Topic "Connection failed"
PeteFishwick
I am running the same .NET routine on two separate servers. On one of them I connect ok on the other the connection fails.
Both use exactly the same protocol, hostname, username and password.
Can anyone suggest why the failing connection fails.
Connected.txt (4.08 KB) [Download]
Description: Session log for successful connection
Connection Failed.txt (4.78 KB) [Download]
Description: Session log for failed connection
On "Windows 7 Professional" the TLS certificate of the FTP server was verified against Windows trusted root certificate.
On "Windows Web Server 2008 R2", it was not. So either you need to update Windows trusted root certificates or verify the certificate from your code using SessionOptions.TlsHostCertificateFingerprint.
See:
http://winscp.net/eng/docs/tls#certificate
http://winscp.net/eng/docs/library_sessionoptions
PeteFishwick
THank you, do you have a code example showing hos to use SessionOptions.TlsHostCertificateFingerprint?
See:
Just copy and paste the certificate from Server and Protocol Information Dialog:
http://winscp.net/eng/docs/ui_fsinfo
