Cannot find C: drive in WinSCP
sriharsha
Plymouth, USA
We have to extract a file from C drive & post it on to a specified directory,
The specified directory comes up, but I cant make C drive come up.
Can you pls help
See the attachment for more info
Re: Cannot find C drive in winscp
You are using Explorer interface of WinSCP. In Explorer interface, you can only see a remove directory. To upload a file, you need to drag it from Windows Explorer and drop it onto WinSCP window.
You may want to switch to Commander interface, when you can see both local and remote directory, side by side.
To learn about WinSCP interaces, see:
https://winscp.net/eng/docs/interfaces
