PowerShell script does not recognize path
sleepersimulant
Switzerland
Hello dear forum
I have written a PowerShell script which should automatically open the saved session and copy files from the source to the destination (Windows to Linux). New files are to be copied or revised, as the script will run every minute.
The connection can be established but then I get the error message:
Compare ...
Local “remote” <= remote station “testfolder
Error displaying the directory “remote\*.*”.
Error retrieving the file list for “remote\*.*”.
What could be the cause? I can see the folder via the WinSCP GUI and the files in it are listed.
The script was tested in PowerShell ISE
$winscpPath = "C:\Program Files (x86)\WinSCP\WinSCP.com"
$sessionName = "testuser"
$sourcePath = "C:\Users\test user\Documents\Test"
$destinationPath = "/testfolder"
$scriptPath = [System.IO.Path]::GetTempFileName()
open $sessionName
lcd "$sourcePath"
cd "$destinationPath"
synchronize -criteria=either -filemask="*>=1D" local remote
"@ | Set-Content -Path $scriptPath
& $winscpPath /script="$scriptPath"
Remove-Item $scriptPath
Re: Powershell script does not recognize path
The local remote shouldn't be there.
Either you want:
lcd "$sourcePath"
or
synchronize -criteria=either -filemask="*>=1D" "$sourcePath" "$destinationPath"
sleepersimulant
Switzerland
Thanks a lot!
I have now taken your input and tested this and get the following output back:
Searching for host...
Connecting to host...
Authenticating...
Using username "testuser".
Authenticated.
Starting the session...
Session started.
Active session: [1] testuser
C:\Users\testuser\Documents\Test
/testfolder/test
Unknown option 'C:\Users\testuser\Documents\Test'.
Which of my two suggestions have you taken? What does your current code look line? What does the generated script file look like?
sleepersimulant
Switzerland
Hello martin!
Thanks for your reply and time.
I have tested both variants.
The first variant:
open $sessionName
lcd "$sourcePath"
Output in ISE:
Aktive Sitzung: [1] testuser
/testfolder
Unbekannte Option „C:\Users\testuser\Documents\Test“.
(translated: unknown option C:\PATH)
Second variant:
open $sessionName
lcd "$sourcePath"
Output:
/testfolder/test
Parameter für Befehl „synchronize“ fehlt.
(translated: Parameter for synchronization missing)
Sorry, I've misunderstood your code.
So the synchronize command needs to include the direction parameter – local or remote or both. Like this:
synchronize -criteria=either -filemask="*>=1D" local "$sourcePath" "$destinationPath"
