Topic "Custom Command Greyed Out"
epitome
Version: 4.3.2 (1201)
OS: Windows 7 SP1
Protocol: FTP Explicit TLS
GUI version
I'm looking to set up a couple of simple custom commands to allow users to easily upload images to a folder on a FTP server. Just for testing, I've tried implementing a simple remote command like "cd /this/directory", but the command appears as a greyed-out button after I add it.
Screenshots:
What could be getting in the way of allowing this command to execute? I noticed a similar post (http://efreedom.com/Question/3-260858/Remote-WinSCP-Commands-Showing) where the user mentioned that he had to use SFTP instead of FTP. Is this a cause?
Thank you in advance for any assistance!
Custom commands are supported with SCP (and indirectly with SFTP) only.
Anyway, you cannot implement custom command for upload.
epitome
Thanks for your response!
