Topic "How to set session defaults, like Compression, in winscp.ini"
ciove
Hi all,
I needed to set compression on for all sessions. Here's how I did it. You can propably use this all other session-spesific items too.
    * Set the Configuration Storage to winscp.ini and open it (located in the same folder as winscp.exe and winscp.com).
    * Search for "[Sessions\Default%20Settings]" -section in winscp.ini. If you don't find it, create it.
    * Add Compression=1 -line to "[Sessions\Default%20Settings]" -section.
    * Save and close winscp.ini.
    Compression=1
I've tested this with these scenarios:
    * Protocol: SFTP, Server-side has compression off ("Compression no" in sshd_config). No effect, i.e. no compression.
    * Protocol: SFTP, Server-side has compression on ("Compression yes" in sshd_config). Desired effect, i.e. file is compressed during transfer. Works both with session URL and stored sessions.
    * Protocol: FTPs. No effect.
    * Protocol: FTP. No effect.
I digged this info from these articles:
