Topic "How to Put the date & time format files into SFTP server?"
limitha
I am doing SFTP task in SSIS.
i am using the following script.
option batch abort
# Connect using a password
# open sftp://MPesa:OXIVMP@123@Mysftpserver:22
# Connect
open sftp://MPesa:OXIVMP@123@MySftpserver:22
# Change remote directory
cd /MPesa/
# Force binary mode transfer
option transfer binary
# Download file to the local directory d:\
put D:\SCW_Reports\Oxigen.txt
# Disconnect
close
The above code working fine.
How to put the Oxigen_03052013.txt format files.
Best would be to use WinSCP .NET assembly.
http://winscp.net/eng/docs/library
Or follow this guide:
http://winscp.net/eng/docs/script_download_timestamped_filename
limitha
// Local path to download to (keep trailing slash)
var LOCALPATH = "\\D:\SCW_Reports";
// Remote path to download from (keep trailing slash)
var REMOTEPATH = "/cd/MPesa";
// File to download
var FILE = "winscp421.exe";
// Session to connect to
var SESSION = "MPesa@OXIVMP@123@127.10.16.223";
// Path to winscp.com
var WINSCP = "C:\Program Files (x86)\WinSCP\WinSCP.com";
// helper function to pad zeroes to the left of number
function pad(n, len)
var s = n.toString();
while (s.length < len)
s = '0' + s;
return s;
var date = new Date();
// format timestamp
var stamp =
pad(date.getFullYear(), 4) +
pad(date.getMonth(), 2) +
pad(date.getDate(), 2) ;
var shell = WScript.CreateObject("WScript.Shell");
// run winscp to download the file into timestamped-filename
exec = shell.Exec("\"" + WINSCP + "\"");
exec.StdIn.Write(
"option batch abort\n" +
"open \"" + SESSION + "\"\n" +
"Put \"" + REMOTEPATH + FILE + "\" \"" + LOCALPATH + FILE + "." + stamp + "\"\n" +
"exit\n");
// wait until the script finishes
while (exec.Status == 0)
WScript.Sleep(100);
WScript.Echo(exec.StdOut.ReadAll());
I ran the above scrpt , output was not showing.
limitha
Error Code: 0 Error Source= Microsoft JScript runtime error Error Description: 'WScript' is undefined Error on Line 30.[/size]
// File to download
s = '0' + s;
return s;
// format timestamp
var stamp =
exec.StdIn.Write(
"exit\n");
WScript.Sleep(100);
How are you running the script?
limitha
I ran the script through SQL agent.
Ok, can you be more specific? Like command-line you used. Do you use wscript or cscript or somethine else?
cdmiss
Hi
I am searching the location/path/file where private keys are stored in sFTP. I mean the private key of encrypted packages.
Does anyone know how i can find some kind of information like this
Thanks a lot
