Topic "(ExtException) **Copying files from remote side failed.**"
jessey316
Hi
Hope someone can help. Odd issue i am having, i have created a scheduled task to connect and download files each morning
My download file is this:
# skip errors
option batch continue
# Connect using a Site
open FTPSite
# Force binary mode transfer
option transfer binary
# Download file to the local directory d:\
get -resume * "D:\Data Storage\0. My Data\Downloaded_Data\" -preservetime
# Disconnect
close
# Exit WinSCP
All files and folders download except one or two files in a certain folder. Everyday its the same files in the same folder, 230 folders all together.
i get this error:
< 2015-10-28 10:00:13.975 250 CWD successful. "/ttttttt_Oooooooooooooooooooo Vvvvvv_3" is current directory.
> 2015-10-28 10:00:13.975 PWD
< 2015-10-28 10:00:14.024 257 "/ttttttt_Oooooooooooooooooooo Vvvvvv_3" is current directory.
> 2015-10-28 10:00:14.024 TYPE A
< 2015-10-28 10:00:14.072 200 Type set to A
> 2015-10-28 10:00:14.072 PASV
< 2015-10-28 10:00:14.121 227 Entering Passive Mode (195,7,83,73,223,185)
> 2015-10-28 10:00:14.121 MLSD
. 2015-10-28 10:00:14.121 Connecting to 195.7.83.73:57273 ...
< 2015-10-28 10:00:14.224 150 Opening data channel for directory listing of "/ttttttt_Oooooooooooooooooooo Vvvvvv_3"
< 2015-10-28 10:00:14.224 226 Successfully transferred "/ttttttt_Oooooooooooooooooooo Vvvvvv_3"
. 2015-10-28 10:00:14.225 type=file;modify=20151027091550;size=1336; ttttttt_Oooooooooooooooooooo Vvvvvv_3Sat. 24 Oct. 2015 - Mon. 26 Oct. 2015.csv
. 2015-10-28 10:00:14.225 type=file;modify=20151028090916;size=1336; ttttttt_Oooooooooooooooooooo Vvvvvv_3Sun. 25 Oct. 2015 - Tue. 27 Oct. 2015.csv
. 2015-10-28 10:00:14.225 Directory listing successful
. 2015-10-28 10:00:14.225 ..;D;0;1899-12-30T00:00:00.000Z;"" [0];"" [0];---------;0
. 2015-10-28 10:00:14.225 ttttttt_Oooooooooooooooooooo Vvvvvv_3Sat. 24 Oct. 2015 - Mon. 26 Oct. 2015.csv;-;1336;2015-10-27T09:15:50.000Z;"" [0];"" [0];---------;0
. 2015-10-28 10:00:14.225 ttttttt_Oooooooooooooooooooo Vvvvvv_3Sun. 25 Oct. 2015 - Tue. 27 Oct. 2015.csv;-;1336;2015-10-28T09:09:16.000Z;"" [0];"" [0];---------;0
. 2015-10-28 10:00:14.225 File: '/ttttttt_Oooooooooooooooooooo Vvvvvv_3/ttttttt_Oooooooooooooooooooo Vvvvvv_3Sat. 24 Oct. 2015 - Mon. 26 Oct. 2015.csv' [2015-10-27T09:15:50.000Z] [1336]
. 2015-10-28 10:00:14.225 Copying "/ttttttt_Oooooooooooooooooooo Vvvvvv_3/ttttttt_Oooooooooooooooooooo Vvvvvv_3Sat. 24 Oct. 2015 - Mon. 26 Oct. 2015.csv" to local directory started.
. 2015-10-28 10:00:14.226 Binary transfer mode selected.
. 2015-10-28 10:00:14.226 Starting download of /ttttttt_Oooooooooooooooooooo Vvvvvv_3/ttttttt_Oooooooooooooooooooo Vvvvvv_3Sat. 24 Oct. 2015 - Mon. 26 Oct. 2015.csv
> 2015-10-28 10:00:14.227 TYPE I
< 2015-10-28 10:00:14.282 200 Type set to I
> 2015-10-28 10:00:14.282 PASV
< 2015-10-28 10:00:14.331 227 Entering Passive Mode (195,7,83,73,223,187)
> 2015-10-28 10:00:14.331 RETR ttttttt_Oooooooooooooooooooo Vvvvvv_3Sat. 24 Oct. 2015 - Mon. 26 Oct. 2015.csv
< 2015-10-28 10:00:14.393 550 File not found
. 2015-10-28 10:00:14.393 Copying files from remote side failed.
