Problems uploading certain files
cjrcomputers
It seems like almost every file type I try to upload, I always receive the message "Target directory contains partially transferred file 'blah.txt'. Do you want to resume file transfer?" I'll click yes and then it will go through the transfer and then after it transfers I receive an error message that the File name not valid.
Any ideas?
Re: Problems uploading certain files
