Topic "Error changing to directory - WebDav Host"
dnmadc
I'm trying to connect to a WebDav host using the same configurations that is working on other FTP/WebDav client (BitKinex) but I'm getting the following error message "Error changing to directory - 405 Method Not Allowed". The host settings are similar on WinSCP and BitKinex, so I'm really not sure what can be wrong - Next you can check the WinSCP log:
WinSCP Version 5.7.5 (Build 5665) (OS 10.0.10240 - Windows 10 Pro)
Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
Log level: Normal
Local account: XAccount
Working directory: XDirectory
Process ID: 8808
Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
Time zone: Current: GMT+1, Standard: GMT+0 (GMT Standard Time), DST: GMT+1 (GMT Daylight Time), DST Start: 29/03/2015, DST End: 25/10/2015
Login time: 18 de setembro de 2015 14:04:50
Session name: XName (Modified site)
Host name: XSite (Port: 80)
User name: clientes (Password: Yes, Key file: No)
Transfer Protocol: WebDAV
Proxy: none
Local directory: XDirectory, Remote directory: /XFolder/, Update: Yes, Cache: No
Cache directory changes: No, Permanent: Yes
DST mode: 1
Compression: No
ah_create, for WWW-Authenticate
Sending request headers:
OPTIONS /XFolder/ HTTP/1.1
User-Agent: WinSCP/5.7.5 neon/0.30.1
Keep-Alive:
Connection: TE, Keep-Alive
TE: trailers
Host: XSite
Sending request-line and headers:
Doing DNS lookup on XSite...
req: Connecting to XX.XX.XX.XX:80
Request sent; retry is 0.
[status-line] < HTTP/1.1 401 Authorization Required
Header Name: [date], Value: [Fri, 18 Sep 2015 13:04:51 GMT]
Header Name: [server], Value: [Apache]
Header Name: [www-authenticate], Value: [Basic realm="name"]
Header Name: [content-length], Value: [401]
Header Name: [connection], Value: [close]
Header Name: [content-type], Value: [text/html; charset=iso-8859-1]
End of headers.
ah_post_send (#0), code is 401 (want 401), WWW-Authenticate is Basic realm="name"
auth: Got challenge (code 401).
auth: Got 'Basic' challenge.
auth: Trying Basic challenge...
auth: Accepted Basic challenge.
sess: Closing connection.
sess: Connection closed.
auth: Sending 'Basic' response.
OPTIONS /XFodler/ HTTP/1.1
Keep-Alive:
TE: trailers
Host: XSite
Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[status-line] < HTTP/1.1 200 OK
Header Name: [allow], Value: [GET,HEAD,POST,OPTIONS,TRACE]
Header Name: [content-length], Value: [0]
Header Name: [content-type], Value: [httpd/unix-directory]
End of headers.
ah_post_send (#1), code is 200 (want 401), WWW-Authenticate is (none)
Request ends, status 200 class 2xx, error line:
200 OK
Request ends.
Using WebDAV protocol.
Doing startup conversation with host.
Changing directory to "/XFolder/".
Trying to open directory "/XFolder/".
<?xml version="1.0" encoding="utf-8"?>
<propfind xmlns="DAV:"><allprop/></propfind>
PROPFIND /XFolder/ HTTP/1.1
Connection: TE
TE: trailers
Host: XSite
Depth: 0
Content-Length: 84
Content-Type: application/xml
Sending request body:
[status-line] < HTTP/1.1 405 Method Not Allowed
Header Name: [date], Value: [Fri, 18 Sep 2015 13:04:52 GMT]
Header Name: [content-length], Value: [235]
End of headers.
ah_post_send (#0), code is 405 (want 401), WWW-Authenticate is (none)
Request ends, status 405 class 4xx, error line:
Request ends.
(ECommand) Error changing directory to '/XFolder/'.
Getting current directory name.
Connection: TE
TE: trailers
Host: XSite
Depth: 1
Content-Length: 84
Header Name: [date], Value: [Fri, 18 Sep 2015 13:04:56 GMT]
End of headers.
Request ends.
(ECommand) Error listing directory '/XFolder'.
Startup conversation with host finished.
Not refreshing directory, caching is off.
The log from BitKinex, that connects without problems is the following:
Resolving host name "XSite" ...
Connecting ( XSite => ip: XX.XX.XX.XX, port: 80 )
Connected (XX.XX.XX.XX:80)
<<< GET /XFolder/ HTTP/1.1
<<< Host: XSite
<<< User-Agent: BitKinex/3.2.3
<<< Accept: */*
<<< Pragma: no-cache
<<< Cache-Control: no-cache
>>> Date: Fri, 18 Sep 2015 12:51:53 GMT
>>> Server: Apache
>>> WWW-Authenticate: Basic realm="name"
>>> Content-Length: 401
>>> Connection: close
>>> Content-Type: text/html; charset=iso-8859-1
Connection closed
<<< Host: XSite
<<< Accept: */*
<<< Authorization: Basic Y2xpZW50ZXM6dWcwVWRPakZWX2s=
>>> HTTP/1.1 200 OK
>>> Server: Apache
>>> Content-Length: 5274
>>> Connection: close
>>> Content-Type: text/html;charset=UTF-8
FIN received
Connection closed
Con someone help me in figuring out why is the WinSCP connection not working?
Best Regards,
Duplicate post:
http://winscp.net/forum/viewtopic.php?t=15901
