Topic "Are transfer presets working in WinSCP.comcommand line mode?"
I am using from a DOS command line prompt, and WinSCP wants to put *.cgi to the server in binary mode. I have tried to turn on the Text preset (transfer mode to automatic, selection rule host name *), but that does not work? Do those settings apply to the interface?
could not get the presets to work -- but when I changed the default to automatic, that works.
Presets cannot be used in scripting. But as you want to change transfer mode only, you do not need presets at all. Just use -transfer switch:
