type: SSH_FXP_OPEN, Size: 57, Number: 39427
< 2011-03-01 13:42:43.570 Type: SSH_FXP_STATUS, Size: 21, Number: 39172
. 2011-03-01 13:42:43.570 Discarding reserved response
< 2011-03-01 13:42:43.664 Type: SSH_FXP_HANDLE, Size: 10, Number: 39427
> 2011-03-01 13:42:43.664 Type: SSH_FXP_FSTAT, Size: 10, Number: 39688
> 2011-03-01 13:42:43.664 Type: SSH_FXP_READ, Size: 22, Number: 39941
< 2011-03-01 13:42:43.764 Type: SSH_FXP_ATTRS, Size: 29, Number: 39688
. 2011-03-01 13:42:43.764 Storing reserved response
< 2011-03-01 13:42:43.975 Status code: 1
. 2011-03-01 13:42:43.975 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:43.976 Type: SSH_FXP_CLOSE, Size: 10, Number: 40452
. 2011-03-01 13:42:43.977 File: "/Download/00669-110201-1049-PARALLEL.zip"
. 2011-03-01 13:42:43.977 Copying "/Download/00669-110201-1049-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:43.978 Binary transfer mode selected.
. 2011-03-01 13:42:44.032 Confirming overwriting of file.
. 2011-03-01 13:42:44.032 Opening remote file.
> 2011-03-01 13:42:44.033 Type: SSH_FXP_OPEN, Size: 57, Number: 40707
< 2011-03-01 13:42:44.060 Type: SSH_FXP_STATUS, Size: 21, Number: 40452
. 2011-03-01 13:42:44.060 Discarding reserved response
< 2011-03-01 13:42:44.147 Type: SSH_FXP_HANDLE, Size: 10, Number: 40707
> 2011-03-01 13:42:44.147 Type: SSH_FXP_FSTAT, Size: 10, Number: 40968
> 2011-03-01 13:42:44.147 Type: SSH_FXP_READ, Size: 22, Number: 41221
. 2011-03-01 13:42:44.241 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:42:44.241 Type: SSH_FXP_ATTRS, Size: 29, Number: 40968
. 2011-03-01 13:42:44.241 Storing reserved response
< 2011-03-01 13:42:44.504 Status code: 1
. 2011-03-01 13:42:44.504 5 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:44.504 Type: SSH_FXP_CLOSE, Size: 10, Number: 42244
< 2011-03-01 13:42:44.591 Type: SSH_FXP_STATUS, Size: 22, Number: 41989
. 2011-03-01 13:42:44.593 File: "/Download/00669-110202-0104-PARALLEL.zip"
. 2011-03-01 13:42:44.593 Copying "/Download/00669-110202-0104-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:44.594 Binary transfer mode selected.
. 2011-03-01 13:42:44.614 Confirming overwriting of file.
. 2011-03-01 13:42:44.614 Opening remote file.
> 2011-03-01 13:42:44.614 Type: SSH_FXP_OPEN, Size: 57, Number: 42499
< 2011-03-01 13:42:44.709 Type: SSH_FXP_STATUS, Size: 21, Number: 42244
. 2011-03-01 13:42:44.709 Discarding reserved response
< 2011-03-01 13:42:44.815 Type: SSH_FXP_HANDLE, Size: 10, Number: 42499
> 2011-03-01 13:42:44.816 Type: SSH_FXP_FSTAT, Size: 10, Number: 42760
> 2011-03-01 13:42:44.816 Type: SSH_FXP_READ, Size: 22, Number: 43013
< 2011-03-01 13:42:44.910 Type: SSH_FXP_ATTRS, Size: 29, Number: 42760
. 2011-03-01 13:42:44.910 Storing reserved response
< 2011-03-01 13:42:45.124 Status code: 1
. 2011-03-01 13:42:45.124 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:45.124 Type: SSH_FXP_CLOSE, Size: 10, Number: 43524
. 2011-03-01 13:42:45.125 File: "/Download/00669-110202-0155-PARALLEL.zip"
. 2011-03-01 13:42:45.126 Copying "/Download/00669-110202-0155-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:45.126 Binary transfer mode selected.
. 2011-03-01 13:42:45.126 Confirming overwriting of file.
. 2011-03-01 13:42:45.127 Opening remote file.
