Topic "WinSCP disconnect from server regualry when using SSL/TLS"
Roberts
Hello!
I am trying to syncronize local folder c:\work with remote on FTP server.
There are ~ 2Gb of files. When I use simple FTP witout SSL/TLS all files
after some time are syncronized to ftp server. But when I am using SSL/TLS
it is giving me errors after WinSCP has cpoied some files to server.
Disconnecting is happening on different file upload stages. After
I start syncronization againt it also coppies some files to server and again disconnect.
If I repeate syncronization lot lot of times WinSCP at the end has copied all files to server.
Errors, taht is shown in log are:
[i]. 2009-07-01 11:21:11.687 Asking user:
. 2009-07-01 11:21:11.687 Error listing directory '/'. ("Could not retrieve directory listing","CWD successful. ""/"" is current directory.")
[/i]
or
. 2009-07-01 11:22:21.046 Asking user:
. 2009-07-01 11:22:21.046 Error listing directory '/'. ("Could not retrieve directory listing","Directory already exists")
Using Server: FileZilla 0.9.32 beta
Using Client: WinSCP 4.22; Windows XP PRO
Transfering using: SSL/TLS Implicit
c:\FileSync\winscp422.exe session@ftp.domainname.lv /script=c:\FileSync\script.txt /log=c:\FileSync\sync.log
##script.txt
option batch on
synchronize remote -criteria=date -delete c:\work /
synchronize remote -criteria=size -delete c:\work /
put c:\FileSync\sync.log /
Roberts
. 2009-07-01 11:19:47.906 --------------------------------------------------------------------------
. 2009-07-01 11:19:47.906 WinSCP Version 4.2.2 (Build 480) (OS 5.1.2600 Service Pack 3)
. 2009-07-01 11:19:47.906 Login time: trediena, 2009. gada 1. jūlijs 11:19:47
. 2009-07-01 11:19:47.906 Session name: 01-WORK@ftp.domainname.lv
. 2009-07-01 11:19:47.906 Host name: ftp.domainname.lv (Port: 21)
. 2009-07-01 11:19:47.906 User name: Username (Password: Yes, Key file: No)
. 2009-07-01 11:19:47.906 Tunnel: No
. 2009-07-01 11:19:47.906 Transfer Protocol: FTP
. 2009-07-01 11:19:47.906 Ping type: C, Ping interval: 10 sec; Timeout: 180 sec
. 2009-07-01 11:19:47.906 Proxy: none
. 2009-07-01 11:19:47.906 FTP: FTPS: Explicit TLS; Passive: No
. 2009-07-01 11:19:47.906 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-07-01 11:19:47.906 Cache directory changes: Yes, Permanent: Yes
. 2009-07-01 11:19:47.906 DST mode: 1
. 2009-07-01 11:19:47.906 Connecting to ftp.domainname.lv ...
. 2009-07-01 11:19:47.906 Connected with ftp.domainname.lv, negotiating SSL connection...
< 2009-07-01 11:19:47.921 220 MWL FTP serveris
> 2009-07-01 11:19:47.921 AUTH TLS
< 2009-07-01 11:19:48.140 234 Using authentication type TLS
. 2009-07-01 11:19:48.359 SSL connection established. Waiting for welcome message...
> 2009-07-01 11:19:48.359 USER username
< 2009-07-01 11:19:48.359 331 Password required for username
> 2009-07-01 11:19:48.359 PASS ********
< 2009-07-01 11:19:48.359 230 Logged on
> 2009-07-01 11:19:48.359 SYST
< 2009-07-01 11:19:48.375 215 UNIX emulated by FileZilla
> 2009-07-01 11:19:48.375 FEAT
< 2009-07-01 11:19:48.375 211-Features:
< 2009-07-01 11:19:48.375 MDTM
< 2009-07-01 11:19:48.375 REST STREAM
< 2009-07-01 11:19:48.375 SIZE
< 2009-07-01 11:19:48.375 MLST type*;size*;modify*;
< 2009-07-01 11:19:48.375 MLSD
< 2009-07-01 11:19:48.375 AUTH SSL
< 2009-07-01 11:19:48.375 AUTH TLS
< 2009-07-01 11:19:48.375 UTF8
< 2009-07-01 11:19:48.375 CLNT
< 2009-07-01 11:19:48.375 MFMT
< 2009-07-01 11:19:48.375 211 End
> 2009-07-01 11:19:48.375 PBSZ 0
< 2009-07-01 11:19:48.375 200 PBSZ=0
> 2009-07-01 11:19:48.375 PROT P
< 2009-07-01 11:19:48.375 200 Protection level set to P
. 2009-07-01 11:19:48.375 Connected
. 2009-07-01 11:19:48.375 --------------------------------------------------------------------------
. 2009-07-01 11:19:48.375 Using FTP protocol.
. 2009-07-01 11:19:48.375 Doing startup conversation with host.
> 2009-07-01 11:19:48.375 PWD
< 2009-07-01 11:19:48.375 257 "/" is current directory.
. 2009-07-01 11:19:48.375 Getting current directory name.
. 2009-07-01 11:19:48.375 Startup conversation with host finished.
. 2009-07-01 11:19:48.375 Collecting synchronization list for local directory 'c:\work' and remote directory '/', mode = 0, params = 3
. 2009-07-01 11:19:48.375 Retrieving directory listing...
> 2009-07-01 11:19:48.375 TYPE A
< 2009-07-01 11:19:48.375 200 Type set to A
> 2009-07-01 11:19:48.375 PORT 192,168,0,109,6,249
< 2009-07-01 11:19:48.390 200 Port command successful
> 2009-07-01 11:19:48.390 LIST -a
< 2009-07-01 11:19:48.390 150 Opening data channel for directory list.
. 2009-07-01 11:19:48.421 SSL connection established
< 2009-07-01 11:19:48.421 226 Transfer OK
. 2009-07-01 11:19:48.421 Directory listing successful
. 2009-07-01 11:19:48.421 Synchronizing local directory 'c:\work\' with remote directory '/', params = 3
. 2009-07-01 11:19:48.421 Copying 1 files/directories to remote directory "/"
. 2009-07-01 11:19:48.421 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask: *.*
. 2009-07-01 11:19:48.421 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-07-01 11:19:48.421 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-07-01 11:19:48.421 File: "c:\work\projects"
. 2009-07-01 11:19:48.421 File: "c:\work\projects\153_Aigas_Nams"
. 2009-07-01 11:19:48.421 File: "c:\work\projects\153_Aigas_Nams\Aigas_nams_apaksuznemeju_novertejums.xls"
. 2009-07-01 11:19:48.421 Copying "c:\work\projects\153_Aigas_Nams\Aigas_nams_apaksuznemeju_novertejums.xls" to remote directory started.
. 2009-07-01 11:19:48.421 Binary transfer mode selected.
. 2009-07-01 11:19:48.421 Starting upload of c:\work\projects\153_Aigas_Nams\Aigas_nams_apaksuznemeju_novertejums.xls
> 2009-07-01 11:19:48.421 CWD /projects/153_Aigas_Nams/
< 2009-07-01 11:19:48.421 550 CWD failed. "/projects/153_Aigas_Nams": directory not found.
< 2009-07-01 11:19:48.437 550 CWD failed. "/projects": directory not found.
> 2009-07-01 11:19:48.437 CWD /
< 2009-07-01 11:19:48.437 250 CWD successful. "/" is current directory.
> 2009-07-01 11:19:48.437 MKD projects
< 2009-07-01 11:19:48.437 257 Directory created successfully
> 2009-07-01 11:19:48.437 CWD /projects/
< 2009-07-01 11:19:48.437 250 CWD successful. "/projects" is current directory.
> 2009-07-01 11:19:48.437 MKD 153_Aigas_Nams
< 2009-07-01 11:19:48.453 257 Directory created successfully
> 2009-07-01 11:19:48.453 CWD /projects/153_Aigas_Nams/
< 2009-07-01 11:19:48.453 250 CWD successful. "/projects/153_Aigas_Nams" is current directory.
> 2009-07-01 11:19:48.453 PWD
< 2009-07-01 11:19:48.453 257 "/projects/153_Aigas_Nams" is current directory.
> 2009-07-01 11:19:48.453 TYPE A
< 2009-07-01 11:19:48.468 200 Type set to A
> 2009-07-01 11:19:48.468 PORT 192,168,0,109,6,250
< 2009-07-01 11:19:48.468 200 Port command successful
> 2009-07-01 11:19:48.468 LIST -a
< 2009-07-01 11:19:48.468 150 Opening data channel for directory list.
. 2009-07-01 11:19:48.484 SSL connection established
< 2009-07-01 11:19:48.484 226 Transfer OK
> 2009-07-01 11:19:48.484 TYPE I
< 2009-07-01 11:19:48.500 200 Type set to I
> 2009-07-01 11:19:48.500 PORT 192,168,0,109,6,251
< 2009-07-01 11:19:48.500 200 Port command successful
> 2009-07-01 11:19:48.500 STOR Aigas_nams_apaksuznemeju_novertejums.xls
< 2009-07-01 11:19:48.500 150 Opening data channel for file transfer.
. 2009-07-01 11:19:48.515 SSL connection established
< 2009-07-01 11:19:48.546 226 Transfer OK
> 2009-07-01 11:19:48.546 MFMT 20081216133901 Aigas_nams_apaksuznemeju_novertejums.xls
< 2009-07-01 11:19:48.546 213 modify=20081216133901; /projects/153_Aigas_Nams/Aigas_nams_apaksuznemeju_novertejums.xls
. 2009-07-01 11:19:48.546 Upload successful
. 2009-07-01 11:19:48.546 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping"
. 2009-07-01 11:19:48.546 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss.xls"
. 2009-07-01 11:19:48.546 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss.xls" to remote directory started.
. 2009-07-01 11:19:48.546 Binary transfer mode selected.
. 2009-07-01 11:19:48.546 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss.xls
> 2009-07-01 11:19:48.546 CWD /projects/153_Aigas_Nams/Bookkeeping/
< 2009-07-01 11:19:48.562 550 CWD failed. "/projects/153_Aigas_Nams/Bookkeeping": directory not found.
> 2009-07-01 11:19:48.562 CWD /projects/153_Aigas_Nams/
< 2009-07-01 11:19:48.562 250 CWD successful. "/projects/153_Aigas_Nams" is current directory.
> 2009-07-01 11:19:48.562 MKD Bookkeeping
< 2009-07-01 11:19:48.578 257 Directory created successfully
> 2009-07-01 11:19:48.578 CWD /projects/153_Aigas_Nams/Bookkeeping/
< 2009-07-01 11:19:48.578 250 CWD successful. "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-01 11:19:48.578 PWD
< 2009-07-01 11:19:48.578 257 "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-01 11:19:48.578 TYPE A
< 2009-07-01 11:19:48.578 200 Type set to A
> 2009-07-01 11:19:48.593 PORT 192,168,0,109,6,252
< 2009-07-01 11:19:48.593 200 Port command successful
> 2009-07-01 11:19:48.593 LIST -a
< 2009-07-01 11:19:48.593 150 Opening data channel for directory list.
. 2009-07-01 11:19:48.609 SSL connection established
< 2009-07-01 11:19:48.625 226 Transfer OK
> 2009-07-01 11:19:48.625 TYPE I
< 2009-07-01 11:19:48.625 200 Type set to I
> 2009-07-01 11:19:48.625 PORT 192,168,0,109,6,253
< 2009-07-01 11:19:48.625 200 Port command successful
> 2009-07-01 11:19:48.625 STOR Aigas nams_Bonuss.xls
< 2009-07-01 11:19:48.640 150 Opening data channel for file transfer.
. 2009-07-01 11:19:48.656 SSL connection established
< 2009-07-01 11:19:48.687 226 Transfer OK
> 2009-07-01 11:19:48.687 MFMT 20081031080650 Aigas nams_Bonuss.xls
< 2009-07-01 11:19:48.687 213 modify=20081031080650; /projects/153_Aigas_Nams/Bookkeeping/Aigas nams_Bonuss.xls
. 2009-07-01 11:19:48.703 Upload successful
. 2009-07-01 11:19:48.703 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss_1.xls"
. 2009-07-01 11:19:48.703 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss_1.xls" to remote directory started.
. 2009-07-01 11:19:48.703 Binary transfer mode selected.
. 2009-07-01 11:19:48.703 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss_1.xls
> 2009-07-01 11:19:48.703 TYPE I
< 2009-07-01 11:19:48.703 200 Type set to I
> 2009-07-01 11:19:48.703 PORT 192,168,0,109,6,254
< 2009-07-01 11:19:48.703 200 Port command successful
> 2009-07-01 11:19:48.703 STOR Aigas nams_Bonuss_1.xls
< 2009-07-01 11:19:48.718 150 Opening data channel for file transfer.
. 2009-07-01 11:19:48.734 SSL connection established
< 2009-07-01 11:19:48.765 226 Transfer OK
> 2009-07-01 11:19:48.765 MFMT 20081031090601 Aigas nams_Bonuss_1.xls
< 2009-07-01 11:19:48.781 213 modify=20081031090601; /projects/153_Aigas_Nams/Bookkeeping/Aigas nams_Bonuss_1.xls
. 2009-07-01 11:19:48.781 Upload successful
. 2009-07-01 11:19:48.781 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti"
. 2009-07-01 11:19:48.781 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Darbu_pienemsanas-nodosanas_akts_1.doc"
. 2009-07-01 11:19:48.781 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Darbu_pienemsanas-nodosanas_akts_1.doc" to remote directory started.
. 2009-07-01 11:19:48.781 Binary transfer mode selected.
. 2009-07-01 11:19:48.781 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Darbu_pienemsanas-nodosanas_akts_1.doc
> 2009-07-01 11:19:48.781 CWD /projects/153_Aigas_Nams/Bookkeeping/Akti/
< 2009-07-01 11:19:48.796 550 CWD failed. "/projects/153_Aigas_Nams/Bookkeeping/Akti": directory not found.
> 2009-07-01 11:19:48.796 CWD /projects/153_Aigas_Nams/Bookkeeping/
< 2009-07-01 11:19:48.796 250 CWD successful. "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-01 11:19:48.796 MKD Akti
< 2009-07-01 11:19:48.812 257 Directory created successfully
> 2009-07-01 11:19:48.812 CWD /projects/153_Aigas_Nams/Bookkeeping/Akti/
< 2009-07-01 11:19:48.812 250 CWD successful. "/projects/153_Aigas_Nams/Bookkeeping/Akti" is current directory.
> 2009-07-01 11:19:48.812 PWD
< 2009-07-01 11:19:48.812 257 "/projects/153_Aigas_Nams/Bookkeeping/Akti" is current directory.
> 2009-07-01 11:19:48.812 TYPE A
< 2009-07-01 11:19:48.812 200 Type set to A
> 2009-07-01 11:19:48.828 PORT 192,168,0,109,6,255
< 2009-07-01 11:19:48.828 200 Port command successful
> 2009-07-01 11:19:48.828 LIST -a
< 2009-07-01 11:19:48.828 150 Opening data channel for directory list.
. 2009-07-01 11:19:48.843 SSL connection established
< 2009-07-01 11:19:48.843 226 Transfer OK
> 2009-07-01 11:19:48.859 TYPE I
< 2009-07-01 11:19:48.859 200 Type set to I
> 2009-07-01 11:19:48.859 PORT 192,168,0,109,7,0
< 2009-07-01 11:19:48.859 200 Port command successful
> 2009-07-01 11:19:48.859 STOR Darbu_pienemsanas-nodosanas_akts_1.doc
< 2009-07-01 11:19:48.875 150 Opening data channel for file transfer.
. 2009-07-01 11:19:48.890 SSL connection established
< 2009-07-01 11:19:48.921 226 Transfer OK
> 2009-07-01 11:19:48.921 MFMT 20081015054543 Darbu_pienemsanas-nodosanas_akts_1.doc
< 2009-07-01 11:19:48.921 213 modify=20081015054543; /projects/153_Aigas_Nams/Bookkeeping/Akti/Darbu_pienemsanas-nodosanas_akts_1.doc
. 2009-07-01 11:19:48.921 Upload successful
. 2009-07-01 11:19:48.921 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Nod_pien_akts_Merks_DLW(4).doc"
. 2009-07-01 11:19:48.921 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Nod_pien_akts_Merks_DLW(4).doc" to remote directory started.
. 2009-07-01 11:19:48.937 Binary transfer mode selected.
. 2009-07-01 11:19:48.937 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Nod_pien_akts_Merks_DLW(4).doc
> 2009-07-01 11:19:48.937 TYPE I
< 2009-07-01 11:19:48.937 200 Type set to I
> 2009-07-01 11:19:48.937 PORT 192,168,0,109,7,1
< 2009-07-01 11:19:48.937 200 Port command successful
> 2009-07-01 11:19:48.937 STOR Nod_pien_akts_Merks_DLW(4).doc
< 2009-07-01 11:19:48.953 150 Opening data channel for file transfer.
. 2009-07-01 11:19:48.968 SSL connection established
< 2009-07-01 11:19:49.000 226 Transfer OK
> 2009-07-01 11:19:49.000 MFMT 20090610063739 Nod_pien_akts_Merks_DLW(4).doc
< 2009-07-01 11:19:49.015 213 modify=20090610063739; /projects/153_Aigas_Nams/Bookkeeping/Akti/Nod_pien_akts_Merks_DLW(4).doc
. 2009-07-01 11:19:49.015 Upload successful
. 2009-07-01 11:19:49.015 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 1.xls"
. 2009-07-01 11:19:49.015 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 1.xls" to remote directory started.
. 2009-07-01 11:19:49.015 Binary transfer mode selected.
. 2009-07-01 11:19:49.015 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 1.xls
> 2009-07-01 11:19:49.015 TYPE I
< 2009-07-01 11:19:49.015 200 Type set to I
> 2009-07-01 11:19:49.015 PORT 192,168,0,109,7,2
< 2009-07-01 11:19:49.015 200 Port command successful
> 2009-07-01 11:19:49.015 STOR Pabeigto darbu akts 1.xls
< 2009-07-01 11:19:49.031 150 Opening data channel for file transfer.
. 2009-07-01 11:19:49.046 SSL connection established
< 2009-07-01 11:19:49.062 226 Transfer OK
> 2009-07-01 11:19:49.062 MFMT 20080227145917 Pabeigto darbu akts 1.xls
< 2009-07-01 11:19:49.078 213 modify=20080227145917; /projects/153_Aigas_Nams/Bookkeeping/Akti/Pabeigto darbu akts 1.xls
. 2009-07-01 11:19:49.078 Upload successful
. 2009-07-01 11:19:49.078 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 2.xls"
. 2009-07-01 11:19:49.078 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 2.xls" to remote directory started.
. 2009-07-01 11:19:49.078 Binary transfer mode selected.
. 2009-07-01 11:19:49.078 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 2.xls
> 2009-07-01 11:19:49.078 TYPE I
< 2009-07-01 11:19:49.078 200 Type set to I
> 2009-07-01 11:19:49.078 PORT 192,168,0,109,7,3
< 2009-07-01 11:19:49.093 200 Port command successful
> 2009-07-01 11:19:49.093 STOR Pabeigto darbu akts 2.xls
< 2009-07-01 11:19:49.093 150 Opening data channel for file transfer.
. 2009-07-01 11:19:49.109 SSL connection established
< 2009-07-01 11:19:49.765 226 Transfer OK
> 2009-07-01 11:19:49.765 MFMT 20080213153722 Pabeigto darbu akts 2.xls
< 2009-07-01 11:19:49.765 213 modify=20080213153722; /projects/153_Aigas_Nams/Bookkeeping/Akti/Pabeigto darbu akts 2.xls
. 2009-07-01 11:19:49.765 Upload successful
. 2009-07-01 11:19:49.765 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 3.xls"
. 2009-07-01 11:19:49.781 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 3.xls" to remote directory started.
. 2009-07-01 11:19:49.781 Binary transfer mode selected.
. 2009-07-01 11:19:49.781 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 3.xls
> 2009-07-01 11:19:49.781 TYPE I
< 2009-07-01 11:19:49.781 200 Type set to I
> 2009-07-01 11:19:49.781 PORT 192,168,0,109,7,4
< 2009-07-01 11:19:49.781 200 Port command successful
> 2009-07-01 11:19:49.781 STOR Pabeigto darbu akts 3.xls
< 2009-07-01 11:19:49.796 150 Opening data channel for file transfer.
. 2009-07-01 11:19:49.812 SSL connection established
< 2009-07-01 11:19:49.828 226 Transfer OK
> 2009-07-01 11:19:49.828 MFMT 20080311081817 Pabeigto darbu akts 3.xls
< 2009-07-01 11:19:49.843 213 modify=20080311081817; /projects/153_Aigas_Nams/Bookkeeping/Akti/Pabeigto darbu akts 3.xls
. 2009-07-01 11:19:49.843 Upload successful
. 2009-07-01 11:19:49.843 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 4.xls"
. 2009-07-01 11:19:49.843 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 4.xls" to remote directory started.
. 2009-07-01 11:19:49.843 Binary transfer mode selected.
. 2009-07-01 11:19:49.843 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 4.xls
> 2009-07-01 11:19:49.843 TYPE I
< 2009-07-01 11:19:49.843 200 Type set to I
> 2009-07-01 11:19:49.843 PORT 192,168,0,109,7,5
< 2009-07-01 11:19:49.843 200 Port command successful
> 2009-07-01 11:19:49.843 STOR Pabeigto darbu akts 4.xls
< 2009-07-01 11:19:49.859 150 Opening data channel for file transfer.
. 2009-07-01 11:19:49.875 SSL connection established
< 2009-07-01 11:19:49.890 226 Transfer OK
> 2009-07-01 11:19:49.890 MFMT 20080805062411 Pabeigto darbu akts 4.xls
< 2009-07-01 11:19:49.906 213 modify=20080805062411; /projects/153_Aigas_Nams/Bookkeeping/Akti/Pabeigto darbu akts 4.xls
. 2009-07-01 11:19:49.906 Upload successful
. 2009-07-01 11:19:49.906 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 5.xls"
. 2009-07-01 11:19:49.906 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 5.xls" to remote directory started.
. 2009-07-01 11:19:49.906 Binary transfer mode selected.
. 2009-07-01 11:19:49.906 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 5.xls
> 2009-07-01 11:19:49.906 TYPE I
< 2009-07-01 11:19:49.906 200 Type set to I
> 2009-07-01 11:19:49.906 PORT 192,168,0,109,7,6
< 2009-07-01 11:19:49.921 200 Port command successful
> 2009-07-01 11:19:49.921 STOR Pabeigto darbu akts 5.xls
< 2009-07-01 11:19:49.921 150 Opening data channel for file transfer.
. 2009-07-01 11:19:49.937 SSL connection established
< 2009-07-01 11:19:49.953 226 Transfer OK
> 2009-07-01 11:19:49.968 MFMT 20081009110231 Pabeigto darbu akts 5.xls
< 2009-07-01 11:19:49.968 213 modify=20081009110231; /projects/153_Aigas_Nams/Bookkeeping/Akti/Pabeigto darbu akts 5.xls
. 2009-07-01 11:19:49.968 Upload successful
. 2009-07-01 11:19:49.968 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 6.xls"
. 2009-07-01 11:19:49.968 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 6.xls" to remote directory started.
. 2009-07-01 11:19:49.968 Binary transfer mode selected.
. 2009-07-01 11:19:49.968 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 6.xls
> 2009-07-01 11:19:49.968 TYPE I
< 2009-07-01 11:19:49.984 200 Type set to I
> 2009-07-01 11:19:49.984 PORT 192,168,0,109,7,7
< 2009-07-01 11:19:49.984 200 Port command successful
> 2009-07-01 11:19:49.984 STOR Pabeigto darbu akts 6.xls
< 2009-07-01 11:19:50.000 150 Opening data channel for file transfer.
. 2009-07-01 11:19:50.015 SSL connection established
< 2009-07-01 11:19:50.046 226 Transfer OK
> 2009-07-01 11:19:50.046 MFMT 20090114105339 Pabeigto darbu akts 6.xls
< 2009-07-01 11:19:50.062 213 modify=20090114105339; /projects/153_Aigas_Nams/Bookkeeping/Akti/Pabeigto darbu akts 6.xls
. 2009-07-01 11:19:50.062 Upload successful
. 2009-07-01 11:19:50.062 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 7.xls"
. 2009-07-01 11:19:50.062 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 7.xls" to remote directory started.
. 2009-07-01 11:19:50.062 Binary transfer mode selected.
. 2009-07-01 11:19:50.062 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 7.xls
> 2009-07-01 11:19:50.062 TYPE I
< 2009-07-01 11:19:50.062 200 Type set to I
> 2009-07-01 11:19:50.062 PORT 192,168,0,109,7,8
< 2009-07-01 11:19:50.062 200 Port command successful
> 2009-07-01 11:19:50.062 STOR Pabeigto darbu akts 7.xls
< 2009-07-01 11:19:50.078 150 Opening data channel for file transfer.
. 2009-07-01 11:19:50.093 SSL connection established
< 2009-07-01 11:19:50.109 226 Transfer OK
> 2009-07-01 11:19:50.109 MFMT 20090515090228 Pabeigto darbu akts 7.xls
< 2009-07-01 11:19:50.125 213 modify=20090515090228; /projects/153_Aigas_Nams/Bookkeeping/Akti/Pabeigto darbu akts 7.xls
. 2009-07-01 11:19:50.125 Upload successful
. 2009-07-01 11:19:50.125 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 8.xls"
. 2009-07-01 11:19:50.125 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 8.xls" to remote directory started.
. 2009-07-01 11:19:50.125 Binary transfer mode selected.
. 2009-07-01 11:19:50.125 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Akti\Pabeigto darbu akts 8.xls
> 2009-07-01 11:19:50.125 TYPE I
< 2009-07-01 11:19:50.125 200 Type set to I
> 2009-07-01 11:19:50.125 PORT 192,168,0,109,7,9
< 2009-07-01 11:19:50.140 200 Port command successful
> 2009-07-01 11:19:50.140 STOR Pabeigto darbu akts 8.xls
< 2009-07-01 11:19:50.140 150 Opening data channel for file transfer.
. 2009-07-01 11:19:50.156 SSL connection established
< 2009-07-01 11:19:50.187 226 Transfer OK
> 2009-07-01 11:19:50.187 MFMT 20090610083358 Pabeigto darbu akts 8.xls
< 2009-07-01 11:19:50.187 213 modify=20090610083358; /projects/153_Aigas_Nams/Bookkeeping/Akti/Pabeigto darbu akts 8.xls
. 2009-07-01 11:19:50.187 Upload successful
. 2009-07-01 11:19:50.187 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Def_saraksts_DLW_A_210509(1).doc"
. 2009-07-01 11:19:50.187 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Def_saraksts_DLW_A_210509(1).doc" to remote directory started.
. 2009-07-01 11:19:50.187 Binary transfer mode selected.
. 2009-07-01 11:19:50.187 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Def_saraksts_DLW_A_210509(1).doc
> 2009-07-01 11:19:50.187 CWD /projects/153_Aigas_Nams/Bookkeeping/
< 2009-07-01 11:19:50.203 250 CWD successful. "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-01 11:19:50.203 PWD
< 2009-07-01 11:19:50.203 257 "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-01 11:19:50.203 TYPE A
< 2009-07-01 11:19:50.203 200 Type set to A
> 2009-07-01 11:19:50.203 PORT 192,168,0,109,7,10
< 2009-07-01 11:19:50.203 200 Port command successful
> 2009-07-01 11:19:50.203 LIST -a
< 2009-07-01 11:19:50.218 150 Opening data channel for directory list.
. 2009-07-01 11:19:50.234 SSL connection established
< 2009-07-01 11:19:50.234 226 Transfer OK
> 2009-07-01 11:19:50.234 TYPE I
< 2009-07-01 11:19:50.234 200 Type set to I
> 2009-07-01 11:19:50.234 PORT 192,168,0,109,7,11
< 2009-07-01 11:19:50.250 200 Port command successful
> 2009-07-01 11:19:50.250 STOR Def_saraksts_DLW_A_210509(1).doc
< 2009-07-01 11:19:50.265 150 Opening data channel for file transfer.
