Topic "Copying folders with FTPS and filezilla server fails"
rdevries
I connect to the server using FTPS and can view the files and folders. I can copy multiple files. When i try to copy a folder i get Error transferring file...copying files from remote side failed. Abort - Retry - Skip - Skip all - Help
When I click the "Skip all" the folder copies all the files
Ralph
