Trouble Uploading
zuckermanf
San Diego
Trouble Uploading
I'm having trouble uploading.
It appears to be successful since it is a large file (12mb) and takes about 60 seconds.
But if I connect to the remote site with FileZilla, the file is not there.
If I upload the file using FileZilla, it works.
But I need to upload the file in a batch file, not interactively.
Thank you for any suggestions.
Here's my script:
open sftp://XXXXX:XXXXX@ftp.XXXXX.com -hostkey="XXXXX"
cd /RemoteFolder/Hotsheet
put -nopreservetime C:\PDDBAPPS\HotSheet.dat
And here is the WinSCP log file:
(Which I cannot fully understand)
. 2022-10-18 01:18:31.388 --------------------------------------------------------------------------
. 2022-10-18 01:18:31.404 WinSCP Version 5.21.5 (Build 12858 2022-10-06) (OS 10.0.19042 - Windows 10 Enterprise)
. 2022-10-18 01:18:31.404 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2022-10-18 01:18:31.404 Log level: Normal
. 2022-10-18 01:18:31.404 Local account: SDPDNT_DOM\fzuckerman
. 2022-10-18 01:18:31.404 Working directory: C:\Windows
. 2022-10-18 01:18:31.404 Process ID: 3420
. 2022-10-18 01:18:31.420 Ancestor processes: cmd, explorer, ...
. 2022-10-18 01:18:31.420 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"  /script=C:\PDDBAPPS\CScript.txt /log=C:\PDDBAPPS\log.txt
. 2022-10-18 01:18:31.435 Time zone: Current: GMT-7, Standard: GMT-8 (Pacific Standard Time), DST: GMT-7 (Pacific Daylight Time), DST Start: 3/13/2022, DST End: 11/6/2022
. 2022-10-18 01:18:31.435 Login time: Tuesday, October 18, 2022 1:18:31 AM
. 2022-10-18 01:18:31.435 --------------------------------------------------------------------------
. 2022-10-18 01:18:31.435 Script: Retrospectively logging previous script records:
> 2022-10-18 01:18:31.435 Script: open sftp://***:***@ftp.civicsmart.com -hostkey="***"
. 2022-10-18 01:18:31.435 Session name: ***.com (Ad-Hoc site)
. 2022-10-18 01:18:31.435 Host name: ***.com (Port: 22)
. 2022-10-18 01:18:31.435 User name: *** (Password: Yes, Key file: No, Passphrase: No)
. 2022-10-18 01:18:31.435 Tunnel: No
. 2022-10-18 01:18:31.435 Transfer Protocol: SFTP
. 2022-10-18 01:18:31.435 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2022-10-18 01:18:31.435 Disable Nagle: No
. 2022-10-18 01:18:31.435 Proxy: None
. 2022-10-18 01:18:31.435 Send buffer: 262144
. 2022-10-18 01:18:31.435 Compression: No
. 2022-10-18 01:18:31.435 Bypass authentication: No
. 2022-10-18 01:18:31.435 Try agent: Yes; Agent forwarding: No; KI: Yes; GSSAPI: Yes
. 2022-10-18 01:18:31.435 GSSAPI: KEX: No; Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2022-10-18 01:18:31.435 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2022-10-18 01:18:31.435 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2022-10-18 01:18:31.435 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2022-10-18 01:18:31.435 Simple channel: Yes
. 2022-10-18 01:18:31.435 Return code variable: Autodetect; Lookup user groups: Auto
. 2022-10-18 01:18:31.435 Shell: default
. 2022-10-18 01:18:31.435 EOL: LF, UTF: Auto
. 2022-10-18 01:18:31.435 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2022-10-18 01:18:31.435 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2022-10-18 01:18:31.435 SFTP Bugs: Auto,Auto
. 2022-10-18 01:18:31.435 SFTP Server: default
. 2022-10-18 01:18:31.435 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2022-10-18 01:18:31.435 Cache directory changes: Yes, Permanent: Yes
. 2022-10-18 01:18:31.435 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2022-10-18 01:18:31.435 DST mode: Unix
< 2022-10-18 01:18:31.435 Script: Searching for host...
. 2022-10-18 01:18:31.435 Looking up host "***.com" for SSH connection
. 2022-10-18 01:18:31.451 Connecting to 64.132.70.132 port 22
. 2022-10-18 01:18:31.514 Connected to 64.132.70.132
< 2022-10-18 01:18:31.514 Script: Connecting to host...