. 2009-07-01 11:19:50.265 SSL connection established
< 2009-07-01 11:19:50.640 226 Transfer OK
> 2009-07-01 11:19:50.640 MFMT 20090610060608 Def_saraksts_DLW_A_210509(1).doc
< 2009-07-01 11:19:50.640 213 modify=20090610060608; /projects/153_Aigas_Nams/Bookkeeping/Def_saraksts_DLW_A_210509(1).doc
. 2009-07-01 11:19:50.640 Upload successful
. 2009-07-01 11:19:50.640 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Def_saraksts_DLW_B_210509(1).doc"
. 2009-07-01 11:19:50.656 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Def_saraksts_DLW_B_210509(1).doc" to remote directory started.
. 2009-07-01 11:19:50.656 Binary transfer mode selected.
. 2009-07-01 11:19:50.656 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Def_saraksts_DLW_B_210509(1).doc
> 2009-07-01 11:19:50.656 TYPE I
< 2009-07-01 11:19:50.656 200 Type set to I
> 2009-07-01 11:19:50.656 PORT 192,168,0,109,7,12
< 2009-07-01 11:19:50.656 200 Port command successful
> 2009-07-01 11:19:50.656 STOR Def_saraksts_DLW_B_210509(1).doc
< 2009-07-01 11:19:50.671 150 Opening data channel for file transfer.
. 2009-07-01 11:19:50.687 SSL connection established
< 2009-07-01 11:19:51.078 226 Transfer OK
> 2009-07-01 11:19:51.078 MFMT 20090610060612 Def_saraksts_DLW_B_210509(1).doc
< 2009-07-01 11:19:51.093 213 modify=20090610060612; /projects/153_Aigas_Nams/Bookkeeping/Def_saraksts_DLW_B_210509(1).doc
. 2009-07-01 11:19:51.093 Upload successful
. 2009-07-01 11:19:51.093 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\DLW_kompensacija.doc"
. 2009-07-01 11:19:51.093 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\DLW_kompensacija.doc" to remote directory started.
. 2009-07-01 11:19:51.093 Binary transfer mode selected.
. 2009-07-01 11:19:51.093 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\DLW_kompensacija.doc
> 2009-07-01 11:19:51.093 TYPE I
< 2009-07-01 11:19:51.093 200 Type set to I
> 2009-07-01 11:19:51.109 PORT 192,168,0,109,7,13
< 2009-07-01 11:19:51.109 200 Port command successful
> 2009-07-01 11:19:51.109 STOR DLW_kompensacija.doc
< 2009-07-01 11:19:51.125 150 Opening data channel for file transfer.
. 2009-07-01 11:19:51.140 SSL connection established
< 2009-07-01 11:19:51.156 226 Transfer OK
> 2009-07-01 11:19:51.187 MFMT 20090416115009 DLW_kompensacija.doc
< 2009-07-01 11:19:51.187 213 modify=20090416115009; /projects/153_Aigas_Nams/Bookkeeping/DLW_kompensacija.doc
. 2009-07-01 11:19:51.187 Upload successful
. 2009-07-01 11:19:51.187 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\DLW_kompensacija_1.doc"
. 2009-07-01 11:19:51.187 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\DLW_kompensacija_1.doc" to remote directory started.
. 2009-07-01 11:19:51.187 Binary transfer mode selected.
. 2009-07-01 11:19:51.187 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\DLW_kompensacija_1.doc
> 2009-07-01 11:19:51.187 TYPE I
< 2009-07-01 11:19:51.187 200 Type set to I
> 2009-07-01 11:19:51.203 PORT 192,168,0,109,7,14
< 2009-07-01 11:19:51.203 200 Port command successful
> 2009-07-01 11:19:51.203 STOR DLW_kompensacija_1.doc
< 2009-07-01 11:19:51.203 150 Opening data channel for file transfer.
. 2009-07-01 11:19:51.218 SSL connection established
< 2009-07-01 11:19:51.250 226 Transfer OK
> 2009-07-01 11:19:51.250 MFMT 20090416115127 DLW_kompensacija_1.doc
< 2009-07-01 11:19:51.250 213 modify=20090416115127; /projects/153_Aigas_Nams/Bookkeeping/DLW_kompensacija_1.doc
. 2009-07-01 11:19:51.250 Upload successful
. 2009-07-01 11:19:51.250 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\garantijas_laika_garantija.jpg"
. 2009-07-01 11:19:51.250 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\garantijas_laika_garantija.jpg" to remote directory started.
. 2009-07-01 11:19:51.250 Binary transfer mode selected.
. 2009-07-01 11:19:51.250 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\garantijas_laika_garantija.jpg
> 2009-07-01 11:19:51.250 TYPE I
< 2009-07-01 11:19:51.250 200 Type set to I
> 2009-07-01 11:19:51.265 PORT 192,168,0,109,7,15
< 2009-07-01 11:19:51.265 200 Port command successful
> 2009-07-01 11:19:51.265 STOR garantijas_laika_garantija.jpg
< 2009-07-01 11:19:51.265 150 Opening data channel for file transfer.
. 2009-07-01 11:19:51.281 SSL connection established
< 2009-07-01 11:19:51.734 226 Transfer OK
> 2009-07-01 11:19:51.734 MFMT 20090110073443 garantijas_laika_garantija.jpg
< 2009-07-01 11:19:51.734 213 modify=20090110073443; /projects/153_Aigas_Nams/Bookkeeping/garantijas_laika_garantija.jpg
. 2009-07-01 11:19:51.734 Upload successful
. 2009-07-01 11:19:51.734 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG"
. 2009-07-01 11:19:51.734 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG aprilis 2009.xls"
. 2009-07-01 11:19:51.734 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG aprilis 2009.xls" to remote directory started.
. 2009-07-01 11:19:51.734 Binary transfer mode selected.
. 2009-07-01 11:19:51.734 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG aprilis 2009.xls
> 2009-07-01 11:19:51.734 CWD /projects/153_Aigas_Nams/Bookkeeping/GG/
< 2009-07-01 11:19:51.750 550 CWD failed. "/projects/153_Aigas_Nams/Bookkeeping/GG": directory not found.
> 2009-07-01 11:19:51.750 CWD /projects/153_Aigas_Nams/Bookkeeping/
< 2009-07-01 11:19:51.750 250 CWD successful. "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-01 11:19:51.750 MKD GG
< 2009-07-01 11:19:51.765 257 Directory created successfully
> 2009-07-01 11:19:51.765 CWD /projects/153_Aigas_Nams/Bookkeeping/GG/
< 2009-07-01 11:19:51.781 250 CWD successful. "/projects/153_Aigas_Nams/Bookkeeping/GG" is current directory.
> 2009-07-01 11:19:51.781 PWD
< 2009-07-01 11:19:51.781 257 "/projects/153_Aigas_Nams/Bookkeeping/GG" is current directory.
> 2009-07-01 11:19:51.781 TYPE A
< 2009-07-01 11:19:51.781 200 Type set to A
> 2009-07-01 11:19:51.781 PORT 192,168,0,109,7,16
< 2009-07-01 11:19:51.781 200 Port command successful
> 2009-07-01 11:19:51.781 LIST -a
< 2009-07-01 11:19:51.796 150 Opening data channel for directory list.
. 2009-07-01 11:19:51.812 SSL connection established
< 2009-07-01 11:19:51.812 226 Transfer OK
> 2009-07-01 11:19:51.812 TYPE I
< 2009-07-01 11:19:51.812 200 Type set to I
> 2009-07-01 11:19:51.812 PORT 192,168,0,109,7,17
< 2009-07-01 11:19:51.812 200 Port command successful
> 2009-07-01 11:19:51.812 STOR GG aprilis 2009.xls
< 2009-07-01 11:19:51.828 150 Opening data channel for file transfer.
. 2009-07-01 11:19:51.843 SSL connection established
< 2009-07-01 11:19:51.859 226 Transfer OK
> 2009-07-01 11:19:51.859 MFMT 20090521072821 GG aprilis 2009.xls
< 2009-07-01 11:19:51.875 213 modify=20090521072821; /projects/153_Aigas_Nams/Bookkeeping/GG/GG aprilis 2009.xls
. 2009-07-01 11:19:51.875 Upload successful
. 2009-07-01 11:19:51.875 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG dec 2008.xls"
. 2009-07-01 11:19:51.875 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG dec 2008.xls" to remote directory started.
. 2009-07-01 11:19:51.875 Binary transfer mode selected.
. 2009-07-01 11:19:51.875 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG dec 2008.xls
> 2009-07-01 11:19:51.875 TYPE I
< 2009-07-01 11:19:51.875 200 Type set to I
> 2009-07-01 11:19:51.875 PORT 192,168,0,109,7,18
< 2009-07-01 11:19:51.875 200 Port command successful
> 2009-07-01 11:19:51.875 STOR GG dec 2008.xls
< 2009-07-01 11:19:51.890 150 Opening data channel for file transfer.
. 2009-07-01 11:19:51.906 SSL connection established
< 2009-07-01 11:19:51.921 226 Transfer OK
> 2009-07-01 11:19:51.921 MFMT 20090120121151 GG dec 2008.xls
< 2009-07-01 11:19:51.937 213 modify=20090120121151; /projects/153_Aigas_Nams/Bookkeeping/GG/GG dec 2008.xls
. 2009-07-01 11:19:51.937 Upload successful
. 2009-07-01 11:19:51.937 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG dec 07.xls"
. 2009-07-01 11:19:51.937 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG dec 07.xls" to remote directory started.
. 2009-07-01 11:19:51.937 Binary transfer mode selected.
. 2009-07-01 11:19:51.937 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG dec 07.xls
> 2009-07-01 11:19:51.937 TYPE I
< 2009-07-01 11:19:51.937 200 Type set to I
> 2009-07-01 11:19:51.937 PORT 192,168,0,109,7,19
< 2009-07-01 11:19:51.953 200 Port command successful
> 2009-07-01 11:19:51.953 STOR GG dec 07.xls
< 2009-07-01 11:19:51.953 150 Opening data channel for file transfer.
. 2009-07-01 11:19:51.968 SSL connection established
< 2009-07-01 11:19:52.000 226 Transfer OK
> 2009-07-01 11:19:52.000 MFMT 20080201130116 GG dec 07.xls
< 2009-07-01 11:19:52.015 213 modify=20080201130116; /projects/153_Aigas_Nams/Bookkeeping/GG/GG dec 07.xls
. 2009-07-01 11:19:52.015 Upload successful
. 2009-07-01 11:19:52.015 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG febr 2009.xls"
. 2009-07-01 11:19:52.015 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG febr 2009.xls" to remote directory started.
. 2009-07-01 11:19:52.015 Binary transfer mode selected.
. 2009-07-01 11:19:52.015 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG febr 2009.xls
> 2009-07-01 11:19:52.015 TYPE I
< 2009-07-01 11:19:52.015 200 Type set to I
> 2009-07-01 11:19:52.015 PORT 192,168,0,109,7,20
< 2009-07-01 11:19:52.015 200 Port command successful
> 2009-07-01 11:19:52.015 STOR GG febr 2009.xls
< 2009-07-01 11:19:52.031 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.046 SSL connection established
< 2009-07-01 11:19:52.062 226 Transfer OK
> 2009-07-01 11:19:52.062 MFMT 20090312100249 GG febr 2009.xls
< 2009-07-01 11:19:52.078 213 modify=20090312100249; /projects/153_Aigas_Nams/Bookkeeping/GG/GG febr 2009.xls
. 2009-07-01 11:19:52.078 Upload successful
. 2009-07-01 11:19:52.078 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG febr.2008.xls"
. 2009-07-01 11:19:52.078 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG febr.2008.xls" to remote directory started.
. 2009-07-01 11:19:52.078 Binary transfer mode selected.
. 2009-07-01 11:19:52.078 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG febr.2008.xls
> 2009-07-01 11:19:52.078 TYPE I
< 2009-07-01 11:19:52.078 200 Type set to I
> 2009-07-01 11:19:52.078 PORT 192,168,0,109,7,21
< 2009-07-01 11:19:52.078 200 Port command successful
> 2009-07-01 11:19:52.078 STOR GG febr.2008.xls
< 2009-07-01 11:19:52.093 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.109 SSL connection established
< 2009-07-01 11:19:52.125 226 Transfer OK
> 2009-07-01 11:19:52.125 MFMT 20080416062452 GG febr.2008.xls
< 2009-07-01 11:19:52.140 213 modify=20080416062452; /projects/153_Aigas_Nams/Bookkeeping/GG/GG febr.2008.xls
. 2009-07-01 11:19:52.140 Upload successful
. 2009-07-01 11:19:52.140 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG janv. 2009.xls"
. 2009-07-01 11:19:52.140 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG janv. 2009.xls" to remote directory started.
. 2009-07-01 11:19:52.140 Binary transfer mode selected.
. 2009-07-01 11:19:52.140 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG janv. 2009.xls
> 2009-07-01 11:19:52.140 TYPE I
< 2009-07-01 11:19:52.140 200 Type set to I
> 2009-07-01 11:19:52.140 PORT 192,168,0,109,7,22
< 2009-07-01 11:19:52.140 200 Port command successful
> 2009-07-01 11:19:52.140 STOR GG janv. 2009.xls
< 2009-07-01 11:19:52.156 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.187 SSL connection established
< 2009-07-01 11:19:52.187 226 Transfer OK
> 2009-07-01 11:19:52.187 MFMT 20090224075200 GG janv. 2009.xls
< 2009-07-01 11:19:52.203 213 modify=20090224075200; /projects/153_Aigas_Nams/Bookkeeping/GG/GG janv. 2009.xls
. 2009-07-01 11:19:52.203 Upload successful
. 2009-07-01 11:19:52.203 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG janv.2008.xls"
. 2009-07-01 11:19:52.203 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG janv.2008.xls" to remote directory started.
. 2009-07-01 11:19:52.203 Binary transfer mode selected.
. 2009-07-01 11:19:52.203 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG janv.2008.xls
> 2009-07-01 11:19:52.203 TYPE I
< 2009-07-01 11:19:52.203 200 Type set to I
> 2009-07-01 11:19:52.203 PORT 192,168,0,109,7,23
< 2009-07-01 11:19:52.203 200 Port command successful
> 2009-07-01 11:19:52.203 STOR GG janv.2008.xls
< 2009-07-01 11:19:52.218 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.234 SSL connection established
< 2009-07-01 11:19:52.250 226 Transfer OK
> 2009-07-01 11:19:52.265 MFMT 20080416062500 GG janv.2008.xls
< 2009-07-01 11:19:52.265 213 modify=20080416062500; /projects/153_Aigas_Nams/Bookkeeping/GG/GG janv.2008.xls
. 2009-07-01 11:19:52.265 Upload successful
. 2009-07-01 11:19:52.265 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG julijs 2008.xls"
. 2009-07-01 11:19:52.265 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG julijs 2008.xls" to remote directory started.
. 2009-07-01 11:19:52.265 Binary transfer mode selected.
. 2009-07-01 11:19:52.265 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG julijs 2008.xls
> 2009-07-01 11:19:52.265 TYPE I
< 2009-07-01 11:19:52.265 200 Type set to I
> 2009-07-01 11:19:52.281 PORT 192,168,0,109,7,24
< 2009-07-01 11:19:52.281 200 Port command successful
> 2009-07-01 11:19:52.281 STOR GG julijs 2008.xls
< 2009-07-01 11:19:52.296 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.312 SSL connection established
< 2009-07-01 11:19:52.328 226 Transfer OK
> 2009-07-01 11:19:52.328 MFMT 20080919083304 GG julijs 2008.xls
< 2009-07-01 11:19:52.343 213 modify=20080919083304; /projects/153_Aigas_Nams/Bookkeeping/GG/GG julijs 2008.xls
. 2009-07-01 11:19:52.343 Upload successful
. 2009-07-01 11:19:52.343 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG maijs 2009.xls"
. 2009-07-01 11:19:52.343 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG maijs 2009.xls" to remote directory started.
. 2009-07-01 11:19:52.343 Binary transfer mode selected.
. 2009-07-01 11:19:52.343 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG maijs 2009.xls
> 2009-07-01 11:19:52.343 TYPE I
< 2009-07-01 11:19:52.343 200 Type set to I
> 2009-07-01 11:19:52.343 PORT 192,168,0,109,7,25
< 2009-07-01 11:19:52.343 200 Port command successful
> 2009-07-01 11:19:52.343 STOR GG maijs 2009.xls
< 2009-07-01 11:19:52.359 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.375 SSL connection established
< 2009-07-01 11:19:52.390 226 Transfer OK
> 2009-07-01 11:19:52.390 MFMT 20090615110520 GG maijs 2009.xls
< 2009-07-01 11:19:52.421 213 modify=20090615110520; /projects/153_Aigas_Nams/Bookkeeping/GG/GG maijs 2009.xls
. 2009-07-01 11:19:52.421 Upload successful
. 2009-07-01 11:19:52.421 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG marts 2009.xls"
. 2009-07-01 11:19:52.421 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG marts 2009.xls" to remote directory started.
. 2009-07-01 11:19:52.421 Binary transfer mode selected.
. 2009-07-01 11:19:52.421 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG marts 2009.xls
> 2009-07-01 11:19:52.421 TYPE I
< 2009-07-01 11:19:52.421 200 Type set to I
> 2009-07-01 11:19:52.421 PORT 192,168,0,109,7,26
< 2009-07-01 11:19:52.421 200 Port command successful
> 2009-07-01 11:19:52.421 STOR GG marts 2009.xls
< 2009-07-01 11:19:52.437 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.453 SSL connection established
< 2009-07-01 11:19:52.468 226 Transfer OK
> 2009-07-01 11:19:52.468 MFMT 20090427085447 GG marts 2009.xls
< 2009-07-01 11:19:52.484 213 modify=20090427085447; /projects/153_Aigas_Nams/Bookkeeping/GG/GG marts 2009.xls
. 2009-07-01 11:19:52.484 Upload successful
. 2009-07-01 11:19:52.484 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG marts-aprilis 08.xls"
. 2009-07-01 11:19:52.484 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG marts-aprilis 08.xls" to remote directory started.
. 2009-07-01 11:19:52.484 Binary transfer mode selected.
. 2009-07-01 11:19:52.484 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG marts-aprilis 08.xls
> 2009-07-01 11:19:52.484 TYPE I
< 2009-07-01 11:19:52.484 200 Type set to I
> 2009-07-01 11:19:52.484 PORT 192,168,0,109,7,27
< 2009-07-01 11:19:52.484 200 Port command successful
> 2009-07-01 11:19:52.484 STOR GG marts-aprilis 08.xls
< 2009-07-01 11:19:52.500 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.515 SSL connection established
< 2009-07-01 11:19:52.546 226 Transfer OK
> 2009-07-01 11:19:52.546 MFMT 20080602061919 GG marts-aprilis 08.xls
< 2009-07-01 11:19:52.562 213 modify=20080602061919; /projects/153_Aigas_Nams/Bookkeeping/GG/GG marts-aprilis 08.xls
. 2009-07-01 11:19:52.562 Upload successful
. 2009-07-01 11:19:52.562 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG novembris 2008.xls"
. 2009-07-01 11:19:52.562 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG novembris 2008.xls" to remote directory started.
. 2009-07-01 11:19:52.562 Binary transfer mode selected.
. 2009-07-01 11:19:52.562 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG novembris 2008.xls
> 2009-07-01 11:19:52.562 TYPE I
< 2009-07-01 11:19:52.562 200 Type set to I
> 2009-07-01 11:19:52.562 PORT 192,168,0,109,7,28
< 2009-07-01 11:19:52.562 200 Port command successful
> 2009-07-01 11:19:52.562 STOR GG novembris 2008.xls
< 2009-07-01 11:19:52.578 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.593 SSL connection established
< 2009-07-01 11:19:52.609 226 Transfer OK
> 2009-07-01 11:19:52.609 MFMT 20081216073105 GG novembris 2008.xls
< 2009-07-01 11:19:52.625 213 modify=20081216073105; /projects/153_Aigas_Nams/Bookkeeping/GG/GG novembris 2008.xls
. 2009-07-01 11:19:52.625 Upload successful
. 2009-07-01 11:19:52.625 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG okt.2007.xls"
. 2009-07-01 11:19:52.625 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG okt.2007.xls" to remote directory started.
. 2009-07-01 11:19:52.625 Binary transfer mode selected.
. 2009-07-01 11:19:52.625 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG okt.2007.xls
> 2009-07-01 11:19:52.625 TYPE I
< 2009-07-01 11:19:52.625 200 Type set to I
> 2009-07-01 11:19:52.625 PORT 192,168,0,109,7,29
< 2009-07-01 11:19:52.625 200 Port command successful
> 2009-07-01 11:19:52.625 STOR GG okt.2007.xls
< 2009-07-01 11:19:52.640 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.656 SSL connection established
< 2009-07-01 11:19:52.671 226 Transfer OK
> 2009-07-01 11:19:52.671 MFMT 20071123101317 GG okt.2007.xls
< 2009-07-01 11:19:52.687 213 modify=20071123101317; /projects/153_Aigas_Nams/Bookkeeping/GG/GG okt.2007.xls
. 2009-07-01 11:19:52.687 Upload successful
. 2009-07-01 11:19:52.687 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG oktobris 2008.xls"
. 2009-07-01 11:19:52.687 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG oktobris 2008.xls" to remote directory started.
. 2009-07-01 11:19:52.687 Binary transfer mode selected.
. 2009-07-01 11:19:52.687 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG oktobris 2008.xls
> 2009-07-01 11:19:52.687 TYPE I
< 2009-07-01 11:19:52.687 200 Type set to I
> 2009-07-01 11:19:52.687 PORT 192,168,0,109,7,30
< 2009-07-01 11:19:52.687 200 Port command successful
> 2009-07-01 11:19:52.687 STOR GG oktobris 2008.xls
< 2009-07-01 11:19:52.703 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.718 SSL connection established
< 2009-07-01 11:19:52.750 226 Transfer OK
> 2009-07-01 11:19:52.750 MFMT 20081201102349 GG oktobris 2008.xls
< 2009-07-01 11:19:52.750 213 modify=20081201102349; /projects/153_Aigas_Nams/Bookkeeping/GG/GG oktobris 2008.xls
. 2009-07-01 11:19:52.750 Upload successful
. 2009-07-01 11:19:52.750 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG uz 30.09.07.xls"
. 2009-07-01 11:19:52.750 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG uz 30.09.07.xls" to remote directory started.
. 2009-07-01 11:19:52.750 Binary transfer mode selected.
. 2009-07-01 11:19:52.750 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\GG\GG uz 30.09.07.xls
> 2009-07-01 11:19:52.750 TYPE I
< 2009-07-01 11:19:52.750 200 Type set to I
> 2009-07-01 11:19:52.765 PORT 192,168,0,109,7,31
< 2009-07-01 11:19:52.765 200 Port command successful
> 2009-07-01 11:19:52.765 STOR GG uz 30.09.07.xls
< 2009-07-01 11:19:52.781 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.796 SSL connection established
< 2009-07-01 11:19:52.812 226 Transfer OK
> 2009-07-01 11:19:52.812 MFMT 20071123101307 GG uz 30.09.07.xls
< 2009-07-01 11:19:52.828 213 modify=20071123101307; /projects/153_Aigas_Nams/Bookkeeping/GG/GG uz 30.09.07.xls
. 2009-07-01 11:19:52.828 Upload successful
. 2009-07-01 11:19:52.828 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\m2_izmaksas.xls"
. 2009-07-01 11:19:52.828 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\m2_izmaksas.xls" to remote directory started.
. 2009-07-01 11:19:52.828 Binary transfer mode selected.
. 2009-07-01 11:19:52.828 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\m2_izmaksas.xls
> 2009-07-01 11:19:52.828 CWD /projects/153_Aigas_Nams/Bookkeeping/
< 2009-07-01 11:19:52.843 250 CWD successful. "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-01 11:19:52.843 PWD
< 2009-07-01 11:19:52.843 257 "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-01 11:19:52.843 TYPE A
< 2009-07-01 11:19:52.843 200 Type set to A
> 2009-07-01 11:19:52.843 PORT 192,168,0,109,7,32
< 2009-07-01 11:19:52.843 200 Port command successful
> 2009-07-01 11:19:52.843 LIST -a
< 2009-07-01 11:19:52.859 150 Opening data channel for directory list.
. 2009-07-01 11:19:52.875 SSL connection established
< 2009-07-01 11:19:52.875 226 Transfer OK
> 2009-07-01 11:19:52.875 TYPE I
< 2009-07-01 11:19:52.890 200 Type set to I
> 2009-07-01 11:19:52.890 PORT 192,168,0,109,7,33
< 2009-07-01 11:19:52.890 200 Port command successful
> 2009-07-01 11:19:52.890 STOR m2_izmaksas.xls
< 2009-07-01 11:19:52.906 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.921 SSL connection established
< 2009-07-01 11:19:52.937 226 Transfer OK
> 2009-07-01 11:19:52.937 MFMT 20090402114949 m2_izmaksas.xls
< 2009-07-01 11:19:52.937 213 modify=20090402114949; /projects/153_Aigas_Nams/Bookkeeping/m2_izmaksas.xls
. 2009-07-01 11:19:52.937 Upload successful
. 2009-07-01 11:19:52.937 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Obj_nod_sap_09-161008_DLW(3).doc"
. 2009-07-01 11:19:52.937 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Obj_nod_sap_09-161008_DLW(3).doc" to remote directory started.
. 2009-07-01 11:19:52.937 Binary transfer mode selected.
. 2009-07-01 11:19:52.937 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Obj_nod_sap_09-161008_DLW(3).doc
> 2009-07-01 11:19:52.937 TYPE I
< 2009-07-01 11:19:52.937 200 Type set to I
> 2009-07-01 11:19:52.953 PORT 192,168,0,109,7,34
< 2009-07-01 11:19:52.953 200 Port command successful
> 2009-07-01 11:19:52.953 STOR Obj_nod_sap_09-161008_DLW(3).doc
< 2009-07-01 11:19:52.953 150 Opening data channel for file transfer.
. 2009-07-01 11:19:52.968 SSL connection established
< 2009-07-01 11:19:53.921 226 Transfer OK
> 2009-07-01 11:19:53.921 MFMT 20081021053609 Obj_nod_sap_09-161008_DLW(3).doc
< 2009-07-01 11:19:53.937 213 modify=20081021053609; /projects/153_Aigas_Nams/Bookkeeping/Obj_nod_sap_09-161008_DLW(3).doc
. 2009-07-01 11:19:53.937 Upload successful
. 2009-07-01 11:19:53.937 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\papilldus_tame.xls"
. 2009-07-01 11:19:53.937 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\papilldus_tame.xls" to remote directory started.
. 2009-07-01 11:19:53.937 Binary transfer mode selected.
. 2009-07-01 11:19:53.937 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\papilldus_tame.xls
> 2009-07-01 11:19:53.937 TYPE I
< 2009-07-01 11:19:53.937 200 Type set to I
> 2009-07-01 11:19:53.937 PORT 192,168,0,109,7,35
< 2009-07-01 11:19:53.937 200 Port command successful
> 2009-07-01 11:19:53.937 STOR papilldus_tame.xls
< 2009-07-01 11:19:53.953 150 Opening data channel for file transfer.
. 2009-07-01 11:19:53.968 SSL connection established
< 2009-07-01 11:19:53.984 226 Transfer OK
> 2009-07-01 11:19:53.984 MFMT 20090206083351 papilldus_tame.xls
< 2009-07-01 11:19:54.000 213 modify=20090206083351; /projects/153_Aigas_Nams/Bookkeeping/papilldus_tame.xls
. 2009-07-01 11:19:54.000 Upload successful
. 2009-07-01 11:19:54.000 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\papilldus_tame_1.xls"
. 2009-07-01 11:19:54.000 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\papilldus_tame_1.xls" to remote directory started.
. 2009-07-01 11:19:54.000 Binary transfer mode selected.
. 2009-07-01 11:19:54.000 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\papilldus_tame_1.xls
> 2009-07-01 11:19:54.000 TYPE I
< 2009-07-01 11:19:54.000 200 Type set to I
> 2009-07-01 11:19:54.000 PORT 192,168,0,109,7,36
< 2009-07-01 11:19:54.000 200 Port command successful
> 2009-07-01 11:19:54.000 STOR papilldus_tame_1.xls
< 2009-07-01 11:19:54.015 150 Opening data channel for file transfer.
