Topic "WinSCP "freeze" when copy to mapped network drive"
crossgate
we using WinSCP on a Windows Terminal Serve 2008 R2 (x64), when we transfer files from remote Server to a mapped network drive, WinSCP looks like "freeze" befor attempt to diplay the "Copy" Windows.
WinSCP needs approx. 2-5 Min. untill copy the file.
This only happen to mapped drives. Transfering files to local disk on Windows Terminal Server 2008 R2 works fine.
We checked:
- that on a Windows 2003 Terminal Server (32Bit) the "issue" doesn`t happen.
- Transfering from Windows Server 2008 to Windows Server 2008 mapped drives still same "issue"
- Used diffrent version of WinSCP (4.1.9 and 4.3.4 and alos Beta 5), in every Version the same "issue"
Do you know about that?
Is there a bug?
What would you recommend?
Thanks!
crossgate
We checked:
Is there a bug?
Thanks!
I'm now registered!
crossgate
What I checked further:
- I also used the portable Version of WinSCP on W2k8 R2 NOT via RDP Session only on Console - same "issue".
- Used latest WinSCP Version on Windoes 7 x64 Client - same "issue" when transfering files to mapped drives.
Thanks!
I have sent you an email.
crossgate
I answer you via email with the debug output.
Tordek
I'm facing the same problems as crossgate, at a customer. Problem started to occur after migrating them to new servers.
In the old situation they would store their data on a local drive on the terminal server (2008R2). In the new situation (2008R2 TS also) their data folder has become a mapped drive.
Problem only occurs when drag and dropping from remote to mapped drive.
As workaround they use F5 or right-mouse-click -> copy which brings up the copy dialog immediately.
WinSCP v4.3.5.
WinSCP v4.3.5.
Thanks for your post. I'll contact you soon on your email address.
Harikishore
Hi
I am facing a issue with the winscp i am using windows server 2008 R2 64bit at one end and 2003 R2 32 bit at the other end i want to transfer the files from 2008 to 2003 server i am able to connect using SFTP mode but i could not paste any files in the 2003 server it says permission denided.I have tried installing some different version of winscp like
(4.1.9 and 4.3.4 and alos Beta 5), in every Version the same "issue" any help would be appreciated .
my mail ID is Harikishore.tr@homail.com
Tech NO Babble
Thanks Tordek! I am glad to have a work around. I am using Windows Server 08r2 and Windows 7 Pro SP1 64bit.
Now that I know I can F5 or right click and no delays, I am a happy user again.
