Topic "SSL host certificate fingerprint Does Not Match"
nuronce
C#.NET 4.0 WinSCP 5.1
When I use the GUI in the registry it creates:
FSProtocol 5
Ftps 1
PortNumber 990
FtpsCertificates: e6:a3:7a:56:5b:e3:bb:0d:1c:34:58:bd:47:94:79:75:32:2b:70:4d
And works fine
When I run in code I get:
SSL host certificate fingerprint "ssh-rsa 1024 e6:a3:7a:56:5b:e3:bb:0d:1c:34:58:bd:47:94:79:75:32:2b:70:4d" does not match pattern /([0-9a-f]{2}Smile{19}[0-9a-f]{2}/
for:
                    Protocol = WinSCP.Protocol.Ftp,
                    FtpMode = FtpMode.Passive,
                    FtpSecure = FtpSecure.Implicit,
                    PortNumber = 990,
                    UserName = "--------",
                    Password = "--------",
                    HostName = "ftp.----.com",
                    SslHostCertificateFingerprint = "ssh-rsa 1024 e6:a3:7a:56:5b:e3:bb:0d:1c:34:58:bd:47:94:79:75:32:2b:70:4d"
I get:
SSH host key fingerprint "ssh-rsa 1024 e6:a3:7a:56:5b:e3:bb:0d:1c:34:58:bd:47:94:79:75:32:2b:70:4d" does not match pattern /(ssh-rsa |ssh-dss )?\d+ ([0-9a-f]{2}Smile{15}[0-9a-f]{2}/
for:
                    PortNumber = 990,
                    SshHostKeyFingerprint = "ssh-rsa 1024 e6:a3:7a:56:5b:e3:bb:0d:1c:34:58:bd:47:94:79:75:32:2b:70:4d"
What am I doing wrong? I could not find anything in the docs.
nuronce
PortNumber = 990,
UserName = "----",
Password = "----",
HostName = "ftp.-----.com",
SslHostCertificateFingerprint = "e6:a3:7a:56:5b:e3:bb:0d:1c:34:58:bd:47:94:79:75:32:2b:70:4d"
The code in the second post looks good. What's wrong with that? Or was that a resolution?
nuronce
Was Resolution Mr. Green
Themistocles
Hey Prikryl,
For me adding the "ssh-rsa 2048" to the beginning of the string I assign to SshHostKeyFingerprint doesn't make the regex exception go away.
I can connect to the host with the UI, and also had some initial success using the scripting engine. I haven't been able to connect after that first time.
Now I am using the .Net library (Version 1.2.8.5316) in a .Net 4 console app. My OS is Win7 Pro.
Here is my SessionOptions:
   FtpMode = WinSCP.FtpMode.Passive,
   PortNumber = 21,
   FtpSecure = FtpSecure.Explicit,
   HostName = "162.253.127.64",
   SshHostKeyFingerprint = "ssh-rsa 2048 e7:d5:b0:a4:6f:24:7f:15:5c:c1:ae:b9:43:c1:86:95:7e:97:35:85"
When I run it, I get:
System.ArgumentException was caught
HResult=-2147024809
Message=SSH host key fingerprint "ssh-rsa 2048 e7:d5:b0:a4:6f:24:7f:15:5c:c1:ae:b9:43:c1:86:95:7e:97:35:85" does not match pattern /((ssh-rsa|ssh-dss)( |-))?(\d+ )?([0-9a-f]{2}(Neutral-)){15}[0-9a-f]{2}(;((ssh-rsa|ssh-dss)( |-))?(\d+ )?([0-9a-f]{2}(Neutral-)){15}[0-9a-f]{2})*/
Source=WinSCPnet
StackTrace:
at WinSCP.SessionOptions.SetSshHostKeyFingerprint(String s)
at WinSCP.SessionOptions.set_SshHostKeyFingerprint(String value)
at Program.Main(String[] args) in C:\Users\Me\Documents\Visual Studio 2010\Projects\WinScpTool\Program.cs:line 16
I am confused about the regex above. Both my fingerprint and the original question have 20 pairs of hex numbers, but the regex only matches 15. I am surprised that this is expected to work.
Can you comment on the regex? Am I reading it wrong?
thanks
SD
You are setting SshHostKeyFingerprint, but you are using FTP over TLS, not SSH. You need to set TlsHostCertificateFingerprint.
How did this work if there is no property for SslHostCertificateFingerprint?
PortNumber = 990,
UserName = "----",
Password = "----",
The SslHostCertificateFingerprint was renamed to TlsHostCertificateFingerprint.
See http://winscp.net/eng/docs/library_sessionoptions
Code_Mechanic
That makes sense thanks for the update.