. 2009-07-01 11:19:54.031 SSL connection established
< 2009-07-01 11:19:54.046 226 Transfer OK
> 2009-07-01 11:19:54.046 MFMT 20081021071550 papilldus_tame_1.xls
< 2009-07-01 11:19:54.046 213 modify=20081021071550; /projects/153_Aigas_Nams/Bookkeeping/papilldus_tame_1.xls
. 2009-07-01 11:19:54.046 Upload successful
. 2009-07-01 11:19:54.046 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\PBK iesn grafiks 2009.xls"
. 2009-07-01 11:19:54.062 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\PBK iesn grafiks 2009.xls" to remote directory started.
. 2009-07-01 11:19:54.062 Binary transfer mode selected.
. 2009-07-01 11:19:54.062 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\PBK iesn grafiks 2009.xls
> 2009-07-01 11:19:54.062 TYPE I
< 2009-07-01 11:19:54.062 200 Type set to I
> 2009-07-01 11:19:54.062 PORT 192,168,0,109,7,37
< 2009-07-01 11:19:54.062 200 Port command successful
> 2009-07-01 11:19:54.062 STOR PBK iesn grafiks 2009.xls
< 2009-07-01 11:19:54.078 150 Opening data channel for file transfer.
. 2009-07-01 11:19:54.093 SSL connection established
< 2009-07-01 11:19:55.296 226 Transfer OK
> 2009-07-01 11:19:55.296 MFMT 20090511074121 PBK iesn grafiks 2009.xls
< 2009-07-01 11:19:55.296 213 modify=20090511074121; /projects/153_Aigas_Nams/Bookkeeping/PBK iesn grafiks 2009.xls
. 2009-07-01 11:19:55.296 Upload successful
. 2009-07-01 11:19:55.296 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\PBK_1_1.xls"
. 2009-07-01 11:19:55.296 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\PBK_1_1.xls" to remote directory started.
. 2009-07-01 11:19:55.296 Binary transfer mode selected.
. 2009-07-01 11:19:55.312 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\PBK_1_1.xls
> 2009-07-01 11:19:55.312 TYPE I
< 2009-07-01 11:19:55.312 200 Type set to I
> 2009-07-01 11:19:55.312 PORT 192,168,0,109,7,57
< 2009-07-01 11:19:55.312 200 Port command successful
> 2009-07-01 11:19:55.312 STOR PBK_1_1.xls
< 2009-07-01 11:19:55.328 150 Opening data channel for file transfer.
. 2009-07-01 11:19:55.343 SSL connection established
< 2009-07-01 11:19:55.578 226 Transfer OK
> 2009-07-01 11:19:55.578 MFMT 20090630092142 PBK_1_1.xls
< 2009-07-01 11:19:55.593 213 modify=20090630092142; /projects/153_Aigas_Nams/Bookkeeping/PBK_1_1.xls
. 2009-07-01 11:19:55.593 Upload successful
. 2009-07-01 11:19:55.593 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\saistību_izpildes_garantija.jpg"
. 2009-07-01 11:19:55.593 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\saistību_izpildes_garantija.jpg" to remote directory started.
. 2009-07-01 11:19:55.593 Binary transfer mode selected.
. 2009-07-01 11:19:55.593 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\saistību_izpildes_garantija.jpg
> 2009-07-01 11:19:55.593 TYPE I
< 2009-07-01 11:19:55.593 200 Type set to I
> 2009-07-01 11:19:55.593 PORT 192,168,0,109,7,58
< 2009-07-01 11:19:55.593 200 Port command successful
> 2009-07-01 11:19:55.593 STOR saistību_izpildes_garantija.jpg
< 2009-07-01 11:19:55.609 150 Opening data channel for file transfer.
. 2009-07-01 11:19:55.640 SSL connection established
< 2009-07-01 11:19:55.906 226 Transfer OK
> 2009-07-01 11:19:55.906 MFMT 20090110073527 saistību_izpildes_garantija.jpg
< 2009-07-01 11:19:55.921 213 modify=20090110073527; /projects/153_Aigas_Nams/Bookkeeping/saistību_izpildes_garantija.jpg
. 2009-07-01 11:19:55.921 Upload successful
. 2009-07-01 11:19:55.921 File: "c:\work\projects\153_Aigas_Nams\Contract"
. 2009-07-01 11:19:55.921 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW"
. 2009-07-01 11:19:55.921 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Citi"
. 2009-07-01 11:19:55.921 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Citi\Piepilsētas (2).xls"
. 2009-07-01 11:19:55.921 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Citi\Piepilsētas (2).xls" to remote directory started.
. 2009-07-01 11:19:55.921 Binary transfer mode selected.
. 2009-07-01 11:19:55.921 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Citi\Piepilsētas (2).xls
> 2009-07-01 11:19:55.921 CWD /projects/153_Aigas_Nams/Contract/00_DLW/Citi/
< 2009-07-01 11:19:55.921 550 CWD failed. "/projects/153_Aigas_Nams/Contract/00_DLW/Citi": directory not found.
< 2009-07-01 11:19:55.937 550 CWD failed. "/projects/153_Aigas_Nams/Contract/00_DLW": directory not found.
> 2009-07-01 11:19:55.937 CWD /projects/153_Aigas_Nams/Contract/
< 2009-07-01 11:19:55.937 550 CWD failed. "/projects/153_Aigas_Nams/Contract": directory not found.
< 2009-07-01 11:19:55.937 250 CWD successful. "/projects/153_Aigas_Nams" is current directory.
> 2009-07-01 11:19:55.937 MKD Contract
< 2009-07-01 11:19:55.953 257 Directory created successfully
> 2009-07-01 11:19:55.953 CWD /projects/153_Aigas_Nams/Contract/
< 2009-07-01 11:19:55.953 250 CWD successful. "/projects/153_Aigas_Nams/Contract" is current directory.
> 2009-07-01 11:19:55.953 MKD 00_DLW
< 2009-07-01 11:19:55.968 257 Directory created successfully
> 2009-07-01 11:19:55.968 CWD /projects/153_Aigas_Nams/Contract/00_DLW/
< 2009-07-01 11:19:55.984 250 CWD successful. "/projects/153_Aigas_Nams/Contract/00_DLW" is current directory.
> 2009-07-01 11:19:55.984 MKD Citi
< 2009-07-01 11:19:56.000 257 Directory created successfully
> 2009-07-01 11:19:56.000 CWD /projects/153_Aigas_Nams/Contract/00_DLW/Citi/
< 2009-07-01 11:19:56.015 250 CWD successful. "/projects/153_Aigas_Nams/Contract/00_DLW/Citi" is current directory.
> 2009-07-01 11:19:56.015 PWD
< 2009-07-01 11:19:56.015 257 "/projects/153_Aigas_Nams/Contract/00_DLW/Citi" is current directory.
> 2009-07-01 11:19:56.015 TYPE A
< 2009-07-01 11:19:56.015 200 Type set to A
> 2009-07-01 11:19:56.015 PORT 192,168,0,109,7,59
< 2009-07-01 11:19:56.015 200 Port command successful
> 2009-07-01 11:19:56.015 LIST -a
< 2009-07-01 11:19:56.031 150 Opening data channel for directory list.
. 2009-07-01 11:19:56.046 SSL connection established
< 2009-07-01 11:19:56.046 226 Transfer OK
> 2009-07-01 11:19:56.046 TYPE I
< 2009-07-01 11:19:56.046 200 Type set to I
> 2009-07-01 11:19:56.046 PORT 192,168,0,109,7,60
< 2009-07-01 11:19:56.046 200 Port command successful
> 2009-07-01 11:19:56.046 STOR Piepilsētas (2).xls
< 2009-07-01 11:19:56.062 150 Opening data channel for file transfer.
. 2009-07-01 11:19:56.078 SSL connection established
< 2009-07-01 11:19:56.093 226 Transfer OK
> 2009-07-01 11:19:56.093 MFMT 20070604055638 Piepilsētas (2).xls
< 2009-07-01 11:19:56.109 213 modify=20070604055638; /projects/153_Aigas_Nams/Contract/00_DLW/Citi/Piepilsētas (2).xls
. 2009-07-01 11:19:56.109 Upload successful
. 2009-07-01 11:19:56.109 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\DLW_MERKS_DNBNord.doc"
. 2009-07-01 11:19:56.109 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\DLW_MERKS_DNBNord.doc" to remote directory started.
. 2009-07-01 11:19:56.109 Binary transfer mode selected.
. 2009-07-01 11:19:56.109 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\DLW_MERKS_DNBNord.doc
> 2009-07-01 11:19:56.109 CWD /projects/153_Aigas_Nams/Contract/00_DLW/
< 2009-07-01 11:19:56.109 250 CWD successful. "/projects/153_Aigas_Nams/Contract/00_DLW" is current directory.
> 2009-07-01 11:19:56.109 PWD
< 2009-07-01 11:19:56.109 257 "/projects/153_Aigas_Nams/Contract/00_DLW" is current directory.
> 2009-07-01 11:19:56.109 TYPE A
< 2009-07-01 11:19:56.109 200 Type set to A
> 2009-07-01 11:19:56.125 PORT 192,168,0,109,7,61
< 2009-07-01 11:19:56.125 200 Port command successful
> 2009-07-01 11:19:56.125 LIST -a
< 2009-07-01 11:19:56.140 150 Opening data channel for directory list.
. 2009-07-01 11:19:56.156 SSL connection established
< 2009-07-01 11:19:56.187 226 Transfer OK
> 2009-07-01 11:19:56.187 TYPE I
< 2009-07-01 11:19:56.187 200 Type set to I
> 2009-07-01 11:19:56.187 PORT 192,168,0,109,7,62
< 2009-07-01 11:19:56.187 200 Port command successful
> 2009-07-01 11:19:56.187 STOR DLW_MERKS_DNBNord.doc
< 2009-07-01 11:19:56.187 150 Opening data channel for file transfer.
. 2009-07-01 11:19:56.187 SSL connection established
< 2009-07-01 11:19:56.218 226 Transfer OK
> 2009-07-01 11:19:56.218 MFMT 20080226140413 DLW_MERKS_DNBNord.doc
< 2009-07-01 11:19:56.234 213 modify=20080226140413; /projects/153_Aigas_Nams/Contract/00_DLW/DLW_MERKS_DNBNord.doc
. 2009-07-01 11:19:56.234 Upload successful
. 2009-07-01 11:19:56.234 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\DLW_MERKS_DNBNord_15.doc"
. 2009-07-01 11:19:56.234 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\DLW_MERKS_DNBNord_15.doc" to remote directory started.
. 2009-07-01 11:19:56.234 Binary transfer mode selected.
. 2009-07-01 11:19:56.234 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\DLW_MERKS_DNBNord_15.doc
> 2009-07-01 11:19:56.234 TYPE I
< 2009-07-01 11:19:56.234 200 Type set to I
> 2009-07-01 11:19:56.234 PORT 192,168,0,109,7,63
< 2009-07-01 11:19:56.234 200 Port command successful
> 2009-07-01 11:19:56.234 STOR DLW_MERKS_DNBNord_15.doc
< 2009-07-01 11:19:56.250 150 Opening data channel for file transfer.
. 2009-07-01 11:19:56.265 SSL connection established
< 2009-07-01 11:19:56.281 226 Transfer OK
> 2009-07-01 11:19:56.281 MFMT 20081028082139 DLW_MERKS_DNBNord_15.doc
< 2009-07-01 11:19:56.296 213 modify=20081028082139; /projects/153_Aigas_Nams/Contract/00_DLW/DLW_MERKS_DNBNord_15.doc
. 2009-07-01 11:19:56.296 Upload successful
. 2009-07-01 11:19:56.296 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\LIGUMS_buvnieciba_04092007Aigas nams.doc"
. 2009-07-01 11:19:56.296 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\LIGUMS_buvnieciba_04092007Aigas nams.doc" to remote directory started.
. 2009-07-01 11:19:56.296 Binary transfer mode selected.
. 2009-07-01 11:19:56.296 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\LIGUMS_buvnieciba_04092007Aigas nams.doc
> 2009-07-01 11:19:56.296 TYPE I
< 2009-07-01 11:19:56.296 200 Type set to I
> 2009-07-01 11:19:56.296 PORT 192,168,0,109,7,64
< 2009-07-01 11:19:56.296 200 Port command successful
> 2009-07-01 11:19:56.296 STOR LIGUMS_buvnieciba_04092007Aigas nams.doc
< 2009-07-01 11:19:56.312 150 Opening data channel for file transfer.
. 2009-07-01 11:19:56.328 SSL connection established
< 2009-07-01 11:19:56.453 226 Transfer OK
> 2009-07-01 11:19:56.453 MFMT 20070904064500 LIGUMS_buvnieciba_04092007Aigas nams.doc
< 2009-07-01 11:19:56.453 213 modify=20070904064500; /projects/153_Aigas_Nams/Contract/00_DLW/LIGUMS_buvnieciba_04092007Aigas nams.doc
. 2009-07-01 11:19:56.453 Upload successful
. 2009-07-01 11:19:56.453 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\MESAKO_DLW_apkopes_ligums(1).doc"
. 2009-07-01 11:19:56.453 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\MESAKO_DLW_apkopes_ligums(1).doc" to remote directory started.
. 2009-07-01 11:19:56.468 Binary transfer mode selected.
. 2009-07-01 11:19:56.468 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\MESAKO_DLW_apkopes_ligums(1).doc
> 2009-07-01 11:19:56.468 TYPE I
< 2009-07-01 11:19:56.468 200 Type set to I
> 2009-07-01 11:19:56.468 PORT 192,168,0,109,7,65
< 2009-07-01 11:19:56.468 200 Port command successful
> 2009-07-01 11:19:56.468 STOR MESAKO_DLW_apkopes_ligums(1).doc
< 2009-07-01 11:19:56.484 150 Opening data channel for file transfer.
. 2009-07-01 11:19:56.500 SSL connection established
< 2009-07-01 11:19:56.531 226 Transfer OK
> 2009-07-01 11:19:56.546 MFMT 20080922092507 MESAKO_DLW_apkopes_ligums(1).doc
< 2009-07-01 11:19:56.546 213 modify=20080922092507; /projects/153_Aigas_Nams/Contract/00_DLW/MESAKO_DLW_apkopes_ligums(1).doc
. 2009-07-01 11:19:56.546 Upload successful
. 2009-07-01 11:19:56.546 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\MESAKO_DLW_apkopes_ligums.doc"
. 2009-07-01 11:19:56.546 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\MESAKO_DLW_apkopes_ligums.doc" to remote directory started.
. 2009-07-01 11:19:56.546 Binary transfer mode selected.
. 2009-07-01 11:19:56.546 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\MESAKO_DLW_apkopes_ligums.doc
> 2009-07-01 11:19:56.546 TYPE I
< 2009-07-01 11:19:56.546 200 Type set to I
> 2009-07-01 11:19:56.562 PORT 192,168,0,109,7,66
< 2009-07-01 11:19:56.562 200 Port command successful
> 2009-07-01 11:19:56.562 STOR MESAKO_DLW_apkopes_ligums.doc
< 2009-07-01 11:19:56.562 150 Opening data channel for file transfer.
. 2009-07-01 11:19:56.578 SSL connection established
< 2009-07-01 11:19:56.609 226 Transfer OK
> 2009-07-01 11:19:56.609 MFMT 20080922104005 MESAKO_DLW_apkopes_ligums.doc
< 2009-07-01 11:19:56.625 213 modify=20080922104005; /projects/153_Aigas_Nams/Contract/00_DLW/MESA
Roberts
. 2009-07-01 11:19:56.625 Upload successful
. 2009-07-01 11:19:56.625 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Papildus_vienosanas_1.doc"
. 2009-07-01 11:19:56.625 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Papildus_vienosanas_1.doc" to remote directory started.
. 2009-07-01 11:19:56.625 Binary transfer mode selected.
. 2009-07-01 11:19:56.625 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Papildus_vienosanas_1.doc
> 2009-07-01 11:19:56.625 TYPE I
< 2009-07-01 11:19:56.625 200 Type set to I
> 2009-07-01 11:19:56.640 PORT 192,168,0,109,7,67
< 2009-07-01 11:19:56.640 200 Port command successful
> 2009-07-01 11:19:56.640 STOR Papildus_vienosanas_1.doc
< 2009-07-01 11:19:56.656 150 Opening data channel for file transfer.
. 2009-07-01 11:19:56.656 SSL connection established
< 2009-07-01 11:19:57.109 226 Transfer OK
> 2009-07-01 11:19:57.109 MFMT 20071213072638 Papildus_vienosanas_1.doc
< 2009-07-01 11:19:57.109 213 modify=20071213072638; /projects/153_Aigas_Nams/Contract/00_DLW/Papildus_vienosanas_1.doc
. 2009-07-01 11:19:57.109 Upload successful
. 2009-07-01 11:19:57.109 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_10_Akts_par _darbu_izpildi.xls"
. 2009-07-01 11:19:57.109 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_10_Akts_par _darbu_izpildi.xls" to remote directory started.
. 2009-07-01 11:19:57.125 Binary transfer mode selected.
. 2009-07-01 11:19:57.125 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_10_Akts_par _darbu_izpildi.xls
> 2009-07-01 11:19:57.125 TYPE I
< 2009-07-01 11:19:57.125 200 Type set to I
> 2009-07-01 11:19:57.125 PORT 192,168,0,109,7,68
< 2009-07-01 11:19:57.125 200 Port command successful
> 2009-07-01 11:19:57.125 STOR Pielikums_10_Akts_par _darbu_izpildi.xls
< 2009-07-01 11:19:57.140 150 Opening data channel for file transfer.
. 2009-07-01 11:19:57.156 SSL connection established
< 2009-07-01 11:19:57.187 226 Transfer OK
> 2009-07-01 11:19:57.187 MFMT 20070829054032 Pielikums_10_Akts_par _darbu_izpildi.xls
< 2009-07-01 11:19:57.187 213 modify=20070829054032; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_10_Akts_par _darbu_izpildi.xls
. 2009-07-01 11:19:57.187 Upload successful
. 2009-07-01 11:19:57.187 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_1_1_Paskaidrojuma_raksts_tikli.doc"
. 2009-07-01 11:19:57.187 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_1_1_Paskaidrojuma_raksts_tikli.doc" to remote directory started.
. 2009-07-01 11:19:57.187 Binary transfer mode selected.
. 2009-07-01 11:19:57.187 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_1_1_Paskaidrojuma_raksts_tikli.doc
> 2009-07-01 11:19:57.187 TYPE I
< 2009-07-01 11:19:57.187 200 Type set to I
> 2009-07-01 11:19:57.187 PORT 192,168,0,109,7,69
< 2009-07-01 11:19:57.187 200 Port command successful
> 2009-07-01 11:19:57.203 STOR Pielikums_1_1_Paskaidrojuma_raksts_tikli.doc
< 2009-07-01 11:19:57.203 150 Opening data channel for file transfer.
. 2009-07-01 11:19:57.218 SSL connection established
< 2009-07-01 11:19:57.312 226 Transfer OK
> 2009-07-01 11:19:57.312 MFMT 20070829051402 Pielikums_1_1_Paskaidrojuma_raksts_tikli.doc
< 2009-07-01 11:19:57.328 213 modify=20070829051402; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_1_1_Paskaidrojuma_raksts_tikli.doc
. 2009-07-01 11:19:57.328 Upload successful
. 2009-07-01 11:19:57.328 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc"
. 2009-07-01 11:19:57.328 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc" to remote directory started.
. 2009-07-01 11:19:57.328 Binary transfer mode selected.
. 2009-07-01 11:19:57.328 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc
> 2009-07-01 11:19:57.328 TYPE I
< 2009-07-01 11:19:57.328 200 Type set to I
> 2009-07-01 11:19:57.328 PORT 192,168,0,109,7,70
< 2009-07-01 11:19:57.328 200 Port command successful
> 2009-07-01 11:19:57.328 STOR Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc
< 2009-07-01 11:19:57.343 150 Opening data channel for file transfer.
. 2009-07-01 11:19:57.359 SSL connection established
< 2009-07-01 11:19:57.703 226 Transfer OK
> 2009-07-01 11:19:57.703 MFMT 20070903124500 Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc
< 2009-07-01 11:19:57.718 213 modify=20070903124500; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc
. 2009-07-01 11:19:57.718 Upload successful
. 2009-07-01 11:19:57.718 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_3_Ligumsaistibu_robezas.xls"
. 2009-07-01 11:19:57.718 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_3_Ligumsaistibu_robezas.xls" to remote directory started.
. 2009-07-01 11:19:57.718 Binary transfer mode selected.
. 2009-07-01 11:19:57.718 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_3_Ligumsaistibu_robezas.xls
> 2009-07-01 11:19:57.718 TYPE I
< 2009-07-01 11:19:57.734 200 Type set to I
> 2009-07-01 11:19:57.734 PORT 192,168,0,109,7,71
< 2009-07-01 11:19:57.734 200 Port command successful
> 2009-07-01 11:19:57.734 STOR Pielikums_3_Ligumsaistibu_robezas.xls
< 2009-07-01 11:19:57.750 150 Opening data channel for file transfer.
. 2009-07-01 11:19:57.765 SSL connection established
< 2009-07-01 11:19:57.781 226 Transfer OK
> 2009-07-01 11:19:57.781 MFMT 20080530111217 Pielikums_3_Ligumsaistibu_robezas.xls
< 2009-07-01 11:19:57.796 213 modify=20080530111217; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_3_Ligumsaistibu_robezas.xls
. 2009-07-01 11:19:57.796 Upload successful
. 2009-07-01 11:19:57.796 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\pielikums_4_YSE_LV_IK_JM.doc"
. 2009-07-01 11:19:57.796 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\pielikums_4_YSE_LV_IK_JM.doc" to remote directory started.
. 2009-07-01 11:19:57.796 Binary transfer mode selected.
. 2009-07-01 11:19:57.796 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\pielikums_4_YSE_LV_IK_JM.doc
> 2009-07-01 11:19:57.796 TYPE I
< 2009-07-01 11:19:57.796 200 Type set to I
> 2009-07-01 11:19:57.796 PORT 192,168,0,109,7,72
< 2009-07-01 11:19:57.796 200 Port command successful
> 2009-07-01 11:19:57.796 STOR pielikums_4_YSE_LV_IK_JM.doc
< 2009-07-01 11:19:57.812 150 Opening data channel for file transfer.
. 2009-07-01 11:19:57.828 SSL connection established
< 2009-07-01 11:19:58.187 226 Transfer OK
> 2009-07-01 11:19:58.187 MFMT 20070622082930 pielikums_4_YSE_LV_IK_JM.doc
< 2009-07-01 11:19:58.187 213 modify=20070622082930; /projects/153_Aigas_Nams/Contract/00_DLW/pielikums_4_YSE_LV_IK_JM.doc
. 2009-07-01 11:19:58.187 Upload successful
. 2009-07-01 11:19:58.187 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_5_Kalend_grafiks.mpp"
. 2009-07-01 11:19:58.187 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_5_Kalend_grafiks.mpp" to remote directory started.
. 2009-07-01 11:19:58.187 Binary transfer mode selected.
. 2009-07-01 11:19:58.187 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_5_Kalend_grafiks.mpp
> 2009-07-01 11:19:58.187 TYPE I
< 2009-07-01 11:19:58.187 200 Type set to I
> 2009-07-01 11:19:58.203 PORT 192,168,0,109,7,73
< 2009-07-01 11:19:58.203 200 Port command successful
> 2009-07-01 11:19:58.203 STOR Pielikums_5_Kalend_grafiks.mpp
< 2009-07-01 11:19:58.218 150 Opening data channel for file transfer.
. 2009-07-01 11:19:58.234 SSL connection established
< 2009-07-01 11:19:58.406 226 Transfer OK
> 2009-07-01 11:19:58.406 MFMT 20070904062048 Pielikums_5_Kalend_grafiks.mpp
< 2009-07-01 11:19:58.421 213 modify=20070904062048; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_5_Kalend_grafiks.mpp
. 2009-07-01 11:19:58.421 Upload successful
. 2009-07-01 11:19:58.421 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_5_Kalend_grafiks_korigets.mpp"
. 2009-07-01 11:19:58.421 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_5_Kalend_grafiks_korigets.mpp" to remote directory started.
. 2009-07-01 11:19:58.421 Binary transfer mode selected.
. 2009-07-01 11:19:58.421 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_5_Kalend_grafiks_korigets.mpp
> 2009-07-01 11:19:58.421 TYPE I
< 2009-07-01 11:19:58.421 200 Type set to I
> 2009-07-01 11:19:58.437 PORT 192,168,0,109,7,74
< 2009-07-01 11:19:58.437 200 Port command successful
> 2009-07-01 11:19:58.437 STOR Pielikums_5_Kalend_grafiks_korigets.mpp
< 2009-07-01 11:19:58.453 150 Opening data channel for file transfer.
. 2009-07-01 11:19:58.468 SSL connection established
< 2009-07-01 11:19:58.625 226 Transfer OK
> 2009-07-01 11:19:58.625 MFMT 20080307152359 Pielikums_5_Kalend_grafiks_korigets.mpp
< 2009-07-01 11:19:58.640 213 modify=20080307152359; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_5_Kalend_grafiks_korigets.mpp
. 2009-07-01 11:19:58.640 Upload successful
. 2009-07-01 11:19:58.640 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_5_Kalend_grafiks_korigets_1.mpp"
. 2009-07-01 11:19:58.640 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_5_Kalend_grafiks_korigets_1.mpp" to remote directory started.
. 2009-07-01 11:19:58.640 Binary transfer mode selected.
. 2009-07-01 11:19:58.640 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_5_Kalend_grafiks_korigets_1.mpp
> 2009-07-01 11:19:58.640 TYPE I
< 2009-07-01 11:19:58.640 200 Type set to I
> 2009-07-01 11:19:58.640 PORT 192,168,0,109,7,75
< 2009-07-01 11:19:58.640 200 Port command successful
> 2009-07-01 11:19:58.640 STOR Pielikums_5_Kalend_grafiks_korigets_1.mpp
< 2009-07-01 11:19:58.656 150 Opening data channel for file transfer.
. 2009-07-01 11:19:58.671 SSL connection established
< 2009-07-01 11:19:58.859 226 Transfer OK
> 2009-07-01 11:19:58.859 MFMT 20080604141330 Pielikums_5_Kalend_grafiks_korigets_1.mpp
< 2009-07-01 11:19:58.859 213 modify=20080604141330; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_5_Kalend_grafiks_korigets_1.mpp
. 2009-07-01 11:19:58.859 Upload successful
. 2009-07-01 11:19:58.859 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_6_Maksajumu_grafiks.xls"
. 2009-07-01 11:19:58.859 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_6_Maksajumu_grafiks.xls" to remote directory started.
. 2009-07-01 11:19:58.875 Binary transfer mode selected.
. 2009-07-01 11:19:58.875 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_6_Maksajumu_grafiks.xls
> 2009-07-01 11:19:58.875 TYPE I
< 2009-07-01 11:19:58.875 200 Type set to I
> 2009-07-01 11:19:58.875 PORT 192,168,0,109,7,76
< 2009-07-01 11:19:58.875 200 Port command successful
> 2009-07-01 11:19:58.875 STOR Pielikums_6_Maksajumu_grafiks.xls
< 2009-07-01 11:19:58.890 150 Opening data channel for file transfer.
. 2009-07-01 11:19:58.906 SSL connection established
< 2009-07-01 11:19:58.937 226 Transfer OK
> 2009-07-01 11:19:58.953 MFMT 20070904062506 Pielikums_6_Maksajumu_grafiks.xls
< 2009-07-01 11:19:58.953 213 modify=20070904062506; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_6_Maksajumu_grafiks.xls
. 2009-07-01 11:19:58.953 Upload successful
. 2009-07-01 11:19:58.953 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_7_merkcenas_korekcija.xls"
. 2009-07-01 11:19:58.953 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_7_merkcenas_korekcija.xls" to remote directory started.
. 2009-07-01 11:19:58.953 Binary transfer mode selected.