> 2011-03-01 13:42:45.127 Type: SSH_FXP_OPEN, Size: 57, Number: 43779
< 2011-03-01 13:42:45.229 Type: SSH_FXP_STATUS, Size: 21, Number: 43524
. 2011-03-01 13:42:45.229 Discarding reserved response
< 2011-03-01 13:42:45.322 Type: SSH_FXP_HANDLE, Size: 10, Number: 43779
> 2011-03-01 13:42:45.322 Type: SSH_FXP_FSTAT, Size: 10, Number: 44040
> 2011-03-01 13:42:45.323 Type: SSH_FXP_READ, Size: 22, Number: 44293
< 2011-03-01 13:42:45.423 Type: SSH_FXP_ATTRS, Size: 29, Number: 44040
. 2011-03-01 13:42:45.423 Storing reserved response
< 2011-03-01 13:42:45.652 Status code: 1
. 2011-03-01 13:42:45.652 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:45.652 Type: SSH_FXP_CLOSE, Size: 10, Number: 44804
. 2011-03-01 13:42:45.654 File: "/Download/00669-110202-0209-PARALLEL.zip"
. 2011-03-01 13:42:45.654 Copying "/Download/00669-110202-0209-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:45.655 Binary transfer mode selected.
. 2011-03-01 13:42:45.655 Checking existence of partially transfered file.
. 2011-03-01 13:42:45.655 Confirming overwriting of file.
. 2011-03-01 13:42:45.655 Opening remote file.
> 2011-03-01 13:42:45.655 Type: SSH_FXP_OPEN, Size: 57, Number: 45059
< 2011-03-01 13:42:45.745 Type: SSH_FXP_STATUS, Size: 21, Number: 44804
. 2011-03-01 13:42:45.745 Discarding reserved response
< 2011-03-01 13:42:45.840 Type: SSH_FXP_HANDLE, Size: 10, Number: 45059
> 2011-03-01 13:42:45.840 Type: SSH_FXP_FSTAT, Size: 10, Number: 45320
> 2011-03-01 13:42:45.840 Type: SSH_FXP_READ, Size: 22, Number: 45573
. 2011-03-01 13:42:45.932 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:42:45.932 Type: SSH_FXP_ATTRS, Size: 29, Number: 45320
. 2011-03-01 13:42:45.933 Storing reserved response
< 2011-03-01 13:42:46.719 Status code: 1
. 2011-03-01 13:42:46.719 9 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:46.719 Type: SSH_FXP_CLOSE, Size: 10, Number: 47620
< 2011-03-01 13:42:46.719 Type: SSH_FXP_STATUS, Size: 22, Number: 46853
< 2011-03-01 13:42:46.719 Type: SSH_FXP_STATUS, Size: 22, Number: 47109
< 2011-03-01 13:42:46.818 Type: SSH_FXP_STATUS, Size: 22, Number: 47365
. 2011-03-01 13:42:46.821 File: "/Download/00669-110202-0240-PARALLEL.zip"
. 2011-03-01 13:42:46.821 Copying "/Download/00669-110202-0240-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:46.821 Binary transfer mode selected.
. 2011-03-01 13:42:46.822 Confirming overwriting of file.
. 2011-03-01 13:42:46.822 Opening remote file.
> 2011-03-01 13:42:46.822 Type: SSH_FXP_OPEN, Size: 57, Number: 47875
< 2011-03-01 13:42:46.914 Type: SSH_FXP_STATUS, Size: 21, Number: 47620
. 2011-03-01 13:42:46.914 Discarding reserved response
< 2011-03-01 13:42:47.006 Type: SSH_FXP_HANDLE, Size: 10, Number: 47875
> 2011-03-01 13:42:47.007 Type: SSH_FXP_FSTAT, Size: 10, Number: 48136
> 2011-03-01 13:42:47.007 Type: SSH_FXP_READ, Size: 22, Number: 48389
< 2011-03-01 13:42:47.104 Type: SSH_FXP_ATTRS, Size: 29, Number: 48136
. 2011-03-01 13:42:47.104 Storing reserved response
< 2011-03-01 13:42:47.355 Status code: 1
. 2011-03-01 13:42:47.355 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:47.355 Type: SSH_FXP_CLOSE, Size: 10, Number: 48900
. 2011-03-01 13:42:47.356 File: "/Download/00669-110202-0305-PARALLEL.zip"
. 2011-03-01 13:42:47.356 Copying "/Download/00669-110202-0305-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:47.357 Binary transfer mode selected.
. 2011-03-01 13:42:47.381 Confirming overwriting of file.
. 2011-03-01 13:42:47.381 Opening remote file.
> 2011-03-01 13:42:47.381 Type: SSH_FXP_OPEN, Size: 57, Number: 49155
< 2011-03-01 13:42:47.461 Type: SSH_FXP_STATUS, Size: 21, Number: 48900
. 2011-03-01 13:42:47.461 Discarding reserved response
< 2011-03-01 13:42:47.563 Type: SSH_FXP_HANDLE, Size: 10, Number: 49155
> 2011-03-01 13:42:47.563 Type: SSH_FXP_FSTAT, Size: 10, Number: 49416
> 2011-03-01 13:42:47.563 Type: SSH_FXP_READ, Size: 22, Number: 49669
. 2011-03-01 13:42:47.698 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-03-01 13:42:47.698 Type: SSH_FXP_ATTRS, Size: 29, Number: 49416
. 2011-03-01 13:42:47.698 Storing reserved response
< 2011-03-01 13:42:48.175 Status code: 1
. 2011-03-01 13:42:48.175 5 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:48.175 Type: SSH_FXP_CLOSE, Size: 10, Number: 50692
< 2011-03-01 13:42:48.290 Type: SSH_FXP_STATUS, Size: 22, Number: 50437
. 2011-03-01 13:42:48.292 File: "/Download/00669-110202-0347-PARALLEL.zip"
. 2011-03-01 13:42:48.292 Copying "/Download/00669-110202-0347-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:48.292 Binary transfer mode selected.
