Topic "powershell connection to sftp via WinSCP"
clt
Hi, thank you for Winscp!
I'm trying to make script in powershell to download and upload files to sftp server. It works well, but I need to check if the folder where I want to upload files is empty. Next thing I need to make is compare the length of files transfered to sftp with files on my local disc. I'm using
if (@(Compare-Object $files_sftp $files_local -SyncWindow 0).Length -eq 0) {
Write-Host "OK" }
else { Write-Host "NOT ok" }
So I need to get content of remote directory with powershell command Get-Childitem to variable $files_sftp or some general advice how to connect winscp scipting with powershell.
Thank you very much!
I do not know powershell (though we would like to add powershell example eventually). But you definitelly need to make use of Session.ListDirectory method:
http://winscp.net/eng/docs/library_session_listdirectory
Basic PowerShell example added
http://winscp.net/eng/docs/library#powershell
More examples (and syntax highlighting) coming soon.