. 2022-10-18 01:18:31.514 We claim version: SSH-2.0-WinSCP_release_5.21.5
. 2022-10-18 01:18:31.592 Remote version: SSH-2.0-srtSSHServer_11.00
. 2022-10-18 01:18:31.592 Using SSH protocol version 2
. 2022-10-18 01:18:31.592 Have a known host key of type rsa2
. 2022-10-18 01:18:31.608 Doing Diffie-Hellman group exchange
. 2022-10-18 01:18:31.779 Doing Diffie-Hellman key exchange using 2070-bit modulus and hash SHA-256 with a server-supplied group
. 2022-10-18 01:18:32.389 Host key fingerprint is:
. 2022-10-18 01:18:32.389 ssh-rsa 4096 SHA256:ito+IWQtNUAtFgtiMfYY0b2VW2DItDXCstK6gCXkgWA
< 2022-10-18 01:18:32.389 Script: Authenticating...
. 2022-10-18 01:18:32.389 Host key matches configured key fingerprint
. 2022-10-18 01:18:32.389 Initialised AES-256 SDCTR (AES-NI accelerated) [aes256-ctr] outbound encryption
. 2022-10-18 01:18:32.389 Initialised HMAC-SHA-256 outbound MAC algorithm
. 2022-10-18 01:18:32.389 Initialised AES-256 SDCTR (AES-NI accelerated) [aes256-ctr] inbound encryption
. 2022-10-18 01:18:32.389 Initialised HMAC-SHA-256 inbound MAC algorithm
! 2022-10-18 01:18:32.467 Using username "***".
< 2022-10-18 01:18:32.467 Script: Using username "***".
. 2022-10-18 01:18:32.530 Server offered these authentication methods: publickey,password
. 2022-10-18 01:18:32.530 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2022-10-18 01:18:32.530 Using stored password.
< 2022-10-18 01:18:32.530 Script: Authenticating with pre-entered password.
. 2022-10-18 01:18:32.530 Sent password
. 2022-10-18 01:18:32.666 Access granted
. 2022-10-18 01:18:32.666 Opening main session channel
. 2022-10-18 01:18:32.729 Opened main channel
. 2022-10-18 01:18:32.791 Started a shell/command
< 2022-10-18 01:18:32.791 Script: Authenticated.
. 2022-10-18 01:18:32.791 --------------------------------------------------------------------------
. 2022-10-18 01:18:32.807 Using SFTP protocol.
. 2022-10-18 01:18:32.807 Doing startup conversation with host.
< 2022-10-18 01:18:32.807 Script: Starting the session...
> 2022-10-18 01:18:32.807 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2022-10-18 01:18:32.869 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2022-10-18 01:18:32.869 SFTP version 3 negotiated.
. 2022-10-18 01:18:32.869 We believe the server has signed timestamps bug
. 2022-10-18 01:18:32.869 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory
. 2022-10-18 01:18:32.869 Getting current directory name.
. 2022-10-18 01:18:32.869 Getting real path for '.'
> 2022-10-18 01:18:32.869 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2022-10-18 01:18:32.947 Type: SSH_FXP_NAME, Size: 51, Number: 16
. 2022-10-18 01:18:32.947 Real path is '/'
. 2022-10-18 01:18:32.947 Startup conversation with host finished.
< 2022-10-18 01:18:32.947 Script: Session started.
< 2022-10-18 01:18:32.947 Script: Active session: [1] ***.com
> 2022-10-18 01:18:32.947 Script: cd /RemoteFolder/Hotsheet
. 2022-10-18 01:18:32.947 Cached directory change via "/RemoteFolder/Hotsheet" to "/RemoteFolder/Hotsheet".
. 2022-10-18 01:18:32.947 Getting current directory name.
< 2022-10-18 01:18:32.947 Script: /RemoteFolder/Hotsheet
> 2022-10-18 01:18:32.947 Script: put -nopreservetime C:\PDDBAPPS\HotSheet.dat
. 2022-10-18 01:18:32.947 Copying 1 files/directories to remote directory "/ToCivicSmart/Hotsheet" - total size: 12,622,198
. 2022-10-18 01:18:32.947   PrTime: No; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2022-10-18 01:18:32.947   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2022-10-18 01:18:32.947   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2022-10-18 01:18:32.947 File: 'C:\PDDBAPPS\HotSheet.dat' [2022-10-18T07:09:07.324Z] [12622198]
. 2022-10-18 01:18:32.947 Copying "C:\PDDBAPPS\HotSheet.dat" to remote directory started.
. 2022-10-18 01:18:32.947 Binary transfer mode selected.
. 2022-10-18 01:18:32.947 Checking existence of file.
> 2022-10-18 01:18:32.947 Type: SSH_FXP_LSTAT, Size: 44, Number: 263
< 2022-10-18 01:18:33.010 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2022-10-18 01:18:33.010 File exists: HotSheet.dat;-;12622198;2022-10-18T08:06:15.000Z;4;"" [0];"" [0];rwx------;0
. 2022-10-18 01:18:33.025 Checking existence of partially transferred file.
