How to configure WinSCP for Webdav with Two Factor Authentication
integration77
I'm trying to connect to a website using WebDav and the Two Factor Authentication and it fails.
As recommended, I'm using the 5.8.2 beta version of WinSCP.
The site is DemandWare (URL beginning with cert.environnement.etc...). We had to create/export a certificate containing the .crt provided by DemandWare + our client information into pkcs12 format.
So it uses WebDav protocol, port 443, and I included the .p12 certificate into "Client certificate file" under Advanced.
BUT... it tries to connect indefinitely...
Do you have any ideas about it ?
Thanks for your help !
integration77
Re : Re: How to configure WinSCP for Webdav with Two Factor Authentication
Thanks for your answer.
I've downloaded the provided 5.8.3 portable version
After few times trying to connect, I get this error message :
"Could not connect to server: Socket error 10057
Connection failed."
Maybe this time it's a configuration issue from my side ?
Re: Re : Re: How to configure WinSCP for Webdav with Two Factor Authentication
integration77
I've enabled logging Debug2 (I think it's the highest level).
Here's the attachment as private file.
  • cert.staging.web.picard.demandware.net.log (3.23 KB, Private file)
integration77
I found the cause of the issue (and that's my mistake) : I had to declare a proxy server for any connexions + specify a remote directory on the advanced settings.
When fields filled, I could connect properly and it works fine with the 5.8.2 beta version.
Sorry for the inconvenience and many thanks for your support !
Regards,
Florent
