Topic "sync to ftp site does not delete destination directory"
pagnin
using winscp version 4.2.4 build 610
origin OS: windows 2003 SP2
destination ftp server: windows 2000 and IIS ftp server
using scripting automation
error message:
> 2009-11-05 17.01.04.666 CWD /test/directory/
< 2009-11-05 17.01.04.666 250 CWD command successful.
> 2009-11-05 17.01.04.853 RMD /test/directory/
< 2009-11-05 17.01.04.853 550 /test/directory: Impossibile accedere al file. Il file utilizzato da un altro processo.
. 2009-11-05 17.01.04.853 Asking user:
. 2009-11-05 17.01.04.853 Error deleting file '\test\directory'. ("/test/directory: Impossibile accedere al file. Il file utilizzato da un altro processo. ")
. 2009-11-05 17.01.04.853 Disconnected from server
this happen during the execution of the command:
synchronize remote -mirror -delete c:\test\directory /test/directory
it seems that windows 2000 server and IIS does not allow to delete the directory if the directory is still in use by a user process.
This lock happen every time because it is winscp that does the CWD command to the directory it has to delete and does not change the directory before trying to delete it.
In fact, issuing the RMD command after winscp has run, with the exact same directory does delete the directory correctly.
Let me know If you need more info.
pagnin
I've sent the full log.
I didn't get it. Can you try again?
pagnin
Yes. I have resent the log, this time I have compressed it in a zip file, may be 380Kb where too much? (the previous mail was still in the delivery queue with a 45X error).
I have monitored the new mail and it has been delivered to the destination mail host, so you should get it, this time.
Regards
pagnin
> From the log it looks like you have used \test\directory as remote directory path instead of /test/directory.
> Is it correct? Can you try it with /test/directory?
I have tried and effectively it works.
why the different behavior, if I can ask?
Before deleting remote directory, WinSCP checks if the current working directory is below the deleted one. If it is, it moves away from it. WinSCP thinks it is deleting \test\test\test and the current directory is /test/test/test, which for WinSCP is different directory. So it does not move out. The problem here is that your server does not care about which slashes are used. Normally if you tell regular *nix server to go to \test\test\test, it would fail. Your server does not, instead it goes to /test/test/test.