. 2009-07-01 11:19:58.953 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_7_merkcenas_korekcija.xls
> 2009-07-01 11:19:58.953 TYPE I
< 2009-07-01 11:19:58.953 200 Type set to I
> 2009-07-01 11:19:58.968 PORT 192,168,0,109,7,77
< 2009-07-01 11:19:58.968 200 Port command successful
> 2009-07-01 11:19:58.968 STOR Pielikums_7_merkcenas_korekcija.xls
< 2009-07-01 11:19:58.968 150 Opening data channel for file transfer.
. 2009-07-01 11:19:58.984 SSL connection established
< 2009-07-01 11:19:59.625 226 Transfer OK
> 2009-07-01 11:19:59.625 MFMT 20080710124024 Pielikums_7_merkcenas_korekcija.xls
< 2009-07-01 11:19:59.625 213 modify=20080710124024; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_7_merkcenas_korekcija.xls
. 2009-07-01 11:19:59.625 Upload successful
. 2009-07-01 11:19:59.625 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_8_Apaksuznemeju_apkopojums.xls"
. 2009-07-01 11:19:59.625 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_8_Apaksuznemeju_apkopojums.xls" to remote directory started.
. 2009-07-01 11:19:59.640 Binary transfer mode selected.
. 2009-07-01 11:19:59.640 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_8_Apaksuznemeju_apkopojums.xls
> 2009-07-01 11:19:59.640 TYPE I
< 2009-07-01 11:19:59.640 200 Type set to I
> 2009-07-01 11:19:59.640 PORT 192,168,0,109,7,78
< 2009-07-01 11:19:59.640 200 Port command successful
> 2009-07-01 11:19:59.640 STOR Pielikums_8_Apaksuznemeju_apkopojums.xls
< 2009-07-01 11:19:59.656 150 Opening data channel for file transfer.
. 2009-07-01 11:19:59.671 SSL connection established
< 2009-07-01 11:19:59.687 226 Transfer OK
> 2009-07-01 11:19:59.687 MFMT 20070823084040 Pielikums_8_Apaksuznemeju_apkopojums.xls
< 2009-07-01 11:19:59.703 213 modify=20070823084040; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_8_Apaksuznemeju_apkopojums.xls
. 2009-07-01 11:19:59.703 Upload successful
. 2009-07-01 11:19:59.703 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_9_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc"
. 2009-07-01 11:19:59.703 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_9_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc" to remote directory started.
. 2009-07-01 11:19:59.703 Binary transfer mode selected.
. 2009-07-01 11:19:59.703 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Pielikums_9_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
> 2009-07-01 11:19:59.703 TYPE I
< 2009-07-01 11:19:59.703 200 Type set to I
> 2009-07-01 11:19:59.703 PORT 192,168,0,109,7,79
< 2009-07-01 11:19:59.718 200 Port command successful
> 2009-07-01 11:19:59.718 STOR Pielikums_9_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
< 2009-07-01 11:19:59.718 150 Opening data channel for file transfer.
. 2009-07-01 11:19:59.734 SSL connection established
< 2009-07-01 11:19:59.781 226 Transfer OK
> 2009-07-01 11:19:59.781 MFMT 20070829054132 Pielikums_9_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
< 2009-07-01 11:19:59.781 213 modify=20070829054132; /projects/153_Aigas_Nams/Contract/00_DLW/Pielikums_9_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
. 2009-07-01 11:19:59.781 Upload successful
. 2009-07-01 11:19:59.781 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Taame_Final.xls"
. 2009-07-01 11:19:59.781 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Taame_Final.xls" to remote directory started.
. 2009-07-01 11:19:59.781 Binary transfer mode selected.
. 2009-07-01 11:19:59.781 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Taame_Final.xls
> 2009-07-01 11:19:59.796 TYPE I
< 2009-07-01 11:19:59.796 200 Type set to I
> 2009-07-01 11:19:59.796 PORT 192,168,0,109,7,80
< 2009-07-01 11:19:59.796 200 Port command successful
> 2009-07-01 11:19:59.796 STOR Taame_Final.xls
< 2009-07-01 11:19:59.812 150 Opening data channel for file transfer.
. 2009-07-01 11:19:59.828 SSL connection established
< 2009-07-01 11:20:00.046 226 Transfer OK
> 2009-07-01 11:20:00.046 MFMT 20080214142430 Taame_Final.xls
< 2009-07-01 11:20:00.062 213 modify=20080214142430; /projects/153_Aigas_Nams/Contract/00_DLW/Taame_Final.xls
. 2009-07-01 11:20:00.062 Upload successful
. 2009-07-01 11:20:00.062 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas"
. 2009-07-01 11:20:00.062 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1"
. 2009-07-01 11:20:00.062 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\akts.jpg"
. 2009-07-01 11:20:00.062 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\akts.jpg" to remote directory started.
. 2009-07-01 11:20:00.062 Binary transfer mode selected.
. 2009-07-01 11:20:00.062 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\akts.jpg
> 2009-07-01 11:20:00.062 CWD /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/
< 2009-07-01 11:20:00.078 550 CWD failed. "/projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1": directory not found.
> 2009-07-01 11:20:00.078 CWD /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/
< 2009-07-01 11:20:00.078 550 CWD failed. "/projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas": directory not found.
< 2009-07-01 11:20:00.093 250 CWD successful. "/projects/153_Aigas_Nams/Contract/00_DLW" is current directory.
> 2009-07-01 11:20:00.093 MKD Vienosanas
< 2009-07-01 11:20:00.109 257 Directory created successfully
> 2009-07-01 11:20:00.109 CWD /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/
< 2009-07-01 11:20:00.109 250 CWD successful. "/projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas" is current directory.
> 2009-07-01 11:20:00.109 MKD 1
< 2009-07-01 11:20:00.140 257 Directory created successfully
> 2009-07-01 11:20:00.140 CWD /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/
< 2009-07-01 11:20:00.140 250 CWD successful. "/projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1" is current directory.
> 2009-07-01 11:20:00.140 PWD
< 2009-07-01 11:20:00.140 257 "/projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1" is current directory.
> 2009-07-01 11:20:00.140 TYPE A
< 2009-07-01 11:20:00.140 200 Type set to A
> 2009-07-01 11:20:00.156 PORT 192,168,0,109,7,81
< 2009-07-01 11:20:00.156 200 Port command successful
> 2009-07-01 11:20:00.187 LIST -a
< 2009-07-01 11:20:00.187 150 Opening data channel for directory list.
. 2009-07-01 11:20:00.187 SSL connection established
< 2009-07-01 11:20:00.187 226 Transfer OK
> 2009-07-01 11:20:00.187 TYPE I
< 2009-07-01 11:20:00.187 200 Type set to I
> 2009-07-01 11:20:00.187 PORT 192,168,0,109,7,82
< 2009-07-01 11:20:00.187 200 Port command successful
> 2009-07-01 11:20:00.187 STOR akts.jpg
< 2009-07-01 11:20:00.203 150 Opening data channel for file transfer.
. 2009-07-01 11:20:00.218 SSL connection established
< 2009-07-01 11:20:00.468 226 Transfer OK
> 2009-07-01 11:20:00.468 MFMT 20081016130435 akts.jpg
< 2009-07-01 11:20:00.484 213 modify=20081016130435; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/akts.jpg
. 2009-07-01 11:20:00.484 Upload successful
. 2009-07-01 11:20:00.484 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\defektu_noversanas_termini.jpg"
. 2009-07-01 11:20:00.484 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\defektu_noversanas_termini.jpg" to remote directory started.
. 2009-07-01 11:20:00.484 Binary transfer mode selected.
. 2009-07-01 11:20:00.484 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\defektu_noversanas_termini.jpg
> 2009-07-01 11:20:00.484 TYPE I
< 2009-07-01 11:20:00.484 200 Type set to I
> 2009-07-01 11:20:00.500 PORT 192,168,0,109,7,83
< 2009-07-01 11:20:00.500 200 Port command successful
> 2009-07-01 11:20:00.500 STOR defektu_noversanas_termini.jpg
< 2009-07-01 11:20:00.515 150 Opening data channel for file transfer.
. 2009-07-01 11:20:00.531 SSL connection established
< 2009-07-01 11:20:00.687 226 Transfer OK
> 2009-07-01 11:20:00.687 MFMT 20081016130240 defektu_noversanas_termini.jpg
< 2009-07-01 11:20:00.703 213 modify=20081016130240; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/defektu_noversanas_termini.jpg
. 2009-07-01 11:20:00.703 Upload successful
. 2009-07-01 11:20:00.703 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\Garantijas defektacijas termiņi un noversana.xlsx"
. 2009-07-01 11:20:00.703 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\Garantijas defektacijas termiņi un noversana.xlsx" to remote directory started.
. 2009-07-01 11:20:00.703 Binary transfer mode selected.
. 2009-07-01 11:20:00.703 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\Garantijas defektacijas termiņi un noversana.xlsx
> 2009-07-01 11:20:00.703 TYPE I
< 2009-07-01 11:20:00.703 200 Type set to I
> 2009-07-01 11:20:00.703 PORT 192,168,0,109,7,84
< 2009-07-01 11:20:00.703 200 Port command successful
> 2009-07-01 11:20:00.703 STOR Garantijas defektacijas termiņi un noversana.xlsx
< 2009-07-01 11:20:00.718 150 Opening data channel for file transfer.
. 2009-07-01 11:20:00.734 SSL connection established
< 2009-07-01 11:20:00.750 226 Transfer OK
> 2009-07-01 11:20:00.750 MFMT 20090505072627 Garantijas defektacijas termiņi un noversana.xlsx
< 2009-07-01 11:20:00.765 213 modify=20090505072627; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/Garantijas defektacijas termiņi un noversana.xlsx
. 2009-07-01 11:20:00.765 Upload successful
. 2009-07-01 11:20:00.765 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\maksajumu_grafiks.jpg"
. 2009-07-01 11:20:00.765 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\maksajumu_grafiks.jpg" to remote directory started.
. 2009-07-01 11:20:00.765 Binary transfer mode selected.
. 2009-07-01 11:20:00.765 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\maksajumu_grafiks.jpg
> 2009-07-01 11:20:00.781 TYPE I
< 2009-07-01 11:20:00.781 200 Type set to I
> 2009-07-01 11:20:00.781 PORT 192,168,0,109,7,85
< 2009-07-01 11:20:00.781 200 Port command successful
> 2009-07-01 11:20:00.781 STOR maksajumu_grafiks.jpg
< 2009-07-01 11:20:00.796 150 Opening data channel for file transfer.
. 2009-07-01 11:20:00.812 SSL connection established
< 2009-07-01 11:20:01.250 226 Transfer OK
> 2009-07-01 11:20:01.250 MFMT 20081016130327 maksajumu_grafiks.jpg
< 2009-07-01 11:20:01.265 213 modify=20081016130327; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/maksajumu_grafiks.jpg
. 2009-07-01 11:20:01.265 Upload successful
. 2009-07-01 11:20:01.265 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\Maksajumu_grafiks.xls"
. 2009-07-01 11:20:01.265 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\Maksajumu_grafiks.xls" to remote directory started.
. 2009-07-01 11:20:01.265 Binary transfer mode selected.
. 2009-07-01 11:20:01.265 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\Maksajumu_grafiks.xls
> 2009-07-01 11:20:01.265 TYPE I
< 2009-07-01 11:20:01.265 200 Type set to I
> 2009-07-01 11:20:01.265 PORT 192,168,0,109,7,86
< 2009-07-01 11:20:01.281 200 Port command successful
> 2009-07-01 11:20:01.281 STOR Maksajumu_grafiks.xls
< 2009-07-01 11:20:01.312 150 Opening data channel for file transfer.
. 2009-07-01 11:20:01.328 SSL connection established
< 2009-07-01 11:20:01.578 226 Transfer OK
> 2009-07-01 11:20:01.578 MFMT 20081013061830 Maksajumu_grafiks.xls
< 2009-07-01 11:20:01.593 213 modify=20081013061830; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/Maksajumu_grafiks.xls
. 2009-07-01 11:20:01.593 Upload successful
. 2009-07-01 11:20:01.593 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\papildus_vienosanas_2.doc"
. 2009-07-01 11:20:01.593 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\papildus_vienosanas_2.doc" to remote directory started.
. 2009-07-01 11:20:01.593 Binary transfer mode selected.
. 2009-07-01 11:20:01.593 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\papildus_vienosanas_2.doc
> 2009-07-01 11:20:01.593 TYPE I
< 2009-07-01 11:20:01.593 200 Type set to I
> 2009-07-01 11:20:01.593 PORT 192,168,0,109,7,87
< 2009-07-01 11:20:01.593 200 Port command successful
> 2009-07-01 11:20:01.593 STOR papildus_vienosanas_2.doc
< 2009-07-01 11:20:01.718 150 Opening data channel for file transfer.
. 2009-07-01 11:20:01.734 SSL connection established
< 2009-07-01 11:20:01.781 226 Transfer OK
> 2009-07-01 11:20:01.781 MFMT 20081015053329 papildus_vienosanas_2.doc
< 2009-07-01 11:20:01.796 213 modify=20081015053329; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/papildus_vienosanas_2.doc
. 2009-07-01 11:20:01.796 Upload successful
. 2009-07-01 11:20:01.796 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\papilldus_tame_1.xls"
. 2009-07-01 11:20:01.796 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\papilldus_tame_1.xls" to remote directory started.
. 2009-07-01 11:20:01.796 Binary transfer mode selected.
. 2009-07-01 11:20:01.796 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\papilldus_tame_1.xls
> 2009-07-01 11:20:01.796 TYPE I
< 2009-07-01 11:20:01.796 200 Type set to I
> 2009-07-01 11:20:01.796 PORT 192,168,0,109,7,88
< 2009-07-01 11:20:01.796 200 Port command successful
> 2009-07-01 11:20:01.796 STOR papilldus_tame_1.xls
< 2009-07-01 11:20:01.828 150 Opening data channel for file transfer.
. 2009-07-01 11:20:01.843 SSL connection established
< 2009-07-01 11:20:01.859 226 Transfer OK
> 2009-07-01 11:20:01.859 MFMT 20081015053446 papilldus_tame_1.xls
< 2009-07-01 11:20:01.875 213 modify=20081015053446; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/papilldus_tame_1.xls
. 2009-07-01 11:20:01.875 Upload successful
. 2009-07-01 11:20:01.875 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\tame.jpg"
. 2009-07-01 11:20:01.875 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\tame.jpg" to remote directory started.
. 2009-07-01 11:20:01.875 Binary transfer mode selected.
. 2009-07-01 11:20:01.875 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\tame.jpg
> 2009-07-01 11:20:01.875 TYPE I
< 2009-07-01 11:20:01.890 200 Type set to I
> 2009-07-01 11:20:01.890 PORT 192,168,0,109,7,89
< 2009-07-01 11:20:01.890 200 Port command successful
> 2009-07-01 11:20:01.890 STOR tame.jpg
< 2009-07-01 11:20:01.937 150 Opening data channel for file transfer.
. 2009-07-01 11:20:01.937 SSL connection established
< 2009-07-01 11:20:02.359 226 Transfer OK
> 2009-07-01 11:20:02.359 MFMT 20081016130138 tame.jpg
< 2009-07-01 11:20:02.359 213 modify=20081016130138; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/tame.jpg
. 2009-07-01 11:20:02.359 Upload successful
. 2009-07-01 11:20:02.359 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\vienosanas.jpg"
. 2009-07-01 11:20:02.359 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\vienosanas.jpg" to remote directory started.
. 2009-07-01 11:20:02.375 Binary transfer mode selected.
. 2009-07-01 11:20:02.375 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\1\vienosanas.jpg
> 2009-07-01 11:20:02.375 TYPE I
< 2009-07-01 11:20:02.375 200 Type set to I
> 2009-07-01 11:20:02.375 PORT 192,168,0,109,7,90
< 2009-07-01 11:20:02.375 200 Port command successful
> 2009-07-01 11:20:02.375 STOR vienosanas.jpg
< 2009-07-01 11:20:02.421 150 Opening data channel for file transfer.
. 2009-07-01 11:20:02.437 SSL connection established
< 2009-07-01 11:20:02.890 226 Transfer OK
> 2009-07-01 11:20:02.890 MFMT 20081016130035 vienosanas.jpg
< 2009-07-01 11:20:02.906 213 modify=20081016130035; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/1/vienosanas.jpg
. 2009-07-01 11:20:02.906 Upload successful
. 2009-07-01 11:20:02.906 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2"
. 2009-07-01 11:20:02.953 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2\19_01_2009_papildus_vienosanas_2.doc"
. 2009-07-01 11:20:02.953 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2\19_01_2009_papildus_vienosanas_2.doc" to remote directory started.
. 2009-07-01 11:20:02.968 Binary transfer mode selected.
. 2009-07-01 11:20:02.968 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2\19_01_2009_papildus_vienosanas_2.doc
> 2009-07-01 11:20:02.968 CWD /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/2/
< 2009-07-01 11:20:02.968 550 CWD failed. "/projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/2": directory not found.
< 2009-07-01 11:20:02.984 250 CWD successful. "/projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas" is current directory.
> 2009-07-01 11:20:02.984 MKD 2
< 2009-07-01 11:20:03.000 257 Directory created successfully
> 2009-07-01 11:20:03.000 CWD /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/2/
< 2009-07-01 11:20:03.015 250 CWD successful. "/projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/2" is current directory.
> 2009-07-01 11:20:03.015 PWD
< 2009-07-01 11:20:03.015 257 "/projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/2" is current directory.
> 2009-07-01 11:20:03.015 TYPE A
< 2009-07-01 11:20:03.015 200 Type set to A
> 2009-07-01 11:20:03.015 PORT 192,168,0,109,7,91
< 2009-07-01 11:20:03.015 200 Port command successful
> 2009-07-01 11:20:03.015 LIST -a
< 2009-07-01 11:20:03.031 150 Opening data channel for directory list.
. 2009-07-01 11:20:03.046 SSL connection established
< 2009-07-01 11:20:03.046 226 Transfer OK
> 2009-07-01 11:20:03.046 TYPE I
< 2009-07-01 11:20:03.046 200 Type set to I
> 2009-07-01 11:20:03.046 PORT 192,168,0,109,7,92
< 2009-07-01 11:20:03.046 200 Port command successful
> 2009-07-01 11:20:03.046 STOR 19_01_2009_papildus_vienosanas_2.doc
< 2009-07-01 11:20:03.093 150 Opening data channel for file transfer.
. 2009-07-01 11:20:03.109 SSL connection established
< 2009-07-01 11:20:03.125 226 Transfer OK
> 2009-07-01 11:20:03.125 MFMT 20090610063753 19_01_2009_papildus_vienosanas_2.doc
< 2009-07-01 11:20:03.140 213 modify=20090610063753; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/2/19_01_2009_papildus_vienosanas_2.doc
. 2009-07-01 11:20:03.140 Upload successful
. 2009-07-01 11:20:03.140 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2\Maksajumu_grafiks.xls"
. 2009-07-01 11:20:03.140 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2\Maksajumu_grafiks.xls" to remote directory started.
. 2009-07-01 11:20:03.140 Binary transfer mode selected.
. 2009-07-01 11:20:03.140 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2\Maksajumu_grafiks.xls
> 2009-07-01 11:20:03.140 TYPE I
< 2009-07-01 11:20:03.156 200 Type set to I
> 2009-07-01 11:20:03.156 PORT 192,168,0,109,7,93
< 2009-07-01 11:20:03.156 200 Port command successful
> 2009-07-01 11:20:03.156 STOR Maksajumu_grafiks.xls
< 2009-07-01 11:20:03.218 150 Opening data channel for file transfer.
. 2009-07-01 11:20:03.234 SSL connection established
< 2009-07-01 11:20:03.250 226 Transfer OK
> 2009-07-01 11:20:03.250 MFMT 20090519072309 Maksajumu_grafiks.xls
< 2009-07-01 11:20:03.250 213 modify=20090519072309; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/2/Maksajumu_grafiks.xls
. 2009-07-01 11:20:03.250 Upload successful
. 2009-07-01 11:20:03.250 File: "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2\papilldus_tame_2.xls"
. 2009-07-01 11:20:03.250 Copying "c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2\papilldus_tame_2.xls" to remote directory started.
. 2009-07-01 11:20:03.250 Binary transfer mode selected.
. 2009-07-01 11:20:03.250 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\00_DLW\Vienosanas\2\papilldus_tame_2.xls
> 2009-07-01 11:20:03.265 TYPE I
< 2009-07-01 11:20:03.265 200 Type set to I
> 2009-07-01 11:20:03.265 PORT 192,168,0,109,7,94
< 2009-07-01 11:20:03.265 200 Port command successful
> 2009-07-01 11:20:03.265 STOR papilldus_tame_2.xls
< 2009-07-01 11:20:03.296 150 Opening data channel for file transfer.
. 2009-07-01 11:20:03.312 SSL connection established
< 2009-07-01 11:20:03.328 226 Transfer OK
> 2009-07-01 11:20:03.328 MFMT 20090515083650 papilldus_tame_2.xls
< 2009-07-01 11:20:03.343 213 modify=20090515083650; /projects/153_Aigas_Nams/Contract/00_DLW/Vienosanas/2/papilldus_tame_2.xls
. 2009-07-01 11:20:03.343 Upload successful
. 2009-07-01 11:20:03.343 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens"
. 2009-07-01 11:20:03.359 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\buvproj_lig_materiali_doc.doc"
. 2009-07-01 11:20:03.359 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\buvproj_lig_materiali_doc.doc" to remote directory started.
. 2009-07-01 11:20:03.359 Binary transfer mode selected.
. 2009-07-01 11:20:03.359 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\buvproj_lig_materiali_doc.doc
> 2009-07-01 11:20:03.359 CWD /projects/153_Aigas_Nams/Contract/01_Grietens/
< 2009-07-01 11:20:03.359 550 CWD failed. "/projects/153_Aigas_Nams/Contract/01_Grietens": directory not found.
< 2009-07-01 11:20:03.375 250 CWD successful. "/projects/153_Aigas_Nams/Contract" is current directory.
> 2009-07-01 11:20:03.375 MKD 01_Grietens
< 2009-07-01 11:20:03.390 257 Directory created successfully
> 2009-07-01 11:20:03.390 CWD /projects/153_Aigas_Nams/Contract/01_Grietens/
< 2009-07-01 11:20:03.406 250 CWD successful. "/projects/153_Aigas_Nams/Contract/01_Grietens" is current directory.
> 2009-07-01 11:20:03.406 PWD
< 2009-07-01 11:20:03.406 257 "/projects/153_Aigas_Nams/Contract/01_Grietens" is current directory.
> 2009-07-01 11:20:03.406 TYPE A
< 2009-07-01 11:20:03.406 200 Type set to A
> 2009-07-01 11:20:03.406 PORT 192,168,0,109,7,95
< 2009-07-01 11:20:03.406 200 Port command successful
> 2009-07-01 11:20:03.406 LIST -a
< 2009-07-01 11:20:03.437 150 Opening data channel for directory list.
. 2009-07-01 11:20:03.453 SSL connection established
< 2009-07-01 11:20:03.453 226 Transfer OK
> 2009-07-01 11:20:03.453 TYPE I
< 2009-07-01 11:20:03.453 200 Type set to I
> 2009-07-01 11:20:03.453 PORT 192,168,0,109,7,96
< 2009-07-01 11:20:03.453 200 Port command successful
> 2009-07-01 11:20:03.468 STOR buvproj_lig_materiali_doc.doc
< 2009-07-01 11:20:03.484 150 Opening data channel for file transfer.
. 2009-07-01 11:20:03.500 SSL connection established
< 2009-07-01 11:20:03.515 226 Transfer OK
> 2009-07-01 11:20:03.515 MFMT 20070503065612 buvproj_lig_materiali_doc.doc
< 2009-07-01 11:20:03.531 213 modify=20070503065612; /projects/153_Aigas_Nams/Contract/01_Grietens/buvproj_lig_materiali_doc.doc
. 2009-07-01 11:20:03.531 Upload successful
. 2009-07-01 11:20:03.531 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas"
. 2009-07-01 11:20:03.546 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas\izm. taame_1.xls"
. 2009-07-01 11:20:03.546 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas\izm. taame_1.xls" to remote directory started.
. 2009-07-01 11:20:03.546 Binary transfer mode selected.
. 2009-07-01 11:20:03.546 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas\izm. taame_1.xls
> 2009-07-01 11:20:03.546 CWD /projects/153_Aigas_Nams/Contract/01_Grietens/Izmainas/
< 2009-07-01 11:20:03.562 550 CWD failed. "/projects/153_Aigas_Nams/Contract/01_Grietens/Izmainas": directory not found.
> 2009-07-01 11:20:03.562 CWD /projects/153_Aigas_Nams/Contract/01_Grietens/
< 2009-07-01 11:20:03.562 250 CWD successful. "/projects/153_Aigas_Nams/Contract/01_Grietens" is current directory.
> 2009-07-01 11:20:03.562 MKD Izmainas
< 2009-07-01 11:20:03.578 257 Directory created successfully
> 2009-07-01 11:20:03.578 CWD /projects/153_Aigas_Nams/Contract/01_Grietens/Izmainas/
< 2009-07-01 11:20:03.593 250 CWD successful. "/projects/153_Aigas_Nams/Contract/01_Grietens/Izmainas" is current directory.
> 2009-07-01 11:20:03.593 PWD
< 2009-07-01 11:20:03.593 257 "/projects/153_Aigas_Nams/Contract/01_Grietens/Izmainas" is current directory.
> 2009-07-01 11:20:03.593 TYPE A
< 2009-07-01 11:20:03.593 200 Type set to A
> 2009-07-01 11:20:03.593 PORT 192,168,0,109,7,97
< 2009-07-01 11:20:03.593 200 Port command successful
> 2009-07-01 11:20:03.593 LIST -a
< 2009-07-01 11:20:03.609 150 Opening data channel for directory list.
. 2009-07-01 11:20:03.625 SSL connection established
< 2009-07-01 11:20:03.625 226 Transfer OK
> 2009-07-01 11:20:03.625 TYPE I
< 2009-07-01 11:20:03.625 200 Type set to I
> 2009-07-01 11:20:03.640 PORT 192,168,0,109,7,98
< 2009-07-01 11:20:03.640 200 Port command successful
> 2009-07-01 11:20:03.640 STOR izm. taame_1.xls
< 2009-07-01 11:20:03.671 150 Opening data channel for file transfer.
. 2009-07-01 11:20:03.671 SSL connection established
< 2009-07-01 11:20:03.687 226 Transfer OK
> 2009-07-01 11:20:03.687 MFMT 20081022081154 izm. taame_1.xls
< 2009-07-01 11:20:03.703 213 modify=20081022081154; /projects/153_Aigas_Nams/Contract/01_Grietens/Izmainas/izm. taame_1.xls
. 2009-07-01 11:20:03.703 Upload successful
. 2009-07-01 11:20:03.703 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas\Pielikums_6_ maksaj_grafix_1.doc"
. 2009-07-01 11:20:03.703 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas\Pielikums_6_ maksaj_grafix_1.doc" to remote directory started.
. 2009-07-01 11:20:03.703 Binary transfer mode selected.
. 2009-07-01 11:20:03.703 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas\Pielikums_6_ maksaj_grafix_1.doc
> 2009-07-01 11:20:03.703 TYPE I
< 2009-07-01 11:20:03.703 200 Type set to I
> 2009-07-01 11:20:03.703 PORT 192,168,0,109,7,99
< 2009-07-01 11:20:03.718 200 Port command successful
> 2009-07-01 11:20:03.718 STOR Pielikums_6_ maksaj_grafix_1.doc
< 2009-07-01 11:20:03.750 150 Opening data channel for file transfer.
. 2009-07-01 11:20:03.765 SSL connection established
< 2009-07-01 11:20:03.781 226 Transfer OK
> 2009-07-01 11:20:03.781 MFMT 20081022081256 Pielikums_6_ maksaj_grafix_1.doc
< 2009-07-01 11:20:03.796 213 modify=20081022081256; /projects/153_Aigas_Nams/Contract/01_Grietens/Izmainas/Pielikums_6_ maksaj_grafix_1.doc
. 2009-07-01 11:20:03.796 Upload successful
. 2009-07-01 11:20:03.796 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas\Vienosanas.doc"
. 2009-07-01 11:20:03.796 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas\Vienosanas.doc" to remote directory started.
