Topic "resume issue in 4.04"
Crepeau
Concerning the resume issue (see my previous topic far below) , I am very disapointed.
I download 4.04 , and use it in DOS mode
And after this downloading, when a communication break occurs, transfer of a large file doesn't restart at all
see the log file:
Searching for host...
Connecting to host...
Authenticating...
Using username "100.0.0.126".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] mysession
batch on
confirm off
transfer binary
D:\data\essai19M.ex | 8924 kB | 376.9 kB/s | binary | 46%
Network error: Software caused connection abort
(A)bort, (R)econnect: Abort
Session 'mysession' closed.
No session.
No session.
end of log file
Is there any difference in settings between 4.02 and 4.04 ?
I currently work with settings in winscp.ini file
I only found the following settings:
confirmResume = 1
resumeSupport=1
resumeThreshold=102400
these settings seems OK
can I check any other settings in winscp.ini ?
Any idea ?
thanks for your product and your support
Alain Crepeau
______________________________________________________________________________
currently use winscp 4.02 in DOS mode.
After a communication break, WinSCP tries to reconnect automatically every 2s . ( By the mean, this delay cannot be changed -refer to my previous topic)
If the communication break is too long ( 2 or 3 hours), the transfer cannot resume correctly after communication repair and
The following message :
No buffer space available.
appears
For information, memory space used by Winscp.exe grows up to 18MB !
OK, thanks. I'll try to solve that.
I have sent you an email.
This has been resolved already. The fix will be included into the next release.
