Cannot get real path
Hanes
Hi
WinSCP can't seem to list a remote directory. It gives a permissions error, but on FileZilla I am able to navigate to the folder. We use the WinSCP binary in our program, so using WinSCP is crucial!
Here is an extract from the log:
Changing directory to "".
Getting real path for ''
Type: SSH_FXP_REALPATH, Size: 21, Number: 7952
Type: SSH_FXP_STATUS, Size: 34, Number: 7952
Status code: 3, Message: 7952, Server: Permission denied, Language:
(ECommand) Error changing directory to ''.
Cannot get real path for ''.
Permission denied.
Error code: 3
Error message from server: Permission denied
WinSCP Version: 5.7.7
Server Details:
File transfer protocol = SFTP-3
Cryptographic protocol = SSH-2
SSH implementation = OpenSSH_7.1
Encryption algorithm = aes
Compression = No
I have disabled "Transfer resuming" as per other topic suggestion, but it still did not work.
Any help would be appreciated!
Hanes
Anything Unclear
Is there anything unclear with my question?
More Info:
I think that the folder I am trying to access is actually a shortcut and WinSCP is unable to get the real path. This should not be a problem, since the username that I connect with has sufficient access to the folder. And how is it possible that FileZilla is able to access the same folder?
Thanks in advance for your feedback.
Re: Cannot get real path
Hanes
Server Log
Thank you for the reply! The server belongs to a third party, I will have to liaise with their IT department. We just want to download files from the server. Just give me some time to get the logs.
Re: Server Log
I've asked for a client (WinSCP) log. Though server log, might provide additional information.
