Topic "Synch mistake please help!"
Franc69
hi!
i new user but think i make a big error....
i want synchronise file to distant to local...
but im synch local to distant.... and my local folder was empty..... the result its deleted my distant files but "delet file" was not ticken...
in my server the file in the folder disapear...
can i go to a "distant recycle bean? or im f**** ?
thank you very mutch !
F
WinSCP won't delete remote files, if you do not check the "Delete files" option.
For the undelete, you are generally out of luck, unfortunately.
See http://winscp.net/eng/docs/faq_undelete