. 2009-07-01 11:20:03.796 Binary transfer mode selected.
. 2009-07-01 11:20:03.796 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Izmainas\Vienosanas.doc
> 2009-07-01 11:20:03.796 TYPE I
< 2009-07-01 11:20:03.796 200 Type set to I
> 2009-07-01 11:20:03.796 PORT 192,168,0,109,7,100
< 2009-07-01 11:20:03.796 200 Port command successful
> 2009-07-01 11:20:03.796 STOR Vienosanas.doc
< 2009-07-01 11:20:03.828 150 Opening data channel for file transfer.
. 2009-07-01 11:20:03.843 SSL connection established
< 2009-07-01 11:20:03.906 226 Transfer OK
> 2009-07-01 11:20:03.906 MFMT 20081022090044 Vienosanas.doc
< 2009-07-01 11:20:03.921 213 modify=20081022090044; /projects/153_Aigas_Nams/Contract/01_Grietens/Izmainas/Vienosanas.doc
. 2009-07-01 11:20:03.921 Upload successful
. 2009-07-01 11:20:03.921 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Ligums.doc"
. 2009-07-01 11:20:03.921 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Ligums.doc" to remote directory started.
. 2009-07-01 11:20:03.921 Binary transfer mode selected.
. 2009-07-01 11:20:03.921 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Ligums.doc
> 2009-07-01 11:20:03.921 CWD /projects/153_Aigas_Nams/Contract/01_Grietens/
< 2009-07-01 11:20:03.921 250 CWD successful. "/projects/153_Aigas_Nams/Contract/01_Grietens" is current directory.
> 2009-07-01 11:20:03.921 PWD
< 2009-07-01 11:20:03.937 257 "/projects/153_Aigas_Nams/Contract/01_Grietens" is current directory.
> 2009-07-01 11:20:03.937 TYPE A
< 2009-07-01 11:20:03.937 200 Type set to A
> 2009-07-01 11:20:03.937 PORT 192,168,0,109,7,101
< 2009-07-01 11:20:03.937 200 Port command successful
> 2009-07-01 11:20:03.937 LIST -a
< 2009-07-01 11:20:03.953 150 Opening data channel for directory list.
. 2009-07-01 11:20:03.968 SSL connection established
< 2009-07-01 11:20:03.968 226 Transfer OK
> 2009-07-01 11:20:03.968 TYPE I
< 2009-07-01 11:20:03.968 200 Type set to I
> 2009-07-01 11:20:03.968 PORT 192,168,0,109,7,102
< 2009-07-01 11:20:03.968 200 Port command successful
> 2009-07-01 11:20:03.968 STOR Ligums.doc
< 2009-07-01 11:20:04.015 150 Opening data channel for file transfer.
. 2009-07-01 11:20:04.031 SSL connection established
< 2009-07-01 11:20:04.109 226 Transfer OK
> 2009-07-01 11:20:04.109 MFMT 20081022075202 Ligums.doc
< 2009-07-01 11:20:04.109 213 modify=20081022075202; /projects/153_Aigas_Nams/Contract/01_Grietens/Ligums.doc
. 2009-07-01 11:20:04.109 Upload successful
. 2009-07-01 11:20:04.109 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Ligums_autoruzraudziba.doc"
. 2009-07-01 11:20:04.109 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Ligums_autoruzraudziba.doc" to remote directory started.
. 2009-07-01 11:20:04.109 Binary transfer mode selected.
. 2009-07-01 11:20:04.109 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Ligums_autoruzraudziba.doc
> 2009-07-01 11:20:04.125 TYPE I
< 2009-07-01 11:20:04.125 200 Type set to I
> 2009-07-01 11:20:04.125 PORT 192,168,0,109,7,103
< 2009-07-01 11:20:04.125 200 Port command successful
> 2009-07-01 11:20:04.125 STOR Ligums_autoruzraudziba.doc
< 2009-07-01 11:20:04.171 150 Opening data channel for file transfer.
. 2009-07-01 11:20:04.187 SSL connection established
< 2009-07-01 11:20:04.234 226 Transfer OK
> 2009-07-01 11:20:04.234 MFMT 20070918081528 Ligums_autoruzraudziba.doc
< 2009-07-01 11:20:04.234 213 modify=20070918081528; /projects/153_Aigas_Nams/Contract/01_Grietens/Ligums_autoruzraudziba.doc
. 2009-07-01 11:20:04.234 Upload successful
. 2009-07-01 11:20:04.234 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc"
. 2009-07-01 11:20:04.250 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc" to remote directory started.
. 2009-07-01 11:20:04.250 Binary transfer mode selected.
. 2009-07-01 11:20:04.250 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc
> 2009-07-01 11:20:04.250 TYPE I
< 2009-07-01 11:20:04.250 200 Type set to I
> 2009-07-01 11:20:04.250 PORT 192,168,0,109,7,104
< 2009-07-01 11:20:04.250 200 Port command successful
> 2009-07-01 11:20:04.250 STOR Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc
< 2009-07-01 11:20:04.281 150 Opening data channel for file transfer.
. 2009-07-01 11:20:04.296 SSL connection established
< 2009-07-01 11:20:04.656 226 Transfer OK
> 2009-07-01 11:20:04.656 MFMT 20070903124500 Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc
< 2009-07-01 11:20:04.656 213 modify=20070903124500; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikums_1_Paskaidrojuma_raksts_AR_BK.doc
. 2009-07-01 11:20:04.656 Upload successful
. 2009-07-01 11:20:04.656 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_1_Paskaidrojuma_raksts_tikli.doc"
. 2009-07-01 11:20:04.656 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_1_Paskaidrojuma_raksts_tikli.doc" to remote directory started.
. 2009-07-01 11:20:04.671 Binary transfer mode selected.
. 2009-07-01 11:20:04.671 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_1_Paskaidrojuma_raksts_tikli.doc
> 2009-07-01 11:20:04.671 TYPE I
< 2009-07-01 11:20:04.671 200 Type set to I
> 2009-07-01 11:20:04.671 PORT 192,168,0,109,7,105
< 2009-07-01 11:20:04.671 200 Port command successful
> 2009-07-01 11:20:04.671 STOR Pielikums_1_Paskaidrojuma_raksts_tikli.doc
< 2009-07-01 11:20:04.734 150 Opening data channel for file transfer.
. 2009-07-01 11:20:04.750 SSL connection established
< 2009-07-01 11:20:04.859 226 Transfer OK
> 2009-07-01 11:20:04.859 MFMT 20070829051402 Pielikums_1_Paskaidrojuma_raksts_tikli.doc
< 2009-07-01 11:20:04.875 213 modify=20070829051402; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikums_1_Paskaidrojuma_raksts_tikli.doc
. 2009-07-01 11:20:04.875 Upload successful
. 2009-07-01 11:20:04.875 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_2_Līgumsaistību robeas_18 06 2007.doc"
. 2009-07-01 11:20:04.875 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_2_Līgumsaistību robeas_18 06 2007.doc" to remote directory started.
. 2009-07-01 11:20:04.875 Binary transfer mode selected.
. 2009-07-01 11:20:04.875 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_2_Līgumsaistību robeas_18 06 2007.doc
> 2009-07-01 11:20:04.875 TYPE I
< 2009-07-01 11:20:04.875 200 Type set to I
> 2009-07-01 11:20:04.875 PORT 192,168,0,109,7,106
< 2009-07-01 11:20:04.875 200 Port command successful
> 2009-07-01 11:20:04.875 STOR Pielikums_2_Līgumsaistību robeas_18 06 2007.doc
< 2009-07-01 11:20:04.906 150 Opening data channel for file transfer.
. 2009-07-01 11:20:04.921 SSL connection established
< 2009-07-01 11:20:05.078 226 Transfer OK
> 2009-07-01 11:20:05.078 MFMT 20070917081508 Pielikums_2_Līgumsaistību robeas_18 06 2007.doc
< 2009-07-01 11:20:05.078 213 modify=20070917081508; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikums_2_Līgumsaistību robeas_18 06 2007.doc
. 2009-07-01 11:20:05.078 Upload successful
. 2009-07-01 11:20:05.078 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_3_Projekta_datalizacijas_prasibas.xls"
. 2009-07-01 11:20:05.078 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_3_Projekta_datalizacijas_prasibas.xls" to remote directory started.
. 2009-07-01 11:20:05.093 Binary transfer mode selected.
. 2009-07-01 11:20:05.093 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_3_Projekta_datalizacijas_prasibas.xls
> 2009-07-01 11:20:05.093 TYPE I
< 2009-07-01 11:20:05.093 200 Type set to I
> 2009-07-01 11:20:05.093 PORT 192,168,0,109,7,107
< 2009-07-01 11:20:05.093 200 Port command successful
> 2009-07-01 11:20:05.093 STOR Pielikums_3_Projekta_datalizacijas_prasibas.xls
< 2009-07-01 11:20:05.125 150 Opening data channel for file transfer.
. 2009-07-01 11:20:05.125 SSL connection established
< 2009-07-01 11:20:05.156 226 Transfer OK
> 2009-07-01 11:20:05.156 MFMT 20070919125731 Pielikums_3_Projekta_datalizacijas_prasibas.xls
< 2009-07-01 11:20:05.156 213 modify=20070919125731; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikums_3_Projekta_datalizacijas_prasibas.xls
. 2009-07-01 11:20:05.156 Upload successful
. 2009-07-01 11:20:05.156 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_5_ darbu grafix_5.xls"
. 2009-07-01 11:20:05.187 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_5_ darbu grafix_5.xls" to remote directory started.
. 2009-07-01 11:20:05.187 Binary transfer mode selected.
. 2009-07-01 11:20:05.187 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_5_ darbu grafix_5.xls
> 2009-07-01 11:20:05.187 TYPE I
< 2009-07-01 11:20:05.187 200 Type set to I
> 2009-07-01 11:20:05.187 PORT 192,168,0,109,7,108
< 2009-07-01 11:20:05.187 200 Port command successful
> 2009-07-01 11:20:05.187 STOR Pielikums_5_ darbu grafix_5.xls
< 2009-07-01 11:20:05.218 150 Opening data channel for file transfer.
. 2009-07-01 11:20:05.234 SSL connection established
< 2009-07-01 11:20:05.250 226 Transfer OK
> 2009-07-01 11:20:05.250 MFMT 20070913103904 Pielikums_5_ darbu grafix_5.xls
< 2009-07-01 11:20:05.265 213 modify=20070913103904; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikums_5_ darbu grafix_5.xls
. 2009-07-01 11:20:05.265 Upload successful
. 2009-07-01 11:20:05.265 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_6_ maksaj. grafix.doc"
. 2009-07-01 11:20:05.265 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_6_ maksaj. grafix.doc" to remote directory started.
. 2009-07-01 11:20:05.265 Binary transfer mode selected.
. 2009-07-01 11:20:05.265 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_6_ maksaj. grafix.doc
> 2009-07-01 11:20:05.265 TYPE I
< 2009-07-01 11:20:05.265 200 Type set to I
> 2009-07-01 11:20:05.265 PORT 192,168,0,109,7,109
< 2009-07-01 11:20:05.281 200 Port command successful
> 2009-07-01 11:20:05.281 STOR Pielikums_6_ maksaj. grafix.doc
< 2009-07-01 11:20:05.281 150 Opening data channel for file transfer.
. 2009-07-01 11:20:05.296 SSL connection established
< 2009-07-01 11:20:05.312 226 Transfer OK
> 2009-07-01 11:20:05.312 MFMT 20070913110454 Pielikums_6_ maksaj. grafix.doc
< 2009-07-01 11:20:05.328 213 modify=20070913110454; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikums_6_ maksaj. grafix.doc
. 2009-07-01 11:20:05.328 Upload successful
. 2009-07-01 11:20:05.328 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_7_ taame_2.xls"
. 2009-07-01 11:20:05.328 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_7_ taame_2.xls" to remote directory started.
. 2009-07-01 11:20:05.328 Binary transfer mode selected.
. 2009-07-01 11:20:05.328 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_7_ taame_2.xls
> 2009-07-01 11:20:05.328 TYPE I
< 2009-07-01 11:20:05.328 200 Type set to I
> 2009-07-01 11:20:05.343 PORT 192,168,0,109,7,110
< 2009-07-01 11:20:05.343 200 Port command successful
> 2009-07-01 11:20:05.343 STOR Pielikums_7_ taame_2.xls
< 2009-07-01 11:20:05.343 150 Opening data channel for file transfer.
. 2009-07-01 11:20:05.359 SSL connection established
< 2009-07-01 11:20:05.375 226 Transfer OK
> 2009-07-01 11:20:05.375 MFMT 20070619062920 Pielikums_7_ taame_2.xls
< 2009-07-01 11:20:05.390 213 modify=20070619062920; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikums_7_ taame_2.xls
. 2009-07-01 11:20:05.390 Upload successful
. 2009-07-01 11:20:05.390 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_8_buvproj_lig_darbu_pien_nod_akts.doc"
. 2009-07-01 11:20:05.390 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_8_buvproj_lig_darbu_pien_nod_akts.doc" to remote directory started.
. 2009-07-01 11:20:05.390 Binary transfer mode selected.
. 2009-07-01 11:20:05.390 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikums_8_buvproj_lig_darbu_pien_nod_akts.doc
> 2009-07-01 11:20:05.390 TYPE I
< 2009-07-01 11:20:05.390 200 Type set to I
> 2009-07-01 11:20:05.406 PORT 192,168,0,109,7,111
< 2009-07-01 11:20:05.406 200 Port command successful
> 2009-07-01 11:20:05.406 STOR Pielikums_8_buvproj_lig_darbu_pien_nod_akts.doc
< 2009-07-01 11:20:05.453 150 Opening data channel for file transfer.
. 2009-07-01 11:20:05.468 SSL connection established
< 2009-07-01 11:20:05.500 226 Transfer OK
> 2009-07-01 11:20:05.500 MFMT 20071101072921 Pielikums_8_buvproj_lig_darbu_pien_nod_akts.doc
< 2009-07-01 11:20:05.515 213 modify=20071101072921; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikums_8_buvproj_lig_darbu_pien_nod_akts.doc
. 2009-07-01 11:20:05.515 Upload successful
. 2009-07-01 11:20:05.515 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi"
. 2009-07-01 11:20:05.531 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Autoruzraudibas ligums.doc"
. 2009-07-01 11:20:05.531 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Autoruzraudibas ligums.doc" to remote directory started.
. 2009-07-01 11:20:05.531 Binary transfer mode selected.
. 2009-07-01 11:20:05.531 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Autoruzraudibas ligums.doc
> 2009-07-01 11:20:05.531 CWD /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/
< 2009-07-01 11:20:05.546 550 CWD failed. "/projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi": directory not found.
> 2009-07-01 11:20:05.546 CWD /projects/153_Aigas_Nams/Contract/01_Grietens/
< 2009-07-01 11:20:05.546 250 CWD successful. "/projects/153_Aigas_Nams/Contract/01_Grietens" is current directory.
> 2009-07-01 11:20:05.546 MKD Pielikumu_paraugi
< 2009-07-01 11:20:05.562 257 Directory created successfully
> 2009-07-01 11:20:05.562 CWD /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/
< 2009-07-01 11:20:05.578 250 CWD successful. "/projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi" is current directory.
> 2009-07-01 11:20:05.578 PWD
< 2009-07-01 11:20:05.578 257 "/projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi" is current directory.
> 2009-07-01 11:20:05.578 TYPE A
< 2009-07-01 11:20:05.578 200 Type set to A
> 2009-07-01 11:20:05.578 PORT 192,168,0,109,7,112
< 2009-07-01 11:20:05.578 200 Port command successful
> 2009-07-01 11:20:05.578 LIST -a
< 2009-07-01 11:20:05.593 150 Opening data channel for directory list.
. 2009-07-01 11:20:05.609 SSL connection established
< 2009-07-01 11:20:05.609 226 Transfer OK
> 2009-07-01 11:20:05.609 TYPE I
< 2009-07-01 11:20:05.609 200 Type set to I
> 2009-07-01 11:20:05.609 PORT 192,168,0,109,7,113
< 2009-07-01 11:20:05.609 200 Port command successful
> 2009-07-01 11:20:05.609 STOR Autoruzraudibas ligums.doc
< 2009-07-01 11:20:05.625 150 Opening data channel for file transfer.
. 2009-07-01 11:20:05.656 SSL connection established
< 2009-07-01 11:20:05.671 226 Transfer OK
> 2009-07-01 11:20:05.671 MFMT 20070917120900 Autoruzraudibas ligums.doc
< 2009-07-01 11:20:05.687 213 modify=20070917120900; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Autoruzraudibas ligums.doc
. 2009-07-01 11:20:05.687 Upload successful
. 2009-07-01 11:20:05.687 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Darbu_grafiks_Skanstes_birojs.pdf"
. 2009-07-01 11:20:05.687 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Darbu_grafiks_Skanstes_birojs.pdf" to remote directory started.
. 2009-07-01 11:20:05.687 Binary transfer mode selected.
. 2009-07-01 11:20:05.687 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Darbu_grafiks_Skanstes_birojs.pdf
> 2009-07-01 11:20:05.687 TYPE I
< 2009-07-01 11:20:05.687 200 Type set to I
> 2009-07-01 11:20:05.687 PORT 192,168,0,109,7,114
< 2009-07-01 11:20:05.703 200 Port command successful
> 2009-07-01 11:20:05.703 STOR Darbu_grafiks_Skanstes_birojs.pdf
< 2009-07-01 11:20:05.718 150 Opening data channel for file transfer.
. 2009-07-01 11:20:05.734 SSL connection established
< 2009-07-01 11:20:05.953 226 Transfer OK
> 2009-07-01 11:20:05.953 MFMT 20070618072346 Darbu_grafiks_Skanstes_birojs.pdf
< 2009-07-01 11:20:05.953 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Darbu_grafiks_Skanstes_birojs.pdf
. 2009-07-01 11:20:05.953 Upload successful
. 2009-07-01 11:20:05.953 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\GramCheckPhraseLog.txt"
. 2009-07-01 11:20:05.953 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\GramCheckPhraseLog.txt" to remote directory started.
. 2009-07-01 11:20:05.953 Ascii transfer mode selected.
. 2009-07-01 11:20:05.953 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\GramCheckPhraseLog.txt
> 2009-07-01 11:20:05.968 TYPE A
< 2009-07-01 11:20:05.968 200 Type set to A
> 2009-07-01 11:20:05.968 PORT 192,168,0,109,7,115
< 2009-07-01 11:20:05.968 200 Port command successful
> 2009-07-01 11:20:05.968 STOR GramCheckPhraseLog.txt
< 2009-07-01 11:20:06.046 150 Opening data channel for file transfer.
. 2009-07-01 11:20:06.046 SSL connection established
< 2009-07-01 11:20:06.140 226 Transfer OK
> 2009-07-01 11:20:06.140 MFMT 20070917121200 GramCheckPhraseLog.txt
< 2009-07-01 11:20:06.140 213 modify=20070917121200; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/GramCheckPhraseLog.txt
. 2009-07-01 11:20:06.140 Upload successful
. 2009-07-01 11:20:06.140 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Ligums 25 05 2007.doc"
. 2009-07-01 11:20:06.140 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Ligums 25 05 2007.doc" to remote directory started.
. 2009-07-01 11:20:06.140 Binary transfer mode selected.
. 2009-07-01 11:20:06.156 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Ligums 25 05 2007.doc
> 2009-07-01 11:20:06.156 TYPE I
< 2009-07-01 11:20:06.156 200 Type set to I
> 2009-07-01 11:20:06.156 PORT 192,168,0,109,7,116
< 2009-07-01 11:20:06.156 200 Port command successful
> 2009-07-01 11:20:06.156 STOR Ligums 25 05 2007.doc
< 2009-07-01 11:20:06.171 150 Opening data channel for file transfer.
. 2009-07-01 11:20:06.203 SSL connection established
< 2009-07-01 11:20:06.281 226 Transfer OK
> 2009-07-01 11:20:06.281 MFMT 20070618072346 Ligums 25 05 2007.doc
< 2009-07-01 11:20:06.281 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Ligums 25 05 2007.doc
. 2009-07-01 11:20:06.281 Upload successful
. 2009-07-01 11:20:06.281 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 1(1)_projektesanas _uzdevums_25 05 2007.doc"
. 2009-07-01 11:20:06.296 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 1(1)_projektesanas _uzdevums_25 05 2007.doc" to remote directory started.
. 2009-07-01 11:20:06.296 Binary transfer mode selected.
. 2009-07-01 11:20:06.296 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 1(1)_projektesanas _uzdevums_25 05 2007.doc
> 2009-07-01 11:20:06.296 TYPE I
< 2009-07-01 11:20:06.296 200 Type set to I
> 2009-07-01 11:20:06.296 PORT 192,168,0,109,7,117
< 2009-07-01 11:20:06.296 200 Port command successful
> 2009-07-01 11:20:06.296 STOR Pielikums 1(1)_projektesanas _uzdevums_25 05 2007.doc
< 2009-07-01 11:20:06.312 150 Opening data channel for file transfer.
. 2009-07-01 11:20:06.328 SSL connection established
< 2009-07-01 11:20:06.390 226 Transfer OK
> 2009-07-01 11:20:06.390 MFMT 20070618072346 Pielikums 1(1)_projektesanas _uzdevums_25 05 2007.doc
< 2009-07-01 11:20:06.406 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Pielikums 1(1)_projektesanas _uzdevums_25 05 2007.doc
. 2009-07-01 11:20:06.406 Upload successful
. 2009-07-01 11:20:06.406 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 1(2)_grafiskas_robeas_25 05 07.doc"
. 2009-07-01 11:20:06.421 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 1(2)_grafiskas_robeas_25 05 07.doc" to remote directory started.
. 2009-07-01 11:20:06.421 Binary transfer mode selected.
. 2009-07-01 11:20:06.421 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 1(2)_grafiskas_robeas_25 05 07.doc
> 2009-07-01 11:20:06.421 TYPE I
< 2009-07-01 11:20:06.421 200 Type set to I
> 2009-07-01 11:20:06.437 PORT 192,168,0,109,7,118
< 2009-07-01 11:20:06.437 200 Port command successful
> 2009-07-01 11:20:06.437 STOR Pielikums 1(2)_grafiskas_robeas_25 05 07.doc
< 2009-07-01 11:20:06.437 150 Opening data channel for file transfer.
. 2009-07-01 11:20:06.468 SSL connection established
< 2009-07-01 11:20:07.906 226 Transfer OK
> 2009-07-01 11:20:07.906 MFMT 20070618072346 Pielikums 1(2)_grafiskas_robeas_25 05 07.doc
< 2009-07-01 11:20:07.921 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Pielikums 1(2)_grafiskas_robeas_25 05 07.doc
. 2009-07-01 11:20:07.921 Upload successful
. 2009-07-01 11:20:07.921 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 2_Līgumsaistību robeas_25 05 2007.doc"
. 2009-07-01 11:20:07.921 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 2_Līgumsaistību robeas_25 05 2007.doc" to remote directory started.
. 2009-07-01 11:20:07.921 Binary transfer mode selected.
. 2009-07-01 11:20:07.921 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 2_Līgumsaistību robeas_25 05 2007.doc
> 2009-07-01 11:20:07.921 TYPE I
< 2009-07-01 11:20:07.921 200 Type set to I
> 2009-07-01 11:20:07.937 PORT 192,168,0,109,7,119
< 2009-07-01 11:20:07.937 200 Port command successful
> 2009-07-01 11:20:07.937 STOR Pielikums 2_Līgumsaistību robeas_25 05 2007.doc
< 2009-07-01 11:20:08.015 150 Opening data channel for file transfer.
. 2009-07-01 11:20:08.031 SSL connection established
< 2009-07-01 11:20:08.265 226 Transfer OK
> 2009-07-01 11:20:08.265 MFMT 20070618072346 Pielikums 2_Līgumsaistību robeas_25 05 2007.doc
< 2009-07-01 11:20:08.265 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Pielikums 2_Līgumsaistību robeas_25 05 2007.doc
. 2009-07-01 11:20:08.265 Upload successful
. 2009-07-01 11:20:08.265 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 3_Projekta_detalizacijas_prasibas 25 05 2007.xls"
. 2009-07-01 11:20:08.265 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 3_Projekta_detalizacijas_prasibas 25 05 2007.xls" to remote directory started.
. 2009-07-01 11:20:08.281 Binary transfer mode selected.
. 2009-07-01 11:
It looks like your log was truncated (these limit in the post). Please email it to me.
Roberts
. 2009-07-01 11:20:08.281 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 3_Projekta_detalizacijas_prasibas 25 05 2007.xls
> 2009-07-01 11:20:08.281 TYPE I
< 2009-07-01 11:20:08.281 200 Type set to I
> 2009-07-01 11:20:08.281 PORT 192,168,0,109,7,120
< 2009-07-01 11:20:08.281 200 Port command successful
> 2009-07-01 11:20:08.281 STOR Pielikums 3_Projekta_detalizacijas_prasibas 25 05 2007.xls
< 2009-07-01 11:20:08.296 150 Opening data channel for file transfer.
. 2009-07-01 11:20:08.312 SSL connection established
< 2009-07-01 11:20:08.359 226 Transfer OK
> 2009-07-01 11:20:08.359 MFMT 20070618072346 Pielikums 3_Projekta_detalizacijas_prasibas 25 05 2007.xls
< 2009-07-01 11:20:08.375 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Pielikums 3_Projekta_detalizacijas_prasibas 25 05 2007.xls
. 2009-07-01 11:20:08.375 Upload successful
. 2009-07-01 11:20:08.375 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 4 Projekta_izstradasanai_nepieciesamie 25 05 2007.doc"
. 2009-07-01 11:20:08.375 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 4 Projekta_izstradasanai_nepieciesamie 25 05 2007.doc" to remote directory started.
. 2009-07-01 11:20:08.375 Binary transfer mode selected.
. 2009-07-01 11:20:08.375 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 4 Projekta_izstradasanai_nepieciesamie 25 05 2007.doc
> 2009-07-01 11:20:08.375 TYPE I
< 2009-07-01 11:20:08.375 200 Type set to I
> 2009-07-01 11:20:08.375 PORT 192,168,0,109,7,121
< 2009-07-01 11:20:08.375 200 Port command successful
> 2009-07-01 11:20:08.375 STOR Pielikums 4 Projekta_izstradasanai_nepieciesamie 25 05 2007.doc
< 2009-07-01 11:20:08.390 150 Opening data channel for file transfer.
. 2009-07-01 11:20:08.406 SSL connection established
< 2009-07-01 11:20:08.468 226 Transfer OK
> 2009-07-01 11:20:08.468 MFMT 20070618072346 Pielikums 4 Projekta_izstradasanai_nepieciesamie 25 05 2007.doc
< 2009-07-01 11:20:08.468 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Pielikums 4 Projekta_izstradasanai_nepieciesamie 25 05 2007.doc
. 2009-07-01 11:20:08.468 Upload successful
. 2009-07-01 11:20:08.484 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 6_Maksajumu_grafiks 25 05 2007.doc"
. 2009-07-01 11:20:08.484 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 6_Maksajumu_grafiks 25 05 2007.doc" to remote directory started.
. 2009-07-01 11:20:08.484 Binary transfer mode selected.
. 2009-07-01 11:20:08.484 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 6_Maksajumu_grafiks 25 05 2007.doc
> 2009-07-01 11:20:08.484 TYPE I
< 2009-07-01 11:20:08.484 200 Type set to I
> 2009-07-01 11:20:08.484 PORT 192,168,0,109,7,122
< 2009-07-01 11:20:08.484 200 Port command successful
> 2009-07-01 11:20:08.484 STOR Pielikums 6_Maksajumu_grafiks 25 05 2007.doc
< 2009-07-01 11:20:08.500 150 Opening data channel for file transfer.
. 2009-07-01 11:20:08.515 SSL connection established
< 2009-07-01 11:20:08.546 226 Transfer OK
> 2009-07-01 11:20:08.546 MFMT 20070618072346 Pielikums 6_Maksajumu_grafiks 25 05 2007.doc
< 2009-07-01 11:20:08.562 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Pielikums 6_Maksajumu_grafiks 25 05 2007.doc
. 2009-07-01 11:20:08.562 Upload successful
. 2009-07-01 11:20:08.562 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 8_Darbu pienemsanas 25 05 2007.doc"
. 2009-07-01 11:20:08.562 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 8_Darbu pienemsanas 25 05 2007.doc" to remote directory started.