> 2022-10-18 01:18:33.025 Type: SSH_FXP_LSTAT, Size: 53, Number: 519
< 2022-10-18 01:18:33.088 Type: SSH_FXP_STATUS, Size: 32, Number: 519
< 2022-10-18 01:18:33.088 Status code: 2
. 2022-10-18 01:18:33.088 Opening remote file.
> 2022-10-18 01:18:33.088 Type: SSH_FXP_OPEN, Size: 69, Number: 771
< 2022-10-18 01:18:33.166 Type: SSH_FXP_HANDLE, Size: 17, Number: 771
> 2022-10-18 01:18:33.166 Type: SSH_FXP_WRITE, Size: 32797, Number: 1286
. 2022-10-18 01:18:34.572 Increasing send buffer from 262144 to 524288
. 2022-10-18 01:19:34.504 693 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2022-10-18 01:19:34.504 Type: SSH_FXP_CLOSE, Size: 17, Number: 91652
< 2022-10-18 01:19:34.504 Type: SSH_FXP_STATUS, Size: 19, Number: 88582
< 2022-10-18 01:19:34.504 Status code: 0
< 2022-10-18 01:19:34.629 Type: SSH_FXP_STATUS, Size: 19, Number: 88838
< 2022-10-18 01:19:34.629 Status code: 0
< 2022-10-18 01:19:35.145 Type: SSH_FXP_STATUS, Size: 19, Number: 89094
< 2022-10-18 01:19:35.145 Status code: 0
< 2022-10-18 01:19:35.145 Type: SSH_FXP_STATUS, Size: 19, Number: 89350
< 2022-10-18 01:19:35.332 Type: SSH_FXP_STATUS, Size: 19, Number: 89606
< 2022-10-18 01:19:35.332 Status code: 0
< 2022-10-18 01:19:35.535 Type: SSH_FXP_STATUS, Size: 19, Number: 89862
< 2022-10-18 01:19:35.535 Status code: 0
< 2022-10-18 01:19:35.738 Type: SSH_FXP_STATUS, Size: 19, Number: 90118
< 2022-10-18 01:19:35.738 Status code: 0
< 2022-10-18 01:19:35.972 Type: SSH_FXP_STATUS, Size: 19, Number: 90374
< 2022-10-18 01:19:35.972 Status code: 0
< 2022-10-18 01:19:36.129 Type: SSH_FXP_STATUS, Size: 19, Number: 90630
< 2022-10-18 01:19:36.129 Status code: 0
< 2022-10-18 01:19:36.316 Type: SSH_FXP_STATUS, Size: 19, Number: 90886
< 2022-10-18 01:19:36.316 Status code: 0
< 2022-10-18 01:19:36.488 Type: SSH_FXP_STATUS, Size: 19, Number: 91142
< 2022-10-18 01:19:36.488 Status code: 0
< 2022-10-18 01:19:36.816 Type: SSH_FXP_STATUS, Size: 19, Number: 91398
< 2022-10-18 01:19:36.816 Status code: 0
< 2022-10-18 01:19:36.816 Type: SSH_FXP_STATUS, Size: 19, Number: 91652
> 2022-10-18 01:19:36.816 Type: SSH_FXP_REMOVE, Size: 44, Number: 91917
< 2022-10-18 01:19:36.894 Type: SSH_FXP_STATUS, Size: 19, Number: 91917
< 2022-10-18 01:19:36.894 Status code: 0
> 2022-10-18 01:19:36.894 Type: SSH_FXP_RENAME, Size: 92, Number: 92178
< 2022-10-18 01:19:36.972 Type: SSH_FXP_STATUS, Size: 19, Number: 92178
< 2022-10-18 01:19:36.972 Status code: 0
> 2022-10-18 01:19:36.972 Type: SSH_FXP_SETSTAT, Size: 52, Number: 1033
< 2022-10-18 01:19:37.035 Type: SSH_FXP_STATUS, Size: 19, Number: 1033
< 2022-10-18 01:19:37.035 Status code: 0
. 2022-10-18 01:19:37.035 Transfer done: 'C:\PDDBAPPS\HotSheet.dat' => '/RemoteFolder/Hotsheet/HotSheet.dat' [12622198]
. 2022-10-18 01:19:37.035 Copying finished: Transferred: 12,622,198, Elapsed: 0:01:04, CPS: 196,951/s
> 2022-10-18 01:19:37.035 Script: exit
. 2022-10-18 01:19:37.035 Script: Exit code: 0
. 2022-10-18 01:19:37.035 Closing connection.
. 2022-10-18 01:19:37.035 Sending special code: 1
. 2022-10-18 01:19:37.097 Main session channel closed
. 2022-10-18 01:19:37.097 All channels closed
Reply with quote E-mail
Re: Trouble Uploading
Post a log file of FileZilla upload. And a log of you checking, if the file is there. What if you add ls command after the put? Would it list the uploaded file?