. 2011-03-01 13:42:48.309 Confirming overwriting of file.
. 2011-03-01 13:42:48.310 Opening remote file.
> 2011-03-01 13:42:48.310 Type: SSH_FXP_OPEN, Size: 57, Number: 50947
< 2011-03-01 13:42:48.400 Type: SSH_FXP_STATUS, Size: 21, Number: 50692
. 2011-03-01 13:42:48.400 Discarding reserved response
< 2011-03-01 13:42:48.501 Type: SSH_FXP_HANDLE, Size: 10, Number: 50947
> 2011-03-01 13:42:48.501 Type: SSH_FXP_FSTAT, Size: 10, Number: 51208
> 2011-03-01 13:42:48.502 Type: SSH_FXP_READ, Size: 22, Number: 51461
< 2011-03-01 13:42:48.599 Type: SSH_FXP_ATTRS, Size: 29, Number: 51208
. 2011-03-01 13:42:48.599 Storing reserved response
< 2011-03-01 13:42:48.805 Status code: 1
. 2011-03-01 13:42:48.805 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:48.805 Type: SSH_FXP_CLOSE, Size: 10, Number: 51972
. 2011-03-01 13:42:48.806 File: "/Download/00669-110202-0527-PARALLEL.zip"
. 2011-03-01 13:42:48.807 Copying "/Download/00669-110202-0527-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:48.807 Binary transfer mode selected.
. 2011-03-01 13:42:48.821 Confirming overwriting of file.
. 2011-03-01 13:42:48.821 Opening remote file.
> 2011-03-01 13:42:48.822 Type: SSH_FXP_OPEN, Size: 57, Number: 52227
< 2011-03-01 13:42:48.905 Type: SSH_FXP_STATUS, Size: 21, Number: 51972
. 2011-03-01 13:42:48.905 Discarding reserved response
< 2011-03-01 13:42:49.002 Type: SSH_FXP_HANDLE, Size: 10, Number: 52227
> 2011-03-01 13:42:49.002 Type: SSH_FXP_FSTAT, Size: 10, Number: 52488
> 2011-03-01 13:42:49.002 Type: SSH_FXP_READ, Size: 22, Number: 52741
< 2011-03-01 13:42:49.115 Type: SSH_FXP_ATTRS, Size: 29, Number: 52488
. 2011-03-01 13:42:49.115 Storing reserved response
< 2011-03-01 13:42:49.392 Status code: 1
. 2011-03-01 13:42:49.392 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:49.392 Type: SSH_FXP_CLOSE, Size: 10, Number: 53252
. 2011-03-01 13:42:49.393 File: "/Download/00669-110202-0539-PARALLEL.zip"
. 2011-03-01 13:42:49.394 Copying "/Download/00669-110202-0539-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:49.395 Binary transfer mode selected.
. 2011-03-01 13:42:49.395 Confirming overwriting of file.
. 2011-03-01 13:42:49.395 Opening remote file.
> 2011-03-01 13:42:49.395 Type: SSH_FXP_OPEN, Size: 57, Number: 53507
< 2011-03-01 13:42:49.514 Type: SSH_FXP_STATUS, Size: 21, Number: 53252
. 2011-03-01 13:42:49.514 Discarding reserved response
< 2011-03-01 13:42:49.613 Type: SSH_FXP_HANDLE, Size: 10, Number: 53507
> 2011-03-01 13:42:49.613 Type: SSH_FXP_FSTAT, Size: 10, Number: 53768
> 2011-03-01 13:42:49.613 Type: SSH_FXP_READ, Size: 22, Number: 54021
< 2011-03-01 13:42:49.706 Type: SSH_FXP_ATTRS, Size: 29, Number: 53768
. 2011-03-01 13:42:49.706 Storing reserved response
< 2011-03-01 13:42:49.965 Status code: 1
. 2011-03-01 13:42:49.965 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:49.965 Type: SSH_FXP_CLOSE, Size: 10, Number: 54532
. 2011-03-01 13:42:49.966 File: "/Download/00669-110202-0622-PARALLEL.zip"
. 2011-03-01 13:42:49.967 Copying "/Download/00669-110202-0622-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:49.967 Binary transfer mode selected.
. 2011-03-01 13:42:49.985 Confirming overwriting of file.
