Topic "Problem configuring FTPS connection in WinSCP"
Dear Support
I am trying to configure a new FTPS connection (in WinSCP 5.8.1 Beta as I believe this is the only version I can do this in ?) to an external site where the supplier has provided a self signed certificate (in DER form). When I try to apply the certificate to the WinSCP connection details I get the error:
error:0906D06C:PEM routines:PEM_read_bio:no start line
I can install the certificate into the Windows certificate store without any problem. A bit of searching suggested converting the certificate to PEM form using OpenSSL which succeeds without error but I then get the same error when I try to load the converted PEM cert in WinSCP.
Can you help please ?
Chris
How does the file look like? Can you post it here? Both formats. Of course, replace the secret parts.
mkeshab
I am trying to connect VISA OFD server via winscp beta version. i am unable to store cleint certificate provided by VISA.
Below are the error getting when load the certificate.
error:0906D06C:PEM routines:PEM_read_bio:no start line.
can some please help...
Duplicate post:
https://winscp.net/forum/viewtopic.php?t=22907
