Topic "WinSCP appends occasionally files when it should overwrite"
Timerus
Since version 4.1.9 I had sometimes the problem, that a changed file was not overwritten (as it should) but appended.
Problem occured on Windows 7, Windows Vista and Windows XP.
GUI-based version (Commander-style)
occured on versions 4.1.9 and 4.2.1beta
Protocol is FTP
Timerus
This phenomena did not occur again yet, it seems to be very rare. But now, I have logging enabled. If it happens again, I will post the log here.
