Topic "Does SSPI work?"
harvey.kwok@...
I am using WinSCP 4.0.4. I was trying to use Kerberos Authentication. I notice there is a GSSAPI/SSPI authentication checkbox. I checked it. However, at the time I checked Attempt Kerberos 5 GSSAPI/SSPI authentication (SSH-2) checkbox, it prompts me
Error
MIT Kerberos 5 GSSAPI not found. You need to install it before using this feature.
OK
I ignore it and go ahead to enter username and leave the password field blank. I could successfully logon to my SSH server using Kerberos.
So, my question is "does SSPI support in WinSCP 4.0.4?" If the answer is "yes", why am I prompted to install MIT Kerberos 5 GSSAPI?
I'll send you a debug version soon.
This is has been resolved already. The fix will be included into the next release.