. 2011-03-01 13:42:49.985 Opening remote file.
> 2011-03-01 13:42:49.985 Type: SSH_FXP_OPEN, Size: 57, Number: 54787
< 2011-03-01 13:42:50.116 Type: SSH_FXP_STATUS, Size: 21, Number: 54532
. 2011-03-01 13:42:50.116 Discarding reserved response
< 2011-03-01 13:42:50.227 Type: SSH_FXP_HANDLE, Size: 10, Number: 54787
> 2011-03-01 13:42:50.227 Type: SSH_FXP_FSTAT, Size: 10, Number: 55048
> 2011-03-01 13:42:50.227 Type: SSH_FXP_READ, Size: 22, Number: 55301
< 2011-03-01 13:42:50.339 Type: SSH_FXP_ATTRS, Size: 29, Number: 55048
. 2011-03-01 13:42:50.339 Storing reserved response
< 2011-03-01 13:42:50.829 Status code: 1
. 2011-03-01 13:42:50.829 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:50.829 Type: SSH_FXP_CLOSE, Size: 10, Number: 55812
. 2011-03-01 13:42:50.832 File: "/Download/00669-110202-0836-PARALLEL.zip"
. 2011-03-01 13:42:50.832 Copying "/Download/00669-110202-0836-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:50.832 Binary transfer mode selected.
. 2011-03-01 13:42:50.851 Confirming overwriting of file.
. 2011-03-01 13:42:50.852 Opening remote file.
> 2011-03-01 13:42:50.852 Type: SSH_FXP_OPEN, Size: 57, Number: 56067
< 2011-03-01 13:42:50.925 Type: SSH_FXP_STATUS, Size: 21, Number: 55812
. 2011-03-01 13:42:50.925 Discarding reserved response
< 2011-03-01 13:42:51.015 Type: SSH_FXP_HANDLE, Size: 10, Number: 56067
> 2011-03-01 13:42:51.015 Type: SSH_FXP_FSTAT, Size: 10, Number: 56328
> 2011-03-01 13:42:51.015 Type: SSH_FXP_READ, Size: 22, Number: 56581
< 2011-03-01 13:42:51.099 Type: SSH_FXP_ATTRS, Size: 29, Number: 56328
. 2011-03-01 13:42:51.099 Storing reserved response
< 2011-03-01 13:42:51.287 Status code: 1
. 2011-03-01 13:42:51.287 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:51.287 Type: SSH_FXP_CLOSE, Size: 10, Number: 57092
. 2011-03-01 13:42:51.289 File: "/Download/00669-110202-0840-PARALLEL.zip"
. 2011-03-01 13:42:51.289 Copying "/Download/00669-110202-0840-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:51.290 Binary transfer mode selected.
. 2011-03-01 13:42:51.308 Confirming overwriting of file.
. 2011-03-01 13:42:51.309 Opening remote file.
> 2011-03-01 13:42:51.309 Type: SSH_FXP_OPEN, Size: 57, Number: 57347
< 2011-03-01 13:42:51.372 Type: SSH_FXP_STATUS, Size: 21, Number: 57092
. 2011-03-01 13:42:51.372 Discarding reserved response
< 2011-03-01 13:42:51.473 Type: SSH_FXP_HANDLE, Size: 10, Number: 57347
> 2011-03-01 13:42:51.473 Type: SSH_FXP_FSTAT, Size: 10, Number: 57608
> 2011-03-01 13:42:51.473 Type: SSH_FXP_READ, Size: 22, Number: 57861
< 2011-03-01 13:42:51.578 Type: SSH_FXP_ATTRS, Size: 29, Number: 57608
. 2011-03-01 13:42:51.578 Storing reserved response
< 2011-03-01 13:42:51.814 Status code: 1
. 2011-03-01 13:42:51.814 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:51.814 Type: SSH_FXP_CLOSE, Size: 10, Number: 58372
. 2011-03-01 13:42:51.816 File: "/Download/00669-110202-0924-PARALLEL.zip"
. 2011-03-01 13:42:51.816 Copying "/Download/00669-110202-0924-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:51.817 Binary transfer mode selected.
. 2011-03-01 13:42:51.823 Confirming overwriting of file.
. 2011-03-01 13:42:51.823 Opening remote file.