. 2009-07-01 11:20:08.562 Binary transfer mode selected.
. 2009-07-01 11:20:08.562 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums 8_Darbu pienemsanas 25 05 2007.doc
> 2009-07-01 11:20:08.562 TYPE I
< 2009-07-01 11:20:08.562 200 Type set to I
> 2009-07-01 11:20:08.578 PORT 192,168,0,109,7,123
< 2009-07-01 11:20:08.578 200 Port command successful
> 2009-07-01 11:20:08.578 STOR Pielikums 8_Darbu pienemsanas 25 05 2007.doc
< 2009-07-01 11:20:08.578 150 Opening data channel for file transfer.
. 2009-07-01 11:20:08.593 SSL connection established
< 2009-07-01 11:20:08.625 226 Transfer OK
> 2009-07-01 11:20:08.625 MFMT 20070618072346 Pielikums 8_Darbu pienemsanas 25 05 2007.doc
< 2009-07-01 11:20:08.640 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Pielikums 8_Darbu pienemsanas 25 05 2007.doc
. 2009-07-01 11:20:08.640 Upload successful
. 2009-07-01 11:20:08.640 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\pielikums Nr 3 detalizacijas prasibas LV-Engl.xls"
. 2009-07-01 11:20:08.640 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\pielikums Nr 3 detalizacijas prasibas LV-Engl.xls" to remote directory started.
. 2009-07-01 11:20:08.640 Binary transfer mode selected.
. 2009-07-01 11:20:08.640 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\pielikums Nr 3 detalizacijas prasibas LV-Engl.xls
> 2009-07-01 11:20:08.640 TYPE I
< 2009-07-01 11:20:08.640 200 Type set to I
> 2009-07-01 11:20:08.640 PORT 192,168,0,109,7,124
< 2009-07-01 11:20:08.640 200 Port command successful
> 2009-07-01 11:20:08.640 STOR pielikums Nr 3 detalizacijas prasibas LV-Engl.xls
< 2009-07-01 11:20:08.671 150 Opening data channel for file transfer.
. 2009-07-01 11:20:08.687 SSL connection established
< 2009-07-01 11:20:08.718 226 Transfer OK
> 2009-07-01 11:20:08.718 MFMT 20070917120959 pielikums Nr 3 detalizacijas prasibas LV-Engl.xls
< 2009-07-01 11:20:08.734 213 modify=20070917120959; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/pielikums Nr 3 detalizacijas prasibas LV-Engl.xls
. 2009-07-01 11:20:08.734 Upload successful
. 2009-07-01 11:20:08.734 File: "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums7_Tame 25 05 2007.xls"
. 2009-07-01 11:20:08.734 Copying "c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums7_Tame 25 05 2007.xls" to remote directory started.
. 2009-07-01 11:20:08.734 Binary transfer mode selected.
. 2009-07-01 11:20:08.734 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\01_Grietens\Pielikumu_paraugi\Pielikums7_Tame 25 05 2007.xls
> 2009-07-01 11:20:08.734 TYPE I
< 2009-07-01 11:20:08.734 200 Type set to I
> 2009-07-01 11:20:08.734 PORT 192,168,0,109,7,125
< 2009-07-01 11:20:08.750 200 Port command successful
> 2009-07-01 11:20:08.750 STOR Pielikums7_Tame 25 05 2007.xls
< 2009-07-01 11:20:08.765 150 Opening data channel for file transfer.
. 2009-07-01 11:20:08.781 SSL connection established
< 2009-07-01 11:20:08.812 226 Transfer OK
> 2009-07-01 11:20:08.812 MFMT 20070618072346 Pielikums7_Tame 25 05 2007.xls
< 2009-07-01 11:20:08.828 213 modify=20070618072346; /projects/153_Aigas_Nams/Contract/01_Grietens/Pielikumu_paraugi/Pielikums7_Tame 25 05 2007.xls
. 2009-07-01 11:20:08.828 Upload successful
. 2009-07-01 11:20:08.828 File: "c:\work\projects\153_Aigas_Nams\Contract\02_AMP"
. 2009-07-01 11:20:08.843 File: "c:\work\projects\153_Aigas_Nams\Contract\02_AMP\GramCheckPhraseLog.txt"
. 2009-07-01 11:20:08.843 Copying "c:\work\projects\153_Aigas_Nams\Contract\02_AMP\GramCheckPhraseLog.txt" to remote directory started.
. 2009-07-01 11:20:08.843 Ascii transfer mode selected.
. 2009-07-01 11:20:08.843 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\02_AMP\GramCheckPhraseLog.txt
> 2009-07-01 11:20:08.843 CWD /projects/153_Aigas_Nams/Contract/02_AMP/
< 2009-07-01 11:20:08.843 550 CWD failed. "/projects/153_Aigas_Nams/Contract/02_AMP": directory not found.
< 2009-07-01 11:20:08.859 250 CWD successful. "/projects/153_Aigas_Nams/Contract" is current directory.
> 2009-07-01 11:20:08.859 MKD 02_AMP
< 2009-07-01 11:20:08.875 257 Directory created successfully
> 2009-07-01 11:20:08.875 CWD /projects/153_Aigas_Nams/Contract/02_AMP/
< 2009-07-01 11:20:08.875 250 CWD successful. "/projects/153_Aigas_Nams/Contract/02_AMP" is current directory.
> 2009-07-01 11:20:08.875 PWD
< 2009-07-01 11:20:08.875 257 "/projects/153_Aigas_Nams/Contract/02_AMP" is current directory.
> 2009-07-01 11:20:08.875 TYPE A
< 2009-07-01 11:20:08.875 200 Type set to A
> 2009-07-01 11:20:08.875 PORT 192,168,0,109,7,126
< 2009-07-01 11:20:08.875 200 Port command successful
> 2009-07-01 11:20:08.875 LIST -a
< 2009-07-01 11:20:08.890 150 Opening data channel for directory list.
. 2009-07-01 11:20:08.906 SSL connection established
< 2009-07-01 11:20:08.906 226 Transfer OK
> 2009-07-01 11:20:08.906 TYPE A
< 2009-07-01 11:20:08.921 200 Type set to A
> 2009-07-01 11:20:08.921 PORT 192,168,0,109,7,127
< 2009-07-01 11:20:08.921 200 Port command successful
> 2009-07-01 11:20:08.921 STOR GramCheckPhraseLog.txt
< 2009-07-01 11:20:08.921 150 Opening data channel for file transfer.
. 2009-07-01 11:20:08.984 SSL connection established
< 2009-07-01 11:20:09.015 226 Transfer OK
> 2009-07-01 11:20:09.015 MFMT 20080423053130 GramCheckPhraseLog.txt
< 2009-07-01 11:20:09.031 213 modify=20080423053130; /projects/153_Aigas_Nams/Contract/02_AMP/GramCheckPhraseLog.txt
. 2009-07-01 11:20:09.031 Upload successful
. 2009-07-01 11:20:09.031 File: "c:\work\projects\153_Aigas_Nams\Contract\02_AMP\Ligums_AMP_DA.doc"
. 2009-07-01 11:20:09.031 Copying "c:\work\projects\153_Aigas_Nams\Contract\02_AMP\Ligums_AMP_DA.doc" to remote directory started.
. 2009-07-01 11:20:09.031 Binary transfer mode selected.
. 2009-07-01 11:20:09.031 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\02_AMP\Ligums_AMP_DA.doc
> 2009-07-01 11:20:09.031 TYPE I
< 2009-07-01 11:20:09.031 200 Type set to I
> 2009-07-01 11:20:09.046 PORT 192,168,0,109,7,128
< 2009-07-01 11:20:09.046 200 Port command successful
> 2009-07-01 11:20:09.046 STOR Ligums_AMP_DA.doc
< 2009-07-01 11:20:09.062 150 Opening data channel for file transfer.
. 2009-07-01 11:20:09.078 SSL connection established
< 2009-07-01 11:20:09.109 226 Transfer OK
> 2009-07-01 11:20:09.109 MFMT 20070725075958 Ligums_AMP_DA.doc
< 2009-07-01 11:20:09.125 213 modify=20070725075958; /projects/153_Aigas_Nams/Contract/02_AMP/Ligums_AMP_DA.doc
. 2009-07-01 11:20:09.125 Upload successful
. 2009-07-01 11:20:09.125 File: "c:\work\projects\153_Aigas_Nams\Contract\02_AMP\papildus_vienosanas.doc"
. 2009-07-01 11:20:09.125 Copying "c:\work\projects\153_Aigas_Nams\Contract\02_AMP\papildus_vienosanas.doc" to remote directory started.
. 2009-07-01 11:20:09.125 Binary transfer mode selected.
. 2009-07-01 11:20:09.125 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\02_AMP\papildus_vienosanas.doc
> 2009-07-01 11:20:09.125 TYPE I
< 2009-07-01 11:20:09.125 200 Type set to I
> 2009-07-01 11:20:09.125 PORT 192,168,0,109,7,129
< 2009-07-01 11:20:09.125 200 Port command successful
> 2009-07-01 11:20:09.125 STOR papildus_vienosanas.doc
< 2009-07-01 11:20:09.171 150 Opening data channel for file transfer.
. 2009-07-01 11:20:09.171 SSL connection established
< 2009-07-01 11:20:09.218 226 Transfer OK
> 2009-07-01 11:20:09.218 MFMT 20080422061939 papildus_vienosanas.doc
< 2009-07-01 11:20:09.234 213 modify=20080422061939; /projects/153_Aigas_Nams/Contract/02_AMP/papildus_vienosanas.doc
. 2009-07-01 11:20:09.234 Upload successful
. 2009-07-01 11:20:09.234 File: "c:\work\projects\153_Aigas_Nams\Contract\02_AMP\Subcontract_S_ lat _2007_doc.doc"
. 2009-07-01 11:20:09.234 Copying "c:\work\projects\153_Aigas_Nams\Contract\02_AMP\Subcontract_S_ lat _2007_doc.doc" to remote directory started.
. 2009-07-01 11:20:09.234 Binary transfer mode selected.
. 2009-07-01 11:20:09.234 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\02_AMP\Subcontract_S_ lat _2007_doc.doc
> 2009-07-01 11:20:09.234 TYPE I
< 2009-07-01 11:20:09.234 200 Type set to I
> 2009-07-01 11:20:09.234 PORT 192,168,0,109,7,130
< 2009-07-01 11:20:09.234 200 Port command successful
> 2009-07-01 11:20:09.234 STOR Subcontract_S_ lat _2007_doc.doc
< 2009-07-01 11:20:09.250 150 Opening data channel for file transfer.
. 2009-07-01 11:20:09.265 SSL connection established
< 2009-07-01 11:20:09.296 226 Transfer OK
> 2009-07-01 11:20:09.296 MFMT 20070725074612 Subcontract_S_ lat _2007_doc.doc
< 2009-07-01 11:20:09.312 213 modify=20070725074612; /projects/153_Aigas_Nams/Contract/02_AMP/Subcontract_S_ lat _2007_doc.doc
. 2009-07-01 11:20:09.312 Upload successful
. 2009-07-01 11:20:09.312 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS"
. 2009-07-01 11:20:09.328 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\GramCheckPhraseLog.txt"
. 2009-07-01 11:20:09.328 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\GramCheckPhraseLog.txt" to remote directory started.
. 2009-07-01 11:20:09.328 Ascii transfer mode selected.
. 2009-07-01 11:20:09.328 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\GramCheckPhraseLog.txt
> 2009-07-01 11:20:09.328 CWD /projects/153_Aigas_Nams/Contract/03_BMGS/
< 2009-07-01 11:20:09.343 550 CWD failed. "/projects/153_Aigas_Nams/Contract/03_BMGS": directory not found.
> 2009-07-01 11:20:09.343 CWD /projects/153_Aigas_Nams/Contract/
< 2009-07-01 11:20:09.343 250 CWD successful. "/projects/153_Aigas_Nams/Contract" is current directory.
> 2009-07-01 11:20:09.343 MKD 03_BMGS
< 2009-07-01 11:20:09.359 257 Directory created successfully
> 2009-07-01 11:20:09.359 CWD /projects/153_Aigas_Nams/Contract/03_BMGS/
< 2009-07-01 11:20:09.359 250 CWD successful. "/projects/153_Aigas_Nams/Contract/03_BMGS" is current directory.
> 2009-07-01 11:20:09.375 PWD
< 2009-07-01 11:20:09.375 257 "/projects/153_Aigas_Nams/Contract/03_BMGS" is current directory.
> 2009-07-01 11:20:09.375 TYPE A
< 2009-07-01 11:20:09.375 200 Type set to A
> 2009-07-01 11:20:09.375 PORT 192,168,0,109,7,131
< 2009-07-01 11:20:09.375 200 Port command successful
> 2009-07-01 11:20:09.375 LIST -a
< 2009-07-01 11:20:09.390 150 Opening data channel for directory list.
. 2009-07-01 11:20:09.406 SSL connection established
< 2009-07-01 11:20:09.406 226 Transfer OK
> 2009-07-01 11:20:09.406 TYPE A
< 2009-07-01 11:20:09.406 200 Type set to A
> 2009-07-01 11:20:09.406 PORT 192,168,0,109,7,132
< 2009-07-01 11:20:09.421 200 Port command successful
> 2009-07-01 11:20:09.421 STOR GramCheckPhraseLog.txt
< 2009-07-01 11:20:09.468 150 Opening data channel for file transfer.
. 2009-07-01 11:20:09.484 SSL connection established
< 2009-07-01 11:20:09.562 226 Transfer OK
> 2009-07-01 11:20:09.562 MFMT 20080122141459 GramCheckPhraseLog.txt
< 2009-07-01 11:20:09.578 213 modify=20080122141459; /projects/153_Aigas_Nams/Contract/03_BMGS/GramCheckPhraseLog.txt
. 2009-07-01 11:20:09.578 Upload successful
. 2009-07-01 11:20:09.578 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Ligums_1.doc"
. 2009-07-01 11:20:09.578 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Ligums_1.doc" to remote directory started.
. 2009-07-01 11:20:09.578 Binary transfer mode selected.
. 2009-07-01 11:20:09.578 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Ligums_1.doc
> 2009-07-01 11:20:09.578 TYPE I
< 2009-07-01 11:20:09.578 200 Type set to I
> 2009-07-01 11:20:09.578 PORT 192,168,0,109,7,133
< 2009-07-01 11:20:09.578 200 Port command successful
> 2009-07-01 11:20:09.578 STOR Ligums_1.doc
< 2009-07-01 11:20:09.625 150 Opening data channel for file transfer.
. 2009-07-01 11:20:09.625 SSL connection established
< 2009-07-01 11:20:09.687 226 Transfer OK
> 2009-07-01 11:20:09.687 MFMT 20070928072212 Ligums_1.doc
< 2009-07-01 11:20:09.703 213 modify=20070928072212; /projects/153_Aigas_Nams/Contract/03_BMGS/Ligums_1.doc
. 2009-07-01 11:20:09.703 Upload successful
. 2009-07-01 11:20:09.703 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Ligums_Izmainas_1.doc"
. 2009-07-01 11:20:09.703 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Ligums_Izmainas_1.doc" to remote directory started.
. 2009-07-01 11:20:09.703 Binary transfer mode selected.
. 2009-07-01 11:20:09.703 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Ligums_Izmainas_1.doc
> 2009-07-01 11:20:09.703 TYPE I
< 2009-07-01 11:20:09.703 200 Type set to I
> 2009-07-01 11:20:09.718 PORT 192,168,0,109,7,134
< 2009-07-01 11:20:09.718 200 Port command successful
> 2009-07-01 11:20:09.718 STOR Ligums_Izmainas_1.doc
< 2009-07-01 11:20:09.765 150 Opening data channel for file transfer.
. 2009-07-01 11:20:09.765 SSL connection established
< 2009-07-01 11:20:09.828 226 Transfer OK
> 2009-07-01 11:20:09.828 MFMT 20071017101230 Ligums_Izmainas_1.doc
< 2009-07-01 11:20:09.843 213 modify=20071017101230; /projects/153_Aigas_Nams/Contract/03_BMGS/Ligums_Izmainas_1.doc
. 2009-07-01 11:20:09.843 Upload successful
. 2009-07-01 11:20:09.843 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Ligums_Izmainas_2.doc"
. 2009-07-01 11:20:09.843 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Ligums_Izmainas_2.doc" to remote directory started.
. 2009-07-01 11:20:09.843 Binary transfer mode selected.
. 2009-07-01 11:20:09.843 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Ligums_Izmainas_2.doc
> 2009-07-01 11:20:09.843 TYPE I
< 2009-07-01 11:20:09.859 200 Type set to I
> 2009-07-01 11:20:09.859 PORT 192,168,0,109,7,135
< 2009-07-01 11:20:09.859 200 Port command successful
> 2009-07-01 11:20:09.859 STOR Ligums_Izmainas_2.doc
< 2009-07-01 11:20:09.906 150 Opening data channel for file transfer.
. 2009-07-01 11:20:09.921 SSL connection established
< 2009-07-01 11:20:09.984 226 Transfer OK
> 2009-07-01 11:20:09.984 MFMT 20080122100349 Ligums_Izmainas_2.doc
< 2009-07-01 11:20:10.000 213 modify=20080122100349; /projects/153_Aigas_Nams/Contract/03_BMGS/Ligums_Izmainas_2.doc
. 2009-07-01 11:20:10.000 Upload successful
. 2009-07-01 11:20:10.000 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_1_Darbu_grafiks.mpp"
. 2009-07-01 11:20:10.015 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_1_Darbu_grafiks.mpp" to remote directory started.
. 2009-07-01 11:20:10.015 Binary transfer mode selected.
. 2009-07-01 11:20:10.015 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_1_Darbu_grafiks.mpp
> 2009-07-01 11:20:10.015 TYPE I
< 2009-07-01 11:20:10.015 200 Type set to I
> 2009-07-01 11:20:10.031 PORT 192,168,0,109,7,136
< 2009-07-01 11:20:10.031 200 Port command successful
> 2009-07-01 11:20:10.031 STOR Pielikums_1_Darbu_grafiks.mpp
< 2009-07-01 11:20:10.031 150 Opening data channel for file transfer.
. 2009-07-01 11:20:10.046 SSL connection established
< 2009-07-01 11:20:10.109 226 Transfer OK
> 2009-07-01 11:20:10.109 MFMT 20070927140955 Pielikums_1_Darbu_grafiks.mpp
< 2009-07-01 11:20:10.109 213 modify=20070927140955; /projects/153_Aigas_Nams/Contract/03_BMGS/Pielikums_1_Darbu_grafiks.mpp
. 2009-07-01 11:20:10.109 Upload successful
. 2009-07-01 11:20:10.109 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_2_rasejumu_sarakasts.xls"
. 2009-07-01 11:20:10.109 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_2_rasejumu_sarakasts.xls" to remote directory started.
. 2009-07-01 11:20:10.125 Binary transfer mode selected.
. 2009-07-01 11:20:10.125 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_2_rasejumu_sarakasts.xls
> 2009-07-01 11:20:10.125 TYPE I
< 2009-07-01 11:20:10.125 200 Type set to I
> 2009-07-01 11:20:10.125 PORT 192,168,0,109,7,137
< 2009-07-01 11:20:10.125 200 Port command successful
> 2009-07-01 11:20:10.125 STOR Pielikums_2_rasejumu_sarakasts.xls
< 2009-07-01 11:20:10.140 150 Opening data channel for file transfer.
. 2009-07-01 11:20:10.156 SSL connection established
< 2009-07-01 11:20:14.312 226 Transfer OK
> 2009-07-01 11:20:14.312 MFMT 20070927143118 Pielikums_2_rasejumu_sarakasts.xls
< 2009-07-01 11:20:14.312 213 modify=20070927143118; /projects/153_Aigas_Nams/Contract/03_BMGS/Pielikums_2_rasejumu_sarakasts.xls
. 2009-07-01 11:20:14.312 Upload successful
. 2009-07-01 11:20:14.312 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_3_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc"
. 2009-07-01 11:20:14.328 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_3_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc" to remote directory started.
. 2009-07-01 11:20:14.328 Binary transfer mode selected.
. 2009-07-01 11:20:14.328 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_3_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
> 2009-07-01 11:20:14.328 TYPE I
< 2009-07-01 11:20:14.328 200 Type set to I
> 2009-07-01 11:20:14.328 PORT 192,168,0,109,7,138
< 2009-07-01 11:20:14.328 200 Port command successful
> 2009-07-01 11:20:14.328 STOR Pielikums_3_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
< 2009-07-01 11:20:14.406 150 Opening data channel for file transfer.
. 2009-07-01 11:20:14.421 SSL connection established
< 2009-07-01 11:20:14.500 226 Transfer OK
> 2009-07-01 11:20:14.500 MFMT 20070919092919 Pielikums_3_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
< 2009-07-01 11:20:14.515 213 modify=20070919092919; /projects/153_Aigas_Nams/Contract/03_BMGS/Pielikums_3_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
. 2009-07-01 11:20:14.515 Upload successful
. 2009-07-01 11:20:14.515 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_4_Darbu_apjoms.doc"
. 2009-07-01 11:20:14.515 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_4_Darbu_apjoms.doc" to remote directory started.
. 2009-07-01 11:20:14.515 Binary transfer mode selected.
. 2009-07-01 11:20:14.515 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_4_Darbu_apjoms.doc
> 2009-07-01 11:20:14.515 TYPE I
< 2009-07-01 11:20:14.515 200 Type set to I
> 2009-07-01 11:20:14.531 PORT 192,168,0,109,7,139
< 2009-07-01 11:20:14.531 200 Port command successful
> 2009-07-01 11:20:14.531 STOR Pielikums_4_Darbu_apjoms.doc
< 2009-07-01 11:20:14.562 150 Opening data channel for file transfer.
. 2009-07-01 11:20:14.578 SSL connection established
< 2009-07-01 11:20:14.609 226 Transfer OK
> 2009-07-01 11:20:14.609 MFMT 20070927144627 Pielikums_4_Darbu_apjoms.doc
< 2009-07-01 11:20:14.625 213 modify=20070927144627; /projects/153_Aigas_Nams/Contract/03_BMGS/Pielikums_4_Darbu_apjoms.doc
. 2009-07-01 11:20:14.625 Upload successful
. 2009-07-01 11:20:14.625 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc"
. 2009-07-01 11:20:14.625 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc" to remote directory started.
. 2009-07-01 11:20:14.625 Binary transfer mode selected.
. 2009-07-01 11:20:14.625 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc
> 2009-07-01 11:20:14.625 TYPE I
< 2009-07-01 11:20:14.625 200 Type set to I
> 2009-07-01 11:20:14.625 PORT 192,168,0,109,7,140
< 2009-07-01 11:20:14.625 200 Port command successful
> 2009-07-01 11:20:14.625 STOR Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc
< 2009-07-01 11:20:14.671 150 Opening data channel for file transfer.
. 2009-07-01 11:20:14.687 SSL connection established
< 2009-07-01 11:20:14.734 226 Transfer OK
> 2009-07-01 11:20:14.734 MFMT 20070919113321 Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc
< 2009-07-01 11:20:14.734 213 modify=20070919113321; /projects/153_Aigas_Nams/Contract/03_BMGS/Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc
. 2009-07-01 11:20:14.734 Upload successful
. 2009-07-01 11:20:14.734 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_7_Kvalitates_plans.doc"
. 2009-07-01 11:20:14.734 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_7_Kvalitates_plans.doc" to remote directory started.
. 2009-07-01 11:20:14.734 Binary transfer mode selected.
. 2009-07-01 11:20:14.734 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_7_Kvalitates_plans.doc
> 2009-07-01 11:20:14.750 TYPE I
< 2009-07-01 11:20:14.750 200 Type set to I
> 2009-07-01 11:20:14.750 PORT 192,168,0,109,7,141
< 2009-07-01 11:20:14.750 200 Port command successful
> 2009-07-01 11:20:14.750 STOR Pielikums_7_Kvalitates_plans.doc
< 2009-07-01 11:20:14.796 150 Opening data channel for file transfer.
. 2009-07-01 11:20:14.796 SSL connection established
< 2009-07-01 11:20:14.890 226 Transfer OK
> 2009-07-01 11:20:14.890 MFMT 20070924072709 Pielikums_7_Kvalitates_plans.doc
< 2009-07-01 11:20:14.906 213 modify=20070924072709; /projects/153_Aigas_Nams/Contract/03_BMGS/Pielikums_7_Kvalitates_plans.doc
. 2009-07-01 11:20:14.906 Upload successful
. 2009-07-01 11:20:14.906 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_8_Work acceptance forms_13-11-06.xls"
. 2009-07-01 11:20:14.984 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_8_Work acceptance forms_13-11-06.xls" to remote directory started.
. 2009-07-01 11:20:14.984 Binary transfer mode selected.
. 2009-07-01 11:20:14.984 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_8_Work acceptance forms_13-11-06.xls
> 2009-07-01 11:20:14.984 TYPE I
< 2009-07-01 11:20:14.984 200 Type set to I
> 2009-07-01 11:20:14.984 PORT 192,168,0,109,7,142
< 2009-07-01 11:20:14.984 200 Port command successful
> 2009-07-01 11:20:14.984 STOR Pielikums_8_Work acceptance forms_13-11-06.xls
< 2009-07-01 11:20:15.000 150 Opening data channel for file transfer.
. 2009-07-01 11:20:15.015 SSL connection established
< 2009-07-01 11:20:15.046 226 Transfer OK
> 2009-07-01 11:20:15.046 MFMT 20070924071418 Pielikums_8_Work acceptance forms_13-11-06.xls
< 2009-07-01 11:20:15.062 213 modify=20070924071418; /projects/153_Aigas_Nams/Contract/03_BMGS/Pielikums_8_Work acceptance forms_13-11-06.xls
. 2009-07-01 11:20:15.062 Upload successful
. 2009-07-01 11:20:15.062 File: "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_9_Work final acceptance form 26-10-05.DOC"
. 2009-07-01 11:20:15.062 Copying "c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_9_Work final acceptance form 26-10-05.DOC" to remote directory started.
. 2009-07-01 11:20:15.062 Binary transfer mode selected.
. 2009-07-01 11:20:15.062 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\03_BMGS\Pielikums_9_Work final acceptance form 26-10-05.DOC
> 2009-07-01 11:20:15.062 TYPE I
< 2009-07-01 11:20:15.062 200 Type set to I
> 2009-07-01 11:20:15.062 PORT 192,168,0,109,7,143
< 2009-07-01 11:20:15.062 200 Port command successful
> 2009-07-01 11:20:15.062 STOR Pielikums_9_Work final acceptance form 26-10-05.DOC
< 2009-07-01 11:20:15.109 150 Opening data channel for file transfer.
. 2009-07-01 11:20:15.125 SSL connection established
< 2009-07-01 11:20:15.203 226 Transfer OK
> 2009-07-01 11:20:15.203 MFMT 20070924071501 Pielikums_9_Work final acceptance form 26-10-05.DOC
< 2009-07-01 11:20:15.203 213 modify=20070924071501; /projects/153_Aigas_Nams/Contract/03_BMGS/Pielikums_9_Work final acceptance form 26-10-05.DOC
. 2009-07-01 11:20:15.203 Upload successful
. 2009-07-01 11:20:15.203 File: "c:\work\projects\153_Aigas_Nams\Contract\04_IMFOMETS"
. 2009-07-01 11:20:15.234 File: "c:\work\projects\153_Aigas_Nams\Contract\04_IMFOMETS\Ligums.doc"
. 2009-07-01 11:20:15.234 Copying "c:\work\projects\153_Aigas_Nams\Contract\04_IMFOMETS\Ligums.doc" to remote directory started.
. 2009-07-01 11:20:15.234 Binary transfer mode selected.
. 2009-07-01 11:20:15.234 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\04_IMFOMETS\Ligums.doc
> 2009-07-01 11:20:15.234 CWD /projects/153_Aigas_Nams/Contract/04_IMFOMETS/
< 2009-07-01 11:20:15.234 550 CWD failed. "/projects/153_Aigas_Nams/Contract/04_IMFOMETS": directory not found.
