Topic "Timestamp without seconds"
Tom2016
I want to backup sum data to my ftp-server by my provider. But by every transfer all files are copied to the ftp-server.
I found out that the timestamp of the files on the ftp-server the seconds are missing, so the files on my local harddisk are always newer, and all files are copy again, and not only the realy new one.
Is there a way that WinSCP ignore the seconds by the time compare? When not, it is possible to implement a checkbox "ignore timestamp seconds"?
See the attached pictures.
Best regards
Thomas
Description: (none)
Description: (none)
Tom2016
prikryl wrote:
You can see in the log file, the seconds of the files are 00!
Web-Backup.log (12.52 KB) Private file
Description: (none)
Sure, because your FTP server (vsftpd) does not support the MLSD command and does not provide seconds in the LIST command:
. 2016-04-06 08:19:55.187 drwxr-xr-x    3 3274     3274         4096 Mar 30 15:35 .
. 2016-04-06 08:19:55.187 drwxr-xr-x    5 3274     3274         4096 Mar 24 15:31 ..
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274          953 Mar 08 14:02 72a295a9f5656e12fd8beecce007fa156661067e264b528a.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274         1145 Mar 08 16:55 72a295a9f5656e12fd8beecce007fa156661067e28695181c64c37cf6af0.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274       152666 Feb 16 12:28 72a29a90c856483fb5ffb98fa511e515647a1b763a0502d2865270dc.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274       170874 Mar 22 16:51 72a29a90c856483fb5ffb98fa511e515647a1b763b0501d6865270dc.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274        97178 Mar 23 12:17 72a29a90c856483fb5ffb98fa511e515647a1b763b0501d7886570d87fff13bc1a64.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274         3577 Feb 02 12:20 72a9b98cd8474c6d9acebf88be43f9122f.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274      5511051 Mar 22 16:50 72aa95bdc3454e03988beecce007fa1566610474281904c99d1837d662ee.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274      5511947 Mar 23 16:25 72aa95bdc3454e03988beecce007fa1566610475281904c99a1c37d662ee.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274      5509835 Mar 21 11:43 72aa95bdc3454e03988beecce007fa1566610477281901c99c1a37d662ee.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274      5511051 Mar 21 16:18 72aa95bdc3454e03988beecce007fa1566610477281904c9991d37d662ee.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274      5512875 Mar 30 15:31 72aa95bdc3454e03988beecce007fa1566610576281904c99b1937d662ee.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274      5494731 Mar 16 16:39 72aa95bdc3454e03988beecce007fa1566610770281904c99b1037d662ee.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274      5492859 Mar 15 16:34 72aa95bdc3454e03988beecce007fa1566610773281904c99b1b37d662ee.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274      5506571 Mar 18 15:51 72aa95bdc3454e03988beecce007fa156661077e281905c99d1837d662ee.cryptsync
. 2016-04-06 08:19:55.187 drwxr-xr-x    2 3274     3274         4096 Mar 24 15:38 72aaa490dc455d
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274       103082 Mar 24 10:43 72aab59df56c4623a8ca83b48362e37a07294634674f4185c54570c26cbe46a21c2862451a192f9f909e27a55a11460f1de0.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274         1273 Feb 05 09:21 72ac81c89a04602aa2c4ae99f174a5573a3e703469455697865270dc.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274        96490 Mar 16 16:38 72b997b7f94d4438a0caa893a311e515647a1b763b0502d288192e8138a95ae8446e.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274        95450 Mar 08 16:56 72b997b7f94d4438a0caa893a311e515647a1b763b0503dc88192e813ea85ae8446e.cryptsync
. 2016-04-06 08:19:55.187 -rw-r--r--    1 3274     3274            2 Mar 24 10:45 __2016-03-24 11-45.txt
Tom2016
It is possible to add a optional checkbox (see attached screen shot) for ignore the seconds by the time compare during upload files.
Description: Sceen shot: optional checkbox
WinSCP does that automatically. If it does not work for you, please attach a log file showing the opposite. Please name the problematic file.
Tom2016
I have attached my log file, what is the 15T16 in the timestamp this must be the problem?
. 2016-04-11 09:55:01.585 Source file timestamp is [2016-03-15T16:34:00.000Z], destination timestamp is [2016-03-15T15:34:00.000Z], will overwrite
Backup.log (10.07 KB) Private file
Description: (none)
Thanks. It might be a bug. I'll take a look.
https://winscp.net/tracker/show_bug.cgi?id=1424
Tom2016
Hello
I have testet the newes version:
1. I have delete all files from the server.
2. I have upload a complete directory with files.
3. I have upload exact the same complete directory with files again, but it seems that some files are uploaded again, because timestamps are different?
I have also problems with the server connection it breaks with error, but I can reconnect, what can be the reason?
. 2016-06-01 08:43:16.244 Transfer done: 'D:\_Sonstiges\_Backup\CloudSync\Crypt\ZW\72aa95bdc3454e03988beecce007fa156061077e281904c99c1b37d662ee.cryptsync' [5567579]
. 2016-06-01 08:43:16.244 File: 'D:\_Sonstiges\_Backup\CloudSync\Crypt\ZW\72aa95bdc3454e03988beecce007fa156061077f281901c9981a37d662ee.cryptsync' [2016-05-19T10:03:31.713Z] [5567899]
. 2016-06-01 08:43:16.244 Copying "D:\_Sonstiges\_Backup\CloudSync\Crypt\ZW\72aa95bdc3454e03988beecce007fa156061077f281901c9981a37d662ee.cryptsync" to remote directory started.
. 2016-06-01 08:43:16.244 Binary transfer mode selected.
. 2016-06-01 08:43:16.244 Beginne D:\_Sonstiges\_Backup\CloudSync\Crypt\ZW\72aa95bdc3454e03988beecce007fa156061077f281901c9981a37d662ee.cryptsync heraufzuladen
. 2016-06-01 08:43:16.244 Source file timestamp is [2016-05-19T10:03:00.000Z], destination timestamp is [2016-05-19T08:03:00.000Z], will overwrite
> 2016-06-01 08:43:16.244 TYPE I
< 2016-06-01 08:43:16.275 200 Switching to Binary mode.
> 2016-06-01 08:43:16.275 PASV
< 2016-06-01 08:43:16.291 227 Entering Passive Mode (79,133,53,17,12,43).
> 2016-06-01 08:43:16.291 STOR 72aa95bdc3454e03988beecce007fa156061077f281901c9981a37d662ee.cryptsync
< 2016-06-01 08:43:16.369 150 Ok to send data.
. 2016-06-01 08:43:16.400 Session ID reused
. 2016-06-01 08:43:16.400 Using TLSv1, cipher TLSv1/SSLv3: AES256-SHA, 2048 bit RSA, AES256-SHA SSLv3 Kx=RSA Au=RSA Enc=AES(256) Mac=SHA1
. 2016-06-01 08:43:16.400 TLS Verbindung hergestellt
< 2016-06-01 08:44:00.860 226 Transfer complete.
> 2016-06-01 08:44:00.860 MDTM 20160519100331 72aa95bdc3454e03988beecce007fa156061077f281901c9981a37d662ee.cryptsync
< 2016-06-01 08:44:00.891 213 File modification time set.
. 2016-06-01 08:44:00.891 Heraufladen erfolgreich
Web-Backup.log (43.93 KB) Private file
Description: (none)
Sorry for late answer. I needed to implement a fix.
This issue was added to the tracker:
https://winscp.net/tracker/show_bug.cgi?id=1431
