Topic "Resources fail to update after transfer...."
HAYESBNYM
I transfer resources from XP to a Xerox Unix controller. I see the resource time-stamps change (in the case of copy/replaces) and I see new resources add to the catalog. I can even copy resources back from the target folder to XP and verify the file. However, when I look for the updated resources on the Unix controller, I see the old versions or in the case of new resources, I see none. I know that this is not just a view issue from the controller, because the old resources are being acquired dynamically for print. I've been using SCP, but might try SFTP, however I'm puzzled as to where the files exist if not in the target path, and how do I get the unix box to update? Thanks - Dave Haves
I'm not really sure I understand your problem
Though this FAQ may be somewhat related:
http://winscp.net/eng/docs/faq_web_cache