* 2015-10-28 10:00:14.393 (ExtException) **Copying files from remote side failed.**
* 2015-10-28 10:00:14.393 File not found
. 2015-10-28 10:00:14.393 Asking user:
. 2015-10-28 10:00:14.394 Error transferring file '/ttttttt_Oooooooooooooooooooo Vvvvvv_3/ttttttt_Oooooooooooooooooooo Vvvvvv_3Sat. 24 Oct. 2015 - Mon. 26 Oct. 2015.csv'. ("Copying files from remote side failed.","File not found")
< 2015-10-28 10:00:14.394 Script: Error transferring file '/ttttttt_Oooooooooooooooooooo Vvvvvv_3/ttttttt_Oooooooooooooooooooo Vvvvvv_3Sat. 24 Oct. 2015 - Mon. 26 Oct. 2015.csv'.
< 2015-10-28 10:00:14.394 Script: Copying files from remote side failed.< 2015-10-28 10:00:14.394 File not found
I tried to download the same file using the winscp console but got the same error. I tried with filezilla, no special settings and it works without issues but as i want to automate the download i wish to use winscp
jessey316
any help? ive searched around net and forum but not having much luck. really odd issue, i tried different settings but still not luck. are there any special characters that winscp doesnt like?
Show us the log file from FileZilla (a real log file, not the message log from the GUI).
This is the logs from filezilla
2015-11-02 14:02:12 4792 1 Status: Resolving address of ftp.site.com
2015-11-02 14:02:13 4792 1 Status: Connecting to 195.7.83.73:21...
2015-11-02 14:02:13 4792 1 Status: Connection established, waiting for welcome message...
2015-11-02 14:02:13 4792 1 Response: 220 This is a private system and not a public service. All access is logged.
2015-11-02 14:02:13 4792 1 Command: AUTH TLS
2015-11-02 14:02:13 4792 1 Response: 502 SSL/TLS authentication not allowed
2015-11-02 14:02:13 4792 1 Command: AUTH SSL
2015-11-02 14:02:13 4792 1 Status: Insecure server, it does not support FTP over TLS.
2015-11-02 14:02:13 4792 1 Command: USER User_Name
2015-11-02 14:02:13 4792 1 Response: 331 Password required for User_Name
2015-11-02 14:02:13 4792 1 Command: PASS *********
2015-11-02 14:02:13 4792 1 Response: 230 Logged on
2015-11-02 14:02:13 4792 1 Command: SYST
2015-11-02 14:02:13 4792 1 Response: 215 UNIX emulated by FileZilla
2015-11-02 14:02:13 4792 1 Command: FEAT
2015-11-02 14:02:13 4792 1 Response: 211-Features:
2015-11-02 14:02:13 4792 1 Response: MDTM
2015-11-02 14:02:13 4792 1 Response: REST STREAM
2015-11-02 14:02:13 4792 1 Response: SIZE
2015-11-02 14:02:13 4792 1 Response: MLST type*;size*;modify*;
2015-11-02 14:02:13 4792 1 Response: MLSD
2015-11-02 14:02:13 4792 1 Response: UTF8
2015-11-02 14:02:13 4792 1 Response: CLNT
2015-11-02 14:02:13 4792 1 Response: MFMT
2015-11-02 14:02:13 4792 1 Response: EPSV
2015-11-02 14:02:13 4792 1 Response: EPRT
2015-11-02 14:02:13 4792 1 Response: 211 End
2015-11-02 14:02:13 4792 1 Status: Connected
2015-11-02 14:02:13 4792 1 Status: Retrieving directory listing...
2015-11-02 14:02:13 4792 1 Command: PWD
2015-11-02 14:02:13 4792 1 Response: 257 "/" is current directory.
2015-11-02 14:02:13 4792 1 Command: TYPE I
2015-11-02 14:02:13 4792 1 Response: 200 Type set to I
2015-11-02 14:02:13 4792 1 Command: PASV
2015-11-02 14:02:13 4792 1 Response: 227 Entering Passive Mode (195,7,83,73,223,23)
2015-11-02 14:02:13 4792 1 Command: MLSD
2015-11-02 14:02:13 4792 1 Response: 150 Opening data channel for directory listing of "/"
2015-11-02 14:02:13 4792 1 Response: 226 Successfully transferred "/"
2015-11-02 14:02:13 4792 1 Status: Directory listing of "/" successful
2015-11-02 14:02:44 4792 1 Status: Retrieving directory listing of "/ttttttt_Oooooooooooooooooooo Vvvvvv_3"...