< 2009-07-01 11:20:15.250 250 CWD successful. "/projects/153_Aigas_Nams/Contract" is current directory.
> 2009-07-01 11:20:15.250 MKD 04_IMFOMETS
< 2009-07-01 11:20:15.265 257 Directory created successfully
> 2009-07-01 11:20:15.265 CWD /projects/153_Aigas_Nams/Contract/04_IMFOMETS/
< 2009-07-01 11:20:15.265 250 CWD successful. "/projects/153_Aigas_Nams/Contract/04_IMFOMETS" is current directory.
> 2009-07-01 11:20:15.265 PWD
< 2009-07-01 11:20:15.265 257 "/projects/153_Aigas_Nams/Contract/04_IMFOMETS" is current directory.
> 2009-07-01 11:20:15.265 TYPE A
< 2009-07-01 11:20:15.265 200 Type set to A
> 2009-07-01 11:20:15.265 PORT 192,168,0,109,7,144
< 2009-07-01 11:20:15.265 200 Port command successful
> 2009-07-01 11:20:15.265 LIST -a
< 2009-07-01 11:20:15.281 150 Opening data channel for directory list.
. 2009-07-01 11:20:15.296 SSL connection established
< 2009-07-01 11:20:15.296 226 Transfer OK
> 2009-07-01 11:20:15.296 TYPE I
< 2009-07-01 11:20:15.296 200 Type set to I
> 2009-07-01 11:20:15.296 PORT 192,168,0,109,7,145
< 2009-07-01 11:20:15.312 200 Port command successful
> 2009-07-01 11:20:15.312 STOR Ligums.doc
< 2009-07-01 11:20:15.343 150 Opening data channel for file transfer.
. 2009-07-01 11:20:15.359 SSL connection established
< 2009-07-01 11:20:15.421 226 Transfer OK
> 2009-07-01 11:20:15.421 MFMT 20070927052114 Ligums.doc
< 2009-07-01 11:20:15.437 213 modify=20070927052114; /projects/153_Aigas_Nams/Contract/04_IMFOMETS/Ligums.doc
. 2009-07-01 11:20:15.437 Upload successful
. 2009-07-01 11:20:15.437 File: "c:\work\projects\153_Aigas_Nams\Contract\04_IMFOMETS\Tame.xls"
. 2009-07-01 11:20:15.437 Copying "c:\work\projects\153_Aigas_Nams\Contract\04_IMFOMETS\Tame.xls" to remote directory started.
. 2009-07-01 11:20:15.437 Binary transfer mode selected.
. 2009-07-01 11:20:15.437 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\04_IMFOMETS\Tame.xls
> 2009-07-01 11:20:15.437 TYPE I
< 2009-07-01 11:20:15.437 200 Type set to I
> 2009-07-01 11:20:15.437 PORT 192,168,0,109,7,146
< 2009-07-01 11:20:15.437 200 Port command successful
> 2009-07-01 11:20:15.437 STOR Tame.xls
< 2009-07-01 11:20:15.500 150 Opening data channel for file transfer.
. 2009-07-01 11:20:15.500 SSL connection established
< 2009-07-01 11:20:15.531 226 Transfer OK
> 2009-07-01 11:20:15.531 MFMT 20080404081213 Tame.xls
< 2009-07-01 11:20:15.546 213 modify=20080404081213; /projects/153_Aigas_Nams/Contract/04_IMFOMETS/Tame.xls
. 2009-07-01 11:20:15.546 Upload successful
. 2009-07-01 11:20:15.546 File: "c:\work\projects\153_Aigas_Nams\Contract\05_TMB_ELEMENTS"
. 2009-07-01 11:20:15.562 File: "c:\work\projects\153_Aigas_Nams\Contract\05_TMB_ELEMENTS\Ligums.doc"
. 2009-07-01 11:20:15.562 Copying "c:\work\projects\153_Aigas_Nams\Contract\05_TMB_ELEMENTS\Ligums.doc" to remote directory started.
. 2009-07-01 11:20:15.562 Binary transfer mode selected.
. 2009-07-01 11:20:15.562 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\05_TMB_ELEMENTS\Ligums.doc
> 2009-07-01 11:20:15.562 CWD /projects/153_Aigas_Nams/Contract/05_TMB_ELEMENTS/
< 2009-07-01 11:20:15.562 550 CWD failed. "/projects/153_Aigas_Nams/Contract/05_TMB_ELEMENTS": directory not found.
< 2009-07-01 11:20:15.578 250 CWD successful. "/projects/153_Aigas_Nams/Contract" is current directory.
> 2009-07-01 11:20:15.578 MKD 05_TMB_ELEMENTS
< 2009-07-01 11:20:15.593 257 Directory created successfully
> 2009-07-01 11:20:15.593 CWD /projects/153_Aigas_Nams/Contract/05_TMB_ELEMENTS/
< 2009-07-01 11:20:15.593 250 CWD successful. "/projects/153_Aigas_Nams/Contract/05_TMB_ELEMENTS" is current directory.
> 2009-07-01 11:20:15.593 PWD
< 2009-07-01 11:20:15.593 257 "/projects/153_Aigas_Nams/Contract/05_TMB_ELEMENTS" is current directory.
> 2009-07-01 11:20:15.593 TYPE A
< 2009-07-01 11:20:15.593 200 Type set to A
> 2009-07-01 11:20:15.593 PORT 192,168,0,109,7,147
< 2009-07-01 11:20:15.593 200 Port command successful
> 2009-07-01 11:20:15.593 LIST -a
< 2009-07-01 11:20:15.609 150 Opening data channel for directory list.
. 2009-07-01 11:20:15.625 SSL connection established
< 2009-07-01 11:20:15.625 226 Transfer OK
> 2009-07-01 11:20:15.625 TYPE I
< 2009-07-01 11:20:15.625 200 Type set to I
> 2009-07-01 11:20:15.640 PORT 192,168,0,109,7,148
< 2009-07-01 11:20:15.640 200 Port command successful
> 2009-07-01 11:20:15.640 STOR Ligums.doc
< 2009-07-01 11:20:15.671 150 Opening data channel for file transfer.
. 2009-07-01 11:20:15.671 SSL connection established
< 2009-07-01 11:20:15.765 226 Transfer OK
> 2009-07-01 11:20:15.765 MFMT 20071003124447 Ligums.doc
< 2009-07-01 11:20:15.765 213 modify=20071003124447; /projects/153_Aigas_Nams/Contract/05_TMB_ELEMENTS/Ligums.doc
. 2009-07-01 11:20:15.765 Upload successful
. 2009-07-01 11:20:15.765 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS"
. 2009-07-01 11:20:15.812 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Betonēanas darbu apraksts.doc"
. 2009-07-01 11:20:15.812 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Betonēanas darbu apraksts.doc" to remote directory started.
. 2009-07-01 11:20:15.812 Binary transfer mode selected.
. 2009-07-01 11:20:15.812 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Betonēanas darbu apraksts.doc
> 2009-07-01 11:20:15.812 CWD /projects/153_Aigas_Nams/Contract/06_ABTONS/
< 2009-07-01 11:20:15.812 550 CWD failed. "/projects/153_Aigas_Nams/Contract/06_ABTONS": directory not found.
< 2009-07-01 11:20:15.828 250 CWD successful. "/projects/153_Aigas_Nams/Contract" is current directory.
> 2009-07-01 11:20:15.828 MKD 06_ABTONS
< 2009-07-01 11:20:15.828 257 Directory created successfully
> 2009-07-01 11:20:15.828 CWD /projects/153_Aigas_Nams/Contract/06_ABTONS/
< 2009-07-01 11:20:15.843 250 CWD successful. "/projects/153_Aigas_Nams/Contract/06_ABTONS" is current directory.
> 2009-07-01 11:20:15.843 PWD
< 2009-07-01 11:20:15.843 257 "/projects/153_Aigas_Nams/Contract/06_ABTONS" is current directory.
> 2009-07-01 11:20:15.843 TYPE A
< 2009-07-01 11:20:15.843 200 Type set to A
> 2009-07-01 11:20:15.843 PORT 192,168,0,109,7,149
< 2009-07-01 11:20:15.843 200 Port command successful
> 2009-07-01 11:20:15.843 LIST -a
< 2009-07-01 11:20:15.859 150 Opening data channel for directory list.
. 2009-07-01 11:20:15.875 SSL connection established
< 2009-07-01 11:20:15.875 226 Transfer OK
> 2009-07-01 11:20:15.875 TYPE I
< 2009-07-01 11:20:15.875 200 Type set to I
> 2009-07-01 11:20:15.875 PORT 192,168,0,109,7,150
< 2009-07-01 11:20:15.890 200 Port command successful
> 2009-07-01 11:20:15.890 STOR Betonēanas darbu apraksts.doc
< 2009-07-01 11:20:15.906 150 Opening data channel for file transfer.
. 2009-07-01 11:20:15.921 SSL connection established
< 2009-07-01 11:20:15.953 226 Transfer OK
> 2009-07-01 11:20:15.953 MFMT 20080116113839 Betonēanas darbu apraksts.doc
< 2009-07-01 11:20:15.968 213 modify=20080116113839; /projects/153_Aigas_Nams/Contract/06_ABTONS/Betonēanas darbu apraksts.doc
. 2009-07-01 11:20:15.968 Upload successful
. 2009-07-01 11:20:15.968 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums.doc"
. 2009-07-01 11:20:15.968 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums.doc" to remote directory started.
. 2009-07-01 11:20:15.968 Binary transfer mode selected.
. 2009-07-01 11:20:15.968 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums.doc
> 2009-07-01 11:20:15.968 TYPE I
< 2009-07-01 11:20:15.968 200 Type set to I
> 2009-07-01 11:20:15.968 PORT 192,168,0,109,7,151
< 2009-07-01 11:20:15.968 200 Port command successful
> 2009-07-01 11:20:15.968 STOR Ligums.doc
< 2009-07-01 11:20:16.015 150 Opening data channel for file transfer.
. 2009-07-01 11:20:16.015 SSL connection established
< 2009-07-01 11:20:16.125 226 Transfer OK
> 2009-07-01 11:20:16.125 MFMT 20071218085440 Ligums.doc
< 2009-07-01 11:20:16.140 213 modify=20071218085440; /projects/153_Aigas_Nams/Contract/06_ABTONS/Ligums.doc
. 2009-07-01 11:20:16.140 Upload successful
. 2009-07-01 11:20:16.140 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums_Izmainas_1.doc"
. 2009-07-01 11:20:16.140 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums_Izmainas_1.doc" to remote directory started.
. 2009-07-01 11:20:16.140 Binary transfer mode selected.
. 2009-07-01 11:20:16.140 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums_Izmainas_1.doc
> 2009-07-01 11:20:16.140 TYPE I
< 2009-07-01 11:20:16.140 200 Type set to I
> 2009-07-01 11:20:16.140 PORT 192,168,0,109,7,152
< 2009-07-01 11:20:16.140 200 Port command successful
> 2009-07-01 11:20:16.140 STOR Ligums_Izmainas_1.doc
< 2009-07-01 11:20:16.218 150 Opening data channel for file transfer.
. 2009-07-01 11:20:16.234 SSL connection established
< 2009-07-01 11:20:16.390 226 Transfer OK
> 2009-07-01 11:20:16.390 MFMT 20080605121902 Ligums_Izmainas_1.doc
< 2009-07-01 11:20:16.406 213 modify=20080605121902; /projects/153_Aigas_Nams/Contract/06_ABTONS/Ligums_Izmainas_1.doc
. 2009-07-01 11:20:16.406 Upload successful
. 2009-07-01 11:20:16.406 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums_Izmainas_2.doc"
. 2009-07-01 11:20:16.406 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums_Izmainas_2.doc" to remote directory started.
. 2009-07-01 11:20:16.406 Binary transfer mode selected.
. 2009-07-01 11:20:16.406 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums_Izmainas_2.doc
> 2009-07-01 11:20:16.406 TYPE I
< 2009-07-01 11:20:16.406 200 Type set to I
> 2009-07-01 11:20:16.406 PORT 192,168,0,109,7,153
< 2009-07-01 11:20:16.421 200 Port command successful
> 2009-07-01 11:20:16.421 STOR Ligums_Izmainas_2.doc
< 2009-07-01 11:20:16.437 150 Opening data channel for file transfer.
. 2009-07-01 11:20:16.484 SSL connection established
< 2009-07-01 11:20:16.562 226 Transfer OK
> 2009-07-01 11:20:16.562 MFMT 20080910094952 Ligums_Izmainas_2.doc
< 2009-07-01 11:20:16.562 213 modify=20080910094952; /projects/153_Aigas_Nams/Contract/06_ABTONS/Ligums_Izmainas_2.doc
. 2009-07-01 11:20:16.562 Upload successful
. 2009-07-01 11:20:16.562 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums_Izmainas_3.doc"
. 2009-07-01 11:20:16.687 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums_Izmainas_3.doc" to remote directory started.
. 2009-07-01 11:20:16.687 Binary transfer mode selected.
. 2009-07-01 11:20:16.687 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Ligums_Izmainas_3.doc
> 2009-07-01 11:20:16.687 TYPE I
< 2009-07-01 11:20:16.687 200 Type set to I
> 2009-07-01 11:20:16.687 PORT 192,168,0,109,7,154
< 2009-07-01 11:20:16.703 200 Port command successful
> 2009-07-01 11:20:16.703 STOR Ligums_Izmainas_3.doc
< 2009-07-01 11:20:16.703 150 Opening data channel for file transfer.
. 2009-07-01 11:20:16.718 SSL connection established
< 2009-07-01 11:20:16.750 226 Transfer OK
> 2009-07-01 11:20:16.750 MFMT 20080917063815 Ligums_Izmainas_3.doc
< 2009-07-01 11:20:16.765 213 modify=20080917063815; /projects/153_Aigas_Nams/Contract/06_ABTONS/Ligums_Izmainas_3.doc
. 2009-07-01 11:20:16.765 Upload successful
. 2009-07-01 11:20:16.765 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_1_Darbu_grafiks.mpp"
. 2009-07-01 11:20:16.765 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_1_Darbu_grafiks.mpp" to remote directory started.
. 2009-07-01 11:20:16.765 Binary transfer mode selected.
. 2009-07-01 11:20:16.765 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_1_Darbu_grafiks.mpp
> 2009-07-01 11:20:16.765 TYPE I
< 2009-07-01 11:20:16.765 200 Type set to I
> 2009-07-01 11:20:16.765 PORT 192,168,0,109,7,155
< 2009-07-01 11:20:16.765 200 Port command successful
> 2009-07-01 11:20:16.765 STOR Pielikums_1_Darbu_grafiks.mpp
< 2009-07-01 11:20:16.796 150 Opening data channel for file transfer.
. 2009-07-01 11:20:16.812 SSL connection established
< 2009-07-01 11:20:16.890 226 Transfer OK
> 2009-07-01 11:20:16.890 MFMT 20071112103026 Pielikums_1_Darbu_grafiks.mpp
< 2009-07-01 11:20:16.906 213 modify=20071112103026; /projects/153_Aigas_Nams/Contract/06_ABTONS/Pielikums_1_Darbu_grafiks.mpp
. 2009-07-01 11:20:16.906 Upload successful
. 2009-07-01 11:20:16.906 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_2_rasejumu_sarakasts.xls"
. 2009-07-01 11:20:16.906 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_2_rasejumu_sarakasts.xls" to remote directory started.
. 2009-07-01 11:20:16.906 Binary transfer mode selected.
. 2009-07-01 11:20:16.906 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_2_rasejumu_sarakasts.xls
> 2009-07-01 11:20:16.906 TYPE I
< 2009-07-01 11:20:16.906 200 Type set to I
> 2009-07-01 11:20:16.906 PORT 192,168,0,109,7,156
< 2009-07-01 11:20:16.906 200 Port command successful
> 2009-07-01 11:20:16.906 STOR Pielikums_2_rasejumu_sarakasts.xls
< 2009-07-01 11:20:16.937 150 Opening data channel for file transfer.
. 2009-07-01 11:20:16.937 SSL connection established
< 2009-07-01 11:20:21.078 226 Transfer OK
> 2009-07-01 11:20:21.078 MFMT 20071012110901 Pielikums_2_rasejumu_sarakasts.xls
< 2009-07-01 11:20:21.078 213 modify=20071012110901; /projects/153_Aigas_Nams/Contract/06_ABTONS/Pielikums_2_rasejumu_sarakasts.xls
. 2009-07-01 11:20:21.078 Upload successful
. 2009-07-01 11:20:21.078 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_3_Kvalitates_plans.doc"
. 2009-07-01 11:20:21.078 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_3_Kvalitates_plans.doc" to remote directory started.
. 2009-07-01 11:20:21.093 Binary transfer mode selected.
. 2009-07-01 11:20:21.093 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_3_Kvalitates_plans.doc
> 2009-07-01 11:20:21.093 TYPE I
< 2009-07-01 11:20:21.093 200 Type set to I
> 2009-07-01 11:20:21.093 PORT 192,168,0,109,7,157
< 2009-07-01 11:20:21.093 200 Port command successful
> 2009-07-01 11:20:21.093 STOR Pielikums_3_Kvalitates_plans.doc
< 2009-07-01 11:20:21.171 150 Opening data channel for file transfer.
. 2009-07-01 11:20:21.171 SSL connection established
< 2009-07-01 11:20:21.390 226 Transfer OK
> 2009-07-01 11:20:21.390 MFMT 20071012110724 Pielikums_3_Kvalitates_plans.doc
< 2009-07-01 11:20:21.390 213 modify=20071012110724; /projects/153_Aigas_Nams/Contract/06_ABTONS/Pielikums_3_Kvalitates_plans.doc
. 2009-07-01 11:20:21.390 Upload successful
. 2009-07-01 11:20:21.390 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_4_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc"
. 2009-07-01 11:20:21.390 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_4_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc" to remote directory started.
. 2009-07-01 11:20:21.406 Binary transfer mode selected.
. 2009-07-01 11:20:21.406 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_4_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
> 2009-07-01 11:20:21.406 TYPE I
< 2009-07-01 11:20:21.406 200 Type set to I
> 2009-07-01 11:20:21.406 PORT 192,168,0,109,7,158
< 2009-07-01 11:20:21.406 200 Port command successful
> 2009-07-01 11:20:21.406 STOR Pielikums_4_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
< 2009-07-01 11:20:21.453 150 Opening data channel for file transfer.
. 2009-07-01 11:20:21.468 SSL connection established
< 2009-07-01 11:20:21.515 226 Transfer OK
> 2009-07-01 11:20:21.515 MFMT 20071012110423 Pielikums_4_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
< 2009-07-01 11:20:21.531 213 modify=20071012110423; /projects/153_Aigas_Nams/Contract/06_ABTONS/Pielikums_4_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
. 2009-07-01 11:20:21.531 Upload successful
. 2009-07-01 11:20:21.531 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc"
. 2009-07-01 11:20:21.531 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc" to remote directory started.
. 2009-07-01 11:20:21.531 Binary transfer mode selected.
. 2009-07-01 11:20:21.531 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc
> 2009-07-01 11:20:21.531 TYPE I
< 2009-07-01 11:20:21.531 200 Type set to I
> 2009-07-01 11:20:21.546 PORT 192,168,0,109,7,159
< 2009-07-01 11:20:21.546 200 Port command successful
> 2009-07-01 11:20:21.546 STOR Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc
< 2009-07-01 11:20:21.593 150 Opening data channel for file transfer.
. 2009-07-01 11:20:21.609 SSL connection established
< 2009-07-01 11:20:21.640 226 Transfer OK
> 2009-07-01 11:20:21.640 MFMT 20071019062524 Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc
< 2009-07-01 11:20:21.640 213 modify=20071019062524; /projects/153_Aigas_Nams/Contract/06_ABTONS/Pielikums_5_Cenas_piedavajuma_pieprasijums_V-01.doc
. 2009-07-01 11:20:21.640 Upload successful
. 2009-07-01 11:20:21.640 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_6_Tame_1.xls"
. 2009-07-01 11:20:21.671 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_6_Tame_1.xls" to remote directory started.
. 2009-07-01 11:20:21.671 Binary transfer mode selected.
. 2009-07-01 11:20:21.671 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_6_Tame_1.xls
> 2009-07-01 11:20:21.671 TYPE I
< 2009-07-01 11:20:21.671 200 Type set to I
> 2009-07-01 11:20:21.687 PORT 192,168,0,109,7,160
< 2009-07-01 11:20:21.687 200 Port command successful
> 2009-07-01 11:20:21.687 STOR Pielikums_6_Tame_1.xls
< 2009-07-01 11:20:21.703 150 Opening data channel for file transfer.
. 2009-07-01 11:20:21.703 SSL connection established
< 2009-07-01 11:20:21.828 226 Transfer OK
> 2009-07-01 11:20:21.828 MFMT 20071105123600 Pielikums_6_Tame_1.xls
< 2009-07-01 11:20:21.828 213 modify=20071105123600; /projects/153_Aigas_Nams/Contract/06_ABTONS/Pielikums_6_Tame_1.xls
. 2009-07-01 11:20:21.828 Upload successful
. 2009-07-01 11:20:21.828 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_7_Work acceptance forms_13-11-06.xls"
. 2009-07-01 11:20:21.828 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_7_Work acceptance forms_13-11-06.xls" to remote directory started.
. 2009-07-01 11:20:21.843 Binary transfer mode selected.
. 2009-07-01 11:20:21.843 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_7_Work acceptance forms_13-11-06.xls
> 2009-07-01 11:20:21.843 TYPE I
< 2009-07-01 11:20:21.843 200 Type set to I
> 2009-07-01 11:20:21.843 PORT 192,168,0,109,7,161
< 2009-07-01 11:20:21.843 200 Port command successful
> 2009-07-01 11:20:21.843 STOR Pielikums_7_Work acceptance forms_13-11-06.xls
< 2009-07-01 11:20:21.906 150 Opening data channel for file transfer.
. 2009-07-01 11:20:21.921 SSL connection established
< 2009-07-01 11:20:21.953 226 Transfer OK
> 2009-07-01 11:20:21.953 MFMT 20071010104632 Pielikums_7_Work acceptance forms_13-11-06.xls
< 2009-07-01 11:20:21.953 213 modify=20071010104632; /projects/153_Aigas_Nams/Contract/06_ABTONS/Pielikums_7_Work acceptance forms_13-11-06.xls
. 2009-07-01 11:20:21.953 Upload successful
. 2009-07-01 11:20:21.953 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_8_Rekina_forma.xls"
. 2009-07-01 11:20:21.953 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_8_Rekina_forma.xls" to remote directory started.
. 2009-07-01 11:20:21.953 Binary transfer mode selected.
. 2009-07-01 11:20:21.953 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_8_Rekina_forma.xls
> 2009-07-01 11:20:21.953 TYPE I
< 2009-07-01 11:20:21.968 200 Type set to I
> 2009-07-01 11:20:21.968 PORT 192,168,0,109,7,162
< 2009-07-01 11:20:21.968 200 Port command successful
> 2009-07-01 11:20:21.968 STOR Pielikums_8_Rekina_forma.xls
< 2009-07-01 11:20:22.000 150 Opening data channel for file transfer.
. 2009-07-01 11:20:22.015 SSL connection established
< 2009-07-01 11:20:22.031 226 Transfer OK
> 2009-07-01 11:20:22.031 MFMT 20070828112122 Pielikums_8_Rekina_forma.xls
< 2009-07-01 11:20:22.031 213 modify=20070828112122; /projects/153_Aigas_Nams/Contract/06_ABTONS/Pielikums_8_Rekina_forma.xls
. 2009-07-01 11:20:22.031 Upload successful
. 2009-07-01 11:20:22.031 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_9_Work final acceptance form 26-10-05.DOC"
. 2009-07-01 11:20:22.031 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_9_Work final acceptance form 26-10-05.DOC" to remote directory started.
. 2009-07-01 11:20:22.031 Binary transfer mode selected.
. 2009-07-01 11:20:22.046 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\Pielikums_9_Work final acceptance form 26-10-05.DOC
> 2009-07-01 11:20:22.046 TYPE I
< 2009-07-01 11:20:22.046 200 Type set to I
> 2009-07-01 11:20:22.046 PORT 192,168,0,109,7,163
< 2009-07-01 11:20:22.046 200 Port command successful
> 2009-07-01 11:20:22.046 STOR Pielikums_9_Work final acceptance form 26-10-05.DOC
< 2009-07-01 11:20:22.078 150 Opening data channel for file transfer.
. 2009-07-01 11:20:22.078 SSL connection established
< 2009-07-01 11:20:22.140 226 Transfer OK
> 2009-07-01 11:20:22.140 MFMT 20071112103321 Pielikums_9_Work final acceptance form 26-10-05.DOC
< 2009-07-01 11:20:22.140 213 modify=20071112103321; /projects/153_Aigas_Nams/Contract/06_ABTONS/Pielikums_9_Work final acceptance form 26-10-05.DOC
. 2009-07-01 11:20:22.140 Upload successful
. 2009-07-01 11:20:22.140 File: "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\PN akts AN 2.DOC"
. 2009-07-01 11:20:22.140 Copying "c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\PN akts AN 2.DOC" to remote directory started.
. 2009-07-01 11:20:22.140 Binary transfer mode selected.
. 2009-07-01 11:20:22.140 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\06_ABTONS\PN akts AN 2.DOC
> 2009-07-01 11:20:22.140 TYPE I
< 2009-07-01 11:20:22.140 200 Type set to I
> 2009-07-01 11:20:22.156 PORT 192,168,0,109,7,164
< 2009-07-01 11:20:22.156 200 Port command successful
> 2009-07-01 11:20:22.156 STOR PN akts AN 2.DOC
< 2009-07-01 11:20:22.187 150 Opening data channel for file transfer.
. 2009-07-01 11:20:22.203 SSL connection established
< 2009-07-01 11:20:22.234 226 Transfer OK
> 2009-07-01 11:20:22.234 MFMT 20081223080440 PN akts AN 2.DOC
< 2009-07-01 11:20:22.250 213 modify=20081223080440; /projects/153_Aigas_Nams/Contract/06_ABTONS/PN akts AN 2.DOC
. 2009-07-01 11:20:22.250 Upload successful
. 2009-07-01 11:20:22.250 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN"
. 2009-07-01 11:20:22.265 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Izmainas_1.doc"
. 2009-07-01 11:20:22.281 Copying "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Izmainas_1.doc" to remote directory started.
. 2009-07-01 11:20:22.281 Binary transfer mode selected.
. 2009-07-01 11:20:22.281 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Izmainas_1.doc
> 2009-07-01 11:20:22.281 CWD /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/
< 2009-07-01 11:20:22.281 550 CWD failed. "/projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN": directory not found.
< 2009-07-01 11:20:22.281 250 CWD successful. "/projects/153_Aigas_Nams/Contract" is current directory.
> 2009-07-01 11:20:22.281 MKD 07_BALTLAINS_INTERN
< 2009-07-01 11:20:22.296 257 Directory created successfully
> 2009-07-01 11:20:22.296 CWD /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/
< 2009-07-01 11:20:22.312 250 CWD successful. "/projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN" is current directory.
> 2009-07-01 11:20:22.312 PWD
< 2009-07-01 11:20:22.312 257 "/projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN" is current directory.
> 2009-07-01 11:20:22.312 TYPE A
< 2009-07-01 11:20:22.312 200 Type set to A
> 2009-07-01 11:20:22.312 PORT 192,168,0,109,7,165
< 2009-07-01 11:20:22.312 200 Port command successful
> 2009-07-01 11:20:22.312 LIST -a
< 2009-07-01 11:20:22.328 150 Opening data channel for directory list.
. 2009-07-01 11:20:22.343 SSL connection established
< 2009-07-01 11:20:22.343 226 Transfer OK
> 2009-07-01 11:20:22.343 TYPE I
< 2009-07-01 11:20:22.343 200 Type set to I
> 2009-07-01 11:20:22.343 PORT 192,168,0,109,7,166
< 2009-07-01 11:20:22.343 200 Port command successful
> 2009-07-01 11:20:22.343 STOR Izmainas_1.doc
< 2009-07-01 11:20:22.390 150 Opening data channel for file transfer.