> 2011-03-01 13:42:51.823 Type: SSH_FXP_OPEN, Size: 57, Number: 58627
< 2011-03-01 13:42:51.920 Type: SSH_FXP_STATUS, Size: 21, Number: 58372
. 2011-03-01 13:42:51.920 Discarding reserved response
< 2011-03-01 13:42:52.017 Type: SSH_FXP_HANDLE, Size: 10, Number: 58627
> 2011-03-01 13:42:52.017 Type: SSH_FXP_FSTAT, Size: 10, Number: 58888
> 2011-03-01 13:42:52.017 Type: SSH_FXP_READ, Size: 22, Number: 59141
< 2011-03-01 13:42:52.107 Type: SSH_FXP_ATTRS, Size: 29, Number: 58888
. 2011-03-01 13:42:52.107 Storing reserved response
< 2011-03-01 13:42:52.287 Status code: 1
. 2011-03-01 13:42:52.287 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:52.287 Type: SSH_FXP_CLOSE, Size: 10, Number: 59652
. 2011-03-01 13:42:52.289 File: "/Download/00669-110202-1240-PARALLEL.zip"
. 2011-03-01 13:42:52.289 Copying "/Download/00669-110202-1240-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:52.290 Binary transfer mode selected.
. 2011-03-01 13:42:52.290 Confirming overwriting of file.
. 2011-03-01 13:42:52.290 Opening remote file.
> 2011-03-01 13:42:52.290 Type: SSH_FXP_OPEN, Size: 57, Number: 59907
< 2011-03-01 13:42:52.372 Type: SSH_FXP_STATUS, Size: 21, Number: 59652
. 2011-03-01 13:42:52.372 Discarding reserved response
< 2011-03-01 13:42:52.469 Type: SSH_FXP_HANDLE, Size: 10, Number: 59907
> 2011-03-01 13:42:52.469 Type: SSH_FXP_FSTAT, Size: 10, Number: 60168
> 2011-03-01 13:42:52.469 Type: SSH_FXP_READ, Size: 22, Number: 60421
< 2011-03-01 13:42:52.571 Type: SSH_FXP_ATTRS, Size: 29, Number: 60168
. 2011-03-01 13:42:52.571 Storing reserved response
< 2011-03-01 13:42:52.758 Status code: 1
. 2011-03-01 13:42:52.758 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:52.758 Type: SSH_FXP_CLOSE, Size: 10, Number: 60932
. 2011-03-01 13:42:52.760 File: "/Download/00669-110203-0115-PARALLEL.zip"
. 2011-03-01 13:42:52.760 Copying "/Download/00669-110203-0115-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:52.760 Binary transfer mode selected.
. 2011-03-01 13:42:52.761 Confirming overwriting of file.
. 2011-03-01 13:42:52.761 Opening remote file.
> 2011-03-01 13:42:52.761 Type: SSH_FXP_OPEN, Size: 57, Number: 61187
< 2011-03-01 13:42:52.850 Type: SSH_FXP_STATUS, Size: 21, Number: 60932
. 2011-03-01 13:42:52.850 Discarding reserved response
< 2011-03-01 13:42:52.933 Type: SSH_FXP_HANDLE, Size: 10, Number: 61187
> 2011-03-01 13:42:52.933 Type: SSH_FXP_FSTAT, Size: 10, Number: 61448
> 2011-03-01 13:42:52.933 Type: SSH_FXP_READ, Size: 22, Number: 61701
< 2011-03-01 13:42:53.041 Type: SSH_FXP_ATTRS, Size: 29, Number: 61448
. 2011-03-01 13:42:53.041 Storing reserved response
< 2011-03-01 13:42:53.232 Status code: 1
. 2011-03-01 13:42:53.232 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:53.232 Type: SSH_FXP_CLOSE, Size: 10, Number: 62212
. 2011-03-01 13:42:53.234 File: "/Download/00669-110203-0128-PARALLEL.zip"
. 2011-03-01 13:42:53.234 Copying "/Download/00669-110203-0128-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:53.235 Binary transfer mode selected.
. 2011-03-01 13:42:53.235 Confirming overwriting of file.
. 2011-03-01 13:42:53.235 Opening remote file.
> 2011-03-01 13:42:53.235 Type: SSH_FXP_OPEN, Size: 57, Number: 62467
< 2011-03-01 13:42:53.323 Type: SSH_FXP_STATUS, Size: 21, Number: 62212
. 2011-03-01 13:42:53.323 Discarding reserved response
< 2011-03-01 13:42:53.414 Type: SSH_FXP_HANDLE, Size: 10, Number: 62467
> 2011-03-01 13:42:53.414 Type: SSH_FXP_FSTAT, Size: 10, Number: 62728
> 2011-03-01 13:42:53.414 Type: SSH_FXP_READ, Size: 22, Number: 62981
< 2011-03-01 13:42:53.515 Type: SSH_FXP_ATTRS, Size: 29, Number: 62728
. 2011-03-01 13:42:53.515 Storing reserved response
< 2011-03-01 13:42:53.745 Status code: 1
. 2011-03-01 13:42:53.745 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:53.745 Type: SSH_FXP_CLOSE, Size: 10, Number: 63492
. 2011-03-01 13:42:53.747 File: "/Download/00669-110203-0205-PARALLEL.zip"
. 2011-03-01 13:42:53.747 Copying "/Download/00669-110203-0205-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:53.748 Binary transfer mode selected.
