Topic "Unable to connect to remote directory IBM mainframe"
abarman_
I am using Winscp.net from nuget.
I am able to open the session with the proper credentials.
It is failing at
var v = session.ListDirectory(@"'EMA.S44.'"); //The string is <single-quote>EMA.S44.<single-quote>
The FTP site is at IBM mainframe.
I was able to connect using WinSCP gui.
I had to add remote directory at the advanced option as 'EMA.S44.' (Note: exactly with the . and single-quote).
Enabled the log while connecting from gui which worked as following. I am just showing the part.
== Log ===
. 2016-08-30 11:14:48.033 Changing directory to "'EMA.S44.'".
> 2016-08-30 11:14:48.033 CWD 'EMA.S44.'
< 2016-08-30 11:14:48.040 250 "EMA.S44." is the working directory name prefix.
. 2016-08-30 11:14:48.040 Getting current directory name.
> 2016-08-30 11:14:48.040 PWD
< 2016-08-30 11:14:48.044 257 "'EMA.S44.'" is working directory.
. 2016-08-30 11:14:48.236 Retrieving directory listing...
== Log ==
Now, while connecting using C# code, digging to exception I found the following.
"winscp> ls -- \"'EMA.S44.'/\""
"Error listing directory ''EMA.S44.''."
"Could not retrieve directory listing\r"
"CWD cmd failed : EDC5129I NO SUCH FILE OR DIRECTORY."
Note:Here is some details about name directory prefix....
https://www.ibm.com/support/knowledgecenter/SSLTBW_2.1.0/com.ibm.zos.v2r1.cs3cod0/ftp250-09.htm
I also used genrate url code, and it is as follows. I did hide server details.
winscp-ftpes://*****@ftp.***.***.***/%27EMA.S44.%27/
Please let me know if you see some thing obvious.
Duplicate post on Stack Overflow:
http://stackoverflow.com/q/39236024/850848
https://winscp.net/tracker/show_bug.cgi?id=1453
