Topic "Help with scripting (use of variables and download)"
TerryP
WinSCP Version: 4.3.5, Build 1463
Windows version: XP SP3
Transfer Protocol: SFTP (SCP)
Method: Scripting Automation (command line)
Question(s): I am brand new to WinSCP and want to automate a download from each of 500 folders on the server. Is there a way to use variables within WinSCP (no Java/VB/etc.) so I can do a move and rename? Example: I'm downloading files from folder \Project\User and I want to rename the files with <User> as a prefix. So file 100.txt would become BillyB100.txt, file 101.txt becomes BillyB101.txt and so on. I'd like to use a common incoming data folder and eliminate the respective user folders (see below).
Or if the only way to do this is with Java, can anyone provide some sample code? I don't know what exactly can be loaded (or how long it would take to clear) because it is a secured computer.
The script text I have is a long one - each folder is represented - so I won't post the whole thing here. Currently, I am doing a get and then handling the rename on the PC side.
Command line: "c:\program files\WinSCP\WinSCP.com" /script=C:\MyScript.txt /log=C:\SCPTest\MyLog.txt
Contents of MyScript:
# Automatically abort script on errors
option batch on
# Connect using a password
# Connect
open daemon@Site.company.com
# Force binary mode transfer
option transfer binary
# Change remote directory and Download files
get /Distribution/Project/BillyB/*.* C:\IncomingData\BillyB\
get /Distribution/Project/BillyC/*.* C:\IncomingData\BillyC\
get /Distribution/Project/BobbyA/*.* C:\IncomingData\BobbyA\
get /Distribution/Project/BobbyB/*.* C:\IncomingData\bobbyB\
get /Distribution/Project/JackieA/*.* C:\IncomingData\JackieA\
get /Distribution/Project/JackieB/*.* C:\IncomingData\JackieB\
get /Distribution/Project/Warren/*.* C:\IncomingData\Warren\
get /Distribution/Project/Zeke/*.* C:\IncomingData\Zeke\
# Disconnect
close
# Exit WinSCP
Terry
You cannot do with without some programming.
These articles may give you some idea:
http://winscp.net/eng/docs/guide_interpreting_xml_log
http://winscp.net/eng/docs/script_download_timestamped_filename