. 2011-03-01 13:42:53.761 Confirming overwriting of file.
. 2011-03-01 13:42:53.762 Opening remote file.
> 2011-03-01 13:42:53.762 Type: SSH_FXP_OPEN, Size: 57, Number: 63747
< 2011-03-01 13:42:53.875 Type: SSH_FXP_STATUS, Size: 21, Number: 63492
. 2011-03-01 13:42:53.875 Discarding reserved response
< 2011-03-01 13:42:53.982 Type: SSH_FXP_HANDLE, Size: 10, Number: 63747
> 2011-03-01 13:42:53.983 Type: SSH_FXP_FSTAT, Size: 10, Number: 64008
> 2011-03-01 13:42:53.983 Type: SSH_FXP_READ, Size: 22, Number: 64261
< 2011-03-01 13:42:54.126 Type: SSH_FXP_ATTRS, Size: 29, Number: 64008
. 2011-03-01 13:42:54.127 Storing reserved response
< 2011-03-01 13:42:54.418 Status code: 1
. 2011-03-01 13:42:54.419 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:54.419 Type: SSH_FXP_CLOSE, Size: 10, Number: 64772
. 2011-03-01 13:42:54.420 File: "/Download/00669-110203-0312-PARALLEL.zip"
. 2011-03-01 13:42:54.420 Copying "/Download/00669-110203-0312-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:54.421 Binary transfer mode selected.
. 2011-03-01 13:42:54.432 Confirming overwriting of file.
. 2011-03-01 13:42:54.433 Opening remote file.
> 2011-03-01 13:42:54.433 Type: SSH_FXP_OPEN, Size: 57, Number: 65027
< 2011-03-01 13:42:54.514 Type: SSH_FXP_STATUS, Size: 21, Number: 64772
. 2011-03-01 13:42:54.514 Discarding reserved response
< 2011-03-01 13:42:54.611 Type: SSH_FXP_HANDLE, Size: 10, Number: 65027
> 2011-03-01 13:42:54.611 Type: SSH_FXP_FSTAT, Size: 10, Number: 65288
> 2011-03-01 13:42:54.611 Type: SSH_FXP_READ, Size: 22, Number: 65541
< 2011-03-01 13:42:54.715 Type: SSH_FXP_ATTRS, Size: 29, Number: 65288
. 2011-03-01 13:42:54.715 Storing reserved response
< 2011-03-01 13:42:54.947 Status code: 1
. 2011-03-01 13:42:54.947 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:54.947 Type: SSH_FXP_CLOSE, Size: 10, Number: 66052
. 2011-03-01 13:42:54.948 File: "/Download/00669-110203-0621-PARALLEL.zip"
. 2011-03-01 13:42:54.949 Copying "/Download/00669-110203-0621-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:54.949 Binary transfer mode selected.
. 2011-03-01 13:42:54.951 Confirming overwriting of file.
. 2011-03-01 13:42:54.951 Opening remote file.
> 2011-03-01 13:42:54.951 Type: SSH_FXP_OPEN, Size: 57, Number: 66307
< 2011-03-01 13:42:55.053 Type: SSH_FXP_STATUS, Size: 21, Number: 66052
. 2011-03-01 13:42:55.053 Discarding reserved response
< 2011-03-01 13:42:55.161 Type: SSH_FXP_HANDLE, Size: 10, Number: 66307
> 2011-03-01 13:42:55.161 Type: SSH_FXP_FSTAT, Size: 10, Number: 66568
> 2011-03-01 13:42:55.161 Type: SSH_FXP_READ, Size: 22, Number: 66821
< 2011-03-01 13:42:55.267 Type: SSH_FXP_ATTRS, Size: 29, Number: 66568
. 2011-03-01 13:42:55.267 Storing reserved response
< 2011-03-01 13:42:55.466 Status code: 1
. 2011-03-01 13:42:55.466 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:55.466 Type: SSH_FXP_CLOSE, Size: 10, Number: 67332
. 2011-03-01 13:42:55.467 File: "/Download/00669-110203-0652-PARALLEL.zip"
. 2011-03-01 13:42:55.468 Copying "/Download/00669-110203-0652-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:55.468 Binary transfer mode selected.
. 2011-03-01 13:42:55.478 Confirming overwriting of file.
. 2011-03-01 13:42:55.478 Opening remote file.
