Synchronise with delete local file if successfly put
sacorman
I have a FTP in passive mode and port range restriction.
Sometime, my application hang to make the FTP because all port are used.
So, I analyse the idea to use winscp for copying generated reports to a folder and sync this folder with my web server.
I can schedule a call to an WinSCP script each hour and sync files with the remote server.
But my desire is: if the file has been successfully transferred, the file on local is deleted.
With this scenario, if the transfers failed the file are keep on local and ready for next run.
