Topic "Command line and Exit Code 1"
sergio77
Hi all,
this is my first post in this forum (so don't kill me please) Smile
This is the question:
I prepared a simple scheduled task to download some files from ad FTPS Server.
This is the code:
echo open ftp://XXXXX:YYYYY@10.10.10.10:990 -explicittls -certificate="......"> auto.txt
echo get file1.txt %HOME%\file1.txt>> auto.txt
echo get file2.txt %HOME%\file2.txt>> auto.txt
echo get file3.txt %HOME%\file3.txt>> auto.txt
echo quit>> auto.txt
winscp.exe /script=auto.txt /log=ftps.log
Script is working fine (if all 3 files exist), if (for example) file2.txt doesn't exist script stop with an error (Exit Code 1) and it doesn't try to download file3.txt....
This is the LOG:
2016-09-06 12.26.17.525 Listing file "file2.txt".
2016-09-06 12.26.17.525 Recupero informazioni file in corso...
2016-09-06 12.26.17.525 MLST file2.txt
2016-09-06 12.26.17.556 550 File or directory not found.
2016-09-06 12.26.17.556 Impossibile recuperare informazioni sul file
2016-09-06 12.26.17.556 Script: Impossibile ottenere attributi del file 'destinazioni.txt'.
2016-09-06 12.26.17.556 Script: Impossibile recuperare informazioni sul file
2016-09-06 12.26.17.556 File or directory not found.
2016-09-06 12.26.17.556 Script: Failed
2016-09-06 12.26.17.556 Script: Exit code: 1
2016-09-06 12.26.17.556 Disconnessione dal server
How can I fix this error?
Sergio
Use the option batch continue
https://winscp.net/eng/docs/scriptcommand_option
sergio77
Thanks a lot.
Bye
