Topic "Cannot authenticate using script?"
o_o
I have used the GUI version of WinSCP to transfer files from my home to my university Linux account since about a year. I am now getting into scripting, and I cannot figure out how to get this to work. I have gone through the documentation on scripting and the FAQ but still I think that I might be doing something obviously wrong.
Using the WinSCP GUI I can log in to my university account both using the Keyboard and using a key. I now tried the following script: (called winscp_trial.sh in my My Documents) My username is masca
option batch on
open masca:passwd@something.uni-stuttgart.de
cd /home/home_dir
I started the cmd prompt on Win XP and got into the My Documents and then entered the following command:
"C:\Program Files\WinSCP3\WinSCP3.exe" /console /script=winscp_trial.sh
I get a black window that opens up with the following text
batch on
confirm off
Initialisation...
Searching for host...
Connecting to host...
Authenticating...
Using username "maca".
Using keyboard-interactive authentication.
Access denied.
Authentication failed.
Access denied.
Unable to authenticate
No session.
winscp>
Any ideas on what I need to do next. Thanks to all who take their time to help me.
Regards,
O.O.
If you login using private key, you have these options:
1) Setup stored session with associated key and use the name of the stored session as parameter of "open" command.
2) Use /privatekey command line option to specify default private key.
3) Use pageant.
o_o
prikryl wrote:
If you login using provate key, you have these options:
2) Use /privatkey command line option to specify default private key.
3) Use pageant.
Dear Martin,
Thanks for responding. I dont know why I cannot login either using a password, or using a private key. However making a stored session and then using the name of the session in the script works.
I have a few more questions, but I think I would post a separate threads on those topics. Thanks for your site and taking the time to answer our questions.
Regards,
O.O.