> 2011-03-01 13:42:55.479 Type: SSH_FXP_OPEN, Size: 57, Number: 67587
< 2011-03-01 13:42:55.593 Type: SSH_FXP_STATUS, Size: 21, Number: 67332
. 2011-03-01 13:42:55.593 Discarding reserved response
< 2011-03-01 13:42:55.707 Type: SSH_FXP_HANDLE, Size: 10, Number: 67587
> 2011-03-01 13:42:55.708 Type: SSH_FXP_FSTAT, Size: 10, Number: 67848
> 2011-03-01 13:42:55.708 Type: SSH_FXP_READ, Size: 22, Number: 68101
< 2011-03-01 13:42:55.813 Type: SSH_FXP_ATTRS, Size: 29, Number: 67848
. 2011-03-01 13:42:55.813 Storing reserved response
< 2011-03-01 13:42:56.059 Status code: 1
. 2011-03-01 13:42:56.059 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:56.059 Type: SSH_FXP_CLOSE, Size: 10, Number: 68612
. 2011-03-01 13:42:56.061 File: "/Download/00669-110203-0754-PARALLEL.zip"
. 2011-03-01 13:42:56.061 Copying "/Download/00669-110203-0754-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:56.062 Binary transfer mode selected.
. 2011-03-01 13:42:56.075 Confirming overwriting of file.
. 2011-03-01 13:42:56.076 Opening remote file.
> 2011-03-01 13:42:56.076 Type: SSH_FXP_OPEN, Size: 57, Number: 68867
< 2011-03-01 13:42:56.156 Type: SSH_FXP_STATUS, Size: 21, Number: 68612
. 2011-03-01 13:42:56.156 Discarding reserved response
< 2011-03-01 13:42:56.256 Type: SSH_FXP_HANDLE, Size: 10, Number: 68867
> 2011-03-01 13:42:56.256 Type: SSH_FXP_FSTAT, Size: 10, Number: 69128
> 2011-03-01 13:42:56.256 Type: SSH_FXP_READ, Size: 22, Number: 69381
< 2011-03-01 13:42:56.349 Type: SSH_FXP_ATTRS, Size: 29, Number: 69128
. 2011-03-01 13:42:56.349 Storing reserved response
< 2011-03-01 13:42:56.577 Status code: 1
. 2011-03-01 13:42:56.577 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:56.577 Type: SSH_FXP_CLOSE, Size: 10, Number: 69892
. 2011-03-01 13:42:56.578 File: "/Download/00669-110203-0833-PARALLEL.zip"
. 2011-03-01 13:42:56.579 Copying "/Download/00669-110203-0833-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:56.579 Binary transfer mode selected.
. 2011-03-01 13:42:56.594 Confirming overwriting of file.
. 2011-03-01 13:42:56.595 Opening remote file.
> 2011-03-01 13:42:56.595 Type: SSH_FXP_OPEN, Size: 57, Number: 70147
< 2011-03-01 13:42:56.724 Type: SSH_FXP_STATUS, Size: 21, Number: 69892
. 2011-03-01 13:42:56.724 Discarding reserved response
< 2011-03-01 13:42:56.835 Type: SSH_FXP_HANDLE, Size: 10, Number: 70147
> 2011-03-01 13:42:56.835 Type: SSH_FXP_FSTAT, Size: 10, Number: 70408
> 2011-03-01 13:42:56.835 Type: SSH_FXP_READ, Size: 22, Number: 70661
< 2011-03-01 13:42:56.945 Type: SSH_FXP_ATTRS, Size: 29, Number: 70408
. 2011-03-01 13:42:56.945 Storing reserved response
< 2011-03-01 13:42:57.196 Status code: 1
. 2011-03-01 13:42:57.196 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:57.196 Type: SSH_FXP_CLOSE, Size: 10, Number: 71172
. 2011-03-01 13:42:57.198 File: "/Download/00669-110203-0919-PARALLEL.zip"
. 2011-03-01 13:42:57.198 Copying "/Download/00669-110203-0919-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:57.199 Binary transfer mode selected.
. 2011-03-01 13:42:57.207 Confirming overwriting of file.
. 2011-03-01 13:42:57.207 Opening remote file.
> 2011-03-01 13:42:57.207 Type: SSH_FXP_OPEN, Size: 57, Number: 71427
< 2011-03-01 13:42:57.313 Type: SSH_FXP_STATUS, Size: 21, Number: 71172
. 2011-03-01 13:42:57.313 Discarding reserved response
< 2011-03-01 13:42:57.415 Type: SSH_FXP_HANDLE, Size: 10, Number: 71427
> 2011-03-01 13:42:57.415 Type: SSH_FXP_FSTAT, Size: 10, Number: 71688
> 2011-03-01 13:42:57.415 Type: SSH_FXP_READ, Size: 22, Number: 71941
< 2011-03-01 13:42:57.512 Type: SSH_FXP_ATTRS, Size: 29, Number: 71688
. 2011-03-01 13:42:57.512 Storing reserved response
< 2011-03-01 13:42:57.701 Status code: 1
. 2011-03-01 13:42:57.701 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:57.701 Type: SSH_FXP_CLOSE, Size: 10, Number: 72452
. 2011-03-01 13:42:57.702 File: "/Download/00669-110203-1020-PARALLEL.zip"
. 2011-03-01 13:42:57.702 Copying "/Download/00669-110203-1020-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:57.703 Binary transfer mode selected.
