Topic "Command-line parameter in scripting is deprecated"
navilor
I just upgraded to the newest version of WinSCP (WinSCP Version 5.5.3 (Build 4214)) and am now getting the following warning:
Opening session using command-line parameter in scripting is deprecated. Use 'open' command instead.
I went to your history page here:
http://winscp.net/eng/docs/history
When I went there I noticed the following information:
Before opening session using command-line parameter in scripting, warning is printed, that this is deprecated function.
I apologize but that doesn't make sense for me right now. I hope that you can provide clarification.
My setup is as follows:
1) I have a batch file that has the following inside of it:
"C:\Program Files (x86)\WinSCP\winscp.com" /script="C:\Users\kevin\Desktop\Utils\winscpbatchfile.txt" /log=C:\Users\Kevin\Desktop\Utils\FreeNASSyncLogs\FreeNAS-%date:~-4,4%-%date:~4,2%-%date:~-7,2%-%time:~0,2%-%time:~3,2%-%time:~6,2%-%time:~9,2%.log
2) The "winscpbatchfile.txt" that is used above has the following in it:
open sftp://usernameremoved:passwordremoved@freenas
option batch continue
option transfer binary
I then have multiple sections in the text file to back up specific locations on my multiple hard drives. Below is just one:
lcd "C:\Users\kevin\Documents"
cd /mnt/share/kevin/users/kevin/Documents
synchronize remote -mirror -delete -nopreservetime -filemask=|"*.tmp; C:\Users\kevin\Documents\My Music\; C:\Users\kevin\Documents\My Pictures\; C:\Users\kevin\Documents\My Videos\;"
I did not notice any changes on this page:
http://winscp.net/eng/docs/scripting
Or this page:
http://winscp.net/eng/docs/commandline
Obviously I missed something in your documentation. Can you please provide a clue for the clueless here?
Your winscp.com command line should generally not produce this warning.
Unless your %date% and %time% magic is wrong and resolve in some parts to a string with spaces. I cannot verify this as I do not know in what locale you run the command. Note that %date% and %time% are locale-specific, so may not be reliable.
If this does not help, please attach your log file.
navilor
That it is. Thank you for the pointer on that. Putting the log file and path in quotes resolved the issue.
"C:\Users\Kevin\Desktop\Utils\FreeNASSyncLogs\FreeNAS-%date:~-4,4%-%date:~4,2%-%date:~7,2%-%time:~0,2%-%time:~3,2%-%time:~6,2%-%time:~9,2%.log"
This was a problem that had plagued me for a while which appeared to be random in nature. The problem was that a space was added in one or more of the time sections. This happens as my instance of Windows 7 64bit will always use "short time" on the command line. I have yet to find a way to force "long time" out on the command line even when parsing this thread:
http://stackoverflow.com/questions/245395/hidden-features-of-windows-batch-files
stduser
Hi, I am having the same issue with WinSCP 5.4.4, with the VBA shell command
Call Shell("C:\Program Files (x86)\WinSCP\winscp.com / script = ""C:\Users\xxxxxx\Documents\Test Library\ConnectCell13.txt"" ")
I get the message "Opening session using command-line parameter in scripting is deprecated. Use 'open' command instead."
The script is pretty simple:
# Automatically abort script on errors
option batch abort
# Force binary mode transfer
open scp://user:passwd@cell13
cd /SPARE_DISK/datalog
get LibrChgLogCell13access.csv
# Exit WinSCP
I don't think I could have the option of upgrading the WinSCP version.
You have spacing and quoting all wrong. It should be:
Call Shell("""C:\Program Files (x86)\WinSCP\winscp.com"" /script=""C:\Users\xxxxxx\Documents\Test Library\ConnectCell13.txt""")