. 2009-07-01 11:20:22.390 SSL connection established
< 2009-07-01 11:20:22.468 226 Transfer OK
> 2009-07-01 11:20:22.468 MFMT 20080303102741 Izmainas_1.doc
< 2009-07-01 11:20:22.484 213 modify=20080303102741; /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/Izmainas_1.doc
. 2009-07-01 11:20:22.484 Upload successful
. 2009-07-01 11:20:22.484 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Izmainas_2.doc"
. 2009-07-01 11:20:22.500 Copying "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Izmainas_2.doc" to remote directory started.
. 2009-07-01 11:20:22.500 Binary transfer mode selected.
. 2009-07-01 11:20:22.500 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Izmainas_2.doc
> 2009-07-01 11:20:22.500 TYPE I
< 2009-07-01 11:20:22.500 200 Type set to I
> 2009-07-01 11:20:22.500 PORT 192,168,0,109,7,167
< 2009-07-01 11:20:22.500 200 Port command successful
> 2009-07-01 11:20:22.500 STOR Izmainas_2.doc
< 2009-07-01 11:20:22.562 150 Opening data channel for file transfer.
. 2009-07-01 11:20:22.578 SSL connection established
< 2009-07-01 11:20:22.671 226 Transfer OK
> 2009-07-01 11:20:22.671 MFMT 20080526084011 Izmainas_2.doc
< 2009-07-01 11:20:22.671 213 modify=20080526084011; /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/Izmainas_2.doc
. 2009-07-01 11:20:22.671 Upload successful
. 2009-07-01 11:20:22.671 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Ligums.doc"
. 2009-07-01 11:20:22.671 Copying "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Ligums.doc" to remote directory started.
. 2009-07-01 11:20:22.671 Binary transfer mode selected.
. 2009-07-01 11:20:22.671 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Ligums.doc
> 2009-07-01 11:20:22.671 TYPE I
< 2009-07-01 11:20:22.671 200 Type set to I
> 2009-07-01 11:20:22.687 PORT 192,168,0,109,7,168
< 2009-07-01 11:20:22.687 200 Port command successful
> 2009-07-01 11:20:22.687 STOR Ligums.doc
< 2009-07-01 11:20:22.703 150 Opening data channel for file transfer.
. 2009-07-01 11:20:22.718 SSL connection established
< 2009-07-01 11:20:22.796 226 Transfer OK
> 2009-07-01 11:20:22.796 MFMT 20071015114247 Ligums.doc
< 2009-07-01 11:20:22.812 213 modify=20071015114247; /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/Ligums.doc
. 2009-07-01 11:20:22.812 Upload successful
. 2009-07-01 11:20:22.812 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Piedāvājums Merks1 .doc"
. 2009-07-01 11:20:22.812 Copying "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Piedāvājums Merks1 .doc" to remote directory started.
. 2009-07-01 11:20:22.812 Binary transfer mode selected.
. 2009-07-01 11:20:22.812 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Piedāvājums Merks1 .doc
> 2009-07-01 11:20:22.812 TYPE I
< 2009-07-01 11:20:22.812 200 Type set to I
> 2009-07-01 11:20:22.812 PORT 192,168,0,109,7,169
< 2009-07-01 11:20:22.812 200 Port command successful
> 2009-07-01 11:20:22.812 STOR Piedāvājums Merks1 .doc
< 2009-07-01 11:20:22.875 150 Opening data channel for file transfer.
. 2009-07-01 11:20:22.890 SSL connection established
< 2009-07-01 11:20:22.937 226 Transfer OK
> 2009-07-01 11:20:22.937 MFMT 20080414055319 Piedāvājums Merks1 .doc
< 2009-07-01 11:20:22.953 213 modify=20080414055319; /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/Piedāvājums Merks1 .doc
. 2009-07-01 11:20:22.953 Upload successful
. 2009-07-01 11:20:22.953 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_1_Darbu_grafiks.mpp"
. 2009-07-01 11:20:22.953 Copying "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_1_Darbu_grafiks.mpp" to remote directory started.
. 2009-07-01 11:20:22.953 Binary transfer mode selected.
. 2009-07-01 11:20:22.953 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_1_Darbu_grafiks.mpp
> 2009-07-01 11:20:22.953 TYPE I
< 2009-07-01 11:20:22.953 200 Type set to I
> 2009-07-01 11:20:22.953 PORT 192,168,0,109,7,170
< 2009-07-01 11:20:22.968 200 Port command successful
> 2009-07-01 11:20:22.968 STOR Pielikums_1_Darbu_grafiks.mpp
< 2009-07-01 11:20:22.984 150 Opening data channel for file transfer.
. 2009-07-01 11:20:23.000 SSL connection established
< 2009-07-01 11:20:23.125 226 Transfer OK
> 2009-07-01 11:20:23.125 MFMT 20071012065705 Pielikums_1_Darbu_grafiks.mpp
< 2009-07-01 11:20:23.125 213 modify=20071012065705; /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/Pielikums_1_Darbu_grafiks.mpp
. 2009-07-01 11:20:23.125 Upload successful
. 2009-07-01 11:20:23.125 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_2_rasejumu_sarakasts.xls"
. 2009-07-01 11:20:23.140 Copying "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_2_rasejumu_sarakasts.xls" to remote directory started.
. 2009-07-01 11:20:23.140 Binary transfer mode selected.
. 2009-07-01 11:20:23.140 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_2_rasejumu_sarakasts.xls
> 2009-07-01 11:20:23.140 TYPE I
< 2009-07-01 11:20:23.140 200 Type set to I
> 2009-07-01 11:20:23.140 PORT 192,168,0,109,7,171
< 2009-07-01 11:20:23.140 200 Port command successful
> 2009-07-01 11:20:23.140 STOR Pielikums_2_rasejumu_sarakasts.xls
< 2009-07-01 11:20:23.171 150 Opening data channel for file transfer.
. 2009-07-01 11:20:23.187 SSL connection established
< 2009-07-01 11:20:23.562 226 Transfer OK
> 2009-07-01 11:20:23.562 MFMT 20071010105621 Pielikums_2_rasejumu_sarakasts.xls
< 2009-07-01 11:20:23.562 213 modify=20071010105621; /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/Pielikums_2_rasejumu_sarakasts.xls
. 2009-07-01 11:20:23.562 Upload successful
. 2009-07-01 11:20:23.562 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_2_rasejumu_sarakasts_1.xls"
. 2009-07-01 11:20:23.562 Copying "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_2_rasejumu_sarakasts_1.xls" to remote directory started.
. 2009-07-01 11:20:23.562 Binary transfer mode selected.
. 2009-07-01 11:20:23.562 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_2_rasejumu_sarakasts_1.xls
> 2009-07-01 11:20:23.578 TYPE I
< 2009-07-01 11:20:23.578 200 Type set to I
> 2009-07-01 11:20:23.578 PORT 192,168,0,109,7,172
< 2009-07-01 11:20:23.578 200 Port command successful
> 2009-07-01 11:20:23.578 STOR Pielikums_2_rasejumu_sarakasts_1.xls
< 2009-07-01 11:20:23.671 150 Opening data channel for file transfer.
. 2009-07-01 11:20:23.687 SSL connection established
< 2009-07-01 11:20:23.703 226 Transfer OK
> 2009-07-01 11:20:23.703 MFMT 20080303110515 Pielikums_2_rasejumu_sarakasts_1.xls
< 2009-07-01 11:20:23.718 213 modify=20080303110515; /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/Pielikums_2_rasejumu_sarakasts_1.xls
. 2009-07-01 11:20:23.718 Upload successful
. 2009-07-01 11:20:23.718 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_3_Kvalitates_plans.doc"
. 2009-07-01 11:20:23.718 Copying "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_3_Kvalitates_plans.doc" to remote directory started.
. 2009-07-01 11:20:23.718 Binary transfer mode selected.
. 2009-07-01 11:20:23.718 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_3_Kvalitates_plans.doc
> 2009-07-01 11:20:23.718 TYPE I
< 2009-07-01 11:20:23.718 200 Type set to I
> 2009-07-01 11:20:23.718 PORT 192,168,0,109,7,173
< 2009-07-01 11:20:23.718 200 Port command successful
> 2009-07-01 11:20:23.718 STOR Pielikums_3_Kvalitates_plans.doc
< 2009-07-01 11:20:23.750 150 Opening data channel for file transfer.
. 2009-07-01 11:20:23.765 SSL connection established
< 2009-07-01 11:20:23.890 226 Transfer OK
> 2009-07-01 11:20:23.890 MFMT 20071010102654 Pielikums_3_Kvalitates_plans.doc
< 2009-07-01 11:20:23.906 213 modify=20071010102654; /projects/153_Aigas_Nams/Contract/07_BALTLAINS_INTERN/Pielikums_3_Kvalitates_plans.doc
. 2009-07-01 11:20:23.906 Upload successful
. 2009-07-01 11:20:23.906 File: "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_4_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc"
. 2009-07-01 11:20:23.906 Copying "c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_4_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc" to remote directory started.
. 2009-07-01 11:20:23.906 Binary transfer mode selected.
. 2009-07-01 11:20:23.906 Starting upload of c:\work\projects\153_Aigas_Nams\Contract\07_BALTLAINS_INTERN\Pielikums_4_Buvlaukuma_ kartibas_ noteikumi_2007_doc.doc
> 2009-07-01 11:20:23.906 TYPE I
< 2009-07-01 11:20:23.906 200 Type set to I
> 2009-07-01 11:20:23.906 PORT 192,168,0,109,7,174
< 2
I got your log. I've sent you back debug version.
Roberts
. 2009-07-06 08:15:10.109 --------------------------------------------------------------------------
. 2009-07-06 08:15:10.109 WinSCP Version 4.2.3 (Build 480) (OS 5.1.2600 Service Pack 3)
. 2009-07-06 08:15:10.109 Login time: pirmdiena, 2009. gada 6. jūlijs 8:15:10
. 2009-07-06 08:15:10.109 Session name: 01-WORK@ftp.domainname.lv
. 2009-07-06 08:15:10.109 Host name: ftp.domainname.lv (Port: 990)
. 2009-07-06 08:15:10.109 User name: username (Password: Yes, Key file: No)
. 2009-07-06 08:15:10.109 Tunnel: No
. 2009-07-06 08:15:10.109 Transfer Protocol: FTP
. 2009-07-06 08:15:10.109 Ping type: C, Ping interval: 10 sec; Timeout: 180 sec
. 2009-07-06 08:15:10.109 Proxy: none
. 2009-07-06 08:15:10.109 FTP: FTPS: Implicit SSL/TLS; Passive: No
. 2009-07-06 08:15:10.109 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-07-06 08:15:10.109 Cache directory changes: Yes, Permanent: Yes
. 2009-07-06 08:15:10.109 DST mode: 1
. 2009-07-06 08:15:10.468 Connecting to ftp.domainname.lv:990 ...
. 2009-07-06 08:15:10.484 Connected with ftp.domainname.lv:990, negotiating SSL connection...
. 2009-07-06 08:15:10.859 SSL connection established. Waiting for welcome message...
< 2009-07-06 08:15:10.859 220 MWL FTP serveris
> 2009-07-06 08:15:10.875 USER username
< 2009-07-06 08:15:10.875 331 Password required for username
> 2009-07-06 08:15:10.875 PASS ********
< 2009-07-06 08:15:10.890 230 Logged on
> 2009-07-06 08:15:10.906 SYST
< 2009-07-06 08:15:10.906 215 UNIX emulated by FileZilla
> 2009-07-06 08:15:10.937 FEAT
< 2009-07-06 08:15:10.937 211-Features:
< 2009-07-06 08:15:10.953 MDTM
< 2009-07-06 08:15:10.968 REST STREAM
< 2009-07-06 08:15:10.968 SIZE
< 2009-07-06 08:15:10.984 MLST type*;size*;modify*;
< 2009-07-06 08:15:11.015 MLSD
< 2009-07-06 08:15:11.015 AUTH SSL
< 2009-07-06 08:15:11.031 AUTH TLS
< 2009-07-06 08:15:11.031 UTF8
< 2009-07-06 08:15:11.031 CLNT
< 2009-07-06 08:15:11.046 MFMT
< 2009-07-06 08:15:11.046 211 End
> 2009-07-06 08:15:11.062 PBSZ 0
< 2009-07-06 08:15:11.062 200 PBSZ=0
> 2009-07-06 08:15:11.078 PROT P
< 2009-07-06 08:15:11.078 200 Protection level set to P
. 2009-07-06 08:15:11.093 Connected
. 2009-07-06 08:15:11.109 --------------------------------------------------------------------------
. 2009-07-06 08:15:11.125 Using FTP protocol.
. 2009-07-06 08:15:11.125 Doing startup conversation with host.
> 2009-07-06 08:15:11.156 PWD
< 2009-07-06 08:15:11.156 257 "/" is current directory.
. 2009-07-06 08:15:11.187 Getting current directory name.
. 2009-07-06 08:15:11.187 Startup conversation with host finished.
. 2009-07-06 08:15:11.234 Collecting synchronization list for local directory 'c:\work' and remote directory '/', mode = 0, params = 3
. 2009-07-06 08:15:11.281 Retrieving directory listing...
> 2009-07-06 08:15:11.296 TYPE A
< 2009-07-06 08:15:11.296 200 Type set to A
> 2009-07-06 08:15:11.312 PORT 192,168,0,109,7,234
< 2009-07-06 08:15:11.328 200 Port command successful
> 2009-07-06 08:15:11.328 LIST -a
< 2009-07-06 08:15:11.421 150 Opening data channel for directory list.
. 2009-07-06 08:15:11.453 SSL connection established
< 2009-07-06 08:15:11.468 226 Transfer OK
. 2009-07-06 08:15:11.484 Directory listing successful
. 2009-07-06 08:15:11.546 Synchronizing local directory 'c:\work\' with remote directory '/', params = 3
. 2009-07-06 08:15:11.562 Deleting file "/sync.log".
> 2009-07-06 08:15:11.578 DELE /sync.log
< 2009-07-06 08:15:11.609 250 File deleted successfully
. 2009-07-06 08:15:11.656 Copying 1 files/directories to remote directory "/"
. 2009-07-06 08:15:11.656 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask: *.*
. 2009-07-06 08:15:11.656 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-07-06 08:15:11.656 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-07-06 08:15:11.671 File: "c:\work\projects"
. 2009-07-06 08:15:11.687 File: "c:\work\projects\153_Aigas_Nams"
. 2009-07-06 08:15:11.718 File: "c:\work\projects\153_Aigas_Nams\Aigas_nams_apaksuznemeju_novertejums.xls"
. 2009-07-06 08:15:11.843 Copying "c:\work\projects\153_Aigas_Nams\Aigas_nams_apaksuznemeju_novertejums.xls" to remote directory started.
. 2009-07-06 08:15:11.875 Binary transfer mode selected.
. 2009-07-06 08:15:11.906 Starting upload of c:\work\projects\153_Aigas_Nams\Aigas_nams_apaksuznemeju_novertejums.xls
> 2009-07-06 08:15:11.906 CWD /projects/153_Aigas_Nams/
< 2009-07-06 08:15:11.921 550 CWD failed. "/projects/153_Aigas_Nams": directory not found.
> 2009-07-06 08:15:11.921 CWD /projects/
< 2009-07-06 08:15:11.937 550 CWD failed. "/projects": directory not found.
> 2009-07-06 08:15:11.953 CWD /
< 2009-07-06 08:15:11.968 250 CWD successful. "/" is current directory.
> 2009-07-06 08:15:11.968 MKD projects
< 2009-07-06 08:15:11.984 257 Directory created successfully
> 2009-07-06 08:15:12.000 CWD /projects/
< 2009-07-06 08:15:12.015 250 CWD successful. "/projects" is current directory.
> 2009-07-06 08:15:12.015 MKD 153_Aigas_Nams
< 2009-07-06 08:15:12.031 257 Directory created successfully
> 2009-07-06 08:15:12.031 CWD /projects/153_Aigas_Nams/
< 2009-07-06 08:15:12.046 250 CWD successful. "/projects/153_Aigas_Nams" is current directory.
> 2009-07-06 08:15:12.062 PWD
< 2009-07-06 08:15:12.078 257 "/projects/153_Aigas_Nams" is current directory.
> 2009-07-06 08:15:12.093 TYPE A
< 2009-07-06 08:15:12.093 200 Type set to A
> 2009-07-06 08:15:12.109 PORT 192,168,0,109,7,235
< 2009-07-06 08:15:12.125 200 Port command successful
> 2009-07-06 08:15:12.140 LIST -a
< 2009-07-06 08:15:12.156 150 Opening data channel for directory list.
. 2009-07-06 08:15:12.187 SSL connection established
< 2009-07-06 08:15:12.218 226 Transfer OK
> 2009-07-06 08:15:12.250 TYPE I
< 2009-07-06 08:15:12.250 200 Type set to I
> 2009-07-06 08:15:12.265 PORT 192,168,0,109,7,236
< 2009-07-06 08:15:12.281 200 Port command successful
> 2009-07-06 08:15:12.296 STOR Aigas_nams_apaksuznemeju_novertejums.xls
< 2009-07-06 08:15:12.328 150 Opening data channel for file transfer.
. 2009-07-06 08:15:12.343 SSL connection established
< 2009-07-06 08:15:12.375 226 Transfer OK
> 2009-07-06 08:15:12.375 MFMT 20081216133901 Aigas_nams_apaksuznemeju_novertejums.xls
< 2009-07-06 08:15:12.390 213 modify=20081216133901; /projects/153_Aigas_Nams/Aigas_nams_apaksuznemeju_novertejums.xls
. 2009-07-06 08:15:12.406 Upload successful
. 2009-07-06 08:15:12.437 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping"
. 2009-07-06 08:15:12.468 File: "c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss.xls"
. 2009-07-06 08:15:12.546 Copying "c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss.xls" to remote directory started.
. 2009-07-06 08:15:12.578 Binary transfer mode selected.
. 2009-07-06 08:15:12.609 Starting upload of c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss.xls
> 2009-07-06 08:15:12.609 CWD /projects/153_Aigas_Nams/Bookkeeping/
< 2009-07-06 08:15:12.625 550 CWD failed. "/projects/153_Aigas_Nams/Bookkeeping": directory not found.
> 2009-07-06 08:15:12.640 CWD /projects/153_Aigas_Nams/
< 2009-07-06 08:15:12.656 250 CWD successful. "/projects/153_Aigas_Nams" is current directory.
> 2009-07-06 08:15:12.656 MKD Bookkeeping
< 2009-07-06 08:15:12.671 257 Directory created successfully
> 2009-07-06 08:15:12.687 CWD /projects/153_Aigas_Nams/Bookkeeping/
< 2009-07-06 08:15:12.703 250 CWD successful. "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-06 08:15:12.718 PWD
< 2009-07-06 08:15:12.734 257 "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-06 08:15:12.734 TYPE A
< 2009-07-06 08:15:12.750 200 Type set to A
> 2009-07-06 08:15:12.765 PORT 192,168,0,109,7,237
< 2009-07-06 08:15:12.765 200 Port command successful
> 2009-07-06 08:15:12.781 LIST -a
< 2009-07-06 08:15:12.796 150 Opening data channel for directory list.
. 2009-07-06 08:15:12.812 SSL connection established
< 2009-07-06 08:15:12.812 226 Transfer OK
. 2009-07-06 08:15:12.828 Copying files to remote side failed.
* 2009-07-06 08:15:12.875 (ExtException) Copying files to remote side failed.
* 2009-07-06 08:15:12.875 Transfer OK
. 2009-07-06 08:15:12.890 Asking user:
. 2009-07-06 08:15:12.890 Error transferring file 'c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss.xls'. ("Copying files to remote side failed.","Transfer OK")
* 2009-07-06 08:15:12.921 (EScpSkipFile) Error transferring file 'c:\work\projects\153_Aigas_Nams\Bookkeeping\Aigas nams_Bonuss.xls'.
* 2009-07-06 08:15:12.921 Copying files to remote side failed.
* 2009-07-06 08:15:12.921 Transfer OK
. 2009-07-06 08:15:12.921 Creating directory "/projects/153_Aigas_Nams/Bookkeeping/".
> 2009-07-06 08:15:12.937 CWD /projects/153_Aigas_Nams/
< 2009-07-06 08:15:12.953 250 CWD successful. "/projects/153_Aigas_Nams" is current directory.
> 2009-07-06 08:15:12.968 MKD Bookkeeping
< 2009-07-06 08:15:12.984 550 Directory already exists
. 2009-07-06 08:15:12.984 Dir already exists in cache!
. 2009-07-06 08:15:13.015 Asking user:
. 2009-07-06 08:15:13.015 Error creating folder '/projects/153_Aigas_Nams/Bookkeeping/'. ("Dir already exists in cache!","Directory already exists")
. 2009-07-06 08:15:13.078 Collecting synchronization list for local directory 'c:\work' and remote directory '/', mode = 0, params = 1539
. 2009-07-06 08:15:13.109 Retrieving directory listing...
> 2009-07-06 08:15:13.125 CWD /
< 2009-07-06 08:15:13.140 250 CWD successful. "/" is current directory.
> 2009-07-06 08:15:13.156 PWD
< 2009-07-06 08:15:13.156 257 "/" is current directory.
> 2009-07-06 08:15:13.171 TYPE A
< 2009-07-06 08:15:13.187 200 Type set to A
> 2009-07-06 08:15:13.187 PORT 192,168,0,109,7,238
< 2009-07-06 08:15:13.203 200 Port command successful
> 2009-07-06 08:15:13.218 LIST -a
< 2009-07-06 08:15:13.218 150 Opening data channel for directory list.
. 2009-07-06 08:15:13.250 SSL connection established
< 2009-07-06 08:15:13.281 226 Transfer OK
. 2009-07-06 08:15:13.281 Directory listing successful
. 2009-07-06 08:15:13.328 Collecting synchronization list for local directory 'c:\work\projects' and remote directory '/projects', mode = 0, params = 1539
. 2009-07-06 08:15:13.375 Retrieving directory listing...
> 2009-07-06 08:15:13.390 CWD /projects/
< 2009-07-06 08:15:13.390 250 CWD successful. "/projects" is current directory.
> 2009-07-06 08:15:13.406 PWD
< 2009-07-06 08:15:13.421 257 "/projects" is current directory.
> 2009-07-06 08:15:13.437 TYPE A
< 2009-07-06 08:15:13.437 200 Type set to A
> 2009-07-06 08:15:13.453 PORT 192,168,0,109,7,239
< 2009-07-06 08:15:13.453 200 Port command successful
> 2009-07-06 08:15:13.468 LIST -a
< 2009-07-06 08:15:13.484 150 Opening data channel for directory list.
. 2009-07-06 08:15:13.515 SSL connection established
< 2009-07-06 08:15:13.546 226 Transfer OK
. 2009-07-06 08:15:13.562 Directory listing successful
. 2009-07-06 08:15:13.593 Collecting synchronization list for local directory 'c:\work\projects\153_Aigas_Nams' and remote directory '/projects/153_Aigas_Nams', mode = 0, params = 1539
. 2009-07-06 08:15:13.750 Retrieving directory listing...
> 2009-07-06 08:15:13.750 CWD /projects/153_Aigas_Nams/
< 2009-07-06 08:15:13.765 250 CWD successful. "/projects/153_Aigas_Nams" is current directory.
> 2009-07-06 08:15:13.781 PWD
< 2009-07-06 08:15:13.796 257 "/projects/153_Aigas_Nams" is current directory.
> 2009-07-06 08:15:13.796 TYPE A
< 2009-07-06 08:15:13.812 200 Type set to A
> 2009-07-06 08:15:13.828 PORT 192,168,0,109,7,240
< 2009-07-06 08:15:13.828 200 Port command successful
> 2009-07-06 08:15:13.843 LIST -a
< 2009-07-06 08:15:13.843 150 Opening data channel for directory list.
. 2009-07-06 08:15:13.875 SSL connection established
< 2009-07-06 08:15:13.906 226 Transfer OK
. 2009-07-06 08:15:13.921 Directory listing successful
. 2009-07-06 08:15:13.984 Collecting synchronization list for local directory 'c:\work\projects\153_Aigas_Nams\Bookkeeping' and remote directory '/projects/153_Aigas_Nams/Bookkeeping', mode = 0, params = 1539
. 2009-07-06 08:15:14.125 Retrieving directory listing...
> 2009-07-06 08:15:14.125 CWD /projects/153_Aigas_Nams/Bookkeeping/
< 2009-07-06 08:15:14.140 250 CWD successful. "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-06 08:15:14.156 PWD
< 2009-07-06 08:15:14.171 257 "/projects/153_Aigas_Nams/Bookkeeping" is current directory.
> 2009-07-06 08:15:14.171 TYPE A
< 2009-07-06 08:15:14.187 200 Type set to A
> 2009-07-06 08:15:14.203 PORT 192,168,0,109,7,241
< 2009-07-06 08:15:14.218 200 Port command successful
> 2009-07-06 08:15:14.218 LIST -a
< 2009-07-06 08:15:14.265 150 Opening data channel for directory list.
. 2009-07-06 08:15:14.296 SSL connection established
. 2009-07-06 08:15:14.312 Could not retrieve directory listing
. 2009-07-06 08:15:14.328 Asking user:
. 2009-07-06 08:15:14.328 Error listing directory '/projects/153_Aigas_Nams/Bookkeeping'. ("Could not retrieve directory listing","Opening data channel for directory list.")
< 2009-07-06 08:15:14.359 226 Transfer OK
. 2009-07-06 08:15:14.390 Copying 1 files/directories to remote directory "/"
. 2009-07-06 08:15:14.390 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2009-07-06 08:15:14.390 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-07-06 08:15:14.390 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-07-06 08:15:14.390 File: "c:\FileSync\sync.log"
. 2009-07-06 08:15:14.406 Copying "c:\FileSync\sync.log" to remote directory started.
. 2009-07-06 08:15:14.437 Binary transfer mode selected.
. 2009-07-06 08:15:14.468 Starting upload of c:\FileSync\sync.log
> 2009-07-06 08:15:14.468 CWD /
< 2009-07-06 08:15:14.484 250 CWD successful. "/" is current directory.
> 2009-07-06 08:15:14.500 PWD
< 2009-07-06 08:15:14.515 257 "/" is current directory.
> 2009-07-06 08:15:14.515 TYPE A
< 2009-07-06 08:15:14.531 200 Type set to A
> 2009-07-06 08:15:14.546 PORT 192,168,0,109,7,242
< 2009-07-06 08:15:14.562 200 Port command successful
> 2009-07-06 08:15:14.562 LIST
< 2009-07-06 08:15:14.718 150 Opening data channel for directory list.
. 2009-07-06 08:15:14.953 SSL connection established
< 2009-07-06 08:15:15.000 226 Transfer OK
> 2009-07-06 08:15:15.031 TYPE I
< 2009-07-06 08:15:15.046 200 Type set to I
> 2009-07-06 08:15:15.062 PORT 192,168,0,109,7,243
< 2009-07-06 08:15:15.078 200 Port command successful
> 2009-07-06 08:15:15.093 STOR sync.log
< 2009-07-06 08:15:15.140 150 Opening data channel for file transfer.
. 2009-07-06 08:15:15.156 SSL connection established
< 2009-07-06 08:15:15.187 226 Transfer OK
> 2009-07-06 08:15:15.187 MFMT 20090706051515 sync.log
< 2009-07-06 08:15:15.203 213 modify=20090706051515; /sync.log
. 2009-07-06 08:15:15.218 Upload successful
. 2009-07-06 08:15:15.312 Disconnected from server
pill
I have the exact same problem, when scripting a file transfer on an explicit TLS FileZilla server.
I am using 4.2.2 (build 480)
It works fine over SSH on other operations I use it for (4.1.9 though), but for some reason over TLS it tries to MKDIR a dir that already exists, like it did not PWD correctly or something, thus hanging when using batch on confirm off.
When batch off confirm off, I (S)kip the directory failure and it transfers some more files, until it regularly loses connection to the server, and tries again, and loses, and tries again..
I know TLS is in early implementation, but I wouldn't mind a fix Wink
Great software by the way!
Regards,
-p
Two issues have been logged based on this thread: 466 and 467.
