Topic "Permission change without checked option"
Mikol
I have an issue with permissions for file uploaded to my server. I don't want permissions to be set by WinSCP (change permission checkbox not checked in transfer settings) but after file creation or file upload, WinSCP set permissions with permissions defined in the transfer dialog properties.
Example: I open transfer settings, check change permission, set rwxrwx---, uncheck change permission, I create a file, the new file has rwxrwx--- permissions. I open transfert settings, check change permission, set ---------, uncheck change permission, I create a file, the new file has --------- permissions.
I'm using the last WinSCP version (5.1.0) but my issue was already there with the 4.3.9 version.
I'm using Windows 7 Pro in 32b, with SCP protocol in GUI explorer mode.
Regards,
Mickael
How do you create the file? Creating local file and uploading it or using Files > New > File command?
Please attach a full log file showing the problem.
Mikol
thanks for your answer.
Please find attached, log file with detailed information.
I made server connect, file "fichier_test" creation (with the popup menu, new and file), and the result is "---------" permissions with the change permission unchecked.
Mickael.
fichier_test creation.log (152.23 KB) [Download]
Description: (none)
WinSCP correctly did not use the -p switch of scp, so your server should not set the permissions.
scp -r  -d -t "/home/lacostem/test_winscp"
