Topic "Moving and deleting contents of subdirectories"
ozdemircili
I have a server that has multiple folders and each folder has its own files inside them.
I would like to use Synchronize function with delete option.
The problem is when I synchronize the files winscp deletes all folders and files inside them.
Is there any way to keep the folders and delete only the files inside them after synchronizing?
Thanks in advance.
There's no way.
Btw, I suppose the folders do not exist localy, right?
ozdemircili
prikryl wrote:
There's no way.
Actually they will be existing in time. For the 1st time sync I will have 150 folders prepared and from then on Ill have to look inside every folder in remote if there is any change and move it inside the same directory that I have in local.
So do you want to delete local or remote empty folders?