. 2011-03-01 13:42:57.716 Confirming overwriting of file.
. 2011-03-01 13:42:57.716 Opening remote file.
> 2011-03-01 13:42:57.716 Type: SSH_FXP_OPEN, Size: 57, Number: 72707
< 2011-03-01 13:42:57.795 Type: SSH_FXP_STATUS, Size: 21, Number: 72452
. 2011-03-01 13:42:57.795 Discarding reserved response
< 2011-03-01 13:42:57.888 Type: SSH_FXP_HANDLE, Size: 10, Number: 72707
> 2011-03-01 13:42:57.888 Type: SSH_FXP_FSTAT, Size: 10, Number: 72968
> 2011-03-01 13:42:57.888 Type: SSH_FXP_READ, Size: 22, Number: 73221
< 2011-03-01 13:42:58.021 Type: SSH_FXP_ATTRS, Size: 29, Number: 72968
. 2011-03-01 13:42:58.021 Storing reserved response
< 2011-03-01 13:42:58.475 Status code: 1
. 2011-03-01 13:42:58.475 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:58.475 Type: SSH_FXP_CLOSE, Size: 10, Number: 73732
. 2011-03-01 13:42:58.477 File: "/Download/00669-110203-1107-PARALLEL.zip"
. 2011-03-01 13:42:58.477 Copying "/Download/00669-110203-1107-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:58.478 Binary transfer mode selected.
. 2011-03-01 13:42:58.478 Confirming overwriting of file.
. 2011-03-01 13:42:58.478 Opening remote file.
> 2011-03-01 13:42:58.478 Type: SSH_FXP_OPEN, Size: 57, Number: 73987
< 2011-03-01 13:42:58.587 Type: SSH_FXP_STATUS, Size: 21, Number: 73732
. 2011-03-01 13:42:58.588 Discarding reserved response
< 2011-03-01 13:42:58.691 Type: SSH_FXP_HANDLE, Size: 10, Number: 73987
> 2011-03-01 13:42:58.691 Type: SSH_FXP_FSTAT, Size: 10, Number: 74248
> 2011-03-01 13:42:58.691 Type: SSH_FXP_READ, Size: 22, Number: 74501
< 2011-03-01 13:42:58.797 Type: SSH_FXP_ATTRS, Size: 29, Number: 74248
. 2011-03-01 13:42:58.797 Storing reserved response
< 2011-03-01 13:42:59.044 Status code: 1
. 2011-03-01 13:42:59.044 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-03-01 13:42:59.044 Type: SSH_FXP_CLOSE, Size: 10, Number: 75012
. 2011-03-01 13:42:59.047 File: "/Download/00669-110203-1129-PARALLEL.zip"
. 2011-03-01 13:42:59.047 Copying "/Download/00669-110203-1129-PARALLEL.zip" to local directory started.
. 2011-03-01 13:42:59.047 Binary transfer mode selected.
. 2011-03-01 13:42:59.109 Checking existence of partially transfered file.
. 2011-03-01 13:42:59.109 Confirming overwriting of file.
. 2011-03-01 13:42:59.110 Opening remote file.
> 2011-03-01 13:42:59.110 Type: SSH_FXP_OPEN, Size: 57, Number: 75267
< 2011-03-01 13:42:59.140 Type: SS
Can you email me a complete logs? They got truncated in the post.
flipman619
Log files have been emailed to you.
Thanks again.
flipman619
Thanks again.
Any update on this? Is there any patches I can test?
itgeek
Let me start out by saying that WinSCP is awesome! Been a user for years and really appreciate the work that is put into it.
But, I am also experiencing the error message "Error Code: 2 Request Code: 3 File not found" on the 101st file when using the synchronize function. This error is encountered with both the command line(synchronize local localpath remotepath)and through the gui, I will e-mail a copy of the full log file.
- Occurs on WinSCP version 4.3.3 Build 1340 and 4.2.9 Build 938
- WinSCP client installed on Windows 7 x64 and Windows Server 2003 x32
- Error encountered through command line and gui
- Server/Protocol Info:
Session protocol = SSH-2
SSH implementation = 1.36_sshlib GlobalSCAPE
Encryption algorithm = aes
Compression = No
File transfer protocol = SFTP-3
- The error is reproducible every time via the command line or gui. Any time a synchronization occurs and there are more than 100 new files on the remote server the 101st file generates the error. If you run another synchronization immediately following the failed sync the remaining files will be transferred unless there is more than 100 files remaining.
Appreciate any assistance and I would be glad to provide more information if I needed. Thanks!
flipman619 wrote:
Thanks again.
For benefit of the others. Apparently this version GlobalSCAPE suppers a bug in batch transfers. While with individual downloading, the server always succeeds, in batch download the servers fails to open the 101th file, despite WinSCP using exactly the same request in both cases. The problem is reproducible even using other SFTP clients.