2015-11-02 14:02:44 4792 1 Command: CWD /ttttttt_Oooooooooooooooooooo Vvvvvv_3
2015-11-02 14:02:44 4792 1 Response: 250 CWD successful. "/ttttttt_Oooooooooooooooooooo Vvvvvv_3" is current directory.
2015-11-02 14:02:44 4792 1 Command: PWD
2015-11-02 14:02:44 4792 1 Response: 257 "/ttttttt_Oooooooooooooooooooo Vvvvvv_3" is current directory.
2015-11-02 14:02:44 4792 1 Command: PASV
2015-11-02 14:02:44 4792 1 Response: 227 Entering Passive Mode (195,7,83,73,223,25)
2015-11-02 14:02:44 4792 1 Command: MLSD
2015-11-02 14:02:44 4792 1 Response: 150 Opening data channel for directory listing of "/ttttttt_Oooooooooooooooooooo Vvvvvv_3"
2015-11-02 14:02:44 4792 1 Response: 226 Successfully transferred "/ttttttt_Oooooooooooooooooooo Vvvvvv_3"
2015-11-02 14:02:44 4792 1 Status: Directory listing of "/ttttttt_Oooooooooooooooooooo Vvvvvv_3" successful
2015-11-02 14:02:54 4792 3 Status: Resolving address of ftp.site.com
2015-11-02 14:02:54 4792 3 Status: Connecting to 195.7.83.73:21...
2015-11-02 14:02:54 4792 3 Status: Connection established, waiting for welcome message...
2015-11-02 14:02:54 4792 3 Response: 220 This is a private system and not a public service. All access is logged.
2015-11-02 14:02:54 4792 3 Command: AUTH TLS
2015-11-02 14:02:54 4792 3 Response: 502 SSL/TLS authentication not allowed
2015-11-02 14:02:54 4792 3 Command: AUTH SSL
2015-11-02 14:02:54 4792 3 Status: Insecure server, it does not support FTP over TLS.
2015-11-02 14:02:54 4792 3 Command: USER User_Name
2015-11-02 14:02:54 4792 3 Response: 331 Password required for User_Name
2015-11-02 14:02:54 4792 3 Command: PASS *********
2015-11-02 14:02:55 4792 3 Response: 230 Logged on
2015-11-02 14:02:55 4792 3 Status: Connected
2015-11-02 14:02:55 4792 3 Status: Starting download of /ttttttt_Oooooooooooooooooooo Vvvvvv_3/ ttttttt_Oooooooooooooooooooo Vvvvvv_3Fri. 30 Oct. 2015 - Sun. 1 Nov. 2015.csv
2015-11-02 14:02:55 4792 3 Command: CWD /ttttttt_Oooooooooooooooooooo Vvvvvv_3
2015-11-02 14:02:55 4792 3 Response: 250 CWD successful. "/ttttttt_Oooooooooooooooooooo Vvvvvv_3" is current directory.
2015-11-02 14:02:55 4792 3 Command: TYPE I
2015-11-02 14:02:55 4792 3 Response: 200 Type set to I
2015-11-02 14:02:55 4792 3 Command: PASV
2015-11-02 14:02:55 4792 3 Response: 227 Entering Passive Mode (195,7,83,73,223,2Cool
2015-11-02 14:02:55 4792 3 Command: RETR ttttttt_Oooooooooooooooooooo Vvvvvv_3Fri. 30 Oct. 2015 - Sun. 1 Nov. 2015.csv
2015-11-02 14:02:55 4792 3 Response: 150 Opening data channel for file download from server of "/ttttttt_Oooooooooooooooooooo Vvvvvv_3/ ttttttt_Oooooooooooooooooooo Vvvvvv_3Fri. 30 Oct. 2015 - Sun. 1 Nov. 2015.csv"
2015-11-02 14:02:55 4792 3 Response: 226 Successfully transferred "/ttttttt_Oooooooooooooooooooo Vvvvvv_3/ ttttttt_Oooooooooooooooooooo Vvvvvv_3Fri. 30 Oct. 2015 - Sun. 1 Nov. 2015.csv"
2015-11-02 14:02:55 4792 3 Status: File transfer successful, transferred 1,341 bytes in 1 second
jessey316
Not sure why that came up as Guest but I pasted the logs there
The filename starts with a space. WinSCP has problems with that. I'll look into it. Meanwhile, remove the space if possible.
jessey316
Great, that appears to have done the trick when i did a test...This runs every morning so i have informed the up-loaders and i shall check again in the morning
This issue is tracked here:
http://winscp.net/tracker/show_bug.cgi?id=26
