This guide contains a simplified description of automating operations on FTP/SFTP server with WinSCP. You may want to see detailed documentation of the scripting functionality instead.
There is also WinSCP .NET assembly built on top of the scripting interface. If you plan to call WinSCP from your .NET code or PowerShell, or if your task requires conditional processing, loops or other control structures, you should better use the .NET assembly. This guide focuses on simple automation tasks using scripting interface only.
Before Starting
Before starting you should:
Commands
For example a typical script to upload a file is:
# Connect to SFTP server using a password
open sftp://user:password@example.com/ -hostkey="ssh-rsa 2048 xxxxxxxxxxx..."
# Upload file
put d:\examplefile.txt /home/user/
# Exit WinSCP
Script file
Use the /script command line option to pass the script to the WinSCP executable. Generally, you should also use /ini=nul switch to isolate the script execution from GUI configuration and /log= switch to enable session logging. You can embed the complete command line into a Windows batch file (.bat), like as follows:
@echo off
winscp.com /ini=nul /log=myscript.log /script=myscript.txt
Generating script
You can have WinSCP generate a script template for you or even a complete batch file.
To generate a script for a file transfer:
/log=D:\test\winscp.log Option Echo off option batch on option confirm off open SFTP:SASNB:Welcome123476*@sftypprd1 #Change LOCAL directory lcd “L:\SNBUAESwift\pull\” lcd “L:\SNBUAESwift\pull\”
#copy an individual file
put -nopermissions -nopreservetime “L:\SNBUAESwift\pull\.*rje”
Notes
When connecting to the SSH host, you will need to accept its host key.
When connecting to FTPS or WebDAVS host with certificate signed by an untrusted authority you will need to verify the certificate.
open mysession
put %1%
winscp.com /ini=nul /log=script.log /script=script.tmp /parameter // c:\myfile.txt
rem Generate a temporary script to upload %1
  echo open mysession
  echo put %1
  echo exit
) > script.tmp
rem Execute the script
rem Delete the temporary script
del script.tmp
upload.bat c:\myfile.txt
See more hints on using parametrized batch file.
See Conditional processing in automation for a more complex example; and Advanced FTP/SFTP scripting for examples of script generation using more powerful languages.
Checking script results
  • Save and inspect log file. XML log format is recommended. Use command-line parameter /xmllog.
Once you find out what was the result of the script, you can perform any action you like: print a message, send an email, etc.
You should also make the batch file indicate a result in its exit code, particularly if it is called from some parent system (for example SSIS).
See an example batch file:
winscp.com /ini=nul /log=example.log /script=example.txt
if %ERRORLEVEL% equ 0 (
  echo Success
  exit /b 0
) else (
  echo Error!
  exit /b 1
A similar error handling is used in the batch file template that WinSCP can generate for you.
If you require checking results of each command individually, you should better use the WinSCP .NET assembly. Alternatively, see the guide Advanced FTP/SFTP scripting for examples of checking script results (including XML log parsing) using more powerful languages and the guide to Interpreting XML log for advanced scripting using C# language.//
Example
Further reading
Last modified: by 83.111.180.100
