Topic "Saving last selected "Local directory" relative to the path"
p-vad
When synchronize several subfolders of sites - everytime we need to select appropriate path in the "Local directory" history.
The same with the "Keep remote directory up to date".
Why not to save last selected "Local directory" relative to the current remote path
You can make a location profile for that.
http://winscp.net/eng/docs/ui_locationprofile
Or even desktop shortcut
http://winscp.net/eng/docs/commandline#operations
p-vad
Desktop shortcuts is a good solution, but not very convenient.
Location profiles works only in Commander interface. It has no problem: on opening synchronize dialog the current local folder already selected.
But I use "Explorer" interface, a feature offered only for him.
Ok, this request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=919
