Topic "VBA using session.MoveFile"
egray
I am using VBA within Access to upload a file to SFtp which works fine.
I need to rename the file on the SFtp site is that possible using the VBA methods?
I keep getting "Object required" below is the code:
Private Sub Upload(ByRef mySession As Session)
' Setup session options
Dim mySessionOptions As New SessionOptions
With mySessionOptions
.Protocol = Protocol_Sftp
.HostName = "ftp.xxxxxxxxxxxxxx.net"
.UserName = "xxxxxxx"
.Password = "xxxxxxxx"
.SshHostKey = "ssh-dss 1024 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
End With
' Get file name
Dim strFile As String
strFile = Dir("\\xxx.xxx.1.3\Corp\IT\scripts\Credit\SendTest\*.u01")
' Connect
mySession.DisableVersioncheck = True
mySession.Open mySessionOptions
' Upload files
Dim myTransferOptions As New TransferOptions
myTransferOptions.TransferMode = TransferMode_Binary
Dim myMoveResult As SessionRemoteException
Set transferResult = mySession.PutFiles("\\xxx.xxx.1.3\Corp\IT\scripts\Credit\SendTest\" & strFile & "", strFile, False, myTransferOptions)
'GET ERROR HERE***********************************************************
Set myMoveResult = mySession.MoveFile(strFile, "cz311660.r01")
' Throw on any error
transferResult.Check
' Display results
Dim intSuccess As Integer
Dim transfer As TransferEventArgs
For Each transfer In transferResult.Transfers
MsgBox "Upload of " & transfer.FileName & " succeeded!"
intSuccess = 1
Next
If intSuccess <> 1 Then
Err.Raise 999, , "Failed to upload file!"
'MsgBox "File did not send properly."
End If
End Sub
On what line do you get the "Object required"?
Davis
I encountered the same Error : Object required : 'MoveFile(...'
Using WinSCP 5.5.6 , VBScripts "MovefileError.vbs". The scripts as below.
The Error occured at 'Line: 20'. The file was renamed from examplefile.txt to newexamplefile.txt successfully.
__________________________________________________________________________________________
Dim sessionOptions
Set sessionOptions = WScript.CreateObject("WinSCP.SessionOptions")
With sessionOptions
.HostName = "xxx.xxx.com"
.UserName = "xxx"
.Password = "xxx"
.SshHostKeyFingerprint = "xxx"
End With
Dim session
Set session = WScript.CreateObject("WinSCP.Session")
' Connect
session.Open sessionOptions
Dim remotePath
remotePath = "/Usr/ftp4datalink/davis/examplefile.txt"
Dim newRemotePath
newRemotePath = "/Usr/ftp4datalink/davis/newexamplefile.txt"
session.MoveFile(remotePath,newRemotePath).Check()
' Disconnect, clean up
session.Dispose
Both @egray and @David:
The Session.MoveFile does not have a return value.
See http://winscp.net/eng/docs/library_session_movefile
