Topic "550 Directory does not exist."
Zyx
This is my WinSPC's log file...
. 2007-08-28 14.59.00.396 -----------------------------------------------------
. 2007-08-28 14.59.00.396 WinSCP Version 4.0.3 (Build 345) (OS 5.1.2600 SP 2)
. 2007-08-28 14.59.00.396 Login time: marted 28 agosto 2007 14.59.00
. 2007-08-28 14.59.00.396 Session name: my2@ftp.my.it
. 2007-08-28 14.59.00.396 Host name: ftp.my.it (Port: 21)
. 2007-08-28 14.59.00.396 User name: my2 (Password: No, Key file: No)
. 2007-08-28 14.59.00.396 Tunnel: No
. 2007-08-28 14.59.00.396 Transfer Protocol: FTP
. 2007-08-28 14.59.00.396 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2007-08-28 14.59.00.396 Proxy: none
. 2007-08-28 14.59.00.396 FTP: Passive: No
. 2007-08-28 14.59.00.396 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-08-28 14.59.00.396 Cache directory changes: Yes, Permanent: Yes
. 2007-08-28 14.59.00.412 DST mode: 1
. 2007-08-28 14.59.00.412 -----------------------------------------------------
. 2007-08-28 14.59.00.458 Password prompt (no password provided or last login attempt failed)
. 2007-08-28 14.59.14.562 Connecting to ftp.my.it ...
. 2007-08-28 14.59.14.687 Connected with ftp.my.it. Waiting for welcome message...
< 2007-08-28 14.59.15.140 220 Welcome to my S.r.l.
> 2007-08-28 14.59.15.140 USER my2
< 2007-08-28 14.59.15.171 331 Please send PASS now.
> 2007-08-28 14.59.15.171 PASS *******************
< 2007-08-28 14.59.15.202 230-Welcome 'my2'.
< 2007-08-28 14.59.15.405 230-There are currently 1 users logged onto this server.
< 2007-08-28 14.59.15.405 230-There are currently 1 users logged onto this account.
< 2007-08-28 14.59.15.405 230 You are currently in directory '/'.
> 2007-08-28 14.59.15.405 SYST
< 2007-08-28 14.59.15.436 215 UNIX Type: L8
> 2007-08-28 14.59.15.436 FEAT
< 2007-08-28 14.59.15.468 500 Command not understood.
. 2007-08-28 14.59.15.468 Connected
. 2007-08-28 14.59.15.468 -----------------------------------------------------
. 2007-08-28 14.59.15.468 Using FTP protocol.
. 2007-08-28 14.59.15.499 Doing startup conversation with host.
> 2007-08-28 14.59.15.499 PWD
< 2007-08-28 14.59.15.546 257 "/" is current directory.
. 2007-08-28 14.59.15.546 Getting current directory name.
. 2007-08-28 14.59.15.608 Retrieving directory listing...
> 2007-08-28 14.59.15.608 TYPE A
< 2007-08-28 14.59.15.639 200 Type set to 'A' (ASCII).
> 2007-08-28 14.59.15.920 PORT xxx,yyy,zzz,kkk,www,qqq
< 2007-08-28 14.59.15.967 200 PORT command successful.
> 2007-08-28 14.59.15.967 LIST -a
< 2007-08-28 14.59.15.999 550 Directory does not exist.
. 2007-08-28 14.59.15.999 Could not retrieve directory listing
* 2007-08-28 14.59.16.045 (ECommand) Error listing directory '/'.
* 2007-08-28 14.59.16.045 Could not retrieve directory listing
* 2007-08-28 14.59.16.045 Directory does not exist.
. 2007-08-28 14.59.18.279 Startup conversation with host finished.
. 2007-08-28 14.59.29.243 Disconnected from server
but if I use FileZilla or other client all is ok!
This is FTP Explorer's log file...
Connecting to: FTP my
Connection Established
Connected to: FTP my
USER my2
PASS
230-Welcome 'my2'.
SYST
215 UNIX Type: L8
PWD
TYPE A
PORT PORT xxx,yyy,zzz,kkk,www,qqq
LIST
150 Data connetion established, beginning transfer.
226 Transfer complete.
How can I solve problem to use WinSCP?
Thanks!
This is known issue that has been resolved already. The fix will be included into the next release.
Zyx
I Am sad because I will not be able to use WinSPC until its new version will be available.
Or exists a tip that allow me to use WinSCP now? Thanks.
No Sad
Zyx
Crying or Very sad does it means that nobody can use WinSCP now ?
Or only can't I use it for some specific reasons ?!
The reason you cannot use it is that your server does not support "LIST -a" command. Upgrade to 4.0.4, it should fix it.
Zyx
I upgraded WinSCP to 4.0.4 (build 346), but now the problem is a loop:
Connected
Starting the session...
Reading remote directory...
Directory listing successful
Is there another problem? I am unlucky?!
Can you post a log with higher details?
